Data Sheet
High Power Programmable DC Power Supplies
PVS Series
The PVS10005, PVS60085, and PVS60085MR
programmable DC power supplies offer clean
output power up to 5.1 kW, excellent regulation,
and fast transient response time characteristics in
an industry leading 2U package.
These power supplies provide many useful
features such as high programming resolution,
multiple remote interfaces for test systems, and a
built-in SAS (solar array simulator) function to
generate PV (photovoltaic) I-V curves. The
optional SAS software allows users to consistently
reproduce various I-V curves to test a PV
inverter’s MPPT efficiency.
For benchtop applications, this series provides an
intuitive user interface with full keypad and rotary
knob. System integrators benefit from the standard
USB (virtual COM), RS232, GPIB, and LAN
interfaces supporting SCPI commands. Free
application software and a complete set of
LabVIEW drivers are available to reduce
programming time and increase productivity. The
application software allows users to control the
power supply, execute test sequences, or log
measurements. It also integrates with Data
Dashboard for LabVIEW apps, enabling users to
remotely monitor select measurement indicators
with iOS, Android, or Windows 8 compatible
tablets or smart phones.
These power supplies are well suited for both
bench use and ATE systems integration, R&D,
design verification, production test, and high
voltage testing.
Special Applications
In particular, the low-noise characteristic of the
PVS Series makes these instruments ideal for
motor inverter testing. When operated with the
optional SAS software, these power supplies
can be used for solar array testing applications
such as validating a solar inverter’s MPPT
algorithm and testing to EN50530 and Sandia
Labs standards.
Model
PVS10005
PVS60085
PVS60085MR**
Max Output Voltage
1000 V
600 V
600 V
Max Output Current
5A
8.5 A
8.5 A
Max Output Power
5000 W
5100 W
3000 W
**Model PVS60085MR is a multi-ranging supply allowing any combination of the rated voltage and
current up to the maximum output power of 3000 W.
Technical data subject to change
© B&K Precision Corp. 2018
www.bkprecision.com
Features & Benefits
■ Compact, high power density, 2U package
■ Output up to 1000 V / 5 A (PVS10005) and
600 V / 8.5 A (PVS60085 & PVS60085MR)
■ Convenient single-phase AC input
configuration
■ Bright VFD display
■ High voltage and current resolution of 0.1 V,
0.1 mA (PVS10005) or 10 mV, 0.2 mA
■ Fast transient response time of ≤0.5 ms
■ Adjustable voltage and current slope (rise and
fall times)
■ List mode: 9 user-defined programs with up to
100 programmable steps each
■ Built-in SAS function for storage of up to 16
I-V curves with Voc, Isc, Vmp, and Imp
parameters and 1024-point table
■ Store up to 100 different instrument settings
to internal memory
■ Control up to 30 power supplies from one PC
via the RS485 interface
■ Timer-controlled output (1 s to 1000 hrs)
■ Standard USB (virtual COM), RS232, RS485,
GPIB and LAN interfaces
■ External analog programming and monitoring
interface
■ Extensive protection features: OVP, OCP, OPP,
OTP, foldback protection mode, and key-lock
function
■ Front to rear airflow allows for efficient cooling
in high rack density environments
■ Master/slave mode for parallel operation
■ LabVIEW™ driver and softpanel for remote
control, test sequence generation, and
datalogging available
PVS Series
Front panel
Bright VFD display
Protection LED indicators Function keys
Numeric keypad
Rotary knob
Cursor keys
Intuitive user interface
The numeric keys and rotary knob provide a convenient interface for setting output levels quickly and precisely. Both measured output values and setting
values are concurrently displayed on the screen. Additionally, the power supplies provide internal memory for storage of up to 10 different instrument
settings that can be set and recalled via both the front panel and remote interfaces.
