Data Sheet
Programmable DC Power Supplies
XLN Series
New Family of High Density System Power Supplies
The B&K Precision XLN series are programmable,
single-output DC power supplies, that provide
clean power up to 1560 watts in a compact 1U
rackmountable package. Comparable supplies
from other manufacturers primarily address the
ATE market only, while the XLN series is designed
for both benchtop users and system integrators.
Standard USB, RS485, and optional GPIB and
LAN interfaces combined with fast average
command processing times of less than 50 ms
make the XLN series ideal for ATE applications.
Free application software and a complete set of
LabVIEW™ drivers are available to provide
remote control capabilities, reduce programming
time, and increase productivity.
For benchtop applications, these power supplies
offer built-in voltage and current meters
displaying setting and output values concurrently,
as well as an intuitive user interface with full
keypad and rotary knob.
Features
When greater output power is required, up to
four XLN models can be connected in series
(high current models only) or parallel and
synchronized with the RS485 interface.
Alternatively, the RS485 interface can be used
to daisy chain up to 30 units and to remotely
control them from one master PC via USB, GPIB,
or LAN interface.
High Current High Voltage
XLN Models XLN Models
Auxiliary Output
5V/1A
Master/Slave Oper.
Parallel/Series
Parallel Only
Display resolution
1 mV/1 mA
10 mV/1 mA
Analog programming
Analog monitoring
These power supplies are perfectly suited for
ATE systems integration, product design and
development, product QC and burn-in testing,
and other applications requiring excellent
regulation, high power, low noise, and a wide
range of voltage and current ratings.
Features & Benefits
■ Compact, high density, 1U package
■ USB interface (standard), GPIB and LAN
(optional)
■ External analog programming interface
■ List mode: execute test sequences with up to
150 steps from instrument memory
■ Average command processing time
很抱歉,暂时无法提供与“XLN10014-GL”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+27467.784941+3545.86090
