M402
M402
    B&K
    ANTENNA DIPOLE 1.25 TO 1.65 GHZ
M402 数据手册
Model 2650A/2651 Series 3.3 GHz/8.5 GHz Spectrum Analyzer USER MANUAL v 092711 Before Using the Product · Please note the following described on the back panel. · For safe use: 1) When abnormal sound, abnormal smell or smoke is found, stop using the product and remove the battery and AC adapter. 2) Never handle this product with wet hands to prevent risks of electric shock, fire, or damage. 3) Never use this product under lightning conditions to prevent risks of damage. 4) Never use any AC adapter other than specified, or it will cause damage. Connect the power cable only to three-terminal outlet for protection from static electricity, otherwise this product or a device under test may be damaged. 5) Never use any battery other than specified, or it may damage this product. Turn off the power and disconnect the AC adapter before removing the battery out of the battery compartment. 6) Be sure to charge the battery as specified in the instructions in this manual. Moreover, an explosion, fire or smoke may occur if battery is handled improperly. Please read the notes for handling the battery. i · Set clock function The time information is set at Japan standard time. Set the year, month, day and time when the 2650A series is used for the first time. (Refer to “24.4 Setting the clock” for the details.) · Quality assurance Warranty If the defect by our responsibility occurs within one year after delivered, it shall be repaired free of charge. However, this warranty does not cover such defect that : 1) is caused by a fire or natural disasters. 2) is caused by inappropriate handling such as dropping while moving the unit delivered. 3) is caused by handling in contradiction to usage or precautions described in the operating manual. 4) is caused by modification or misuse. We will not be responsible for direct or indirect damage caused by use or defect of this product. Refer to the end of this manual for details. Warm-up time Warm up the product for at least ten minutes after turning on the power in order to stabilize the internal circuit. Precautions for storage 1) Avoid direct sunlight or dust. 2) Store this unit in a place where temperature is between -20 °C to 60 °C, humidity less than 60 °C/70 %RH and variations in temperature and humidity are small. After service Please contact us without hesitation if you have any questions about this product: B&K PRECISION 22820 Savi Ranch Parkway Yorba Linda CA, 92887 TEL. (714) 921 - 9095 FAX. (714) 921 - 6422 URL: http://www.bkprecision.com ii Contents 1. OUTLINE --------------------------------------------------------------------------------------1 1.1 1.2 1.3 1.4 2. PRODUCT OUTLINES -------------------------------------------------------------------------- 1 STANDARD ACCESSORIES ------------------------------------------------------------------- 2 OPTIONAL ACCESSORIES -------------------------------------------------------------------- 2 OVERVIEW OF ALL FOUR MODELS ---------------------------------------------------------- 3 SPECIFICATIONS--------------------------------------------------------------------------4 2.1 2.2 PERFORMANCE-------------------------------------------------------------------------------- 4 EXTERNAL VIEW ------------------------------------------------------------------------------- 7 3. EXPLANATION OF PANEL -------------------------------------------------------------8 4. EXPLANATION OF SCREEN --------------------------------------------------------- 11 5. FUNCTION MENU------------------------------------------------------------------------ 12 5.1 5.2 6. LIST OF FUNCTION MENU------------------------------------------------------------------ 12 MENU TREE ---------------------------------------------------------------------------------- 13 PREPARING FOR OPERATION ----------------------------------------------------- 19 6.1 6.2 6.3 6.4 7. STAND ---------------------------------------------------------------------------------------- 19 CONNECTION TO POWER SUPPLY -------------------------------------------------------- 19 BATTERY CHARGE -------------------------------------------------------------------------- 20 INSTALLATION OF BATTERY --------------------------------------------------------------- 20 CENTER FREQUENCY ---------------------------------------------------- 21 7.1 7.2 7.3 7.4 8. SETTING WITH STEP KEYS ( [F1], [F2] ) ------------------------------------------------- 21 SETTING WITH ENCODER ------------------------------------------------------------------ 21 SETTING WITH NUMERIC KEY-------------------------------------------------------------- 22 ACCORDING TO MARKER POSITION ----------------------------------------------------- 23 FREQUENCY SPAN -------------------------------------------------------- 23 8.1 9. SWITCHING FREQUENCY BAND ----------------------------------------------------------- 24 REFERENCE LEVEL ----------------------------------------------------- 25 9.1 9.2 9.3 9.4 9.5 9.6 9.7 9.8 10. 10.1 11. 11.1 11.2 11.3 SETTING OF REFERENCE LEVEL --------------------------------------------------------- 25 CHANGE OF UNIT OF AMPLITUDE AXIS -------------------------------------------------- 25 SETTING OF STEP SIZE OF REFERENCE LEVEL---------------------------------------- 25 ON-OFF SETTING OF OFFSET ------------------------------------------------------------ 25 SETTING OF OFFSET LEVEL --------------------------------------------------------------- 25 SETTING OF INPUT IMPEDANCE----------------------------------------------------------- 26 REFERENCE LEVEL SETTING RANGE FOR EACH UNIT ------------------------------- 26 RELATIONSHIP BETWEEN REFERENCE LEVEL AND ATT/AMP (AT DBM) ---------- 27 DISPLAY SCALE ------------------------------------------------------- 29 SETTING THE FUNCTION KEY ------------------------------------------------------------- 29 RESOLUTION BANDWIDTH ------------------------------------------- 29 MANUAL MODE ---------------------------------------------------------------------------- 29 AUTO MODE -------------------------------------------------------------------------------- 30 ALL AUTO MODE -------------------------------------------------------------------------- 30 iii 12. 12.1 12.2 12.3 13. 13.1 13.2 13.3 13.4 13.5 VIDEO BANDWIDTH ------------------------------------------------------ 30 MANUAL MODE ---------------------------------------------------------------------------- 30 AUTO MODE -------------------------------------------------------------------------------- 30 ALL AUTO MODE -------------------------------------------------------------------------- 31 SWEEP AXIS / DETECTION MODE ------------------------------ 31 MANUAL MODE ---------------------------------------------------------------------------- 31 AUTO MODE -------------------------------------------------------------------------------- 31 ALL AUTO MODE -------------------------------------------------------------------------- 31 SETTING OF DETECTION MODE ---------------------------------------------------------- 31 SETTING OF TRIGGER SOURCE ---------------------------------------------------------- 32 14. AUTO TUNING --------------------------------------------------- 32 15. HOLD / RUN -------------------------------------------------------- 32 16. CALCULATION FUNCTION ------------------------------------------- 33 16.1 16.2 16.3 16.4 16.5 16.6 17. 17.1 17.2 17.3 17.4 18. 18.1 18.2 18.3 18.4 18.5 18.6 19. 19.1 19.2 19.3 19.4 19.5 19.6 20. 20.1 20.2 21. 21.1 21.2 21.3 NORMAL MODE ---------------------------------------------------------------------------- 33 MAX HOLD MODE ------------------------------------------------------------------------- 33 MIN HOLD MODE -------------------------------------------------------------------------- 33 AVERAGE MODE -------------------------------------------------------------------------- 34 OVERWRITE MODE ---------------------------------------------------------------------- 34 SPURIOUS FREE MODE (2658A ONLY) ---------------------------------------------- 34 MARKER & PEAK SEARCH ------------------------------------------- 35 MOVEMENT AND BASIC FUNCTION OF MARKER --------------------------------------- 36 NORMAL PEAK SEARCH ------------------------------------------------------------------- 36 ZONE PEAK SEARCH ----------------------------------------------------------------------- 36 CHANGE UNIT OF MARKER LEVEL ------------------------------------------------------- 37 SAVE / LOAD ---------------------------------------------------- 37 SELECTION OF STORAGE DEVICE -------------------------------------------------------- 38 SAVE FUNCTION ---------------------------------------------------------------------------- 39 ABOUT FILE NAME -------------------------------------------------------------------------- 39 LOAD FUNCTION ---------------------------------------------------------------------------- 40 DELETE FUNCTION ------------------------------------------------------------------------- 41 PRESETTING (INITIALIZATION) ------------------------------------------------------------ 41 MEASURING FUNCTION ---------------------------------------------- 42 CHANNEL POWER MEASUREMNT ------------------------------------ 42 ADJACENT CHANNEL LEAKAGE POWER MEASUREMENT ------------------ 43 OCCUPIED BANDWIDTH MEASUREMENT ------------------------------------- 45 ELECTRIC FIELD STRENGTH MEASUREMENT --------------------------- 45 MAGNETIC FIELD STRENGTH MEASUREMENT --------------------- 49 FREQUENCY COUNTER --------------------------------------------- 51 EMI TEST (2651) ---------------------------------------------------------------------- 51 ADDITIONAL FUNCTION FOR EMI TEST ------------------------------------------------- 51 EMI TEST ------------------------------------------------------------------------------------ 52 SCREEN CONTROL ----------------------------------------------------- 54 SETTING SCREEN DISPLAY COLOR ------------------------------------------------------ 55 ON/OFF SWITCHING OF LCD BACKLIGHT --------------------------------------------- 55 ADJUSTING BRIGHTNESS OF LCD BACKLIGHT----------------------------------------- 55 iv 22. 22.1 22.2 22.3 22.4 23. 23.1 23.2 23.3 23.4 23.5 23.6 24. 24.1 24.2 24.3 24.4 25. 