TL3
TL3
    B&K
    TESTLEADTIPSFORTL-2
TL3 数据手册
TL-130A CP-3 Model TL-130A General Purpose DMM Kit Model CP-3 If you need only one basic accessory kit for your meter, this is the one. Attach probes or clips to the sheath plug to complete your test. Soft, flexible silicone leads make movement easy. Kit is voltage and current rated for either electronic or electrical applications. DC/AC Current Clamp ■ Converts any DMM to a current clamp ■ Measures current without disconnecting circuit under test ■ Measures to 400A DC or AC ■ Outputs 1 mV per Amp, operates on ■ All components compliant 2V range of any DMM to IEC61010-2-031 ■ Silicone Lead Wire length 60" (1.5m) ■ Tri-fold Velcro Pouch Specifications TL-50 model CP-3 Features 4mm Straight to Right-Angle Silicone Leads, 1.5m Probe Bodies w/Ø2mm Tip Alligator Style Clips Alligator Clips model TL-130A 1000V 1000V 1000V 300V CATIII CATIII CATIII CATI 12A 36A 20A 3A (Accuracy specified at 18˚ to 28˚C) Current Range 2A to 400A, DC or AC Frequency Response (AC) 50 Hz - 400 Hz Accuracy ±(2% reading + 2A) Input Resistance 10kΩ min. Maximum Conductor Size 1.1" (30mm) Power Requirement 9V battery, NEDA 1604 Battery Life 100 hr typical Operating Temperature 0˚ to 40˚C,
很抱歉,暂时无法提供与“TL3”相匹配的价格&库存,您可以联系我们找货
TL 3
