9121A
9121A
    B&K
    PWR SUP SNG OUTPUT PROG 20V 5A
9121A 数据手册
Model: 9120A, 9121A, 9122A, 9123A, 9124, 9150, 9151, 9152, 9153 Single Output Programmable DC Power Supply USER MANUAL Safety information Please review the following safety precautions before operating our equipment. General information The following safety precautions should be observed before using this product and any associated instrumentations. This product is intended for use by qualified personnel who recognize shock hazards and are familiar with the safety precautions required to avoid possible injury. Read and follow all installation, operation, and maintenance information carefully before using the product. Refer to this manual for complete product specifications. If the product is used in a manner not specified, the protection provided by the product may be impaired. Before performing any maintenance, disconnect the line cord and all test cables. Protection from electric shock Operators of this instrument must be protected from electric shock at all times. The responsible body must ensure that operators are prevented access and/or insulated from every connection point. In some cases, connections must be exposed to potential human contact. Under these circumstances personnel must be trained to protect themselves from the risk of electric shock. If the circuit is capable of operating at or above 1000 volts, no conductive part of the circuit may be exposed. Definition of users Responsible body is the individual or group responsible for the use and maintenance of equipment is operated within its specifications and operating limits, and for ensuring that operators are adequately trained. This product should only be used as intended. Users must be trained in electrical safety procedures and proper use of the instrument. Users must be protected from electric shock and contact with hazardous live circuits. Service is only to be performed by qualified service personnel. Safety symbols and terms Connect to safety earth ground using the wire recommended in the user manual. This symbol on an instrument indicates that the user should refer to the operating instructions located in the manual. Certification We certify that this product met its published specifications at time of shipment from the factory. 2 TABLE OF CONTENTS 1. Introduction............................................................................................................ 4 Description ............................................................................................................................................... 4 Features .................................................................................................................................................... 4 2. Quick Reference ..................................................................................................... 5 2.1 The Front Panel .......................................................................................................................................... 5 2.2 The Rear Panel ......................................................................................................................................... 6 2.3 Preliminary Checkout ................................................................................................................................. 7 1. Check the list of supplied items............................................................................................................ 7 2. Connect the power cord and turn on the power supply ........................................................................ 7 3. Checkout Procedure ............................................................................................................................. 7 1.4 Output Verification ..................................................................................................................................... 8 Voltage Output Check............................................................................................................................... 8 Current Output Check .............................................................................................................................. 9 1.5 If the power supply does not turn On ......................................................................................................... 9 1.5.1 Fuse Replacement............................................................................................................................ 