Rear panel
RS-232 interface
Output and
remote sense
terminal
2
USB interface
LAN interface
RS-485
interface
GPIB interface
External analog
control interface
Ground chassis
Single-phase AC line input
Unlike other 5 kW power supplies that need a
3-phase mains connection, this series only
requires a single-phase connection, which is
easier to wire and much more commonly
available than 3-phase AC outlets.
www.bkprecision.com
PVS Series
Remote control and programming
Test system integration
Web server interface
These power supplies offer standard USB, RS-232, GPIB, and LAN interfaces
to facilitate test system development and integration. The PVS Series supports
SCPI-compliant protocols and come with LabVIEW™ drivers.
The PVS Series models provide a built-in web server that allows users to
configure, control, or monitor the basic settings of the power supply from a
remote computer using a web browser.
Test sequence execution in list mode
The list mode feature allows users to program a list of steps to the power
supply’s internal memory and execute them. A total of 100 steps
can be allocated to each internal memory location, up to a maximum of 9
locations. The test sequence can be programmed remotely via the USB,
RS-232, GPIB, or LAN interfaces using SCPI commands or with the included
application software. Test sequences can be configured for single or repeated
execution. Each steps’ settings include voltage, current, duration, and output
status.
Analog programming and monitoring interface
In addition to front panel and remote interface control, voltage and current
values can also be programmed with an analog control signal. The power
supplies can be externally controlled from zero to full scale by either voltage
source (0-5 V/0-10 V selectable) or resistance ( 0-5 kΩ/0-10 kΩ selectable
for high voltage models). The analog interface also offers the ability to
monitor the output voltage and current, regulation mode (CV or CC), or
to indicate the occurrence of a fault condition.
Socket and Telnet interface
The power supply can be controlled with SCPI commands using a socket or
Telnet connection via the Ethernet interface.
Application software
PC software is provided for front panel emulation, generating and executing test sequences or logging measurement data without the need to write source code.
• Remote monitoring on iOS, Android, or Windows 8 compatible tablets or
smart phones via NI Data Dashboard for LabVIEW apps. Quickly develop a
custom dashboard consisting of one (smart phone) or several (tablet)
indicators, charts, or gauges to monitor your power supply.
3
• Log voltage, current, and power values as well as time stamp, CV/CC,
and output status.
• Save and load list files to/from the power supply’s internal memory.
• Create an unlimited number of external list files to be executed from PC
memory. Save and recall list files to/from the PC.
www.bkprecision.com
PVS Series
Flexible configuration
Extensive device protection
Multi-unit control
To protect your DUT, the PVS Series provides several safety features: overvoltage (OVP), overcurrent (OCP), overpower (OPP), and overtemperature
(OTP) protection. When a fault occurs, the power supply will turn off the
output, sound an alarm, and display an error message. Similarly, with constant
voltage-to-constant current (CV-to-CC) or constant current-to-constant
voltage (CC-to-CV) foldback protection mode activated, the supply will shut
down if load changes force the supply to transition between the two operating
modes. The power supply is also able to detect abnormally low or high AC
input power and turn the output off when this condition occurs.
In multi-unit control mode, multiple units can be daisy chained via RS485 and
controlled from one master unit through the USB, GPIB, or LAN interface.
Convenient front panel guided calibration
Using a 5 ½ digit multimeter, voltage and current parameters can be
conveniently calibrated from the front panel via the calibration menu.
Master/Slave operation
Models with the same rating can be connected in parallel and operate in
master/slave mode. The RS-485 interface is used for communication between
the master and slave(s). Once configured, the master will automatically search
for and detect slave units, and display the voltage and current of the complete
system.
AC input power cord (Standard)
4
Rackmount kit (Optional)
www.bkprecision.com
PVS Series
Solar Array Simulation (SAS) Software Option
Solar inverter designers need to verify their inverter is capable of delivering the maximum power available from solar modules. The I-V curve of solar cells can be
influenced by various weather conditions such as a cloudy day. Combined with the SAS application software, PVS users can easily simulate the I-V curve of different
arrays under various irradiance conditions while measuring and validating the effectiveness of the inverter’s MPPT algorithm.
