Model 760DX
Intelligent PH Meter
Data Sheet
ATC PROBE
Model 760ATC
PH electrode
Model 760PH
• Plug in the 760 to be
a PH electrode Meter.
• Range: 0 to 14 PH
• Measuring Temp.:
0ºC to 100ºC
DISSOLVED
OXYGEN PROBE
Model 760DOP
• Plug in the 760 to be a
professional Dissolved
Oxygen Meter.
• Range: 0 - 20.0 mg/L,
0.1 mg/L.
• With automatic
temperature: 0 - 50.0
ºC, 0.1 ºC/0.1 ºF.
• Diaphragms &
electrolyte included.
a ATC (Automatic
Temp. Compensation)
probe to gain the Max.
possible accuracy.
• Temperature range:
0 to 65 ºC,
32 to 149 ºF.
CONDUCTIVITY
PROBE
Model 760CP
• plug in the 760 to be a
professional Conductivity
Meter,
• Conductivity : 2/20 mS,
2 ranges
• Temperature : 0 to 60.0
ºC/0.1 ºF.
• ATC & variable temp.
compensation factor
adjustment (0 to 5.0%
per ºC).
INTELLIGENT PH METER
Model 760
• PH Meter with mV and “plug and play”
function.
• pH (0.00 to 14.00 pH), mV (± 1999 mV).
• manual temp. compensation adj. or ATC
via the
optional temp. probe (760 ATC).
• Be plugged with “plug and play”
probes:760CP, 760DOP, 760ATC to be a
professional Conductivity Meter, ATC Meter,
Dissolved Oxygen Meter.
• RS-232, Hold, Memory record, ºC/ºF, 0.1
degree.
• Patent obtained.
SOFTWARE W/RS-232 CABLE
Model AK 760
• For windows 95 & 98
• Data logging system, data recorder
B&K Precision Corporation
22820 Savi Ranch Parkway, Yorba Linda, CA 92887
Tel: 714-921-9095, Fax: 714-921-6422
www.bkprecision.com
PROTECTIVE CARRYING CASE
Model LC 760
• Dimensions: (HxWxD) 2.75” x 15” x 10”
Specifications subject to change without notice
很抱歉,暂时无法提供与“760PH”相匹配的价格&库存,您可以联系我们找货