25.1 25.2 25.3 25.4 25.5 25.6 25.7 25.8 TRACKING GENERATOR MODE (2652A) ------------------------------------ 55 SPECIFICATION OF T.G. FUNCTION ------------------------------------------------------ 55 DESCRIPTION OF I/O CONNECTOR------------------------------------------------------- 56 ON/OFF SWITCHING OF T.G. FUNCTION ----------------------------------------------- 56 NORMALIZING FUNCTION ------------------------------------------------------------------ 57 STORAGE/PRINT SCREEN IMAGE -------------------------------- 58 SELECTION OF IMAGE AREA -------------------------------------------------------------- 58 PRINT ON PRINTER ------------------------------------------------------------------------- 58 STORAGE INTO USB MEMORY ----------------------------------------------------------- 58 TRANSFERRING INTERNAL DATA TO USB MEMORY IN LUMP SUM ----------------- 59 USB PRINTER (OPTION) ------------------------------------------------------------------- 59 USB MEMORY ------------------------------------------------------------------------------- 60 UTILITY FUNCTION ------------------------------------------------------- 61 LABEL FUNCTION --------------------------------------------------------------------------- 61 MENU OFF ----------------------------------------------------------------------------------- 62 BUZZER SETTING --------------------------------------------------------------------------- 62 SETTING THE CLOCK ----------------------------------------------------------------------- 62 USB DEVICE FUNCTION ----------------------------------------------------------- 64 OUTLINE -------------------------------------------------------------------------------------- 64 HOW TO CONNECT ------------------------------------------------------------------------- 64 INSTALLATION OF DRIVER ----------------------------------------------------------------- 64 SAMPLE PROGRAM ------------------------------------------------------------------------- 64 EXPLANATION OF COMMAND-------------------------------------------------------------- 65 INPUT OF FREQUENCY --------------------------------------------------------------------- 74 TRANSFER OF SPECTRUM DATA --------------------------------------------------------- 74 WRITING OF ORIGINAL COMPENSATION DATA ----------------------------------------- 75 26. OPTION ---------------------------------------------------------------------------------- 77 27. BASIC PERFORMANCE TEST (2650A/2651/2652A/2658A) ------------ 78 27.1 27.2 27.3 27.4 27.5 FREQUENCY CHARACTERISTICS --------------------------------------------------------- 78 ACCURACY OF REFERENCE LEVEL ------------------------------------------------------ 79 DISPLAY ACCURACY OF CENTER FREQUENCY ---------------------------------------- 79 DISPLAY ACCURACY OF FREQUENCY SPAN -------------------------------------------- 80 LINEARITY OF AMPLITUDE AXIS ---------------------------------------------------------- 80 v 1. Outline 1.1 Product outlines The 2650A series are authentic spectrum analyzers in a compact and lightweight form factor providing performance and functions comparable to large-size bench type instruments. The features are as follows. 1) Compact and lightweight 1.8 kg. The dimensions are 162(W)×71(H)×265(D) mm, and the weight is only 1.8 kg including the battery, making the instrument very convenient for field use. 2) Large color TFT display 5.7 inches, 640×480 color LCD 3) Four hours battery operation The included Lithium-ion battery, when fully charged, can provide power for up to four hours of operation with the backlight turned off. And about 3 ½ hours with the backlight set to the minimum level. 4) USB host adapter USB host port can be used with removable storage USB flash drives. The screen image is stored as BMP format, and the spectrum and the setting parameters are stored as CSV format. The port conforms to USB 1.1 standards and is backwards compatible with USB 2.0 devices. 5) USB device for PC connectivity USB interface with transfer rates up to 12 Mbps maximum (conform to USB 1.1 standards). 6) Accurate frequency measurement by PLL synthesizer The center frequency is accurately set by PLL (Phase Locked Loop) synthesizer. Moreover, the frequency counter (factory option) enables more accurate measurements of the frequency of a signal. 7) Average noise level -127 dBm The low average noise level of -127 dBm @ 1 GHz provides a wide dynamic range. 8) 100 dB display dynamic range Wide dynamic range display with a display scale of 100 dB/10div (at 10 dB/div) in the amplitude axis. 9) Easy operation with AUTO mode ● Auto range operation: RBW, VBW and sweep time are automatically selected based on the frequency span. ● Auto tuning operation: The center frequency is adjusted to the maximum level within full span, and the optimum RBW, VBW and sweep time are chosen. 1 10) Abundant functions ● Measuring functions : Channel power, Adjacent channel power, Occupied bandwidth, Electric field strength, Magnetic field strength and Frequency measurement. ● Calculation functions : Max hold, Min hold, Averaging, Over write ● Marker measurement and peak search function ● Save/Load function ● Hard copy with printer 11) PC Software The included PC software controls all four models of the 2650A/2651 series via PC. The software emulates the front panel keys and supports transfer of 1001 point trace data from the analyzer to the PC. Screen images can be stored in BMP format and the spectrum data in CSV format (stores frequency and level). 12) Options There are many options available, such as dipole antennas, magnetic field probes and USB printer 1.2 Standard accessories 1. AC adaptor MA400 2. Carrying case LC2650A 3. Accessory pouch 4. User manual 5. PC software and USB cable 6. Lithium Ion battery MB400 1.3 Optional accessories 1. Dipole antennas M401, M402, M403, M404, M405, M406 2. Magnetic field probe PR 26M with a dedicated double shielded coaxial cable 3. Printer PT2650A with AC adaptor, 4pcs of AA batteries, one roll paper 4. Roll paper PX2650A for PT2650A printer (with 10 rolls) 2 1.4 Overview of all four models Model 2650A 2658A 2652A 2651 Contents 50 kHz to 3.3 GHz Applications: Cellular phone, 2.4 GHz wireless LAN, 2.5 GHz WiMAX, RF-ID, Broadcasting 50 kHz to 8.5 GHz Covering most of the wireless communication frequency spectrum Applications: 5 GHz wireless LAN, 3.5/5.8 GHz WiMAX, Maintenance of wireless base station 50 kHz to 3.3 GHz With 5 MHz to 3.3 GHz tracking generator Applications: Frequency characteristics measurement of electronic component/circuit and return loss measurement 50 kHz to 3.3 GHz For EMI test Applications: Radiated and conducted emission measurement 3 2. Specifications 2.1 Performance  Frequency section Frequency range Center frequency Setting resolution Accuracy RBW frequency error Frequency span Setting range Accuracy Display resolution # of points per trace Resolution bandwidth 2650A, 2652A, 2651 50 kHz to 3.3 GHz 2658A 50 kHz to 8.5 GHz ――― Frequency range 50 k to 3.5 GHz 3.3 G to 6.3 GHz 6.1 G to 8.5 GHz Frequency band Base band Harmonic order 1 Band 1- 1 Band 1+ 1 20 kHz Allows rotary encoder, numeric key and function key within ± (30+20T) kHz±1 dot within ±(30+20T) kHz ± 1 dot @frequency span: 200 kHz to 10 MHz, @frequency span: 200 kHz to 10 MHz, RBW 3 kHz, 23±5°C RBW 3 kHz, 23±5°C within ± (60+300T) kHz±1dot within ± (60+300T) kHz±1dot @frequency span: 20 MHz to 3.3 GHz, @frequency span: 20 MHz to 8.5 GHz, RBW 100 kHz、23±5°C RBW 100 kHz, 23±5°C T: sweep time (s) T: sweep time (s) within ±4 kHz @ 3 kHz, 10 kHz, 30 kHz within 20% of RBW @ RBW: 100 kHz, 300 kHz within 10% of RBW @ RBW: 1 MHz, 3 MHz 0 Hz (zero span), 0 Hz (zero span), 200 kHz to 2 GHz (1-2-5 step) and 200 kHz to 5 GHz (1-2-5 step) and 3.3 GHz (full span) 8.5 GHz (full span) within ±3% ±1dot @ sweep time of 0.3s, 23±5 °C 501dots on LCD screen, 1001dots readout via PC (501 dots are visible on the display, 1001 dots of trace data are captured internally and can be transferred to a PC via USB device interface.) 3 dB bandwidth (6 dB for 2651 @ 9 kHz, 120 kHz) Setting range 3 kHz to 3 MHz (1-3 step) and AUTO (2651: 3 kHz, 9 kHz, 30 kHz, 120 kHz, 300 kHz, 1 MHz, 3 MHz) Accuracy ±20% Selectivity 1:12 (typical, 3 dB : 60 dB) Video bandwidth 100 Hz to 1 MHz (1-3 step) and AUTO SSB phase noise -90 dBc/Hz (typical) @100 kHz offset, RBW : 3 kHz, VBW : 100 Hz, sweep time: 1 s Spurious response less than -60 dBc Harmonics less than -40 dBc @ ≧100 MHz 4  Amplitude section 2650A, 2652A, 2651 Reference level Setting range Accuracy 2658A +10 to -60 dBm (1dB step) Frequency characteristics Input impedance within ± 0.8 dB ± 1 dot @ center frequency : 100 MHz, RBW : 3 MHz, VBW : 1 MHz, REF : -15 dBm, 23±5 °C dBm, dBV, dBmV, dBμV, dBμV/m, dBμA/m (dBμV/m and dBμA/m are used for measurement functions) -127 dBm (typical) @ CF : 1 GHz, RBW : 3 kHz, VBW : 100 Hz, Ref. level < - 40dBm ( preamp automatically ON) within ±2.0 dB ±1dot @50 kHz to 100 MHz within ±2.0 dB ±1dot @50 kHz to 100 MHz within ±1.0 dB ±1dot @ 100 MHz to 3.3 GHz within ±1.0 dB ±1dot @100 MHz to 8.5 GHz 50 Ω Input VSWR less than 2.0 Unit Average noise level Input attenuator Operating range 0 to 25 dB (1 dB step), coupled with reference level Switching error ±0.6 dB @100 MHz RBW switching error ±0.6 dB Display resolution (vertical) Scale Display scale Accuracy 381 dots/10div Input damage level  10 dB/div, 5 dB/div, 2 dB/div ±(0.2 dB+1dot)/2 dB ±(0.4 dB+1dot)/5 dB ±(0.8 dB+1dot)/10 dB ±(1.8 dB+1dot)/83 dB +27 dBm (CW average power), 25 VDC Sweep section 2650A, 2652A, 2651 2658A 10 ms to 30 s and AUTO @frequency span : 0 to 2 GHz 30 ms to 30 s and AUTO @frequency span : full span 1-3 step Within ±0.1 %±1dot @frequency span : 0 to 2GHz within ±1.5 %±1dot @ full span 10 ms to 30 s and AUTO @frequency span : 0 to 2 GHz 30 ms to 30 s and AUTO @frequency span : 5 GHz, full span 1-3 step Within ±0.1 %±1dot @frequency span : 0 to 5GHz within ±2.5 %±1dot @ full span Sweep time Setting range Accuracy Trigger Trigger mode AUTO (Available only for zero span) Trigger source Internal and External 5 External trigger Input voltage range Frequency range Input coupling Trigger level Input RC Input damage level Input connector Detection mode  Positive peak, Negative peak, Sample ( QP and AV for model 2651 only.) Function Save 2650A, 2652A, 2658A, 2651 common NORM:displays frequency (8digits max) and level (4digits max) at marker point. DELTA:displays frequency difference and level difference between two markers. Searches for peak level with all of 10 div (NORM mode) or within ZONE specified (ZONE mode) and displays frequency and level at peak level, and moreover NEXT peak at NORM mode. NORM, MAX HOLD, MIN HOLD, AVERAGE, OVER WRITE Number of sweeps is 2 to 1024 (power of 2 ) and infinite. Channel power, Adjacent channel power, Occupied bandwidth, Electric field strength (needs optional dipole antenna), Magnetic field strength (needs optional magnetic field probe) and Frequency counter When pressing AUTO TUNE key, the spectrum of maximum level within full span is adjusted to center, and reference level, RBW, VBW and sweep time are set to optimum parameters. Saves 200 spectrums and 200 setting parameters Load Loads one spectrum and one setting parameter Marker measurement Peak search function Calculation function Measuring function Auto tuning Save/ Load  1 to 10 Vp-p DC to 5 MHz DC coupling approx. 0.56 V(fix) approx. 10 kΩ / less than 15 pF ±50 V(DC+AC peak) SMA(J) General Input connector 2650A, 2652A, 2658A, 2651 common N(J) connector USB Communication Protocol Device Connector USB version 1.1 (will also work with USB 2.0 devices) B plug Transfer rate Hard copy 12 Mbps USB printer (option) connected to A plug (host) enables hard copy of screen. host connector Display Display Backlight Number of dots Power supply Dedicated AC adaptor A plug Lithium-ion battery Charge function Remainder indication 5.7 inches and color LCD LED backlight 640(H) x 480(V) dots Input : 100 to 240 VAC Output : 9 VDC/2.6 A MB400 : 7.4 V/5000 mAh Li-Ion battery Capable of charging during power-off. Indicates 4 conditions with two colors LED (red and green). 