1550-220V
1550-220V
    B&K
    PWR SPLY 36V 0-3A W/USB 220V-IN
1550-220V 数据手册
Data Sheet Switching DC Power Supply with USB Charger Output 1-36 V, 0-3 A Specifications Model 1550 1550 MAIN OUTPUT Output Voltage Adjustable Range 1.0 – 36 VDC Output Current Adjustable Range 0–3A Voltage Regulation New touch pad design Load (10 % to 100 %) Line (min to max) ±20 mV Ripple ±5 mV rms Noise (Peak to Peak) ±50 mV + V OUTPUT ON/OFF A _ ±50 mV Current Regulation Load (10 % to 100 %) ±20 mA Line (min to max) ±20 mA USB OUTPUT The model 1550 is a compact 108 watt power supply delivering 1-36 V and 0-3 A from its main isolated output. A unique feature of the 1550 supply is the USB charging port located on the front panel allowing the user to charge a cell phone or MP3 player. Clean power and quiet operation make this power supply ideal for any bench in laboratories, work shops and schools where bench space is limited. Features: ■ USB charging port on front panel ■ Rear panel security loop ■ Compact design ■ Output On/Off control ■ Large bright easy to read LCD display ■ Constant voltage and constant current operation ■ Overvoltage protection ■ 230 VAC version with banana style outputs (model 1550-220V) Output Voltage 5 V (±10 %) Output Current 400 mA (±10 %) Load Voltage Regulation 80 mV (±10 %) Ripple & Noise (no load rms) 8 mV (±10 %) OTHER AC Input 100 – 120 Vac (50~60 Hz)* Efficiency at Max Power 83 % (±10 %) Voltmeter and Ammeter Display 3 Digit Voltmeter Accuracy ±1 % of rdg. ± 5 digits Switching Operation Frequency 80 kHz to 120 kHz Ammeter Accuracy ±1 % of rdg. ± 5 digits Full Load Input Current at 120 Vac 1.8 A (±10 %) LCD Indication CC, CV, Amp, Volt, Output ON-OFF GENERAL Protection Short Circuit, Overload, Over Temperature, Over Voltage Dimensions (W x H x D) 2.8” x 6.0” x 9.8” (70 x 150 x 250 mm) Weight 4.4 Lbs. (2 kgs) Supplied Accessories User manual and power cord One-Year Warranty USB C harging P ort Charge your cell phone or MP3 player while you work *For 230V input, order model number 1550-220V. Rear P anel Sec urit y Loop Secure the power supply to a work station to prevent unwanted removal Technical data subject to change © B&K Precision Corp. 2014 v040914 w w w.bk prec ision.c om
1550-220V 价格&库存
很抱歉,暂时无法提供与“1550-220V”相匹配的价格&库存,您可以联系我们找货
