306C
306C
    TPI(TPI 公司)
    POCKET DIGITAL THERMOMETER
306C 数据手册
306C Data Sheet 04.10 306C Pocket Digital Thermometer Test the TPI advantage Features: • Field calibrateable to ±2°F • Easy-to-read LCD • Data Hold for hard to reach areas • Penetration tip • Auto off • 3-year limited warranty Compact easy to use thermometer with large display and auto power off. Comes with A306 protective boot APPLICATIONS: HVACR • Ambient Air • Calibrate Thermostats • Vents • Compressor Heads • Registers FOOD • Grill & Surface Temperatures • Serving Temperatures Specifications: Temperature Range Accuracy Resolution Sample Rate Stem Length Tip Type Water Resistant Water Proof °C / °F Selectable Data Hold Auto Off Battery Type ELECTRICAL • Motor Temperatures •Transformer Temperatures www.tpithevalueleader.com Copyright © 2010 Test Products International, Inc. -58°F to 300°F (-50°C to 150°C) +/-2°F (+/-1°C) 0.1°F/°C 1 reading every 1.5 second 4.9” Penetration N/A N/A Yes Yes Yes LR44
很抱歉,暂时无法提供与“306C”相匹配的价格&库存,您可以联系我们找货
