2530B
2530B
    B&K
    25 MHZ,500 MSA/S DGTL OSC SCOPE
2530B 数据手册
Data Sheet Digital Storage Oscilloscopes Models 2530B and 2532B Features and Benefits ■ 25/40 ■ 500 MHz bandwidth (2530B / 2532B) MSa/s sample rate ■ Bright ■ Long 5.7” color display waveform memory up to 32,000 pts/Ch (when time base is 50 ns or 25 ns and maximum data depth mode is enabled) ■ For educators - ability to disable the Auto Set button ■ Five different math functions – Add, Subtract, Multiply, Divide, and FFT ■ Versatile triggering capabilities including pulse width, line-selectable video, slope, and alternating trigger ■ 32 automatic measurements ■ Advanced tools include digital filter with adjustable limits, pass/fail testing, and wave The 2530B and 2532B combine performance and value all in one portable solution. With advanced triggering capabilities, long waveform memory up to 32,000 pts/Ch, and extensive features such as pass/fail limit testing, digital filtering, waveform recorder, and automatic measurements, these oscilloscopes offer powerful tools in a small affordable package. Maximize productivity with the included EasyScope PC software that lets you easily capture, save, and analyze measurement results. All oscilloscope parameters can be controlled via a PC without the need for programming. Technical data subject to change © B&K Precision Corp. 2011 Educators will appreciate the ability to disable the Auto button that would automatically setup the scope to display a signal circumventing the need to know how to set up scope parameters. This is key for teaching waveform measurement fundamentals as if it was an analog oscilloscope. The 2530B and 2532B are ideal oscilloscopes for applications in education, troubleshooting and debug, service and repair. w w w.bk prec ision.c om form recorder mode ■ 12 different language user interfaces and context sensitive help ■ USB device port connectivity for remote PC control through EasyScope PC software ■ USB host port for convenient storing and recalling of waveform data, setups, and screenshots on a USB flash drive Digital Storage Oscilloscopes Models 2530B and 2532B Front panel features Display 5.7” color display. M enu On/Off butto n Configure the menu parameters and hide the menu with the push of a button to view your signal in full screen. Wavefo rm analysis wi th math an d FFT Analyze your signals with add, subtract, multiply, and divide functions. View the signal’s frequency spectrum and perform harmonic distortion analysis. Co nte xt sens itiv e he lp feature While in help mode, push any button and a help window will pop up describing the functionality. Auto s etup Vertical, horizontal, and trigger controls are automatically adjusted for fast signal display. Advanced t ri ggerin g Isolate the signal with advanced triggering including pulse width and selectable video trigger. USB h ost port Connect your USB flash drive to conveniently update firmware and store/recall waveform data, setups, and screenshots. Prin t butto n Simply press the Print button to save a screenshot in bitmap format to a USB flash drive. Rear panel Security l oop Use the built-in security loop to secure your instrument to your location. Co mmunicatio n RS232 and USB ports enable remote PC control via EasyScope PC software. 2 w w w.bk prec ision.c om Digital Storage Oscilloscopes Models 2530B and 2532B The tools you need PC Connectivity Powe rful Measurement Functions The included EasyScope software provides seamless integration between the oscilloscope and PC. Capture and transfer waveforms, screen images, setups and measurement results to a Windows PC via the USB device port on the back of the instrument. A USB host port on the front allows for quick and easy screen saving. Display and measure the input signal’s frequency spectrum. Select one of the 4 FFT windows: Rectangular, Hanning, Hamming, and Blackman. Use cursors to measure the spectral component’s magnitude and frequency. Large Internal S torage Multi-Lang uage Interface Minimize debug time by saving and recalling setups and waveforms from internal memory. Save and recall up to 20 different oscilloscope setups and 10 different waveforms. Operate the oscilloscope in a language you understand best with the built-in multi-language interface. Choose from English, Simplified Chinese, Traditional Chinese, Arabic, French, German, Russian, Spanish, Portuguese, Japanese, Korean, and Italian. Waveform Record er Monitor and analyze long-term signal behavior by recording data continuously over an extensive period of time and playing them back for post acquisition analysis. Data is recorded in a sequence of up to 2500 frames. Digital Filtering Noisy signal Pass/Fail Testing Noisy signal with filter applied Filter out unwanted signal components such as various types of noise with built-in digital filters. Choose from Low-Pass, High-Pass, Band-Pass, and Band-Stop filters. Generate user-defined pass/fail limits to quickly identify go/no go test results. 3 w w w.bk prec ision.c om Digital Storage Oscilloscopes Models 2530B and 2532B Specifications M ode l 2530B 2532B 25 MHz 40 MHz Pe rformance Characteris tics Bandwidth Reading Resolution Real Time Sampling Rate Single Channel: 500 MSa/s Dual Channel: 250 MSa/s (for timebase faster than 250 ns/div) Channels 2 Rise time Record Length
2530B 价格&库存
很抱歉,暂时无法提供与“2530B”相匹配的价格&库存,您可以联系我们找货
