1762
1762
    B&K
    LAMP INCAND T1-3/4 WIRE TERM
1762 数据手册
Data Sheet Triple Output DC Power Supplies Models 1760A, 1761 & 1762 Specifications Spe ci fication s 1760A 1761 1762 Output Voltage 0-30V (A & B) 4-6.5 V (C) 0-35V (A & B) 2-6.5 V (C) 0-60V (A & B) 2-6.5 V (C) Output Current 0-2A (A & B) 5A (C) 0-3A (A & B) 5A (C) 0-2A (A & B) 5A (C) Main Ou tpu t Constant Voltage Operation Line Regulation (120 VAC ±10%) Load Regulation Recovery Time Ripple Temperature Coefficient ≤ 0.01% +3 mV (A&B) ≤10 mV (C) ≤0.01% +3 mV (A&B) ≤10 mV (C) 100µs ≤1mVrms ≤300 ppm°C Constant Cur rent Operation The 1760A series triple output DC power supplies offer three independent outputs with coarse and fine adjustment knobs for volts. The 4-digit LED display offers 10 mV and 1 mA resolution, providing the capability to set voltage and current values more accurately than 3-digit displays found in most comparable power supplies. Adjustable Current Limit 5% to 100% (A&B) Line Regulation (120 VAC ±10%) ≤0.2% + 3 mA Load Regulation Current Ripple ≤0.2% + 3 mA ≤3 mA rms Meter ing Display Two 4-digit LED Voltmeter Resolution 10 mV Features: Voltmeter Accuracy ± (0.5% rdg + 9 digits) ■ Constant voltage (CV) and constant current (CC) Ammeter Resolution 1 mA Ammeter Accuracy ± (0.5% rdg + 9 digits) operation ■ Independent or series tracking/parallel mode operation to double voltage or current Gen eral Overload Protection Current limiting, Reverse polarity, overvoltage, Short circuit AC Input 108-132 VAC 60 Hz 120/220/230/240/ VAC, ±10%, 50/60 Hz version available ■ Coarse and fine voltage controls ■ Adjustable current limiting ■ Designed to operate continuously at rated output ■ Overvoltage protection and reverse polarity protection Power Consumption Operating Temperature 350 W 0° to 40°C ≤ 85% R.H. Storage Temperature -15° to 70°C ≤ 85% R.H. Dimensions (W x H x D) 10.5 x 5.7 x 15" (267 x 145 x 381 mm) Weight 21 lbs (9.5 kg) Supplied Accessories User manual, spare fuse and power cord Two-Year Warranty Models 1760A & 1761 only Technical data subject to change © B&K Precision Corp. 2015 v082515 www.bkprecision.com Tel.: 714.921.9095
很抱歉,暂时无法提供与“1762”相匹配的价格&库存,您可以联系我们找货