9 1.6 Adjusting the Carrying Handle ................................................................................................................. 10 1.7 Rack Mounting the Instrument ................................................................................................................. 11 3. Front-panel Operation ........................................................................................ 12 3.1 Front Panel Keys ...................................................................................................................................... 12 Numerical Keys/Secondary Shift Functions........................................................................................... 13 Shift Functions ....................................................................................................................................... 13 Primary Function Keys ........................................................................................................................... 13 Up/Down and Entry key ......................................................................................................................... 13 3.2 Front-panel Operation Overview .............................................................................................................. 13 3.3 Setting the Voltage.................................................................................................................................... 13 3.4 Setting the Current.................................................................................................................................... 14 3.5 Save and Recall Operation ....................................................................................................................... 14 3.6 Menu Operation........................................................................................................................................ 14 3.7 Output Operation ...................................................................................................................................... 14 3.8 Remote Sense and digital port functions .................................................................................................. 14 3.9 Digital Volt Meter (DVM) ........................................................................................................................ 14 3.10 Milliohm Meter ...................................................................................................................................... 15 4. Remote Operation ................................................................................................ 16 4.1 Serial adapter connector ........................................................................................................................... 16 4.2 Communication between Power Supply and PC ...................................................................................... 17 4.3 SCPI Command Overview ....................................................................................................................... 19 Common IEEE488.2 Commands ........................................................................................................... 19 Essential SCPI Commands ..................................................................................................................... 19 Port Configuration Commands ............................................................................................................... 21 Trigger Command .................................................................................................................................. 21 SCPI Condition Register ........................................................................................................................ 21 4.4 SCPI Command Description .................................................................................................................... 23 Common IEEE488.2 Commands ........................................................................................................... 23 Essential SCPI Commands ..................................................................................................................... 25 Output Commands .................................................................................................................................. 28 List File Commands ............................................................................................................................... 