Data Sheet
LCR Meter
Model 875B
The rugged 875B LCR meter is a reliable,
easy-to-use workhorse that will measure
inductors, resistors, and capacitors quickly
and accurately. Utilizing special circuitry, the
measurement more closely replicates true
in-circuit measurements. The meter allows for
resistance measurement down to 1 mΩ of
resolution and zero adjustment for removing
lead resistance.
Specifications
Precision measurement of very low resistances
Measures D (dissipation factor)
Unique drop-proof construction
Tilt stand
Measures resistance using a test frequency
that can cause an inductive reactance
875B
Range
Resolution
200 pF
0.1 pF
2 nF
1 pF
20 nF
10 pF
200 nF
100 pF
2 µF
1000 pF
20 µF
0.01 µF
200 µF
0.1 µF
Capacitance
2 mF
1 µF
20 mF
10 µF
20 Ω
10 mΩ
2Ω
200 Ω
2 kΩ
Resistance
20 kΩ
200 kΩ
Inductance
Features & Benefits
Accuracy
1%+2
2%+10
1 mΩ
1%+5
100 mΩ
1Ω
1%+2
10 Ω
100 Ω
2 MΩ
1 kΩ
20 MΩ
10 kΩ
200 µH
0.1 µH
2 mH
1 µH
20 mH
10 µH
200 mH
100 µH
2H
1 mH
20 H
10 mH
200 H
100 mH
2%+2
2%+2
1%+2
Not specified, ranges are used
for referance only
General
Power requirements
9 V 006P battery
Display
0.5” digital height, 31/2 digits liquid crystal display with “LOBAT” and decimal annunciators
Low battery warning
Display will “LOBAT” in the last 5% of battery life
Current consumption
17.3 mA
Temperature
32° to 104° F (0° to 40° C) Operating / -4° to 158° F (-20° to 70° C) Storage
Dimensions (LxWxH)
6.97” x 3.46” x 1.57” (177 x 88 x 40 mm)
Weight
14 oz (400 grams)
Included accessories
Operation manual and one pair of test clips (red & black)
Three-Year Warranty
Technical data subject to change
© B&K Precision Corp. 2015
v041715
www.bkprecision.com
很抱歉,暂时无法提供与“TLLCR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+122.418311+15.31173
