XLN10014
XLN10014
    B&K
    PWR SUPP PROGRAMABLE DC 100V/14A
XLN10014 数据手册
Data Sheet Programmable DC Power Supplies XLN Series New Family of High Density System Power Supplies The B&K Precision XLN series are programmable, single-output DC power supplies, that provide clean power up to 1560 watts in a compact 1U rackmountable package. Comparable supplies from other manufacturers primarily address the ATE market only, while the XLN series is designed for both benchtop users and system integrators. Standard USB, RS485, and optional GPIB and LAN interfaces combined with fast average command processing times of less than 50 ms make the XLN series ideal for ATE applications. Free application software and a complete set of LabVIEW™ drivers are available to provide remote control capabilities, reduce programming time, and increase productivity. For benchtop applications, these power supplies offer built-in voltage and current meters displaying setting and output values concurrently, as well as an intuitive user interface with full keypad and rotary knob. Features When greater output power is required, up to four XLN models can be connected in series (high current models only) or parallel and synchronized with the RS485 interface. Alternatively, the RS485 interface can be used to daisy chain up to 30 units and to remotely control them from one master PC via USB, GPIB, or LAN interface. High Current High Voltage XLN Models XLN Models Auxiliary Output 5V/1A Master/Slave Oper. Parallel/Series Parallel Only Display resolution 1 mV/1 mA 10 mV/1 mA Analog programming √ √ Analog monitoring - √ These power supplies are perfectly suited for ATE systems integration, product design and development, product QC and burn-in testing, and other applications requiring excellent regulation, high power, low noise, and a wide range of voltage and current ratings. - Features & Benefits ■ Compact, high density, 1U package ■ USB interface (standard), GPIB and LAN (optional) ■ External analog programming interface ■ List mode: execute test sequences with up to 150 steps from instrument memory ■ Average command processing time
XLN10014 价格&库存
很抱歉,暂时无法提供与“XLN10014”相匹配的价格&库存,您可以联系我们找货
XLN10014
  • 1+22539.911611+2912.88010
