A202
A202
    TPI(TPI 公司)
    LINE SPLITTER FOR CLAMP METERS
A202 数据手册
A202 Line Splitter Specifications Operating Voltage: 130V AC maximum Operating Amperage: 15A AC maximum Male Recepticle: Plugs into standard 2 conductor with ground outlets Female Recepticle: Accepts 2 conductor without ground and 2 conductor with ground cords. Accepts 2 conductor without ground and 2 conductor with ground cords Test holes for measuring voltage using test lead tips Features • Enables clamp on meter amperage tests to be performed on devices with power cords without altering the cord. • Can be used on 2 conductor no ground and 2 conductor with ground cords. X1 and X10 turn test areas • X1 and X10 turn test areas • Use the X10 test hole to measure smaller amperage. For example, 0.5A will be amplified to 5A for easier measurement and display on a clamp on meter • Test holes for measuring voltage using test lead tips. Dimensions Size: 6” x 2.1” x 1.0” (152mm x 53mm x 25mm) Weight: 0.4lbs (181g) Copyright © 2015 Test Products International, Inc. Plugs into standard 2 conductor with ground outlets
很抱歉,暂时无法提供与“A202”相匹配的价格&库存,您可以联系我们找货