5 level indicator 6  Other 2650A, 2652A, 2658A, 2651 common 0 to 50° C (guaranteed at 23±10 °C, without soft carrying case) less than 40 °C/80 %RH (guaranteed at less than 33 °C/70 %RH, without soft carrying case) Storage temperature -20 to 60 °C, less than 60 °C/70 %RH Dimensions 162(W) x 71(H) x 265(D) mm , 6.38 (W) x 2.80 (H) x 10.43 (D) inch (excluding projections, protection bumper and stand) Weight approx. 1.8 kg or 4 lbs (including battery) * Refer to section 22) Tracking Generator Mode for the specifications of the tracking generator, model 2652A. Operating temperature Operating humidity 2.2 External view [Unit : mm] * B&K Precision reserves the right to make changes in design, specification and other information without prior notice. 7 3. Explanation of Panel 1) TFT display This is a large liquid crystal display with 640 (H) x 480 (V) dots. It simultaneously displays spectrum (10div x 10 div), various setting parameters and measured values. 2) Function key (F1 to F6) The function can change according to the operation key. 3) Center frequency key 8 The center frequency is set with this key. The setting range is 0 to 3.3 GHz (for 2650A, 2652A, and 2651), and 0 to 8.5 GHz (for 2658A). The setting resolution is 20 kHz. 4) Frequency span key The frequency span is set with this key. For 2650A, 2652A, and 2651, it is set in the range from 200 kHz to 2 GHz, ZERO SPAN or FULL SPAN (3.3 GHz). For 2658A, it is set in the range from 200 kHz to 5 GHz, ZERO SPAN or FULL SPAN (8.5 GHz). 5) Reference level key The reference level is set with this key. It can be set in the range from +10 dBm to –60 dBm by 1 dB step. 6) Resolution bandwidth key The resolution bandwidth is set with this key. It can be set in the range from 3 kHz to 3 MHz and to AUTO. 7) Video bandwidth key The video bandwidth is set with this key. It can be set in the range from 100 Hz to 1 MHz and to AUTO. 8) AUTO tuning key When pushing this key, the spectrum with the maximum level is searched within full span (3.3 GHz @ 2650A/2652A/2651 and 8.5 GHz @ 2658A), and then it is adjusted to the center of the screen, and the optimum setting parameters are set. In the case when in zero span, full span, input signal level lower than –40 dBm and input frequency lower than 50 MHz, this function will not work correctly. 9) Measuring function key Available for Channel power, Adjacent channel leakage power, Occupied frequency bandwidth, Electric field strength, and Magnetic field strength measurement. 10) Calculation function key Available for Max hold, Min hold, Average and Over write. 11) Display scale key The display scale of amplitude axis can be selected as 2 dB/div, 5 dB/div or 10 dB/div with this key. 12) Sweep key The sweep time can be set in the range from 10 ms to 30 s or AUTO. This key can also select the detection mode. 13) Hold/Run key Used to hold or run measurements. 9 14) Marker & Peak search key This key is used for setting marker or peak search. 15) Save/Load key Used for saving or loading a spectrum or settings parameters. 16) Copy key This key allows the screen image to be printed on USB printer (option) or stored in USB memory. 17) UTIL key Used for setting label entry, clock, and buzzer. 18) Display control key Used for setting color, backlight ON/OFF or brightness of backlight. 19) Rotary encoder This is used for adjusting settings and parameters. 20) Power switch This is for power ON or OFF. 21) Input connector N(J) connector 22) Indicator for charging condition Two color LED indicates the charging conditions of battery. 23) Input connector for DC power source Connect AC adaptor MA400. 24) USB A plug For connecting USB printer (option) or USB memory. 25) USB B plug For interfacing with a PC 10 4. Explanation of Screen Frequency Axis Setting Values Display Active Area Display Center frequency, Frequency span, Resolution bandwidth, Video bandwidth Remaining Battery Display Amplitude Axis Setting Values Display Spectrum Display 10div x 10 div **UNCAL Display Reference level, Input attenuator, Display scale Sweep Axis Setting UNCAL Values Display Sweep time, Detection mode Calculation function display Measuring function display Operating Information display Loaded spectrum information display Function Menu * This is also used as a display for set values Upper: Label Display when the measuring function is used. Lower: Clock Display Measured Values display **UNCAL is displayed when a normal measurement cannot be done due to sweep rate being too fast. In such cases, slowing down the sweep rate will change this indicator. 11 5. Function Menu 5.1 List of Function Menu The function menu is shown in the table below. For descriptions of each function, see their respective page. For the sequence of selection for the function menu, refer to “5.2 Menu tree”. A B Function menu ACP OFFSET ACP ACP WIDTH ANT AVG BACK LT BACK SPACE BAND CNTR BAND WIDTH C D E BRIGHT BUZZER CENTER FREQ ← CENTER FREQ → CH POWER CLEAR CLOCK CONFIG COLOR CONV DELETE DEVICE MEM DET DISP CLEAR E/F ANT EncST EMI-C **1 EMI-R **1 F I K L M FREQ COUNT IMP KeyST LABEL LOAD M/F PROBE MAX HLD MEAS OFF MIN HLD MARKER DELTA MARKER NORMAL Key Sequence MEAS → (F2)→ F2 MEAS → F2 MEAS → (F2) → F3 MEAS → (F4)→ F1 CALC → F4 DSPL → F2 FREQ → F6 → F5 MEAS → (F1) → (F1) → F2 MEAS → (F1) → (F1) → F3 DSPL → F3 UTIL → F3 FREQ → F1 FREQ → F2 MEAS → F1 FREQ → F6 → F4 UTIL → F4 DSPL → F1 MKR → F6 SAVE/LOAD → F3 SAVE/LOAD → F4 SWEEP → F4 SAVE/LOAD → F2 → F5 MEAS → F4 FREQ → F4 SAVE/LOAD → F6 → F2 SAVE/LOAD → F6 → F3 MEAS → F6 REFER → F6 FREQ → F3 UTIL → F1 SAVE/LOAD → F2 MEAS → F5 CALC → F2 MEAS → (F1~5) → F6 CALC → F3 MKR → F2 MKR → F1 Page 42 41 42 44 32 53 21 41 M Function menu MODE N NEXT PEAK Key Sequence MEAS → (F1 → F3) → F1 MKR → (F4) → F2 NORMAL CALC → F1 31 NORMAL **1 SAVE/LOAD → F6 → F1 MEAS → F3 REFER → F5 REFER → F3 CALC → F5 MKR → (F5)→ F1 MKR → F4 50 O OBW OFSdB OFS STEP OVR WR P PEAK SEACH PEAK SERCH NORM PEAK SERCH MKR → F5 ZONE PRE SET SAVE/LOAD → F6 PROBE MEAS → (F5) → F1 R RATIO MEAS → (F3) → F2 RBW ALL AUTO RBW → F3 RBW AUTO RBW → F2 RBW MANUAL RBW → F1 REFERENCE MEAS → (F2) → F4 CENTER REFERENCE MEAS → (F2) → F1→ F5 WIDTH S SAVE SAVE/LOAD → F1 SCALE 5dB SCALE → F3 SET MKR FREQ → F5 SPR. FR **2 CALC → F6 SWEEP AUTO SWEEP → F2 SWEEP MANUAL SWEEP → F1 T T.G. MODE **3 SWEEP → F6 TRIG SWEEP → F5 Ten Key MODE FREQ → F6 U UNIT REFER → F1 → 4 V VBW ALL AUTO VBW → F3 VBW AUTO VBW → F2 VBW MANUAL VBW → F1 Z ZONE CENTER MKR → (F5) → F1 ZONE WIDTH MKR → (F5) → F2 **1 2651 only **2 2658A only **3 2652A only 41 53 59 20 20 41 21 59 53 33 36 36 29 38 43 20 50 50 49 25 20 58 38 47 31 41 31 33 33 12 Page 41 to 43 34 42 24 24 32 34 34 34 36 48 43 28 28 27 42 42 36 27 20 32 29 29 55 30 20 24 29 28 28 35 35 5.2 Menu Tree The following is the sequence of selection for the function menu. The function menu corresponds to the function key of F1 to F6. “Function menu” FREQ E/F M/F FREQ PROBE COUNT CH POWER ACP OBW ANT F1 F2 F3 F4 KeyStep EncStep SET Ten Key 100 MHz 10 MHz MKR MODE F5 F6 * Refer to “7. Center Frequency” for details. CENTER FREQ : Set the center frequency BACK GHz SPAN MHz CLEAR “.” SPACE RETURN * Refer to “8. Frequency Span” for details. NORMAL FULL ZERO SPAN SPAN SPAN SPAN 1 GHz 50 MHz 1 MHz : Set the frequency span REFER * Refer to “9. Reference Level” for details. UNIT RL STEP OFS STEP OFFSET OFS dB IMP dBm 1dB 1dB OFF 0dB 50Ω : Set the reference level 13 SCALE * Refer to “10. Display scale” for details. SCALE 10dB/ 2dB/ 5dB/ : Set the display scale RBW * Refer to “11. Resolution Bandwidth” for details. RBW MANUAL AUTO ALL AUTO : Set the RBW VBW * Refer to “12. Video Bandwidth” for details. VBW MANUAL AUTO ALL AUTO : Set the VBW * Refer to “13. Sweep Axis / Detection Mode” for details. SWEEP * T.G. MODE is only for 2658A. SWEEP TIME MANUAL AUTO ALL AUTO : Set the sweep time T.G. NORM ON ON 14 DET TRG T.G. SMPL INT MODE CALC * Refer to “16. Calculation Function” for details. * “SPR. FR” is only for 2658A. NORMAL MAX HLD MIN HLD AVG OVR WR SPR. FR 256 256 256 256 OFF : Set the number MKR * Refer to “17. Marker & Peak Search” for details. PEAK SEARCH MARKER NORMAL DELTA OFF : Move the marker (NORM mode) PEAK NEXT SEARCH PEAK NORMAL CONV ZONE dBm → W F4: Peak Search RETURN : Move the marker (NORM mode) F5: Zone marker ZONE CENTER WIDTH RETURN : Set the zone center frequency (ZONE mode) 15 SAVE/LOAD * Refer to “18. Save / Load” for details. Main menu MODE SELECT SAVE LOAD DEVICE DELETE MEM PRE USB SET Save menu SAVE OBJECT SPECT PARAM BOTH RETURN EXECUTE : Set the address to store the spectrum or the parameter Load menu File Search Step 10 1 100 LOAD DISP EXECUTE CLEAR RETURN : Set the address to call the spectrum or the parameter Delete menu DELETE File Search Step 1 10 100 EXECUTE RETURN : Set the address to eliminate the trace or parameter For 2651 Preset menu for 2651 PRESET NORMAL EMI - C EMI - R 16 MEAS * Refer to “19. Measuring Function” for details CH POWER ACP OBW E/F M/F Freq ANT PROBE COUNT : Set the parameter MODE BAND BAND CENTER MEAS OFF WIDTH : Set the parameter ADJ CH MODE BAND OFFSET MEAS REFERENCE WIDTH CENTER WIDTH OFF : Set the parameter MODE RATIO % Enc Step MEAS N% 99.5% 1% OFF ANT MEAS M401 OFF Input the probe ID (first time only) *Refer to “19.5 Magnetic field strength measurement” for details. PROBE MEAS CP-2S OFF 17 DSPL COPY UTIL * Refer to “21. Screen Control” for details COLOR BACK LT BRIGHT COLOR1 ON 80 * Refer to “23. Storage/Print Screen Image” for details AREA PRINT Bmp->USB MEM->USB WHOLE EXECUTE COPY EXECUTE * Refer to “24. Utility Function” for details LABEL 012 MENU BUZZER CLOCK OFF ALARM CONFIG abc ABC @%* BACK SP ENTER ← → ENTER : Select the character YEAR MONTH DATE HOUR MIN 08 JUN 30 23 50 : Select the numeric value 18 6. Preparing for Operation 6.1 Stand Utilize the stand on the back to use the screen in an easier-to-see angle on the desk. 6.2 Connection to power supply The AC adapter MA400 is used to power the instrument and for charging the MB400 battery. (Charging starts automatically if the AC adapter is connected and unit is power-off.) Connect the adapter as in the figure below and connect the AC plug to the power line (100-240 VAC, 50/60 Hz). For static electricity protection, ground the unit by connecting the three cores if possible. Not grounding the unit can damage the unit and/or device being measured. Do not use an AC adapter other than the MA400 supplied with the unit. Using an AC adapter other than the MA400 may cause damage to the unit. Battery full charge time: approx. 