29 Interface Configuration Commands ....................................................................................................... 33 Trigger commands .................................................................................................................................. 34 5. Specifications ........................................................................................................ 36 5.1 Specifications ........................................................................................................................................... 36 5.2 Supplemental Characteristics ................................................................................................................... 39 3 1. Introduction Description Models 9120A, 9121A, 9122A, 9123A, 9124, 9150, 9151, 9152, and 9153 are fully programmable, linear DC Power Supplies that provide you with clean and reliable power, high resolution and accuracy combined with fast transient response times and excellent temperature stability. The front panel keys and the control knob provide a convenient interface for adjusting Voltage and Current, storing and recalling operating states or enabling/disabling the output. This power supply is suitable for either bench or rack mounted operation. The 912xA is a compact, laboratory grade power supply well suited for applications in design, production or use in university labs. Features  Very high accuracy and resolution: 0.1 mV, 0.1 mA  Low ripple and low noise  Fast settling time of } :RANGe? Trigger Command TRIGger [:IMMediate] :SOURce {} SCPI Condition Register You can obtain the state of the power supply and read parameters from the operation register. The different states of the power supply can be read from 7 condition registers. These registers are status byte register, standard event register, quest condition register and operation status register. The status byte register stores the information of 3 other registers. The following table provides the details on each register’s meaning. BIT Signal 0 1 2 3 4 CAL WTG CV CC RI 0 1 2 OV OT UNR 0 2 3 OPC QYE DDE Meaning Operation status register The power supply is calculating new calibration parameter. The power supply is waiting for a trigger signal. The power supply is in constant voltage condition. The power supply is in constant current condition. Show the input level condition of RI Quest condition register Over voltage Over temperature The output of the power supply is unregulated. Standard event status register Operation of power supply is completed. Query error. Data of output array is missing. Device-dependent error. Data stored in register is missing or error occurs in 21 4 5 EXE CME 7 PON 3 5 6 QUES ESB MSS RQS OPER 7 preliminary checkout. Execution error. Command parameter overflows or the condition is not right. Command error. Syntax or semantic error occurs when receiving information. Power on. It is 1when power supply is reset. Status byte register If a quest enable condition changes, QUES is 1. If a standard event status enable register changes, ESB is 1. If a operation event enable register changes, OPER is 1. Structure of condition register: Quest condition register condition event enable 0 1 2 3 4 5 6 7 OV OT Unr n.u. n.u. n.u n.u n.u 0 1 2 3 4 5 6 7 L O G I C 0 1 2 3 4 5 6 7 O R Operation event register Status byte register condition event enable CAL WTG CV CC RI n.u n.u n.u 0 1 2 3 4 5 6 7 0 1 2 3 4 5 6 7 Standard event status register event enable OPC 0 0 n.u 1 1 QYE 2 2 DDE 3 3 EXE 4 4 CME 5 5 n.u 6 6 PON 7 7 0 1 2 3 4 5 6 7 L O G I C O R event n.u 0 n.u 1 n.u 2 QUES 3 n.u 4 ESB 5 RQS 6 OPER 7 L O G I C O R 22 enable 0 1 2 3 4 5 6 7 L O G I C O R 4.4 SCPI Command Description Common IEEE488.2 Commands *CLS This command clears the following registers:  Standard event status register  Quest condition register  Operation event register  Status byte register  Error code Command syntax: *CLS Parameter: None *ESE This command sets the parameter of the standard event enable register. The value determines which bit value of the standard event register is set to 1. The ESB bit in of status byte register will change to 1 to reflect the changes. Command syntax: *ESE Parameter: 0~255 Reset value: Consult *PSC command Example: *ESE 128 Query syntax: *ESE? Return parameter: Reference command: *ESR? *PSC *STB? Bit map of standard event status enable register Bit position 7 6 Bit Name PON Not used Bit Weight 128 PON Power-on CME Command error EXE Execution error 5 CME 32 4 EXE 16 DDE QYE OPC 3 2 1 DDE QYE Not used 8 4 Device-dependent error Query