TL-130A
CP-3
Model TL-130A
General Purpose DMM Kit
Model CP-3
If you need only one basic accessory kit for your
meter, this is the one. Attach probes or clips to
the sheath plug to complete your test. Soft, flexible
silicone leads make movement easy. Kit is voltage
and current rated for either electronic or electrical
applications.
DC/AC Current Clamp
■ Converts any DMM to a current clamp
■ Measures current without disconnecting
circuit under test
■ Measures to 400A DC or AC
■ Outputs 1 mV per Amp, operates on
■ All components compliant
2V range of any DMM
to IEC61010-2-031
■ Silicone Lead Wire length 60" (1.5m)
■ Tri-fold Velcro Pouch
Specifications
TL-50
model
CP-3
Features
4mm Straight to Right-Angle
Silicone Leads, 1.5m
Probe Bodies w/Ø2mm Tip
Alligator Style Clips
Alligator Clips
model
TL-130A
1000V
1000V
1000V
300V
CATIII
CATIII
CATIII
CATI
12A
36A
20A
3A
(Accuracy specified at 18˚ to 28˚C)
Current Range
2A to 400A, DC or AC
Frequency Response (AC) 50 Hz - 400 Hz
Accuracy
±(2% reading + 2A)
Input Resistance
10kΩ min.
Maximum Conductor Size 1.1" (30mm)
Power Requirement
9V battery, NEDA 1604
Battery Life
100 hr typical
Operating Temperature
0˚ to 40˚C,
很抱歉,暂时无法提供与“LC29B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+193.729191+24.11747
- 国内价格 香港价格
- 2+386.050922+48.05972