4 hours Battery operating time: 4 hours maximum (with backlight set to minimum) *Tested at normal temperature with initial setting parameters. Please make sure to connect to ground. Connect to 100 to 240 VAC, 50/60 Hz The battery indicator is divided into five levels and is displayed on the screen. When the mark of the battery remainder displays , the buzzer will sound even if buzzer is OFF under settings, and the power will turn off within a few minutes. Ensure to protect any data or measurements promptly by saving into memory to prevent data lost if the unit shuts down. 19 6.3 Battery Charge When the unit is powered off and connected to AC adaptor MA400, the battery will be charged. The charging conditions are indicated by two colors LED , and they correspond to the table below. Charging condition On Charge Completion of Charge No battery Abnormal Color of LED Red Green Green Blinking Red Good usage of battery Remove the battery when unit is connected to the AC adaptor. Otherwise, battery life will be shortened. ※LED is turned off at power-on. The “abnormal” condition means that the charging time is more than the time expected, or the battery voltage is too high. Note: The battery charges only when the unit is turned off (and the AC adapter connected). It is not possible to charge the batteries while the unit is turned on. Please charge batteries with ambient temperature in the range of 0 ºC to 40 ºC. Caution Misuse of the battery may cause leaks, abnormal heat, fire or explosion. For safe use, please observe the following precautions fully. * Do not short-circuit the terminal of the removed battery. * Do not cause an impacted shock due to throwing, dropping or striking. * Do not disassemble or remodel the battery. * Do not throw the battery into a fire or any sources with heat. * Do not leave the battery in a place with high temperature. * Do not wet the terminal of the battery. * Do not cool the battery, and do not charge it in cold outdoor conditions. It decreases performance and battery life. * Do not charge the battery in any other way except according to specifications. * When you keep the battery, please keep it in a cool, dark environment where humidity is low. Moreover, please keep it out of reach from children. If the battery remains not used for a long time, it might decrease its charges. * Please exchange the battery for a new one (MB400) when operating time extremely shortens. 6.4 Installation of Battery To install the battery, please turn off the power and unplug the AC adaptor if in use. Remove the battery cover on the back of the unit by first pressing down with light pressure, then slide towards the direction of the arrow as shown in Fig.1. Next, put the battery as shown in Fig.2. Move it in the direction of the arrow shown in Fig.3 until it locks in. Use only the MB400 battery as specified. Otherwise, the unit may cause problems or malfunction. Fig. 1 Fig. 2 20 Fig. 3 7. Center Frequency When is pushed, the following function menu is displayed. FREQ CENTER FREQ KeyStep EncStep SET Ten Key ← → 100M 0.1M MKR Mode F1 F2 F3 F4 F5 F6 * Center frequency setting range: 0 to 3.3 GHz for 2650A/2652A/2651, 0 to 8.5 GHz for 2658A * The center frequency may shift for a while (up to 10 sec.), after setting is changed. 7.1 Setting with step keys ( [F1], [F2] ) 1. When F1 is pushed, the center frequency decreases in the set step size. 2. When F2 is pushed, the center frequency increases in the set step size. 3. Setting step size: F3 When AUTO is pushed, the step size is changed according to the following. 100MHz 10MHz 1MHz 100kHz 20kHz AUTO : The step size is 1/10 of the frequency span. However, only for 500 kHz frequency span, the step size is set to 50 kHz. If the frequency span is less than 500 kHz, the step size is set to 20 kHz. AUTO is recommended for normal use. 7.2 Setting with encoder 1. By rotating , the center frequency is changed in the set step size. 2. Setting step size: F4 When AUTO is pushed, the step size is changed according to the following. 100MHz 10MHz 1MHz 100kHz 20kHz AUTO : The step size is 1/500 of the frequency span However, if the frequency span is less than 5 MHz, the step size is set to 20 kHz. AUTO is recommended for normal use. 21 7.3 Setting with numeric key F6 1. When is pushed, the following function menu is displayed. BACK 2. GHz MHz “.” CLEAR SPACE RETURN F1 F2 F3 F4 F5 F6 F1 , F4 and and F2 F5 correspond to , and F3 correspond to and . Changing the center frequency by encoder is available in Ten Key Mode. 3. The center frequency can be entered directly according to “Numeric Key Mapping Diagram” as follows. “Numeric Key Mapping Diagram” RBW VBW AUTO TUNE MEAS CALC 1 2 3 4 5 SCALE SWEEP HOLD RUN MKR SAVE LOAD 6 7 8 9 0 COPY UTIL DSPL . MHz GHz 4. The center frequency is determined by inputting the unit of frequency. To enter the unit, ( F1 and UTIL F2 and DSPL are available. are also available.) * Any figures below the setting resolution (20 kHz) will be truncated. 5. Change of setting The setting can be changed before pushing the unit key. F4 : The setting values are cleared. F5 : The last input digit is deleted. 22 6. Cancel of Ten Key Mode FREQ By pushing F6 or , unit will return to function menu. 7.4 According to Marker Position F5 When is pushed, the center frequency is set according to the frequency of current marker position. * Any figures below the setting resolution (20 kHz) will be truncated. * When the marker is not displayed, this operation is invalid. (The menu option disappears.) 8. Frequency Span SPAN When is pushed, the following function menu is displayed. NORMAL FULL ZERO SPAN SPAN SPAN 1GHz 50MHz 1MHz F1 F2 F3 F4 F5 F6 By operating SPAN , the frequency span is set. SPAN 2650A / 2652A / 2651 By rotating , the frequency span is changed in the specified step size as follows. ZERO 200k 20M 50M 500k 100M 1M 2M 200M 500M 5M 1G 10M 2G FULL (3.3 GHz) 2658A 1. By rotating , the frequency span is changed in the specified step size as follows. ZERO 200k 500k 1M 50M 100M 200M 500M 2. By pushing F2 2M 1G 5M 10M 2G 5G F3 FULL (8.5 GHz) , the frequency span is set to FULL SPAN. Under this condition, the instrument will return to the former span when the rotary knob is rotated. 3. By pushing 20M , the frequency span is set to ZERO SPAN. 23 4. When is pushed and then the setting is FULL or ZERO span, the frequency span is returned to F1 the last setting. 5. By pushing F4 ~ F6 , the frequency span in function menu is set. 8.1 Switching Frequency Band 2658A has three frequency bands. Frequency band Base band Measured frequency range 50 kHz to 3.5 GHz Band 1Band 1+ 3.3 GHz to 6.3 GHz 6.1 GHz to 8.5 GHz The frequency band is automatically set to the appropriate band based on the center frequency and span. (At the span less than 200 MHz, only one band is used.) When the setting frequency range belongs to two bands, the lower band has priority. The frequency connection point of two bands is fixed as follows. Two bands Base band and Band 1Band 1- and Band 1+ Frequency connection point 3.4 GHz 6.2 GHz Note: The spectrum may change a little at the frequency connection point. For accurate measurement, center frequency and span should be set as the measured frequency range in one band. 24 9. Reference Level When REFER is pushed, the following function menu is displayed. UNIT RL STEP OFS STEP OFFSET OFSdB IMP dBm 1dB 1dB OFF 0.0 50Ω F1 F2 F3 F4 F5 F6 9.1 Setting of Reference Level By rotating , the reference level is changed. (Refer to “9.7 Reference Level Setting Range for Each Unit” for details.) 9.2 Change of Unit of Amplitude Axis F1 When is pushed, the unit is set as follows. dBμV dBm dBmV dBV 9.3 Setting of Step Size of Reference Level By pushing F2 , the step size is changed to 10 dB or 1 dB. 9.4 On-Off Setting of Offset By pushing F4 , the offer set ON/OFF is changed. 9.5 Setting of Offset Level 1. By operating F5 , the offset of reference level is set. When external amplifier or attenuator is used, the display level can be matched by the offset. The setting range is -50.0 to 50.0 dB. The reference level is displayed including the offset. * If the offset is set, “OFST” is displayed in Amplitude axis setting values display area. Furthermore, the level at the marker point is displayed including the offset. 25 * If the unit is changed to dBμV, dBmV, dBV or dBm, the offset is automatically changed. F3 2. By pushing , the step size of offset is changed. (10 dB, 1 dB, 0.1 dB) 9.6 Setting of Input Impedance By pushing F6 , the input compensation can be set to 50 Ω (no offset) or 75 Ω. (5.6 dB offset compensation) The reference level is adjusted automatically, based on the input impedance selection. When the input impedance is set to 75 Ω, the reference level is displayed including offset and conversion of 75Ω. For the amplitude reading to be correct, a coaxial 50 Ω /75 Ω impedance conversion adapter must be connected to the RF input. * When “75 Ω” is selected, values in Amplitude axis setting values display area will change according to 75 Ω, and the offset is set to 5.7 dB (insertion loss of 50 Ω /75 Ω adapter ). Moreover, the offset can be changed. When the unit at marker point is set to W, V, V/m or other, it is converted correctly from dBm. * Be sure to attach a coaxial 50 Ω /75 Ω impedance conversion adapter when selecting “75 Ω” 9.7 Reference Level Setting Range for Each Unit Unit dBm dBμV dBmV dBV Maximum Minimum Minimum (shifted spectrum data) 10 -40 117 67 57 7 -3 -53 -60 47 -13 -73 “Available unit in measuring function” Setting M401 M402 M403 M404 M405 M406 dBμA/m (Magnetic field strength measurement) CP-2S Maximum Minimum Minimum (shifted spectrum data) 143 93 146 96 149 99 150 100 137 87 159 109 160 ~ 203 110 ~ 153 73 76 79 80 67 89 90 ~ 133 dBμV/m (Electric field strength measurement) Unit * When the reference level is set between “Minimum” and “Minimum (shifted spectrum data)”, the spectrum of “Minimum” is shifted and displayed on the screen. 26 * When the reference level is set below “Minimum”, “*S/W AMP” is displayed in Amplitude axis setting values display area on the screen. Calculation formula (conversion from dBm) ● A[dBμV] = 107 + X [dBm] ● B[dBmV] = 47 + X [dBm] ● C[dBV] = -13 + X [dBm] ● D[dBμV/m] = 68.8 / λ×√(X/Gar) [dBm] λ : Wavelength[m] Gar : Antenna absolute gain[times] ● E[dBμA/m] = 107 + X + F[dBm] F : Probe calibration coefficient[dB] **changes depending on the frequency. 9.8 Relationship Between Reference Level and ATT/AMP (at dBm) REFER ATT AMP REFER ATT AMP REFER ATT AMP REFER ATT AMP (dBm) (dB) (dB) (dBm) (dB) (dB) (dBm) (dB) (dB) (dBm) (dB) (dB) 10 25 0 -3 12 0 -16 20 21 -29 7 21 9 24 0 -4 11 0 -17 19 21 -30 6 21 8 23 0 -5 10 0 -18 18 21 -31 5 21 7 22 0 -6 9 0 -19 17 21 -32 4 21 6 21 0 -7 8 0 -20 16 21 -33 3 21 Internal input attenuator (ATT) and IF amplifier (AMP) are automatically set to the optimum values based on the reference level (REFER). (The input attenuator cannot be set independently.) 27 5 20 0 -8 7 0 -21 15 21 -34 2 21 4 19 0 -9 6 0 -22 14 21 -35 1 21 3 18 0 -10 5 0 -23 13 21 -36 5 26 2 17 0 -11 4 0 -24 12 21 -37 4 26 1 16 0 -12 3 0 -25 11 21 -38 3 26 0 15 0 -13 2 0 -26 10 21 -39 2 26 -1 14 0 -14 1 0 -27 9 21 -40 1 26 -2 13 0 -15 0 0 -28 8 21 * When the input signal level is higher than the proper level for 1st mixer’s terminal, harmonics distortion and spurious are generated. This product is designed so that the input signal level of 1st mixer is determined to proper level based on the reference level. 