error Operation complete 0 OPC *ESR? This command queries the standard event status register. After executing this command, the standard event status register is reset. The bit definition of the standard event status register is identical to the standard event status enable register Query syntax: *ESR? Parameter: None Return parameter: Reference command: *CLS *ESE *ESE? *OPC *IDN? This command reads information about the power supply. The return value contains 4 segments divided by a comma. Query syntax: *IDN? Parameter: None Return parameter: segment description 23 BK Precision XXXX XXXXXX manufacturer product mode product serial number VX.XX software version number For example: BK PRECISION,9120A,000004,V1.01 *OPC When all commands sent to the instrument prior to this command have been executed, OPC of the standard event status register will be set to 1. Command syntax: *OPC Parameter: None Query syntax: *OPC? Return parameter: *PSC This command controls whether or not the power supply sends when it is reset. 1 OR ON: When power supply is reset, operation event enable register, query event enable register and standard event status register are all reset. 0 OR OFF: The data of status byte register, operation event enable register, quest event enable register and standard event status enable register is stored in nonvolatile register, and is recalled when power supply is reset. Command syntax: *PSC Parameter: 0|1|ON|OFF Query syntax: *PSC? Return parameter: 0|1 Reference command: *ESE *SRE STAT:OPER:ENAB STAT:QUES:ENAB *RST This command resets the power supply to its default setting. CAL:SEC:STAT OFF OUTP OFF, CURR MAX VOLT:PROT:MAX VOLT: MIN TRIG:SOUR BUS SYST:SENS OFF PORT:MODE TRIG RI:MODE OFF DFI:SOUR OFF VOLT:PROT:STAT OFF Command syntax: *RST Parameter: None *SRE This command can set the parameter of the status byte enable register. The value of this parameter determines which bit value of the status byte register is 1 and the byte will enable RQS of status byte register is 1. The bit definition of the status byte enable register is the same as the status byte register. Command syntax: *SRE Parameter: 0~255 Reset value: Consult *PSC command Example: *SRE 128 Query syntax: *SRE? 24 Return parameter: Reference Command: *ESE *ESR? *PSC *STB? *STB? This command reads data from the status byte register. After executing this command, the status byte register is reset. Query syntax: *STB? Parameter: None Return parameter: Reference command: *CLS *ESE *ESR Bit map of the standard event status enable register Bit Position Bit Name Bit Value 7 OPER 128 6 RQS 64 5 ESB 32 4 no use 3 QUES 8 2 no use 1 no use 0 no use *TRG When the power supply’s trigger source is set to Bus command, this command will generate a trigger signal. Its function is identical to the [SYSTem:]TRIGger command. Command syntax: *TRG Parameter: None Reference command: TRIG TRIG:SOUR *SAV This command saves the operating parameters of the power supply to non volatile memory. The parameters include constant current, constant voltage, maximum voltage value and step voltage values. Command syntax: *SAV Parameter: 1~50 Example: *SAV 3 Reference command: *RCL *RCL This command recalls the parameter saved with the *SAV command. Command syntax: *RCL Parameter: 1~50 Example: *RCL 3 Reference command: *SAV Essential SCPI Commands SYSTem:ERRor[:NEXT]? This command queries the error code and error information of the power supply. (0) No error (1) Too many numeric suffices in Command Spec (10) No Input Command to parse (14) Numeric suffix is invalid value (16) Invalid value in numeric or channel list, e.g. out of range (17) Invalid number of dimensions in a channel list (20) Parameter of type Numeric Value overflowed its storage (30) Wrong units for parameter (40) Wrong type of parameter(s) 25 (50) (60) (65) (70) (80) (90) (101) (100) (110) 1. 2. 3. 4. Wrong number of parameters Unmatched quotation mark (single/double) in parameters Unmatched bracket Command keywords were not recognized No entry in list to retrieve (number list or channel list) Too many dimensions in entry to be returned in parameters Command Execution error Too many command Rxd error Parity Error EEPROM Config data error Error Calibration data Factory Data error Command syntax: SYST:ERR? Parameter: None Return parameter: , SYSTem:VERSion? This command queries the software version. Command syntax: SYST:VERS? Parameter: None Return parameter: SYSTem:ADDRess? This command queries the address of the power supply Command syntax: SYST:ADDR? Parameter: None Return parameter: SYSTem:REMote This command puts the power supply in remote control mode. Command syntax: SYST:REM Parameter: None Query syntax: None SYSTem:LOCal This command configures the instrument for front panel operation Command syntax: SYST:LOC Parameter: None Query syntax: None SYSTem:RWLock[:STATe] This command also sets the instrument to remote control mode. When using this command, it is not possible to press LOCAL key on the front panel to revert back to manual mode. Command syntax: SYST:RWL STATus:QUEStionable[:EVENt]? This command queries the parameters of the quest event register. After execution, the quest event register is reset. Query syntax: STATus:QUEStionable[:EVENt]? Parameter: None Return parameter: Reference command: STATus:QUEStionable:ENABle 26 Bit map of standard event status enable register Bit Position Bit name Bit Value 7 no use 6 no use 5 no use 4 no use 3 no use 2 unr 4 1 OT 2 0 OV 1 STATus:QUEStionable:CONDition? This command queries the parameters of the quest condition register. When a bit of the quest condition changes, the corresponding bit value in the quest event register will be set to 1. Query syntax:STATus:QUEStionable: CONDition? Parameter:None Return parameter: STATus:QUEStionable:ENABle This command sets the parameter of the quest event enable register. This parameter determines which bit of the quest event register is set to 1. If a QUES condition changes, the QUES bit of status byte register will be set to 1. Command syntax: STATus:QUEStionable:ENABle Parameter: 0~255 Reset value: Consult *PSC command Example: STATus:QUEStionable:ENABle 128 Query syntax: STATus:QUEStionable:ENABle? Return parameter: Reference command: *PSC STATus:OPERation[:EVENt]? This command queries the parameters of the operation event register. After executing this command the operation event register is reset. Query syntax: STATus: OPERation [:EVENt]? Parameter: None Return parameter: Reference command: STATus: OPERation:ENABle Bit map of standard event status enable register Bit Position Bit Name Bit value 7 no use 6 no use 5 no use 4 RI 16 3 CC 8 2 CV 4 1 WTG 2 0 CAL 1 STATus:OPERation:CONDition? This command queries the parameters of the operation condition. When a parameter of the operation condition register changes, the corresponding bit in the operation event register will be set to 1. Query syntax: STATus: OPERation: CONDition? Parameter: None Return parameter: STATus:OPERation:ENABle This command sets the parameter of the operation event enable register. The parameter determines which bit value of quest event register is set to 1. If a OPER condition changes, the OPER bit of the status byte register 27 will be set to 1. Command syntax: STATus: OPERation:ENABle Parameter: 0~255 Reset value: Consult *PSC command Example: STATus: OPERation:ENABle 128 Query syntax: STATus: OPERation:ENABle? Return parameter: Reference command: *PSC Output Commands OUTPut[:STATe] This command sets the power supply output on or off. Command syntax: OUTPut[:STATe] Parameter: 0|1|ON|OFF *RST value: OFF Query syntax: OUTPut:STATe? Return parameter: 0|1 Usage: If output timer is required, send command OUTPUT:TIMER ON first, then set OUTPUT ON. These two commands must be set in this order to function properly. OUTPut:TIMer[:STATe] This command sets the output timer state of the power supply. Command syntax: OUTPut:TIMer[:STATe] Parameter: 0|1|ON|OFF *RST value: OFF Query syntax: OUTPut:TIMer[:STATe]? Return parameter: 0|1 Usage: To start Timer - First, set OUTPUT:TIMER ON, then set OUTPUT ON. To end Timer - Set OUTPUT:TIMER OFF to turn timer off. To check timer status - Send command OUTPUT:TIMER? OUTPut:TIMer:DATA This command sets the time of the output timer. The unit is in SECOND and decimal fractions cannot be used for this command. Command syntax: ONPut:TIMer:DATA Parameter: *RST value: 1 Query syntax: OUPut:TIMer:DATA? Return parameter: [SOURce:]MODE This command configures the power supply for command fixed mode, list mode or DVM mode. FIXed Command fixed mode LIST List mode DRM Digital milliohm meter Command syntax: [SOURce:]MODE 28 Parameter: FIXed|LIST|DRM *RST value: FIXed Example: MODE FIX Query syntax: [SOURce:] MODE? Return parameter: Usage: MODE FIX command can also be used to stop a list execution. [SOURce:]CURRent [:LEVel] This command sets the current value of the power supply. Command syntax: [SOURce:]CURRent [:LEVel] Parameter: MIN TO MAX|MIN|MAX Unit: A mA *RST value: MIN Example: Query syntax: Parameter: Example: Return parameter: CURR 3A, CURR 30mA, CURR MAX, [SOURce:]CURRent [:LEVel]? [MIN|MAX] CURR? , CURR? MAX, CURR? MIN CURR MIN [SOURce:]VOLTage[:LEVel] This command sets the voltage value of the power supply. Command syntax: [SOURce:]VOLTage[:LEVel] Parameter: MIN TO MAX|MIN|MAX Unit: V mV kV *RST value: MAX Query syntax: [SOURce:]VOLTage[:LEVel]? Parameter: [MIN|MAX] Return parameter: List File Commands List file operations can be executed using standard SCPI commands. The commands must be executed in a certain order to successfully complete a list file. Below is an example that demonstrates how to set a list in continuous mode with correct command order. LIST:MODE CONT LIST:STEP ONCE LIST:COUNT 2 LIST:VOLT 1,2 LIST:VOLT 2,4 LIST:UNIT SECOND LIST:WID 1,1 LIST:WID 2,2 LIST:NAME ‘TEST’ LIST:SAVE 1 MODE LIST Note: Be sure to specify LIST:AREA prior to using a set of list commands similar to above. For details on setting values for each commands, refer to the descriptions below. [SOURce:]LIST:MODE 29 This command sets the trigger condition for executing the list file CONTinious List operation is continuous mode. STEP List operation is step mode. Command syntax: [SOURce:]LIST:MODE Parameter: CONTinious|STEP Query syntax: [SOURce:]LIST:MODE? Return parameter: [SOURce:]LIST:STEP This command sets the operation mode of the list file. ONCE List operate once REPeat Repeat list operation Command syntax: [SOURce:]LIST:STEP Parameter: ONCE|REPeat Query syntax: [SOURce:]LIST:STEP? Return parameter: Note to usage: When setting to LIST:STEP REPEAT, the list would run repeatedly for an indefinite amount of time. Below is an example set of commands to setup a repeated list properly: *IDN? PORT:FUNCTION TRIGGER OUTPUT:TIMER OFF OUPUT OFF LIST AREA 4 LIST:COUNT 2 LIST:UNIT SECOND TRIGGER:SOURCE BUS LIST:VOLTAGE 1,5 LIST:VOLTAGE 2,1 LIST:WIDTH 1,4 LIST:WIDTH 2,2 LIST:MODE CONT LIST:STEP REPEAT LIST:NAME ‘MX’ LIST:SAVE 1 MODE LIST OUTPUT ON TRIGGER [SOURce:]LIST:COUNt This command sets the number of steps for the list operation. Command syntax: [SOURce:]LIST:COUNt Parameter: 2~400 Query syntax: [SOURce:]LIST:COUNt? Parameter: None Return parameter: [SOURce:]LIST :CURRent[:LEVel] This command sets the current step. Command syntax: [SOURce:]LIST:CURRent[:LEVel] Parameter: 0~30A 30 Unit: Example: Query syntax: Parameter: Example: Return parameter: A mA LIST:CURR 1,3A; [SOURce:]LIST:CURRent:[LEVel]? None LIST:CURR? 1; [SOURce:]LIST :VOLTage[:LEVel] This command sets the voltage step. Command syntax: [SOURce:]LIST:VOLTage [:LEVel] Parameter: 0~360V Unit: V mV Example: LIST:VOLT 1,3V; Query syntax: [SOURce:]TRANsition: VOLTage:TLEVel? Parameter: None Example: LIST:VOLT? ; Return parameter: [SOURce:]LIST:WIDth This command sets the minimum step time. Decimal fractions are not allowed for this command. Units are in seconds or milliseconds, which are set using LIST:UNIT command (see LIST:UNIT). Set units first before using this command. Command syntax: [SOURce:]LIST:WIDth Parameter: MIN TO MAX|MIN|MAX Unit: S mS Example: LIST:WID 1, 100; Query syntax: [SOURce:]LIST:WIDth? Parameter: None Example: LIST:WID? 1; Return parameter: [SOURce:]LIST:NAME This command sets the name for the list file. Make sure the file name does not exceed 8 characters. Command syntax: [SOURce:]LIST:NAME Parameter: Example: LIST:NAME ‘TEST’; Query syntax: [SOURce:]LIST:NAME? Return parameter: [SOURce:]LIST:AREA This command divides up the storage area for the list file in one of the 4 ways listed below. 1.1 group per store area, 400 steps 2.2 groups per storage area, each group contains 200 steps. 4.4 groups per storage area, each group has 100 steps. 8.8 groups of storage area, each group has 50 steps. Command syntax: [SOURce:]LIST:AREA Parameter: 1|2|4|8 Example: LIST:AREA 1 Query syntax: [SOURce:]LIST:AREA? Return parameter: [SOURce:]LIST:SAVe 31 This command saves the list file to a register (non volatile memory). approximately 0.1 million times. The memory can be written Command syntx:[SOURce:]LIST:SAVe Parameter: 1~8 Example: LIST:SAV 1 [SOURce:]LIST:RCL This command can recall the list file saved before from the register. Command syntax: [SOURce:]LIST:SAV Parameter: 1~8 Example: LIST:SAV 1 [SOURce:]LIST:UNIT This command sets the unit for the list width in either seconds (SECOND) or milliseconds (MSECOND). Command syntax: [SOURce:]LIST:UNIT Parameter: SECOND or MSECOND Example: LIST:UNIT SECOND Measurement commands Note: All measurement commands have units in Volts (V), Ampere (A), or Watts (W). allowed. MEASure[:SCALar]:VOLTage[:DC]? This command queries the input voltage of the power supply. Command syntax: