IR5
IR5
    KLEINTOOLS
    INFRAREDTEMPERATUREMETER-12
IR5 数据手册
IR -22° – 752° F -30° – 400° C 12:1 DUAL-LASER 1m INFRARED THERMOMETER 2m 3 Dual lasers for more accurate measurements IR 2m 12:1 Dual-Laser Infrared Thermometer Laser dots indicate the measurement diameter: Diameter at Spot 0.5" 1" (13 mm) (25 mm) 2" 4" (51 mm) 3 (102 mm) 6" (152 mm) 12" (305 mm) 24" (610 mm) 48" (1219 mm) The IR5 dual lasers assist in targeting the measurement area. The distance between the two laser spots on the surface of the object being measured approximates the diameter of the circular measurement area from which the infrared sensor is collecting data. Distance to Object The IR5 is a professional dual-laser targeting infrared thermometer that offers a wide measurement range, a tight distance-to-spot ratio, and several calculation modes to facilitate different temperature measurement applications. Features: Measurement Dual-Laser Targeting -22° – 752° F (-30° – 400° C) Temperature Backlight High/Low Alarm Max/Min Value Auto Power-Off Apo Data Hold HOLD Adjustable Emissivity • Dual-laser Targeting • 12:1 Distance to spot ratio • Auto Scan 0.10 – 1.00 Durability 6.6 ft. (2 m) Drop Protection • Max/Min/Avg/Diff Included Accessories: Pouch, Battery • High/Low Alarm • Backlit Display • Auto Power Off • Adjustable Emissivity -22° – 752° F -30° – 400° C Cat. No. UPC# 0-92644+ IR5 69030-3 Batteries 1 x 9V Height 6.83" (173 mm) Width 1.85" (47 mm) Depth 4.53" (115 mm) Weight (oz.) 9.84 (279 g) CAUTION: Reflective materials may be hotter than indicated. Laser radiation-Do NOT stare into beam. Class 2 laser product. See our complete line of Test & Measure products www.kleintools.com Pats. Pending © 2016 Klein Tools, Inc. Lincolnshire, IL 60069-1418 96445 Rev. 03/16 A
很抱歉,暂时无法提供与“IR5”相匹配的价格&库存,您可以联系我们找货
