275
275
    TPI(TPI 公司)
    DGTL CLAMP-ON W/11,000 CNT DISP
275 数据手册
275 Product Sheet 02.11 275 Clamp-On Tester with True RMS Digital Multimeter & 11,000 Count Display Test the TPI Advantage Why pay more? APPLICATIONS Perfect for tight, narrow, spaces... • Measure DC amperage of motor drive units The new TPI 275 with slim jaw and body is ideal for cramped work areas and crowded electrical panels. • Measure flame safety control current Features • Test run and start capacitors and motors • 11,000 count display • Measure motor run current and capture peak motor start up amperage • Auto & Manual Ranging • True RMS • Up to 400 amps AC/DC • Data Hold • Low Battery Indicator • Measure heat anticipator current • Over Range Indication (“OL”) • Determine thermocouple voltage • Peak Hold • Test line and control voltages • Relative Mode • Min/Max • Hi Voltage Indicator(>30V AC/DC) • Measure heating element resistance • Non-contact voltage detection • Measure air temperature in ducts • Auto Power Off after 30 minutes • Test for the presence of voltage in circuits without contacting the circuit • Low Ohm Range (110) • Separate Battery Compartment • Amps AC Resolution: 0.01A 10” x 1.3” x 2.5” • Measure temperature differential using relative mode • VDC/VAC Resolution: 0.01mV • DCìA measurement (0.01A resolution) • Temperature measurement www.tpithevalueleader.com Copyright © 2011 Test Products International, Inc. 275 Clamp-On Tester General Features and Specifications 275 Data Sheet 02.11 Test the TPI Advantage TPI offers acomplete lineof… CO, Combustibles & Combustion (CEA) Refrigerant Leak Detectors Digital Manometers Temperature Contact & IR Instruments IAQ: Air Flow / Humidity Handheld Oscilloscopes Digital Multimeters & Clamp-on Meters Accessories & Kits Instrument Specifications Basic DC Accuracy: 0.5% DC Voltage (maximum): 600V Resolution (maximum): 0.01mV AC Voltage (maximum): 600V Resolution (maximum): 0.01mV DC Amps (maximum): 400A Resolution (maximum): 0.01A DC Microamps (maximum): 1,100FA Resolution (maximum): 0.01A AC Amps (maximum): 400A Resolution (maximum): 0.01A Resistance (maximum): 110M Resolution (maximum): 0.01 Frequency (maximum): 110MHz Resolution (maximum): 0.1Hz Capacitance (maximum): 110mF Resolution (maximum): 0.001nF Temperature (maximim): 1,000°F Resolution (maximum): 0.1°F Diode: Test Current Max 1.5mA Continuity: Buzzer sounds at
很抱歉,暂时无法提供与“275”相匹配的价格&库存,您可以联系我们找货