28 10. Display Scale When SCALE is pushed, the following function menu is displayed. SCALE 10div/ 5div/ 2div/ F1 F2 F3 F4 F5 F6 10.1 Setting the Function Key 1. By pushing F1 , 10 dB/div display scale is set. 2. By pushing F2 , 5 dB/div display scale is set. 3. By pushing F3 , 2 dB/div display scale is set. 11. Resolution Bandwidth When RBW is pushed, the following function menu is displayed. RBW MANUAL AUTO ALL AUTO F1 F2 F3 F4 F5 F6 11.1 MANUAL Mode By pushing By rotating F1 or rotating , RBW is set as follows. 2650A/2652A/2658A: 3kHz 2651: 3kHz , MANUAL mode is set. 9kHz 10kHz 30kHz 30kHz 120kHz 100kHz 300kHz 29 300kHz 1MHz 1MHz 3MHz 3MHz 11.2 AUTO Mode F2 By pushing , the optimum RBW is set based on the frequency span and sweep time. * When AUTO mode is set, “*” is displayed on the right end of RBW setting value display. 11.3 ALL AUTO Mode F3 By pushing , the optimum RBW, VBW and sweep time are set based on the frequency span. * When ALL AUTO mode is set, “*” is displayed on the right end of each setting value display. * When RBW is set to 3 kHz or 10 kHz, the selectivity at 60 dB becomes larger than an actual value due to SSB phase noise. 12. Video Bandwidth When VBW is pushed, the following function menu is displayed. VBW MANUAL AUTO ALL AUTO F1 F2 F3 F4 F5 F6 12.1 MANUAL Mode F1 By pushing By rotating 100Hz or rotating , MANUAL mode is set. , VBW is set as follows. 300Hz 100kHz 1kHz 300kHz 3kHz 10kHz 30kHz 1MHz 12.2 AUTO Mode By pushing F2 , the optimum VBW is set based on the frequency span and sweep time. When AUTO mode is set, “*” is displayed on the right end of VBW setting value display. 30 12.3 ALL AUTO Mode By pushing F3 , the optimum RBW, VBW and sweep time are set based on the frequency span. * When ALL AUTO mode is set, “*” is displayed on the right end of each setting value display. 13. Sweep Axis / Detection Mode When SWEEP is pushed, the following function menu is displayed. SWEEP DET TRIG T.G. MANUAL AUTO ALL AUTO SMPL INT MODE F1 F2 F3 F4 F5 F6 * T.G. MODE [F6] is only for 2652A. This menu is not displayed on 2650A, 2651 and 2658A. For the details, refer to “22. Tracking Generator Mode”. [F5] is only displayed when an external trigger signal is detected at the trigger port. 13.1 MANUAL Mode By pushing F1 By rotating , sweep time is set as follows. 10ms or rotating 30ms 0.1s , MANUAL mode is set. 0.3s 1s 3s 10s 30s * For 2650A, 2651 and 2652A, when the setting is FULLSPAN, it cannot be set to 10 ms. * For 2658A, when the setting is 5 GHz SPAN or FULLSPAN, it cannot be set to 10 ms. 13.2 AUTO Mode By pushing F2 , the optimum sweep time is set based on the frequency span and RBW. * When AUTO mode is set, “*” is displayed on the right end of SWEEP setting value display. 13.3 ALL AUTO Mode By pushing F3 , the optimum RBW, VBW and sweep time are set based on the frequency span. * When ALL AUTO mode is set, “*” is displayed on the right end of each setting value display. 13.4 Setting of Detection Mode (For 2651, refer to “20. EMI test”) 31 F4 By pushing POS , the detection mode is set. SMPL NEG POS (Positive Peak): The maximum value of the sample points is detected. SMPL (Sample): The momentary value of the sample points is detected. NEG (Negative Peak): The minimum value of the sample points is detected. 13.5 Setting of Trigger Source By pushing F5 INT , the trigger source is set. EXT INT: The sweep is automatically repeated. This setting is normally used. EXT: When the signal over the trigger level (0.56 V) is input to external trigger input, the sweep starts. The sweep automatically starts without an input. (Available only for zero span) 14. AUTO Tuning When AUTO TUNE is pushed, the spectrum with the maximum level is searched within full span, and then it is adjusted to the center of the screen, and the optimum setting parameters are set. * Set the frequency span before setting AUTO tuning. * There is no function menu displayed for this mode. Auto tuning will execute upon pushing the key. * The auto tuning does not operate normally in the following conditions. 1) Zero span 2) Full span 3) The signal level is –40 dBm or lower. 4) The signal frequency is 50 MHz or lower. 15. Hold / Run By pushing HOLD / RUN , the sweep is switched to halt and continuance. * There is no function menu displayed for this mode. 32 16. Calculation Function When is pushed, the following function menu is displayed. CALC NORMAL MAX HLD MIN HLD AVG OVRWR SPRI FR * * * * 56 * * OFF F2 F3 F4 F5 F6 F1 * By pushing HOLD / RUN * By pushing F1 ~ , the sweep is restarted. F5 , the calculation function is selected. , the number of times of the sweep can be set. By rotating 16.1 NORMAL Mode F1 1. When is pushed, the normal mode is set. The calculation is not performed in this mode. The number of times of the sweep is infinite. This mode is normally used. * When this mode is set, “NORMAL” is displayed in the CALC area on the screen. (Refer to “4. Explanation of Screen” for the details.) 16.2 MAX HOLD Mode F2 1. By the operation of , the number of times of the sweep in the MAX HOLD mode is set. 2. The update spectrum data is compared with the data left last time at each point, and the larger one is retained and displayed. 2 4 256 8 512 16 1024 32 * * 64 128 (infinite) * When this mode is set, “MAX --- (number of times)” is displayed in the CALC area on the screen. (Refer to “4. Explanation of Screen” for the details.) 16.3 MIN HOLD Mode 1. By the operation of F3 , the number of times of the sweep in the MIN HOLD mode is set. 33 2. The update spectrum data is compared with the data left last time at each point, and the smaller one is retained and displayed. 2 4 256 8 512 16 1024 32 * * 64 128 (infinite) * When this mode is set, “MIN --- (number of times)” is displayed in the CALC area on the screen. (Refer to “4. Explanation of Screen” for the details.) 16.4 AVERAGE Mode F4 1. By the operation of , the number of times of the sweep in the AVERAGE mode is set. 2. The simple averaging process is executed at each sweep. 2 4 256 8 512 16 32 64 128 1024 * When this mode is set, “AVG --- (number of times)” is displayed in the CALC area on the screen. (Refer to “4. Explanation of Screen” for the details.) 16.5 OVERWRITE Mode F5 1. By the operation of , the number of times of the sweep in the OVER WRITE mode is set. 2. The image on the screen is not cleared at each sweep, and the overwriting display is executed. 2 4 256 8 512 16 1024 32 * * 64 128 (infinite) * When this mode is set, “OVER WR” is displayed in the CALC area on the screen. (Refer to “4. Explanation of Screen” for the details.) * Only the last spectrum is saved. 16.6 SPURIOUS FREE Mode (2658A only) 1. By pushing F6 , the SPRIOUS FREE mode, by which the spurious response at band 1- and band 1+ is simply deleted, is selected. * “SPR” is displayed in CALC area on the screen. (Refer to “4. Explanation of Screen” for the details.) 34 * Differing from base band at which the up-conversion of input frequency is done with a frequency mixer, the spurious response peculiar to band 1- and band 1+ is generated because the down-conversion is done at those two bands. * About SPURIOUS FREE mode 1. SPURIOUS FREE mode is a mode by which the spurious response peculiarly caused at band 1+ is simply deleted. 2. SPURIOUS FREE mode is especially effective in the measurement of a stationary wave. 3. If SPURIOUS FREE mode is used in measurement of a signal with level change or frequency change, the phenomenon that the level goes down will occur. 4. The noise level goes down a little in case of a noise changing at random. In short, the same phenomenon as MIN HOLD function happens. * How to judge SPURIOUS response at band 1- and band 1+ The procedure for judging SPURIOUS response at band 1- and band 1+ is as follows. 1. Set the center frequency to < (current setting value) + f >. 2. The spectrum shifting left by f is a correct spectrum, but another spectrum shifting such as left by 2f, left by 3f, right by f, right by 2f or right by 3f is a spurious response. * “f ” should be changed according to SPAN for easy judgment. For reference; f = SPAN / (10 to 50) (corresponding to 0.2 to 1 div) Example: judging a spectrum displayed at 6.92 GHz (setting : center frequency 6.92 GHz and SPAN 500 MHz) 1. Set the center frequency to < 6.92 GHz + 500 MHz/25 > = 6.94GHz. 2. A spectrum at 6.92 GHz (shifting left by f from 6.94 GHz) is correct. A spectrum at 6.98 GHz (shifting right by 2f from 6.94 GHz) is spurious. * Additionally, a spurious response mentioned above shifting right by 2f at band 1+ is largest, and other spurious response are about 25 to 50 dB smaller than that. 17. Marker & Peak Search When MKR is pushed, the following function menu is displayed. ● Main menu of marker function MARKER CONV CENTER FREQ NORMAL DELTA OFF NORMAL ZONE dBm →W F1 F2 F3 F4 F5 F6 35 17.1 Movement and Basic Function of Marker 1. By rotating , the marker moves. 2. By pushing , the normal marker mode is selected and the marker operates as an independent F1 marker. The frequency and the level at the marker point are displayed in the lower right side. F2 3. When is pushed, the delta marker mode is selected, and the reference marker and the active marker are displayed. The frequency and the level at the marker points are displayed as follows; Frequency = (freq. at active marker) – (freq. at reference marker) Level = (level at active marker) – (level at reference marker) 4. By pushing , the marker is erased (marker off). F3 17.2 Normal Peak Search ● Menu of normal peak search When F4 is pushed, the following function menu is displayed. PEAK NEXT SEARCH PEAK F1 F2 RETURN F3 F4 F5 F6 1. When F1 is pushed, the marker moves to the maximum peak position of spectrums. 2. When F2 is pushed, the marker moves to the next highest peak. Fifty or less peaks are available. 3. When F6 is pushed, the function menu is returned to the main menu of marker function. 17.3 Zone Peak Search ● Menu of normal peak search When F5 is pushed, the following function menu is displayed. 36 ZONE CENTER RETURN WIDTH F1 F2 F3 F4 F5 F6 At the Zone mode, the marker automatically moves to the maximum peak point within the range set beforehand. When entering this mode, the zone is displayed with thin blue shadow in the spectrum display area. The marker moves to maximum level within this zone at each sweep. The center of the zone can be adjusted by pressing F1 The width of the zone can be adjusted by pressing F2 Note: The marker does not move in HOLD. 17.4 Change Unit of Marker Level F6 When is pushed, the unit of the marker level is changed. If the unit of the reference level is dBm, it can be changed to [dBm] [W]. If the unit of the reference level is dBμV, dBmV or dBV, it can be changed to [dBμV, dBmV, dBV] Note: [V]. If the unit of the reference level is dBμV/m, it can be changed to [dBμV/m] [V/m]. If the unit of the reference level is dBμA/m, it can be changed to [dBμA/m] [A/m]. “V/M” is only displayed when the electric field strength measurement is selected “A/M” is only displayed when the magnetic field strength measurement is selected Each unit change as described above has their own sub-menu for more unit display options. They are shown below: [W] [W, mW, μW, nW, pW, fW] [V] [V, mV, μV, nV] [V/m] [V/m, mV/m, μV/m, nV/m] [A/m] [A/m, mA/m, μA/m, nA/m] 18. Save / Load When SAVE / LOAD is pushed, SAVE/LOAD menu is displayed as follows. 