TL885A
TL885A
    B&K
    TWEEZER SMD PROBE
TL885A 数据手册
Data Sheet Synthesized In-Circuit LCR/ESR Meters Models 885 & 886 Specifications 885 & 886 Test Frequencies 100 Hz, 120 Hz, 1 kHz, 10 kHz, 100 kHz (model 886 only) Frequency Accuracy ± 0.1% Test Levels 1 Vrms, 0.25 Vrms, 0.05 Vrms, 1 Vdc (for DCR) Level Accuracy ± 5% Output Impedance 100 Ω, ± 5% Impedance (Z) Model 885 SMD Probe (included) Capacitance (C) The B&K Precision models 885 and 886 synthesized in-circuit LCR/ESR meters are the first handheld meters of this type on the market, with a wide range of test frequencies up to 10 kHz for model 885 and 100 kHz for model 886, many measurement parameters including Z, L, C, DCR, ESR, D, Q, and Ø as well. The 885 and 886 are designed for both component evaluation on the production line and fundamental impedance testing for benchtop applications. With a built-in direct test fixture, you can test the lead components very easily. The optional 4-wire test clip can give a convenient connection to larger components and assemblies with the accuracy of 4-wire testing. The LCR meters offer fast, reliable, and versatile testing at low cost, making the 885 and 886 the most advanced handheld LCR meters available on the market today. Features & Benefits Inductance (L) Frequency Maximum Minimum Best Resolution DCR 20 MΩ 0.1 Ω 0.001 100 Hz 20 MΩ 0.1 Ω 0.001 120 Hz 20 MΩ 0.1 Ω 0.001 1 kHz 20 MΩ 0.1 Ω 0.001 10 kHz 20 MΩ 0.1 Ω 0.001 100 kHz 10 MΩ 0.1 Ω 0.001 Frequency Maximum Minimum Best Resolution 100 Hz 15.91 mF 79.57 pF 0.001 120 Hz 13.26 mF 66.31 pF 0.001 1 kHz 1.591 mF 7.957 pF 0.001 10 kHz 159.1 µF 0.795 pF 0.001 100 kHz 15.91 µF 0.159 pF Frequency Maximum Minimum 0.001 Best Resolution 100 Hz 31.83 kH 159.1 µH 0.001 120 Hz 26.52 kH 132.6 µH 0.001 1 kHz 31.83 kH 15.91 µH 0.001 10 kHz 318.3 H 1.591 µH 0.001 100 kHz 31.83 H 0.159 µH 0.001 General Operating Temperature 32 ˚F to 104 ˚F (0 ˚C to 40 ˚C) Storage Temperature -4 ˚F to 158 ˚F (-20 ˚C to 70 ˚C) Relative Humidity up to 85% Battery Type Ni-MH or Alkaline (2 x AA size) Battery Charge Constant current 150 mA approximately Battery Operating Life 2.5 hours typical AC Operation 110 V/220 VAC, 60/50 Hz with proper adapter* ■ Measurement parameters: Z, L, C, DCR, ESR, D, Q, and Ø ■ Test conditions: 100 Hz, 120 Hz, 1 kHz, 10 kHz, Low Power Warning under 2.2 V 100 kHz (model 886 only), 1 Vrms, 0.25 Vrms, 0.05 Vrms Dimensions (LxWxH) 6.9” x 3.4” x 1.9" (174 x 86 x 48mm) Weight 1.1 lbs (470 g) Standard Accessories User manual, SMD probe, rechargeable battery, shorting bar, and AC adapter* Optional Accessories Carrying case, TL08C Kelvin clip, TL885B 4-wire test clip, BC 885 110 V AC adapter, and BC 885 EXD 220 V AC adapter ■ 0.5% basic accuracy ■ Dual LCD display ■ SMD surface mount tweezer probe included ■ Very quick response, user-friendly ■ Fully auto/manual selection ■ DC resistance measurement ■ Rechargeable battery / AC powered Technical data subject to change © B&K Precision Corp. 2013 v060413 Three-Year Warranty * The 885 and 886 include a 110 V AC adapter. For a 220 V AC adapter, order model 885 EXD or 886 EXD. w w w.bk prec ision.c om
TL885A 价格&库存
很抱歉,暂时无法提供与“TL885A”相匹配的价格&库存,您可以联系我们找货