Features
Variety of input parameters
(Voc/Isc/Vmp/Imp/FF/FFv/FFi)
Monitors and logs real-time voltage,
current, power, MPPT efficiency, and average
MPPT efficiency
Simulate I-V curve under different weather
conditions during a day
User-definable irradiance profile
Generate a custom I-V curve with up to
1,024 data points
Test to EN50530 and Sandia Labs standards
PV Simulation
Solar arrays consist of multiple solar cells characterized by a complex voltage and current profile that is represented in an I-V curve.
PV simulation curve
The PVS power supply outputs points on the I-V curve in 1 ms
intervals to test the inverter’s MPPT efficiency.
5
Automatically generate the I-V curve
of a solar array in the software by
specifying open circuit voltage (Voc),
short circuit current (Isc), maximum
power voltage (Vmp), and maximum
power current (Imp) along with fill
factor parameters.
Generate an I-V curve
manually via a 1,024-point
voltage and current table
with Notepad or MS Excel
and load it in the software.
Use any of the software’s built-in
irradiance profiles or generate your
own point-by-point irradiance
profile.
www.bkprecision.com
PVS Series
Specifications
Model
PVS60085
PVS60085MR
PVS10005
3000 W
0 - 1000 V
0-5A
5000 W
Output Rating
Output Voltage (1)
Output Current (2)
Max. Output Power
0 - 600 V
0 - 8.5 A
5100 W
Line Regulation
Voltage
Current
60 mV
4.25 mA
100 mV
2.5 mA
Voltage
Current
60 mV
8.5 mA
100 mV
5 mA
Voltage
Current
≤100 mVrms / ≤500 mVpp
15 mA
≤100 mVrms / ≤600 mVpp
10 mA
Programming
Readback
10 mV/0.2 mA
10 mV/0.2 mA
0.1 V/0.1 mA
0.1 V/0.1 mA
400 mV
0.03% + 3.5 mA
700 mV
0.03% + 2 mA
0.05% + 300 mV
0.1% + 8.5 mA
0.05% + 500 mV
0.1% + 5 mA
Load Regulation
Ripple and Noise (20 Hz - 20 MHz)
Resolution
Programming Accuracy
Voltage
Current (3) ± (%output + offset)
Readback Accuracy ± (%output + offset)
Voltage
Current (3)
General
Transient Response Time (4)
OVP adjustment Range
OVP Accuracy
OCP Accuracy
Command Response Time
Efficiency (5)
Power Factor
Remote Sense Compensation
Rising Time at Full Load
Rising Time at No Load
Falling Time at Full Load
Falling Time at No Load
Standard Interfaces
AC Input (6)
Rated Frequency
Maximum Rated Input Power
Temperature Ratings
Dimensions ( W× H× D )
Weight
≤0.5 ms
5 - 660 V
6V
85 mA
20 ms
90%
0.99
6V
≤100 ms
≤100 ms
≤0.5 ms
5 - 1100 V
10 V
50 mA
20 ms
90%
0.99
10 V
≤250 ms
≤250 ms
≤100 mS
≤150 ms
≤250 ms
≤3000 ms
≤5000 ms
Analog Programming, USB, RS485, RS232, GPIB, and Ethernet
170 - 265 VAC single phase
47 - 63 Hz
5800 VA
3500 VA
5800 VA
Operation (0 °C~40 °C)
Storage (-40 °C~85 °C)
16.53” x 3.46” x 20.94” (420 x 88 x 532 mm)
32.18 lbs (14.6 kg)
Three-Year Warranty
Standard Accessories
Optional Accessories
(1)
(2)
(3)
(4)
(5)
(6)
6
Power cord, test report & certificate of calibration
SASPVS (SAS software), RKPVS (rackmount kit)
Minimum voltage is guaranteed to 5V.
Minimum current is guaranteed to maximum 0.4% of rated output current.
Current accuracy is applied when output power > 0.1% of full power.
Time for output voltage to recover within 0.5% of its rated output for a load change 50 – 100% of rated output current.
90% typical at nominal line and max load.
10% of output de-rated when operating below 190 VAC.
v052218
www.bkprecision.com
