Data Sheet
Triple Output DC Power Supplies
Models 1672 & 1673
Quad LED Display
Simultaneously display voltage and current for both
variable outputs
B&K Precision’s 1672 and 1673 are quad
display triple output DC power supplies that
provide two variable outputs and one fixed
output. The variable outputs can work
independently, in series tracking, or parallel
mode. Conveniently adjust voltage and current
with independent front panel knobs and bright
quad LED display.
The 1672 and 1673 are both designed to
operate in a constant voltage or a constant
current mode with automatic crossover, allowing
continuous transition from constant current to
constant voltage modes in response to load
condition changes.
Accessible through a simple push/pull switch, the
1672 and 1673’s unique series and parallel
tracking features let you easily double the output
voltage or current. For achieving even higher
voltages or current, multiple units can be
connected in series or parallel.
These power supplies are ideally suited for
applications in electronic test, production, and
service, where multiple independent DC power
supplies are required.
Ratings/Model
Fixed output
Technical data subject to change
© B&K Precision Corp. 2010
Three independent outputs
Individual control knobs for voltage and
CV (constant voltage)/CC (constant current)
current settings of variable outputs
mode operation
Separate 3-digit voltage and current displays
for variable outputs
LED indication for CV/CC mode
Overload indication LED for fixed output
Series tracking and parallel tracking mode
operation to double output voltage or current
respectively
1672
1673
Voltage (variable outputs)
Current (variable outputs)
Features and Benefits
0 - 32 V
0-3A
0-6A
5 V/ 3 A
w w w.bk prec ision.c om
Models 1672 & 1673
User-Friendly Design
Intuitive Operation
Quad Display
Safety in Mind
Easy-to-use voltage and current adjustment
knobs with simple push/pull switch mechanism
for series and parallel tracking modes.
The 1672 and 1673’s bright, quad 3-digit LED
displays provide excellent readability at a distance
and allows you to view voltage and current
output values for variable outputs independently.
Both models use sheathed safety banana input
jacks that accept sheathed or shrouded banana
plugs and meet the latest international safety
standards.
CC and CV mode LEDs clearly indicate constant
current or constant voltage mode.
Front panel
Power On/Off switch
Bright, easy-to-read LED
displays for both variable voltage
and current outputs
Series and parallel tracking
mode LED indicators
Individual voltage and
current controls for
variable outputs
Overload indication
LED indicators for
constant current and
2
Models 1672 & 1673
Specifications
Mod el
1 67 2
16 73
Output Paramet ers
Number of Outputs
Range
Three (two variable and one fixed)
0 to 32 VDC / 0 to 3 A (variable)
and 5 V / 3 A (fixed)
0 to 32 VDC / 0 to 6 A (variable)
Const an t V oltage Mode (variable out put s)
Line Regulation
Load Regulation
Ripple & Noise
很抱歉,暂时无法提供与“1672”相匹配的价格&库存,您可以联系我们找货