37 MODE SELECT PRE DEVICE SAVE LOAD DELETE MEM USB SET F1 F2 F3 F4 F5 F6 18.1 Selection of Storage Device 1. When When F4 F5 is pushed, the built-in flash memory is selected as a storage device. is pushed, the external USB memory is selected as a storage device. * Install the USB memory in USB A- plug on the right side firmly. Refer to the figure below. * Once you disconnect, then reconnect the same or a different USB flash memory drive, the 2650A series will not automatically recognize the new USB drive. After connecting the drive, you must first press the Save/Load key, followed by F5 key (USB) in order for the 2650A to "see" the new drive., then proceed as described below. . 38 18.2 Save Function When F1 is pushed, SAVE menu is displayed as follows. OBJECT SAVE PRE RETURN SET SPECT PARAMM BOTH EXECUTE F1 F2 F3 F4 F5 F6 1. In this function, the data is stored in the built-in memory or USB memory by CSV format. The data stored in USB memory can be used with a personal computer as a CSV file. “2650A_csvData” folder will automatically be created and the data will be stored in it as a file. 2. The object to be stored is selected with F1 , F2 or F3 . SPECT: The current spectrum on the screen is stored. PARAM: The setting parameters are stored. BOTH: The spectrum and setting parameters are stored as one file. * The selected key will look pushed-in on the display. 3. F4 When is pushed, SAVE is executed. The data is stored based on the file name displayed in the active area (refer to “4. Explanation of screen”). As for the file name, refer to “18.3 About File Name”. Up to 200 files can be stored in the built-in memory. Up to 1000 files can be stored in USB memory. 4. Pushing F6 will return to the former menu. 18.3 About File Name 1. The file name is attached to the file stored using this function as follows. LABEL-SP001.csv (1) (2) (3) (4) (1) This is the label entered from the label function. Refer to “24.1 Label function.” Note: Symbols and spaces are not recognized as a file name. (2) S : The object stored is the spectrum (SPECT). P: The object stored is the setting parameters (PARAM). SP: The object stored is both of spectrum and setting parameters (BOTH). (3) The consecutive three digit number from “000” is automatically attached if (1) and (2) are same. (4) This is the extension showing CSV format and is automatically attached. 39 2. If the label is not named, “2650A” will be the first part of the file name instead. For example: 2650A_SP001.csv 3. About file name at the time of storage When SAVE is selected, the file name is displayed in the active area following according to the above labeling convention. When SAVE is executed as it is, the data is stored with that file name. If the file exists in the storage device and is rotated left before SAVE is executed, those file names are displayed one by one. If SAVE is executed with an existing file name displayed, the data is overwritten on it. 18.4 Load Function F2 When is pushed, LOAD menu is displayed as follows. File Search Step LOAD DISP 1 10 100 EXECUTE CLEAR RETURN F1 F2 F3 F4 F5 F6 1. When is rotated right or left, the stored file name is displayed one by one from the specified storage device in the active area as follows. 1) USB : LOAD 2) 2650A_SP012.csv 3) 12 1) The storage device in which the file is stored. (USB: USB memory, MEM: built-in memory) 2) The file name selected. 3) Number attached to file The files in the specified folder of the storage device are sorted in alphabetical order, and this shows that number. 2. To search files, press , and the file will be displayed in order of the number attached to it in the active area. F1 The search steps can be adjusted by pressing F3 F2 to search in steps of 10 files at a time or pressing to search in steps of 100 files at a time. Select it according to the number of stored files. 3. When F4 is pushed, LOAD is executed. * When SPECT is selected, a spectrum waveform is loaded. The setting parameters of loaded spectrum are displayed in the setting parameters display area. [Refer to “4. Explanation of screen” for details.] 40 * When PARAM is selected, setting parameters are loaded. * When the spectrum is loaded, the 2650A series enters HOLD state and the current spectrum disappears, replacing it with the loaded spectrum on main display. When HOLD/RUN is pushed right after, the loaded spectrum and a current spectrum are displayed together. 4. When is pushed, the loaded spectrum can be cleared on display. F5 18.5 Delete Function When F3 is pushed, DELETE menu is displayed as follows. DELETE File Search Step 1 10 100 EXECUTE F1 F2 F3 F4 RETURN F5 F6 1. The file name to be deleted is selected from the specified device with , and the active area will indicate this name. As for the number of search steps, it is the same as “18.4 Load Function”. 2. When is pushed, DELETE is executed. The file displayed in the active area is deleted at this F4 time. 3. Repeat step 1 and 2 above to delete more than one file. 18.6 Presetting (Initialization) (For 2651, refer to “20. EMI test”) When F6 is pushed, the setting parameters are reset to the preset values as shown below. Items Parameters Center frequency Frequency span Reference level Offset Impedance Sweep time Detection mode 1 GHz 20 MHz 10 dBm 0.0 dB 50 Ω 30 ms Sample mode (SMPL) RBW VBW Display scale 100 kHz 30 kHz 10 dB/div 41 19. Measuring Function When MEAS is pushed, the following function menu is displayed. E/F M/F FREQ CH POWER ACP OBW ANT PROBE COUNT F1 F2 F3 F4 F5 F6 The measuring function can be selected as follows. F1 CH POWER ----------- Channel power measurement F2 ACP ----------------------- Adjacent channel leakage power measurement F3 OBW ---------------------- Occupied bandwidth measurement F4 E/F ANT ---------------- Electric field strength measurement F5 M/F PROBE ----------- Magnetic field strength measurement F6 FREQ COUNT --------- Frequency counter (factory option) * Once the measuring function is set, when MEAS is pushed, the function menu is directly returned to the last setting of the measuring function. In order to stop the measuring function or to select the other measuring function, push [F6] key (MEAS OFF), then the function menu is returned to the main menu of the measuring function. * Each of the four functions (Channel power, Adjacent channel leakage power, Occupied bandwidth and Frequency counter) and the marker function cannot be used at the same time. When MKR is pushed while each of the four functions is selected, the measuring function will stop. Similarly, when the measuring function is selected while using the marker function, the marker function will stop. * Although 501 points can be displayed on the screen, the number of points calculated in the instrument is 1001. 19.1 Channel Power Measuremnt The total power in the specified frequency band is measured. Two modes, TOTAL and BAND, are available. • TOTAL mode [ By pushing F1 (MODE), TOTAL mode is selected.] The sum of power in the displayed spectrum specified by center frequency and frequency span is measured. 42 * “CP TOTAL” is displayed in MEAS area on the screen. * The measured value is displayed at the lower right corner on the screen. [Measuring Mode] • [Measured Value] F1 BAND mode [ By pushing (MODE), BAND mode is selected.] The sum of power in the band specified by band center and bandwidth is measured. * “CP BAND” is displayed in MEAS area on the screen. * The measured value and the setting parameter are displayed at the lower part of the screen. 1. By F2 (BAND ENTER) , the band center is set. 2. By F3 (BAND WIDTH) , the band width is set. [Measuring Mode] [Measured Value] [Setting parameter] 19.2 Adjacent Channel Leakage Power Measurement F2 The adjacent channel leakage power is measured as the ratio of power in the range specified by offset frequency and bandwidth to carrier power. Both leakage power at the upper and lower side are measured. Furthermore, the method for measurement is selected out of three methods based on the classification of definition of carrier power; total power method, reference level method and in-band method. • Mode selection and measurement [ By pushing F1 (MODE), TOTAL, BAND or PEAK mode is selected.] * “ACP TOTAL”, “ACP BAND” or “ACP PK” is displayed in MEAS area on the screen. 43 * The measured value and the setting parameter are displayed at the lower part of the screen. 1. By F2 (ACP OFFSET) , the offset frequency of adjacent channel is set. * The offset is from the center frequency of the reference carrier. 2. By F3 (ACP WIDTH) , the band width of adjacent channel is set. 3. By [Measuring mode] [Setting parameter] [Measured value] F4 (REFERENCE CENTER) , the center frequency of the reference carrier is set. * [F4] is only for TOTAL and BAND mode. 4. By F5 (REFERENCE WIDTH) , the band width of reference carrier is set. * [F5] is only for BAND mode. • Definition of Reference Carrier for each Mode TOTAL (total power method) BAND (in-band method) PEAK (reference level method) This is based on the sum of power in the This is based on the sum of power in the This is based on the power of peak on the displayed spectrum. The center frequency specified bandwidth. The center screen. The center frequency of the of the reference carrier is set by [F4]. frequency of the reference carrier is set by reference carrier is automatically set to the [F4]. peak on the screen. 44 19.3 Occupied Bandwidth Measurement F3 It is possible to measure the occupied frequency bandwidth defined as the width of points at N(%) of the total power (N% POWER), or as the width of points that are X(dB) lower than the peak level (XdB DOWN). • F1 N% POWER mode [ By pushing (MODE), N% POWER mode (N%) is selected.] The bandwidth of points at N(%) of the total power is measured. * “OBW N%” is displayed in MEAS area on the screen. * The measured value is displayed at the lower right corner on the screen. F2 1. By (RATIO %) , the percentage of the total power is set. * Setting range : 80.0 to 99.9% F3 2. By [Measuring mode] • [Setting parameter] , the step size of RATIO % can be set to 1% or 0.1%. [Measured value] F1 XdB DOWN mode [ By pushing (MODE), XdB DOWN mode (X dB) is selected.] The bandwidth of points that are X(dB) lower than the peak level is measured. * “OBW XdB” is displayed in MEAS area on the screen. * The measured value is displayed at the lower right corner on the screen. 1. By F2 (XdB) , the down level from the peak level is set. * Setting range : 0.1 to 99.0dB 2. By [Measuring mode] [Setting parameter] F3 , the step size of XdB can be set to 1dB or 0.1dB. [Measured value] 19.4 Electric Field Strength Measurement F4 Connecting a dipole antenna (option) to the RF input enables the measurement of the electric field strength. Other than the optional antenna is also available by creating the original compensation data. (Refer to “25.8 Writing of Original Compensation Data” for the details.) 