1690
1690
    B&K
    TIP FORCE FIT SOLDERLESS
1690 数据手册
Data Sheet Regulated 28 A DC Power Supplies Models 1689 & 1690 Model 1689 Model 1690 Models 1689 and 1690 are high current DC power supplies designed for continuous duty. These power supplies provide up to 28 A maximum current output continuously hour after hour without overheating, making them ideal car battery substitutions for servicing or powering high power car stereos, cellular phone products, or ham radios. The models offer analog (model 1689) or digital (model 1690) displays with multiple output terminals. Two pairs of 3 A, snap-in connectors are easily accessible on the front panel, and a pair of 28 A screw-on output terminals are located on the rear panel. Features & Benefits ■ 1 V to 15 V variable output ■ 28 A output at 13.8 V* ■ Overload protection ■ High RFI stability ■ Multiple DC output terminals (one 28 A and two 3 A output terminals) Specifications 1689 1690 Output Voltage and Current OUTPUT 1-15 V *28 A (at 13.8 V) Line Regulation 5 mV (±2% Load) Load Regulation 50 mV (0-100% Load) Ripple & Noise 5 mV 35 Output Current (A) Voltage Current METERING 30 25 20 15 10 5 Accuracy 7% F.S. ±(0.2% + 2 digits) GENERAL 0 0 2 4 6 8 10 12 14 16 Output Voltage (V) Display Precision Analog Digital LED AC Input 110 VAC, 60 Hz Dimension (W x H x D) 9.84” x 5.5” x 8.86" (250 x 140 x 225 mm) Weight 19.9 lbs. (9 kg) Supplied Accessories User manual One-Year Warranty * See graph for output current and output voltage Technical data subject to change © B&K Precision Corp. 2014 v040914 www.bkprecision.com Graph showing relationship between output voltage and output current
很抱歉,暂时无法提供与“1690”相匹配的价格&库存,您可以联系我们找货
