Data Sheet
100 MHz Dual Trace Analog Oscilloscope
Model 2190B
B&K Precision Model 2190B is one of the most economical 100 MHz analog oscilloscopes on the market, yet it has all of the high performance features needed for
most applications, including delayed time base, bandwidth limiter, and Y axis output.
Dual time base oscilloscope (2 channel)
5mV/division sensitivity
Sweeps to 5ns/division
23 calibrated ranges, main time base
Signal delay line
15 kV accelerating voltage
Channel 2 output
cUL certified
Specifications
TV-H
Slope
B Trigger
2 190B
EXTERNAL TRIGGER
VERTICAL AMPLIFIERS (CH 1 and CH 2)
Sensitivity
Attenuator
Accuracy
Input Impedance
Input Capacitance
Frequency Response
X5 MAG
AC
Rise Time
Signal Delay Time
Square Wave Characteristics
Maximum Input Voltage
5 mV/div to 5 V/div. 1 mV/div to 1V/div (at X5 MAG)
10 calibrated steps in 1-2-5 sequence.
Vernier control provides fully adjustable sensitivity
between steps, adjustment range 1/1 to 1/3
±3% (±5% at X5 MAG)
1 MΩ +2%
25 pF ±10 pF
DC: DC to 100 MHz (-3 dB)
DC to 25 MHz (-3 dB)
10 Hz to 100 MHz (-3 dB)
3.5 ns (Overshoot ≤5%)
Variable
Overshoot less than 5%, 10 mV/div range
Other ranges within 5% additional
400 V (DC + AC peak)
VERTICAL AMPLIFIERS
Operating Modes
Delay Time Between Channels
Crosstalk
CH 1, CH 2, Dual, Add
Within 1 ns between CH 1 and CH 2
30:1 at 100 kHz
SWEEP SYSTEM
Operating Modes
A
B
B TRIGGERED
A Time Base
Sweep Mode
Sweep Time:
Accuracy
Hold Off Time
B Time Base
Delay Method
Sweep Time
Accuracy
Delay Time
Delay Jitter
TV-V
Technical data subject to change
© B&K Precision Corp. 2012
v013012
300 V (DC + AC peak)
HORIZONTAL AMPLIFIER
X-Y Mode
Sensitivity
Accuracy
Frequency Response
X Axis = CH 1. Y Axis = CH 2
5 mV/div to 5 V/div, CH 1 and CH 2
±3% calibrated position, ±6% using x10 MAG
DC to 2 MHz (-3 dB)
CH2 (Y) OUTPUT
Output Voltage
Freq. Response
Output Impedance
Approx. 100 mV/div open circuit
Approx. 50 mV/div into 50 Ω
20 Hz to 100 MHz, -3 db
approx. 50 Ω
CRT
Type
Display Area
Accelerating Voltage
Phosphor
Scale Illumination
Trace Rotation
Rectangular with integral graticule
8 x 10 div (1 div = 1 cm)
12 kV
P31
None
Electrical, front panel adjustable
Other Specifications
A sweep
Delayed B sweep
B sweep triggered after delay
Main, Mix, Delay, XY
5 s to 20 ns/div., 23 steps in 1-2-5 sequence
with variable control
± 3%
Continuously variable. Adjustment range from
normal to 5 times normal
Z Axis
(Intensity Modulation)
Input Impedance
Usable Freq. Range
CAL/Probe Compensation
Waveform
Output Voltage
Frequency
Power Requirements
Dimensions (HxWxD)
Weight
Sensitivity: 3 V or greater, TTL level.
Intensity increasing with more positive levels
50 kΩ
DC to 5 MHz
30 V (DC + AC peak)
Positive going squareware
2 V p-p ±3%
Approx. 1 kHz
100/120/220/240/ VAC ±10%, 50/60 Hz,
approximately 55 W
12.76 x 15.68 x 5.2" (324 x 398 x 132 mm)
18.7 lbs (8.5 kg)
Continuous delay. Triggered delay
20 ns. to 0.5 s/div., 23 steps in 1-2-5 sequence
± 3%
Start point: 0.5 div to + 0.3 div.
End point: 10 div + 1 div
Within 1/10,000 of full scale sweep time
ENVIRONMENT
CH 1, CH 2, LINE, EXT, ALT
30 Hz to 110 MHz
1.5 div (internal), ≥0.5 p-p (external)
20 Hz - 30 kHz
Supplied Accessories: Instruction Manual, Two PR 37A x1/x10/Ref. Probes or equivalent,
AC Power Cord, Spare Fuse
Optional Accessories: PR 32A Demodulator Probe, PR 37AG x1/x10/REF. Probe,
PR 100A x100 Probe, PR-55 High Voltage x1000 Probe,
LC 210A Carrying Case
Within Specified Accuracy
Full Operation
Storage
TRIGGERING
A Trigger
Source
Sensitivity
1.0 div (internal), ≥0.5 p-p (external)
3 kHz - 100 kHz
+ or The A trigger is also the B trigger
50˚ to 95˚F (10˚ to 35˚C), 10-80% RH
32˚ to 122˚F (0˚ to +50˚C), 10-80% RH
-22˚ to 158˚F (-30˚to +70˚C), 10-90% RH
Three Year Warranty
www.bkprecision.com
Tel.: 714.921.9095
很抱歉,暂时无法提供与“PR100A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+530.137151+68.51074
- 国内价格 香港价格
- 1+649.063981+83.87990
