CC545
CC545
    B&K
    GENERAL PURPOSE PWR SUPPLY ASSY
CC545 数据手册
Data Sheet Triple Output Programmable DC Power Supply Model 9130 Specifications The 9130 is a fully programmable triple Output DC Power Supply delivering 0-30V/0-3A on 2 outputs and 0-5V/0-3A on 1 output. Each output is fully floating and outputs can be adjusted independently or connected in series or parallel to produce higher voltages or currents. The 9130 is ideally suited for applications in Electronic Test, Production and Service where multiple independent DC supplies are required and bench space is at a premium. Features & Benefits ■ 3 independent, fully programmable and electrically isolated outputs ■ Display & adjust Voltage and Current settings for all 3 channels Model 9130 Output Ratings 0 ~ 30 V (Ch1 & Ch2) 0 ~ 5 V (Ch3) 0 ~ 3 A (Ch1 & Ch2) 0 ~ 3 A (Ch3) Load Regulation ±(% of output+offset) ≤ 0.01% + 3 mV ≤ 0.1% + 3 mA Line Regulation ±(% of output+offset) ≤ 0.01% + 3 mV ≤ 0.1% + 3 mA Programming Resolution 1 mV 1 mA Readback Resolution 1 mV 1 mA Programming accuracy (12 month) ±(% of output+offset) ≤ 0.03% + 10 mV ≤ 0.1% +5 mA Readback accuracy (at 25 °C ± 5 °C) ±(% of output+offset) ≤ 0.03% + 10 mV ≤ 0.1% +5 mA Ripple & Noise (20 Hz - 20 MHz) Voltage: ≤ 1 mVrms/3 mVp-p Current: ≤ 5 mArms Transient Response < 500 µs for CH1&2,
CC545 价格&库存
很抱歉,暂时无法提供与“CC545”相匹配的价格&库存,您可以联系我们找货
