2558
2558
    B&K
    300 MHZ 2 GSA/S 2 CH DSO
2558 数据手册
Data Sheet Digital Storage Oscilloscopes 2550 Series Features & Benefits ■ Bandwidth up to 300 MHz ■ 2 GSa/s sample rate ■ 4-channel acquisition (on select models) ■ Large 7” widescreen color display ■ FFT including four additional math functions - Add, Subtract, Multiply, and Divide ■ ■ 32 automatic measurements 50 Ω input coupling (200 MHz and 300 MHz models) ■ Additionally, these oscilloscopes can be integrated with AWGs using B&K Precision's waveform editing software, WaveXpress. WaveXpress allows users to easily modify waveforms downloaded from the scope and can also be used for analysis of deep memory acquisitions. The 2550 series digital storage oscilloscopes provide high performance and value in 2-channel and 4-channel configurations. With bandwidth from 70 MHz to 300 MHz and 2 GSa/s sample rates, these oscilloscopes offer 24 kpts/Ch waveform memory, 32 automatic measurements, and advanced triggering capabilities including math functions. Engineered to allow you to see more of your signal under test, the 2550 series’ widescreen 7” TFT display offers a significantly larger viewing area than typical economy oscilloscopes (5.7”). Educators who want to teach waveform measurement fundamentals can benefit from the ability to disable the Auto set button, a function that automatically sets up the scope to display a signal. Maximize productivity with PC connectivity via LAN and USB. The downloadable PC software lets you easily capture, save, and analyze measurement results. All oscilloscope parameters can be controlled via a PC without the need for programming. Model 2552 Bandwidth Channels 2553 2554 70 MHz 2 The 2550 series oscilloscopes are ideal for applications in design and debug, service and repair, and education. 2555 2556 100 MHz 4 2 2557 2558 200 MHz 4 2 4 2 For more information, visit www.bkprecision.com/WaveXpress Technical data subject to change © B&K Precision Corp. 2015 2559 300 MHz www.bkprecision.com 4 Standard LAN (supports SCPI) and USB device port (USBTMC compliant) ■ Front and rear panel USB host port for saving and recalling waveform setups, data, and screenshots on a USB flash drive ■ ■ Software provided for remote PC control Advanced tools include digital filters with adjustable limits, pass/fail testing and waveform recorder mode ■ Multi-language user interface and context sensitive help Digital Storage Oscilloscopes 2550 Series Front panel Widescreen display Menu On/Off button Context sensitive help Auto setup The 7" widescreen color display lets you see more of your signal. Configure the menu parameters and hide the menu with the push of a button to view your signal in full screen. A pop up window will display the functionality of a control while help mode is active. Vertical, horizontal, and trigger controls are automatically adjusted for fast signal display. Waveform analysis with math and FFT Analyze your signals with add, subtract, multiply, and divide functions. View the signal’s frequency spectrum and perform harmonic distortion analysis. Advanced triggering Isolate the signal with advanced triggering including pulse width and selectable video trigger. Power standby USB host port Connect your USB flash drive to conveniently store and recall waveform data, setups, and screenshots. Probe compensation Terminal Print button Intuitive channel operation Simply press the Print button to save a screenshot in bitmap format to a USB flash drive. All channels in the 2550 series are clearly indicated by their own color, labeled on the input, knobs, and display. Rear panel AC line power switch Input fuse holder AC line input Kensington security slot Helps to secure your oscilloscope and prevent theft. 2 Pass/Fail BNC Communication USB host port LAN and USB ports Additional USB port on rear enable remote control for data storage to a USB flash from a PC. drive. www.bkprecision.com Digital Storage Oscilloscopes 2550 Series The tools you need Powerful measurement functions Digital filtering Filter OFF Filter ON 3 Display and measure the input signal’s frequency spectrum. Select one of the 4 FFT windows: Rectangular, Hanning, Hamming, and Blackman. Use cursors to measure the spectral component’s magnitude and frequency. Filter out unwanted signal components such as various types of noise with built-in digital filters. Choose from Low-Pass, High-Pass, Band-Pass, and Band-Stop filters. Waveform recorder Delayed sweep/zoom Monitor and analyze long-term signal behavior by recording data continuously over an extensive period of time and playing it back for post acquisition analysis. Data is recorded in a sequence of up to 2500 frames. Use the oscilloscope’s delayed sweep feature to zoom in a particular area of a signal in real time while viewing the entire captured waveform simultaneously. Large internal storage Pass/Fail testing Minimize debug time by saving and recalling setups and waveforms from internal memory. Save and recall up to 20 different oscilloscope setups and 20 different waveforms. Generate user-defined pass/fail limits to quickly identify go/no go test results. www.bkprecision.com Digital Storage Oscilloscopes 2550 Series PC connectivity PC software is provided (free download at B&K Precision’s website at www.bkprecision.com) for seamless integration between the oscilloscope and PC. Capture and transfer waveforms, screen images, setups and measurement results to a Windows PC via the USB device port on the back of the instrument. A USB host port on the front and rear allows for quick and easy screen saving. High bandwidth passive oscilloscope probes PR150B Avoid limiting the bandwidth of your measurement system. All 2550 series models come standard with high bandwidth, slimline passive probes (one per channel) to help you get the most out of your scope. Features ■ Slim, stylish body ■ Large accessory set ■ Snap-locking sprung hook ■ Meets IEC 61010-031 CATII ■ Easily replaceable tip ■ RoHS compliant Model 4 PR250B & PR500B Included Probes 2552 two 150 MHz bandwidth, x1/x10 probes (model PR150B) 2553 four 150 MHz bandwidth, x1/x10 probes (model PR150B) 2554 two 150 MHz bandwidth, x1/x10 probes (model PR150B) 2555 four 150 MHz bandwidth, x1/x10 probes (model PR150B) 2556 two 250 MHz bandwidth, x10 probes (model PR250B) 2557 four 250 MHz bandwidth, x10 probes (model PR250B) 2558 two 500 MHz bandwidth, x10 probes (model PR500B) 2559 four 500 MHz bandwidth, x10 probes (model PR500B) www.bkprecision.com Digital Storage Oscilloscopes 2550 Series Specifications 2552 2553 2554 2555 2556 2557 2558 2559 Performance Characteristics Bandwidth 70 MHz 100 MHz Channels 200 MHz 300 MHz 2 GSa/s (half-channel interleaved)(1), 1 GSa/s (per channel) Real Time Sampling Rate 2 4 2 4 2 4 2 4 Rise Time < 5 ns < 3.5 ns < 1.8 ns < 1.2 ns Ch to Ch Isolation (Both channels in same V/div setting) >100:1 at 35 MHz >100:1 at 50 MHz >100:1 at 100 MHz >100:1 at 150 MHz 24 kpts (half-channel interleaved)(1)(2), 12 kpts (per channel) Max Memory Depth Vertical Resolution 8 bit Vertical Sensitivity 2 mV/div -10 V/div (1-2-5 order) DC Gain Accuracy
很抱歉,暂时无法提供与“2558”相匹配的价格&库存,您可以联系我们找货
