Data Sheet
Triple Output DC Power Supplies
Models 1670A and 1671A
These triple output DC power supplies are ideal for general electronic servicing, school
electronics labs, and powering up hobbyist’s projects.
Model
1670A
1671A
Output Parameters
Number of Outputs
Range
Three (1 variable, 2 fixed)
0-30 V / 0-3 A (variable)
12 V ±5% / 500 mA (fixed)
5 V ± 5% / 500 mA (fixed)
Model 1671A
0-30 V / 0-5 A (variable)
Constant Voltage Operation
Line Regulation
≤0.05% + 10 mV (main)
≤1% (fixed output)
Load Regulation
≤1% (fixed output)
0 - 3 A variable section (1670A)
0 - 5 A variable section (1671A)
≤5 mV rms
One 12 VDC fixed section
One 5 VDC fixed section
5% to 100% (Main)
Constant voltage (CV) and constant current
Ripple & Noise
Constant Current Operation
Adjustable Current Range
≤0.4% + 10 mA
Line Regulation
(CC) operation modes
≤0.4% + 10 mA
Load Regulation
≤10 mA rms
Ripple & Noise
Metering
Display
3-digit LCDs
Voltmeter Resolution
0.1 V
Voltmeter Accuracy
±(1% reading + 2 digits)
Ampmeter Resolution
0.01 A
Ampmeter Accuracy
General
Overload Protection
Current limiting, Reverse polarity, Overvoltage, Short circuit
AC Input
Power Consumption
Operating Temperature
Storage Temperature
115/230 VAC, 50/60 Hz
165 W
265 W
0° to 40°C < 10-80% R.H.
-15° to 70°C < 85% R.H.
Dimensions (H x W xD)
4.9” x 8.5” x 9.5"
(124 x 216 x 242 mm)
Weight
10 lbs (4.5 kg)
4.9” x 8.5” x 11.5"
(124 x 216 x 292 mm)
14.3 lbs (6.5 kg)
One-Year Warranty
Included Accessories
Technical data subject to change
© B&K Precision Corp. 2016
v122116
One variable 0 - 30 VDC,
Instruction manual and spare fuse
www.bkprecision.com
Short circuit and reverse polarity protection
很抱歉,暂时无法提供与“1671A”相匹配的价格&库存,您可以联系我们找货
