2160A
2160A
    B&K
    O'SCOPE 60MHZ DUAL TR/DLY SWEEP
2160A 数据手册
Data Sheet 60 MHz Analog Oscilloscope with Probes Model 2160A B&K Precision's model 2160A is a high performance oscilloscope with many features at a low cost. The model 2160A includes a built in component tester, which is an excellent tool for in circuit troubleshooting. This oscilloscope is built by and backed by B&K Precision, a company that has been selling reliable, durable, value priced test instruments for over 50 years. ■ ■ ■ ■ ■ ■ ■ ■ 5mV/div sensitivity 23 calibrated ranges (main time base) 23 calibrated ranges (delayed time base) Signal delay time Component tester Z axis input Single sweep cUL certified Specifications model 2160A VERTICAL AMPLIFIERS (CH 1 and 2) Sensitivity Attenuator Accuracy Input impedance Input Capacitance Frequency Response Rise Time Operating Modes Polarity Reversal Maximum Input Voltage 5 mV/ 5 V/div, 1 mV/div to 1 V/div (X5 MAG) 1-2-5 sequence, plus x 5 gain step, Vernier control provide fully adjustable sensitivity between steps range 1/1 to at least 1/2.5 ±3%, 5 mV to 5 V/div; ±5%, 1 mV, 2 mV/div 1 MΩ ±2% 25 pF±10% DC to 60 MHz (5 mV/div to 5 V/div), DC to 15 MHz (X5 MAG) 5.8 ns (Overshoot ≤5%) CH1, CH2, Dual, Alternate Chop CH 2 invert 400V (DC + AC peak) CH 2 Output (on rear panel) Output Voltage Output Impedance Frequency Response CRT Type Display Area Accelerating Voltage Phosphor Scale Illumination Trace Rotation Components Tested Test Voltage Test Current Test Frequency Main, Mix, Delay, XY 5:1 continuously variable Sweep Speed Accuracy Variable Time Control Sweep Magnification 0.1µs/div. to 2.0s/div. in 1-2-5 sequence, 23 steps ±3% 5:1,uncalibrated, continuously variable between steps 10 x , ±10%, extended sweep speed up to 10 ns/div Delay Sweep Sweep Speed Accuracy Sweep Magnification Delay Time Position 0.1 µs/div. to 2.0 s/div. in 1-2-5 sequence, 23 steps ±3% 10 x , ±10%, extended sweep speed up to 10 ns/div Variable control to locate desirable waveform for extending Triggering Cal/Probe Compensation Voltage Sweep Output Input Signal Input Impedance Usable Freq. Range Maximum Input Voltage TTL level, intensity increasing with more positive levels 50 kΩ DC to 5 MHz 30 V (DC + AC peak) Environment AUTO, NORM, TV-V, TV-H CH1, CH2, ALT, EXT. LINE +/- CH 1: X axis. CH 2: Y axis Same as vertical channel 2 Same as vertical channel 2 DC: DC to 1MHz (-3 dB). AC: 5 Hz or 2 MHz (-3 dB) 3˚or less at 50 kHz Same as vertical channel 2 Technical data subject to change © B&K Precision Corp. 2012 v013012 2.0 V p-p ±3% square wave, 1 kHz nominal TTL level allows synchronization of external equipment with scope sweep Intensity Modulation Within Specified Accuracy Full Operation Storage Power Requirements Dimensions (H x W x D) Weight HORIZONTAL AMPLIFIER (Input through channel 2 input) X-Y Mode Sensitivity Input Impedance Frequency Response X-Y Phase Difference Maximum Input Voltage Resistors, capacitors, inductors, and semiconductors 6 V rms maximum (open) 11 mA maximum (shorted) Line frequency (60 Hz in USA) Other Specifications Main Sweep Trigger Coupling Trigger Source Slope 6-inch rectangular with internal graticule 8 x 10 div (1 div = 1 cm) 12 kV P31 Continuously variable Electrical, front panel adjustable COMPONENT TESTER SWEEP SYSTEM Sweep Display Modes Hold Off Time 50 mV/div (nominal into 50 Ω load) Approximately 50 Ω 20 Hz to 60 MHz, -3 dB into 50 V 50˚ to 95˚F (10˚ to 35˚C), 10-80% RH 32˚ to 122˚F (0˚ to +50˚C), 10 - 80% RH -22˚ to 158˚F (-30˚ to +70˚C), 10 - 90% RH 110/120/220/240 V ±10%, 50/60 Hz 12.76 x 15.68 x 5.2" (324 x 398 x 132mm) 16.75 lbs. (7.6kg) Three Year Warranty Accessories Supplied: Instruction Manual, Two PR 33A x1/x10 Probes or equivalent, AC Power Cord, Spare Fuse Optional: PR 32A Demodulator Probe, PR 37AG x1/x10/REF. Probe, PR 100A x100 Probe, PR-55 High Voltage x1000 Probe, LC 210A Carrying Case www.bkprecision.com Tel.: 714.921.9095
2160A 价格&库存
很抱歉,暂时无法提供与“2160A”相匹配的价格&库存,您可以联系我们找货
