2522C
2522C
    B&K
    20 MHZ-40 MS/S DSO W/2 PROBES
2522C 数据手册
Data sheet 20 MHz Analog/Digital Storage Oscilloscope Model 2522C 20 MHz analog bandwidth 40 MS/s sampling rate each channel ■ 2 k memory per channel ■ USB host port for saving screen images to USB flash drives ■ 1 GHz equivalent time sampling (at 0.1 µs/div) ■ Pretrigger capture ■ ■ SWEE P SYSTEM B&K Precision's Model 2522C is one of the lowest cost digital storage / analog oscilloscopes in the industry, yet it includes all the basic features needed by most technicians and engineers. Spe ci fi cations Accuracy: +3% Sweep Magnification: 10X, +6% Hold off TRI GGERI NG Variable Modes Maximum External Trigger Voltage 200V (DC + AC peak) Sensitivity Internal - 0.5 division, External - 500 mV Vertical Resolution Horizontal Resolution 1 in 2048, approximately 200 samples/div. Sampling Rate 40 M samples/sec to 4 samples/sec, reduced in proportion to time base. Direct sampling at time base settings of 20 µs/div and slower, equivalent time sampling at time base settings of 10 µs/div and faster Time Base Expander For storage of slow time events, time base steps 10 ms/div and slower have selectable 1/1 or 1/100 rate. 1/100 rate expands time base from 1 sec/div to 50 sec/div in 1-2-5 sequence Equivalent time Sampling Bandwidth Dot Joining 0.1 µs/div to 2 s/div in 1-2-5 sequence, 23 steps. Vernier control provides fully adjustable sweep time between steps 2522C 2048 x 8 bits/channel; (2 k/channel with direct sampling, 1 k/channel with equivalent time sampling) 1 in 256, approximately 25 steps/div. Storage Word Size Sweep Speed AUTO (free run) or NORM. Source: CH1, CH2, ALT, EXT, LINE. TRI GGER COUPLING AC 30 Hz to 30 MHz. TV H/HF: Used for triggering from horizontal sync pulses. Low frequencies are attenuated. TV V DC/LF: Used for triggering from vertical sync pulses. High frequencies are attenuated. Direct coupled. H OR IZONTAL A MPLIFIER(I npu t thru CH 1 Input) X-Y Mode 20 MHz for repetitive waveforms Switch selectable using X-Y switch CH 1: X axis CH 2: Y axis Sensitivity Same as vertical channel 1 Linear interpolation between samples Accuracy Y-Axis: ±3%. X-Axis: ±6% Input Impedance Same as vertical channel 1 Roll Stored data and display updated continually Frequency Response DC to 2 MHz typical (-3 dB) (to 6 divisions horizontal deflection) Refresh Stored data and display updated by triggered sweep X-Y Phase Difference Approximately 3˚ at 50 kHz Hold Freezes channel 1 and channel 2 data immediately Maximum Input Voltage Same as vertical channel 1 Save CH 2 Freezes channel 2 data immediately. Pretrigger Storage Available in single shot mode, switchable to 0% or 50%. Type Rectangular with internal graticule LED Indicators Trigger, Arm, Data Transfer Display Area 8 x 10 div (1 div = 1 cm). Accelerating Voltage 2 kV D IGI TA L DI SPLA Y MOD ES CR T I /O In terface USB host port (rear panel) A NA LOG MODE SPECI FI CATI ONS Save screen images to USB flash memory Phosphor Trace Rotation E NVI RONM ENT VERTICAL AMPLIFIERS (CH 1 and CH 2) Sensitivity 5 mV/div to 5 V/div in 1-2-5 sequence, 10 steps. Vernier control provides fully adjustable gain between steps. Pull x5 increases maximum sensitivity to 1 mV/div (at reduced bandwidth) Accuracy ±3%, ±5% at x5 MAG Input Resistance 1MΩ +2% 25pF +10pF Frequency Response 5 mV to 5 V/div: DC to 20 MHz (-3 db) x5: DC to 10MHz (-3dB) Rise Time Approximately 17.5 ns (overshoot
2522C 价格&库存
很抱歉,暂时无法提供与“2522C”相匹配的价格&库存,您可以联系我们找货
