317C
317C
    TPI(TPI 公司)
    THERM POCKET STYLE W/AIR TIP
317C 数据手册
Field calibration for thermometers 317c 09.10 Field calibration for thermometers TPI 317c FIELD CALIBRATION Test the TPI advantage Acessories Adapters Cables/Connectors Oscilloscope Probes Test Leads Clamp-on meters (Current) Combustion Efficiency Analyzers Gas Detection Carbon Monoxide (CO) Combustibles Refrigeration Indoor Air Quality (IAQ) Manometers (Pressure) Multimeters (DMMs) Oscilloscopes (Hand held) Specialty Testers Insulation Multifunction Photo-tachometer Step-by-Step Procedures 1. Fill a plastic or metal container with crushed ice and add clean water to a depth of at least 4 inches. Stir the ice and water for 2 to 3 minutes prior to performing calibration to ensure the water is completely chilled. Make certain there is plenty of ice in the mixture and always use clean water. Distilled water works well. The temperature of an ice bath is approximately 32°F (0°C). 2. Insert the stainless steel shaft of the 317c into the ice bath making sure at least one inch of the tip is immersed. Allow the reading on the thermometer to stabilize. Note: The temperature reading must be within 23°F to 41°F (-5°C to 5°C) for calibration to have effect. 3. Press and hold the D-H/CAL button for approximately 8 seconds until "CAL" is displayed. "CAL" will display for approximately 2 seconds and then the 317c will return to normal operation. Calibration is complete. Note: If the temperature reading was not within 23°F to 41°F (-5°C to 5°C) when step 3 was performed no change in calibration occurred. The 317c was designed with this feature to prevent improper calibration. Temperature Contact Non-Contact (IR) Pocket Digital Temperature Probes J-Type K-Type T-Type Thermistor Test Leads & Accessories Fused Modular Push-on Screw-on TPI Headquarters: 9615 SW Allen Blvd. Beaverton, OR 97005 USA 503-520-9197 Fax: 503-520-1225 www.tpithevalueleader.com Copyright © 2010 Test Products International, Inc.
很抱歉,暂时无法提供与“317C”相匹配的价格&库存,您可以联系我们找货