45 [Antenna connection] [Measurement environment] Antenna M401 M402 M403 M404 M405 M406 Connect to RF INPUT. 2650A series * Turn the back to the signal source. [Specifications of dipole antenna (The antenna gain and VSWR are specified at the center of frequency range.)] Items M401 M402 M403 M404 M405 M406 Type Sleeve Sleeve Sleeve Sleeve ¼ λ whip Sleeve Frequency range 0.8 to 1GHz 1.25 to 1.65GHz 1.7 to 2.2GHz 2.25 to 2.65GHz 300 to 500MHz 4.7 to 6.2GHz Antenna gain >1dB >1dB >1dB >1dB >1dB >1dB VSWR < 1.5 < 1.5 < 1.5 < 1.5 < 1.5 < 1.5 Dimensions 7.5φ ×280mm 7.5φ ×280mm 7.5φ ×210mm 7.5φ ×210mm 8.0φ ×212mm 7.5φ ×152mm Weight Approx. 58g Approx. 60g Approx. 58g Approx. 56g Approx. 62g Approx. 54g 93 to 143 96 to 146 99 to 149 100 to 150 87 to 137 109 to 159 dBμV/m dBμV/m dBμV/m dBμV/m dBμV/m dBμV/m Reference level setting range (except for the minimum value in screen shift) * When M405 is used, the measurement errors will occur due to how to hold of instrument and influence of human body, because M405 is ¼ λwhip antenna. The error value will be several dB or more. In order to reduce the error, separate 2650A series from human body as much as possible. • Mode Selection and Measurement By pushing F1 (ANT), the antenna (M401/M402/M403/M404/M405/M406/USER) can be selected The measurement starts as soon as the antenna is selected. 46 * “E/F M40X” or “E/F USER” is displayed in MEAS area on the screen. * “USER” is the original compensation data which is created by the user. (Refer to “25.8 Writing of Original Compensation Data” for the details.) * The spectrum may exceed the area on the screen depending on the antenna gain compensation. The unit of amplitude axis automatically changes into [dBμV/m]. * The optimum center frequency and frequency span are automatically set according to the antenna. In addition, a spectrum other than the frequency range of the antenna is not displayed. • Directivity of Antenna (reference data) E plane: X-Y axis (X direction=0°) 0° 270° 90° 180° * The following are the data when the antenna is connected to RF input directly with no obstacles around. Actually, the directivity changes due to the human body when handling the unit. * However, the data of M405 is the reference data which is included the influence of the human body. M401 (900 MHz, E plane) Antenna gain vs. Frequency 47 M402 (1.5 GHz, E plane) Antenna gain vs. Frequency M403 (2 GHz, E plane) Antenna gain vs. Frequency 5.5 5 ANT Gain (dBi) 4.5 4 3.5 3 2.5 2 1.5 1 0.5 1.7 1.8 1.9 2 2.1 2.2 Frequency (GHz) M404 (2.4 GHz, E plane) Antenna gain vs. Frequency 5.5 5 ANT Gain (dBi) 4.5 4 3.5 3 2.5 2 1.5 1 2.25 2.35 2.45 Frequency (GHz) 48 2.55 2.65 M405 (horizontal plane) Antenna gain vs. Frequency M406 (5.4 GHz, E plane) Antenna gain vs. Frequency 3.5 ANT Gain (dB) 3 2.5 2 1.5 1 4.70 4.95 5.20 5.45 5.70 Frequency(GHz) 19.5 Magnetic Field Strength Measurement The magnetic field distribution can be measured by using the magnetic field probe CP-2S (option). 49 5.95 F5 6.20 [Magnetic field probe connection] The tip of the magnetic field probe CP-2S is made of glass-ceramic board. Take care when handling the probe even though the strength of the glass-ceramic board is durable under normal operation. “Specifications of magnetic field probe CP-2S” (Refer to the operating manual of CP-2S for the details.) Item Specifications Frequency range 10 MHz to 3 GHz approx. 0.25 mm (depending on objects) Space resolution (-6 dB) 160 to 203 dBμA/m Reference level setting range: maximum Reference level setting range: minimum (except for the minimum value in screen shift) Measurement error • 110 to 153 dBμA/m approx. ±1 dB (probe simple substance) Mode Selection and Measurement By pushing F1 (PROBE), CP-2S or USER mode is selected. The measurement starts as soon as the probe is selected. * “M/F CP2S” or “M/F USER” is displayed in MEAS area on the screen. * “USER” is the original compensation data which is created by the user. (Refer to “25.8 Writing of Original Compensation Data” for the details.) The unit of amplitude axis automatically changes into [dBμA/m]. * A spectrum other than the frequency range of the probe is not displayed. 50 19.6 Frequency Counter F6 This function currently not supported. 20. EMI Test (2651) 20.1 Additional Function for EMI Test Detection mode (Refer to “13.4 Setting of Detection mode”) SWEEP By pushing POS F6 SMPL NEG , the detection mode can be set. QP AV In the 2651, QP detection and AV detection are added for EMI measurement. POS (Positive Peak) : The spectrum of the maximum value between the sample points SMPL (Sample) : The spectrum of the momentary value between the sample points NEG (Negative Peak) : The spectrum of the minimum value between the sample points QP (Quasi Peak) : The spectrum of the quasi peak value between the sample points AV (Average) : The spectrum of the average value between the sample points As for QP detection, the following characteristics are chosen according to RBW settings. (based on CISPR16) RBW • charging dis-charging meter time constant time constant time constant 9kHz 1ms 160ms 160ms 120kHz 1ms 550ms 100ms Preset (Initialization) (Refer to “18. Save / Load”) In the 2651, the radiated emission measurement and the conducted emission measurement are added to the preset as a default setting. By pushing SAVE/LOAD F6 , the menu is displayed F1 NORMAL : The initial parameters of normal mode are set. F2 EMI-C : The initial parameters of conducted emission measurement are set. F3 EMI-R : The initial parameters of radiated emission measurement are set In the radiated mission measurement, “USER” is selected as an antenna. It is necessary to input the compensation data of antenna beforehand. 51 20.2 EMI Test The QP detection is usually used in both of the radiated and conducted emission measurements, and the AV detection is usually used in the conducted emission measurement. The measurement time can be shortened by using them in the final measurement to the spectrums narrowed by the PK detection. Conducted Emission Measurement The conducted emission discharged through the power supply line is measured. In this measurement, LISN* (Line Impedance Stabilization Network) device is needed. The connection is shown in the figure below. Please refer to the manual of LISN for details of the connection and notes. Power Supply EUT LISN * 2651 1. Turn on the power of the 2651 after the connection. 2. Set the initial parameters of conducted emission measurement by pushing SAVE/LOAD F6 F2 Center Frequency : 25.5 MHz Frequency span : 50 MHz RBW : 9 kHz VBW : 1 MHz Sweep time : 3 sec Detection mode : Positive peak mode . The setting parameters are as follows. 3. Confirm whether the connection and the operation are correct by supplying the power to the EUT and measuring. 4. Set the number of times of the sweep in the MAX HOLD mode by operating CALC F2 . 5. Search the frequency of disturbance noise that exceeds the AV or QP limits by using the marker function. 6. Set the center frequency to the point that exceeds the limits, the SPAN to 2 MHz and the SWEEP to 0.1 sec. And measure the frequency accurately. 52 7. Moreover, measure the frequency detected in the above with QP or AV detection, then the SPAN is 200 kHz and the SWEEP is 10 sec. Radiated Emission Measurement The electric field strength of disturbance noise that EUT radiates in the air is measured. Antenna EUT 2651 1. Set the compensation data of the antenna beforehand. Refer to “25.8 Writing original compensation data” for the details. 2. Turn on the power of the 2651 after connection. 3. Set the initial parameters of radiated emission measurement by pushing SAVE/LOAD . The setting parameters are as follows. F6 F3 Center Frequency : 515 MHz Frequency span : 1 GHz RBW : 120 kHz VBW : 1 MHz Sweep time : 0.3 sec Detection mode : Positive peak mode 4. Confirm whether the connection and the operation are correct by supplying the power to the EUT and measuring. 5. Set the number of times of the sweep in the MAX HOLD mode by operating F2 CALC . 6. Search the frequency of disturbance noise that exceeds the QP limits by using the marker function. 7. Set the center frequency to the point that exceeds the limits, the SPAN to 50MHz and the SWEEP to 30 msec. And measure the frequency accurately. 8. Moreover, measure the frequency detected in the above with QP detection, then the SPAN is 1MHz and the SWEEP is 30 sec. 53 EMI standards (selected) Frequency Quasi Peak CISPR22 class A Limits of conducted disturbance at mains ports 0.15 MHz to 0.50 MHz 0.50 MHz to 30 MHz 79 dBuV 73 dBuV CISPR22 class B Limits of conducted disturbance at mains ports 0.15 MHz to 0.50 MHz 0.50 MHz to 5 MHz 5 MHz to 30 MHz 66 to 56 dBuV 56 dBuV 60 dBuV 56 to 46 dBuV 46 dBuV 50 dBuV Decreasing linearly with the logarithm of the frequency CISPR22 class A Limits of radiated disturbance 30 MHz to 230 MHz 230 MHz to 1000 MHz 1000 MHz to 3000 MHz 3000 MHz to 6000 MHz 40 dBuV/m 47 dBuV/m 76 dBuV/m 80 dBuV/m ----56 dBuV/m 60 dBuV/m Measurement distance 10 m CISPR22 class B Limits of radiated disturbance 30 MHz to 230 MHz 230 MHz to 1000 MHz 1000 MHz to 3000 MHz 3000 MHz to 6000 MHz 30 dBuV/m 37 dBuV/m 70 dBuV/m 74 dBuV/m ----50 dBuV/m 54 dBuV/m Measurement distance 10 m VCCI class A Limits of conducted disturbance at mains ports 0.15 MHz to 0.50 MHz 0.50 MHz to 30 MHz 79 dBuV 73 dBuV 66 dBuV 60 dBuV VCCI class B Limits of conducted disturbance at mains ports 0.15 MHz to 0.50 MHz 0.50 MHz to 5 MHz 5 MHz to 30 MHz 66 to 56 dBuV 56 dBuV 60 dBuV 56 to 46 dBuV 46 dBuV 50 dBuV Decreasing linearly with the logarithm of the frequency. VCCI class A Limits of radiated disturbance 30 MHz to 230 MHz 230 MHz to 1000 MHz 40 dBuV/m 47 dBuV/m ----- Measurement distance 10 m 1000 MHz to 3000 MHz 3000 MHz to 6000 MHz 76 dBuV/m 80 dBuV/m 56 dBuV/m 60 dBuV/m Measurement distance 3 m 30 MHz ~ 230 MHz 230 MHz ~ 1000 MHz 30 dBuV/m 37 dBuV/m ----- Measurement distance 10 m 1000 MHz to 3000 MHz 3000 MHz to 6000 MHz 70 dBuV/m 74 dBuV/m 50 dBuV/m 54 dBuV/m Measurement distance 3 m FCC part15 subpartB class A Limits of conducted disturbance at mains ports 0.15 MHz to 0.50 MHz 0.50 MHz to 30 MHz 79 dBuV 73 dBuV 66 dBuV 60 dBuV FCC part15 subpartB class B Limits of conducted disturbance at mains ports 0.15 MHz to 0.50 MHz 0.50 MHz to 5 MHz 5 MHz to 30 MHz 66 to 56 dBuV 56 dBuV 60 dBuV 56 to 46 dBuV 46 dBuV 50 dBuV Decreasing linearly with the logarithm of the frequency. FCC part15 subpartB class A Limits of radiated disturbance 30 MHz to 88 MHz 88 MHz to 216 MHz 216 MHz to 960 MHz over 960 MHz 39.1 dBuV/m 43.5 dBuV/m 46.4 dBuV/m 49.5 dBuV/m --------- Measurement distance 10 m FCC part15 subpartB class B Limits of radiated disturbance 30 MHz to 88 MHz 88 MHz to 216 MHz 216 MHz to 960 MHz over 960 MHz 40 dBuV/m 43.5 dBuV/m 46 dBuV/m 54 dBuV/m --------- Measurement distance 3 m VCCI class B Limits of radiated disturbance Average (Note: Information provided in this table serves as a reference only. B&K Precision is not liable for any damages due to any mistakes in the table.) 