MEASure[:SCALar]:VOLTage[:DC]? Parameter: None Return parameter: Return parameter unit: V Example: MEAS:VOLT? MEASure[:SCALar]:CURRent[:DC]? This command queries the input current of the power supply. Command syntax: MEASure[:SCALar]:CURRent[:DC]? Parameter: None Return parameter: Return parameter unit: A Example: MEAS:CURR? MEASure[:SCALar]:POWer[:DC]? This command queries the input power of the power supply. Command syntax: MEASure[:SCALar]:POWer? Parameter: None Return parameter: Return parameter unit: W Example: MEAS:POW? MEASure[:SCALar]:DVM[:DC]? This command queries the voltage reading of the digital volt meter. Command syntax: MEASure[:SCALar]:DVM? Parameter: None Return parameter: Return parameter unit: V Example: MEAS:DVM? 32 Decimal fractions are SENSe:RESistance:RANGe This command sets the range of the milliohm meter. LOW: 0.01W resistance range MIDDLE: 0.1W resistance range HIGH: 1W resistance range Command syntax: SENSe:RESistance:RANGe Parameter: LOW | MIDdle | HIGH Example: RES:RANG LOW Query syntax: SENSe:RESistance:RANGe? Return parameter: MEASure[:SCALar]:RESistance[:DC]? This command queries the resistance reading of the milliohm meter. Command syntax: MEASure[:SCALar]: RESistance? Parameter: None Return parameter: Return parameter unit: Ohm Example: MEAS:RES? Interface Configuration Commands [SOURce:]SYSTem:SENSe [:STATe]{} This command enables/disables the power supply’s remote sense function. Command syntax: SYSTem: SENSe [:STATe] Parameter: 0|1|ON|OFF Query syntax: SYSTem:SENSe [:STATe]? *RST value: 0 [SOURce:]PORT:FUNCtion This command sets the mode of the port in the rear panel. TRIGGER function: Pin1, pin2 are configured as external trigger source for the power supply and to control the list operation. RI/DFI function: Inhibit Input controls the output state of the power supply. The Fault Output can indicate the reason for internal failure. DIGITAL I/O function: Read and control the state of the digital port Command syntax: SOURce:PORT:FUNCtion Parameter: TRIGger|RIDFi|DIGital Query syntax: SOURce:PORT:FUNCtion? *RST value: TRIGger [SOURce:]RI:MODE This command sets the input mode of the RI input pin Command syntax: SOURce:RI:MODE Parameter: OFF|LATChing|LIVE Query syntax: SOURce:RI:MODE? *RST value: OFF [SOURce:]DFI:SOURce This command sets output source of the DFI output pin. 33 (Not available for models 9150, 9151, 9152, and 9153) Command syntax: SOURce:DFI:SOURce Parameter: OFF|QUES|OPER|ESB|RQS Query syntax: SOURce:DFI:SOURce? *RST value: OFF [SOURce:]DIGital:OUTPut[:STATe] This command sets the output state of the digital port. This command can be used when the mode of the port is set to DIGITAL. (Not available for models 9150, 9151, 9152, and 9153) Command syntax: SOURce:OUTPut[:STATe] Paremeter: OFF|ON|0|1 [SOURce:]DIGital:INPut[:STATe]? This command sets the input state of port. This command can be used when the mode of the port is set to DIGITAL. Command syntax: SOURce:DIG:INPut[:STATe] ? Trigger commands TRIGger[:IMMediate] When trigger source is command mode, this command will give a trigger signal. Its function is as the same as *TRG command. Order syntax: * TRIGger[:IMMediate] Parameter: None Reference order: TRIG TRIG:SOUR TRIGger:SOURce This command sets the trigger mode of the power supply.  IMMediate: When this function is enabled, you can generate an immediate trigger pulse by pressing Shift plus Trigger.  EXTernal trigger signal (TTL): When this function is enabled, the power supply can be triggered with a TTL pulse applied to pin 1 of the terminal connector in the rear. The TTL on pulse width should be at least 5 ms.  BUS Command When this function is enabled, you can trigger the power supply by sending a *TRG or TRIgger command to the power supply Command syntax: TRIGger:SOURce Parameter: IMMediate|EXTernal|BUS *RST value: KEY Note on usage: When using the trigger command to initiate a list, commands have to be set in a particular order in order to complete the trigger. Example: Below shows how to initiate a list in continuous mode using trigger under bus command mode: *IDN? PORT:FUNCTION TRIGGER TRIGGER:SOURCE BUS 34 LIST:MODE CONT LIST:STEP ONCE LIST:COUNT 2 LIST:VOLT 1,2 LIST:VOLT 2,4 LIST:UNIT SECOND LIST:WID 1,1 LIST:WID 2,2 LIST:NAME ‘TEST’ LIST:SAVE 1 MODE LIST TRIGGER 35 5. Specifications 5.1 Specifications Models 9120A, 9121A and 9124 Parameter Voltage Output Ratings Current ( 0 °C~40 °C) LVP* 9120A 0 - 32 V 0-3A 0 - 33 V 9121A 0 - 20 V 0-5A 0 - 21 V 9124 0 - 72 V 0 - 1.2 A 0 - 73 V Load Regulation Voltage
9121A 价格&库存
很抱歉,暂时无法提供与“9121A”相匹配的价格&库存,您可以联系我们找货
