9110
9110
    B&K
    HANDLE RND .187"DIA .625"H ALUM
9110 数据手册
Data Sheet 100 W Multi Range 60 V / 5 A DC Power Supply Model 9110 The 9110 is a new type of power supply. Unlike conventional power supplies with fixed output ratings, the 9110 automatically recalculates voltage/current limits for each setting. The 9110 provides 100 W output power in any Volt/Amp combination within the rated voltage (60 V) and current (5 A) limits. By providing greatly expanded choices of maximum power Volt/Amp combinations, users can cut down on the number of power supplies required and free up valuable bench space. V Features & Benefits ■ Digitally controlled, mixed mode linear/switching DC power supply ■ 10mV/1mA resolution over the full range ■ Bright, easy to read display ■ Very compact and lightweight ■ Low ripple and noise ■ High reliability due to OCP, OVP and OTP protection ■ Output On/Off control ■ Store and Recall 4 x 100 groups of preset Volt/Amp values ■ Temperature controlled, variable speed fan cooling Specifications 60 100% Power Output Ratings Max. Power 40 Load Regulation Line Regulation 20 Setting Accuracy Display Accuracy 1 2 3 4 Voltage Current 5 Ripple Voltage Current Voltage Current Voltage Current Voltage Current Voltage Current 9110 0-60 V 0-5 A 100 W ≤ 0.01% + 3 mV ≤ 0.01% + 3 mA ≤ 0.01% + 3 mV ≤ 0.1% + 2 mA ≤ 0.05% + 10 mV ≤ 0.2% + 2 mA ≤ 0.05% + 10 mV ≤ 0.1% + 2 mA ≤ 2.0 mVrms ≤ 5 mArms General Example: When setting the voltage to the maximum of 60V, the maximum current value is 100 W/60 V = 1.66 A. For a 20V setting, the maximum current is 5 A. Maximum output power of 100 W is possible for all Volt/Amp combinations that lie on the hyperbolic curve. Technical data subject to change © B&K Precision Corp. 2012 v10112012 State Storage Memory Weight Dimensions (W x H x D) 100 groups with 4 sets of Volt/Amp memories each 5.9lbs (2.65 kg) 3.47" x 6.9" x 11.11" (88 x 175 x 282 mm) Included Accessories Line cord, manual TL 5A (5A test leads), TL 30 (30A test leads), TLPS (Power supply test lead kit) One Year Warranty Optional Accessories www.bkprecision.com
很抱歉,暂时无法提供与“9110”相匹配的价格&库存,您可以联系我们找货
