270
270
    TPI(TPI 公司)
    CLAMP-ON TESTER W/DMM
270 数据手册
270 Clamp-On Tester with Digital Multimetervisit 270 Product Sheet 02.11 Test the TPI Advantage Why pay more? APPLICATIONS Perfect for tight, narrow, spaces... • Measure flame safety control current The new TPI 270 with slim jaw and body is ideal for cramped work areas and crowded electrical panels. • Test run and start capacitors and motors Features • Measure motor run current and capture peak motor start up amperage • Measure motor in-rush current and run current • Measure temperature differential with relative mode • Non-contact voltage feature can be used to immediately see if power is being supplied to the 24VAC control circuit of thermostats • Measure heat anticipator current • Determine thermocouple voltage • Frequency, Min/Max/Record, Data Hold and Peak Hold • Up to 40,000 Microfarads to test run and start capacitors • Test line and control voltages • 4,000 count display with 41 segment analog bargraph • Measure heating element resistance ALL THESE PLUS... • Measure air temperature in ducts • Auto & Manual Ranging • Test for the presence of voltage in circuits without contacting the circuit • Over Range Indication (“OL”) • Low Battery Indicator • Hi Voltage Indicator (>30V AC/DC) • Auto Power Off after 30 minutes • Measure temperature differential using relative mode • Separate Battery/Fuse Compartment • Low Ohm Range (400V) 10” x 1.3” x 2.5” • Amps AC Resolution: 0.01A • VDC/VAC Resolution: 0.1mV • DCA measurement (0.01A resolution) • Temperature measurement with 0.1 ° resolution www.tpithevalueleader.com Copyright © 2011 Test Products International, Inc. 270 Clamp-On Tester General Features and Specifications 270 Data Sheet 02.11 Test the TPI Advantage TPI offers acomplete lineof… CO, Combustibles & Combustion (CEA) Refrigerant Leak Detectors Digital Manometers Temperature Contact & IR Instruments IAQ: Air Flow / Humidity Handheld Oscilloscopes Digital Multimeters & Clamp-on Meters Accessories & Kits Instrument Specifications Basic DC Accuracy: 0.5% DC Voltage (maximum): 600V Resolution (maximum): 0.1mV AC Voltage (maximum): 600V Resolution (maximum): 0.1mV DC Amps(maximum): 400A Resolution (maximum): 0.01A AC Amps(maximum): 400A Resolution (maximum): 0.01A Resistance (maximum): 40 Resolution (maximum): 0.1 Frequency (maximum): 400MHz Resolution (maximum): 0.001KHz Capacitance (maximum): 40,000F Resolution (maximum): 0.001nF Temperature (maximum) 1,000°F Resolution (maximum) 0.1° Diode: Test Current Max 1.5mA Continuity: Buzzer sounds at
很抱歉,暂时无法提供与“270”相匹配的价格&库存,您可以联系我们找货
