1511
1511
    B&K
    FIXED IND 4MH 600MA 11 OHM CHASS
1511 数据手册
SPECIFICATIONS 1511 DESCRIPTION: 0-20VDC, 5A 0-80VDC, 10mA AC 1.1V, 2.2V, 3.3V, 4.4V, 5.5V, 6.6V 2A INPUT VOLTAGE: 115VAC, 60Hz ENVIRONMENTAL TEMPERATURE: 25°C 0-20VDC: Output Voltage Range Minimum Output Voltage Range Maximum Output Voltage Output Current Protection Current (start point) Load Voltage Regulation (0-100% load) Line Voltage Regulation (100-130VAC Variation) Ripple & Noise 0-500VDC, 10mA Power Supply Min. 1V 0.8V, typical 20.5V 5A 5A Max. 20V 1V 22.5V 8A 2.5V 2.5V 50mVrms 0-80VDC: Max. Output Voltage No Load Max. Output Voltage Full Load Output Current 90V 120V 80V 100V 10mA, typical 0-500VDC: Max. Output Voltage No Load Max. Output Voltage Full Load Output Current 600V 800V 500V 10mA, typical AC Output Voltage 1 AC Output Voltage 2 AC Output Voltage 3 AC Output Voltage 4 AC Output Voltage 5 AC Output Voltage 6 1V 2.1V 3.2V 4.2V 5.3V 6.3V No Load Input Current Full load Input Current Meter Accuracy: Voltmeter Ammeter +- 1%+1 digit +- 1%+1 digit Fuse 3Amps Dimensions (W X D X H): 258 mm x 216 mm x 108 mm Weight: 5.80 kgs 1.4V 2.5V 3.6V 5V 6.1V 7.5V 160mA 1.5A Operation: Plug model 1511 into AC outlet. Turn power switch on. Select desired voltage, use control knobs to adjust output.
很抱歉,暂时无法提供与“1511”相匹配的价格&库存,您可以联系我们找货
