310C
310C
    TPI(TPI 公司)
    METER TEMP DIG POCKET W/REVERSE
310C 数据手册
310C Data Sheet 04.10 310C Pocket Digital Thermometer Test the TPI advantage Features: • Reversible head for best viewing • Field calibrateable to ±2°F • Easy-to-read LCD • Data Hold for hard to reach areas • Penetration tip • Auto off • 3-year limited warranty Auto Field Calibrate to ± 2°F in less than 10 seconds in ice water. Specifications: Temperature Range Accuracy Resolution Sample Rate Stem Length Tip Type Water Resistant Water Proof °C / °F Selectable Data Hold Auto Off Battery Type APPLICATIONS: HVACR • Ambient Air • Calibrate Thermostats • Vents • Compressor Heads • Registers FOOD • Grill & Surface Temperatures • Serving Temperatures ELECTRICAL • Motor Temperatures •Transformer Temperatures www.tpithevalueleader.com 310 FEATURE Reverse LCD to gain best viewing angle Insert small coin into notch and gently pry while turning head to new 180° viewing position. Shielded wires keep head and stem from separating. Head easily snaps back into original position. Copyright © 2010 Test Products International, Inc. -58°F to 300°F (-50°C to 150°C) +/-2°F (+/-1°C) 0.1°F/°C 1 reading every 1.5 second 4.9” Penetration N/A N/A Yes Yes Yes LR44
很抱歉,暂时无法提供与“310C”相匹配的价格&库存,您可以联系我们找货
