CM-850-C
CM-850-C
    GREENLEECOMMUNICATIONS(格林利)
    CLAMPMETER AC RMS
CM-850-C 数据手册
CLAMPMETER, AC RMS True RMS Clamp Meter Cat No: CM-850-C UPC No: 783310108573 Description • • • • • • • • • True RMS for the most accurate measurement when harmonicsare present AC amperage, AC/DC voltage, frequency and resistance measuring capability Easy-to-read backlit display for use in low light conditions Peak and data hold to capture measurement MIN/MAX feature for added versatility Analog bar graph to view quick changes Selectable Auto Off for longer battery life Accessories included: (1) 9V battery, test leads, carrying case Lifetime Limited Warranty Specifications • • • • • • • • • • • Amperage Measurement : 400, 600 AMP Display : LCD, 4000 Count Frequency Rating : 0.400 KHZ Includes : 9 V Battery, Test Leads, Carrying Case Jaw Opening : 1.340 IN Measurement Category : CAT III, 600 V Replacement Part : TSG-3 Sure-Grip Test Leads, TC-10 Carrying Case Resistance Measurement : 400 OHM Standard : CAT III, C/US UL Listed, CE Type : AC, TRMS Voltage Measurement : 400, 600 V
CM-850-C 价格&库存
很抱歉,暂时无法提供与“CM-850-C”相匹配的价格&库存,您可以联系我们找货
