1652
1652
    B&K
    PWRSUPPLYTRIOUTPUTDGTLDC
1652 数据手册
Data Sheet Triple Output DC Power Supplies Models 1651A & 1652 Model 1651A Model 1652 Specifications The models 1651A & 1652 are Triple Output DC Power Supplies with two variable 0 to 24 VDC outputs capable of supplying 0 to 500 mA, and one fixed 5 VDC output capable of supplying up to 4 A. Connect outputs in series for higher voltage or connect in parallel for higher current output (switch selectable). Voltage and current metering is provided by two, three-digit LED displays (model 1652) or two analog displays (model 1651A). These units are fully protected against short circuit, overload, and reverse polarity. Mode l 1651A Number of Outputs Three (two variable and one fixed) 0 to 24 VDC (A & B) 5 VDC (C) 0 to 500 mA (A & B) 4 A (C) Output Voltage Output Current Const an t Vo ltage Ope ratio n < 0.01% + 3 mV main < 5 mV for line fixed supply < 0.01% + 3 mV main < 10 mV fixed 100 uS
很抱歉,暂时无法提供与“1652”相匹配的价格&库存,您可以联系我们找货