21. Screen Control When DSPL is pushed, the following function menu is displayed. 54 COLOR BACK LT BRIGHT COLOR1 ON 80 F1 F2 F3 F4 F5 F6 21.1 Setting Screen Display Color When F1 COLOR1 • • • is pushed, the color of screen display can be selected. COLOR2 MONO COLOR1 : For normal use COLOR2 : For printing screen MONO : Monochrome 21.2 ON/OFF Switching of LCD Backlight Use F2 button to toggle the backlight ON or OFF. 21.3 Adjusting Brightness of LCD Backlight Use F3 to set the brightness. It can be set in the range of 0 to 100. 22. Tracking Generator Mode (2652A) 22.1 Specification of T.G. Function Item Frequency range Output Level Output flatness Output impedance Output VSWR Output connector Specification 5 MHz to 3.3 GHz -10 dBm ± 1 dB @1 GHz(Fixed value) ±1.5 dB 50 Ω Less than 2.0 N(J) connector 55 22.2 Description of I/O Connector 1) Input connector N (J) connector Input for an external signal Make sure that the total power of input signals does not exceed +27 dBm. 2) Output connector N (J) connector It is an output terminal of Tracking Generator. *Please set to “TG : OFF” to prevent the influence of the leak from the Tracking Generator in case of disuse of the T.G. function.. 22.3 ON/OFF Switching of T.G. Function SWEEP When is pushed, the following function menu is display. SWEEP AUTO MANUAL F1 1. When F2 F6 ALL AUTO F3 is pushed, T.G. MODE is set. 56 DET TRIG T.G. SMPL INT MODE F4 F5 F6 T.G. NORM ON ON F1 F2 2. Each time F1 F3 F4 F5 F6 is pressed, T.G. output is alternately switched to ON or OFF. 22.4 Normalizing Function NORM ON: The input level is made flat to the red line on the screen. 1. When SWEEP 2. When F6 is pushed, the same function menu as the previous item is displayed. is pushed, TG. MODE is set. F2 3. Each time is pushed, the normalizing function is alternately switched to ON or OFF. If the normalizing function is switched to ON, “NORM ON” is displayed on the screen. * If the setting is changed as follows, the normalizing function is automatically turned off. · The span is expanded. · The center frequency is changed beyond the range normalized. ( When SPAN is changed from FULL SPAN according to center frequency, it is turned off.) · The magnetic field strength measurement is selected. · The AUTO tuning is executed. · The power supply is turned off. · The presetting is executed. * When the scale is 2 dB or 5 dB, the normalizing function does not operate correctly if the spectrum level is not displayed at a proper position on the screen. 57 23. Storage/Print Screen Image COPY The following function menu is displayed when is pushed. AREA PRINT Bmp → USB MEM → USB WHOLE EXECT COPY EXECT F1 F2 F3 F4 F5 F6 23.1 Selection of Image Area When F1 is pushed, the image area to be stored or printed can be selected. WHOLE : the whole screen image is stored or printed. SPECT : only the spectrum display area is stored or printed. 23.2 Print on Printer When pushing F2 after connecting the printer (option), the area selected in 23.1 is printed. 23.3 Storage into USB Memory When pushing F3 after connecting USB memory (removable storage) to this unit, the area selected in 23.1 is stored in USB memory in BMP (bit map) format. As for the file name, the number is automatically set and incremented in the form “2650A_001.bmp”. In the case when some characters are written in the label area, the file name will consist of it and the number put automatically such as “LABEL001.bmp”. The folder “2650A_IMG” is automatically generated and these files are stored inside. To change the color of the display before print, refer to “21. Screen Control”. 58 ※ Once you disconnect, then reconnect the same or a different USB flash memory drive, the 2650A series will not automatically recognize the new USB drive. After connecting the drive, you first must press the Save/Load, followed by F5 key (USB) in order for the 2650A to "see" the new drive, then proceed with copying data to the drive. 23.4 Transferring Internal Data to USB Memory in Lump Sum F5 When pushing after connecting USB memory (removable storage) to this unit, the data stored in the internal memory with SAVE/LOAD function are transferred to USB memory in a lump sum. During the transfer process, the screen on the lower right corner will display “Saving”. Wait until it disappears, indicating that transfer is complete, before continuing operation. The folder “2650A_SaveAll” is automatically generated and these files are stored inside. ※ Once you disconnect, then reconnect the same or a different USB flash memory drive, the 2650A series will not automatically recognize the new USB drive. After connecting the drive, you must first press the Save/Load key, followed by F5 key (USB) in order for the 2650A to "see" the new drive, then proceed as normal. 23.5 USB Printer (option) The 2650A/2651 series enables a hard copy of the screen by connecting a USB printer (option) to USB A plug with the included USB cable. 59 USB B plug USB A plug Printer * Turn on the power of the 2650A/2651 series unit first. After that, turn on the power of USB printer. Otherwise, it will not work correctly. 23.6 USB Memory USB memory can be used as a removable storage. 60 24. Utility Function When UTIL is pushed, the following function menu is displayed. LABEL F1 MENU BUZZER CLOCK OFF ALWAYS CONFIG F2 F3 F4 F5 F6 F1 Label Function : Enters the label menu for customizing filename. F2 Menu Off : Turns off menu and active area display. F3 Buzzer Setting : Sets the condition of the buzzer sound. F4 Clock Function Setting : Sets the built-in clock. 24.1 Label Function When UTIL F1 abc 012 F1 ABC F2 F3 is pushed, the following function menu is displayed. @%* BACK SP ENTER + ← → F4 F5 F6 1. The kind of character to be written is selected with F1 to F4 . F1 012 : 0 to 9 (numeral) F2 abc : a to z (lower case alphabet) F3 ABC : A to Z (upper case alphabet) F4 @%* : Special characters ( ! ” # $ % & ’ ( ) * + , - . / : ; < = > ? @ [ ¥ ] ^ _ ` { Ω } µ) *Note: Certain special characters may not be recognized or valid as a filename. 2. A block cursor will be displayed in the label display area. By rotating , a number, small letter alphabet, capital letter alphabet or special character will be indicated on the cursor position. Turn the knob until the desired label character is displayed. 3. When F6 is pushed, the cursor position will move right by one character. And the previous character is set. 61 F5 4. When is pushed, the cursor position will move left by one character. To change the character, turn the encoder. To delete, press F5 again. Characters previously entered can be deleted by consecutively pushing F5. 5. When finished, press to exit the label menu. UTIL 24.2 Menu Off By pushing F2 , the display of the function menu and the active area can be turned off temporarily. 24.3 Buzzer Setting By pushing F3 , the buzzer sound can be set to beep when keys are pressed or rotary encoder is turned. The following three options are selectable by pressing F3 until the desired option is displayed. OFF : The buzzer is off. ALARM : The buzzer will sound off when an incorrect setting is made. ALWAYS : The buzzer will sound whenever a key or the rotary encoder is operated. ※ When the battery voltage becomes low during battery operation, the buzzer will sound. (Even if OFF is selected, it will sound.) 24.4 Setting the Clock When UTIL F4 is pushed, the following function menu is displayed. YEAR MONTH DATE HOUR MIN 08 JUN 30 23 50 F1 F2 F3 F4 F5 ENTER F6 The year, month, day and time are displayed below the screen. (Refer to “4. Explanation of Screen”) Set the year, month, day and time when 2650A/2651 series is used for the first time. The time information is updated even if the power is turned off. 62 1. By rotating , the values for a selected parameter (choosen by pressing any button between F1 and F5) can be changed. 2. F1 Used to set the year. Two last digits of the year are displayed. This can be set from 00 to 99. F2 Used to set the month. This can be set from 1 to 12. F3 Used to set the date. This can be set from 1 to 31. F4 Used to set the hour. It is displayed in twenty-four hour format. Values can be set from 1 to 24. F5 Used to set the minute. 3. By pushing F6 , the values which are set from item 2. above are saved. The values are updated only when this key is pushed. * The clock function of the 2650A/2651 series is driven by a dedicated LSI, and the power is supplied by a built-in lithium battery. 63 25. USB Device Function 25.1 Outline The 2650A/2651 series is equipped with two kinds of USB connecters; A and B plugs. The A plug is for USB host and is connected to USB devices such as USB memory or printer. The B plug is for USB device and is connected to USB host such as a personal computer. The device function is explained in this chapter. As for the host function using USB A plug, refer to “23. Storage and print of screen image”. 25.2 How to Connect When using the USB device, connect with the included USB cable as illustrated USB A plug USB B plug 25.3 Installation of Driver An instrument specified USB driver is necessary in order to control the 2650A/2651 series with a PC via USB interface, and should be installed in the PC prior to using the software. The driver along with instructions can be downloaded from our website www.bkprecision.com. (Go to the Support section and select download). After the downloaded file is unzipped, the 2650A/2651 series is connected to a PC with the USB cable and then the power is turned on. The detection wizard for the USB driver starts on the PC screen the moment the power of the 2650A/2651 series is turned on, and install it following this wizard. 25.4 Sample Program Please contact us at www.bkprecision.com to request a sample code which demonstrates how to write a custom program using the commands in the following section. 64 25.5 Explanation of Command * “CR(0D[HEX])+LF(0A[HEX])” is added to the end of every command. When the command is sent from PC, 2650A/2652A/2651 and 2658A return some responses, which include “OK” + CR + LF, “ERR” + CR + LF, or “(response to command)” + CR + LF. * By inputting “?” instead of “* *” for each command, the current setting parameters will be queried and a response of the value will be received by the PC. (Except for “ ---- Request” command and the command for inputting corrected data.) 1) Setting center frequency Command : FREQ* * * * * * * (* * * * * * *: Refer to “25.6 Input of frequency”) Example: FREQ1.235G Query: FREQ? 2) Request set marker Command : FREQSETMK * The center frequency is set according to the frequency of current marker position. 3) Setting frequency span Command : SPAN* * * * 2650A, 2652A, 2651: (* * * * = ZERO, 200K, 500K, 1M, 2M, 5M, 10M, 20M, 50M, 100M, 200M, 500M, 1G, 2G, FULL [unit : Hz]) 2658A : (* * * * = ZERO, 200K, 500K, 1M, 2M, 5M, 10M, 20M, 50M, 100M, 200M, 500M, 1G, 2G, 5G, FULL [unit : Hz]) Example: SPAN500K * When the unit is other than dBm, convert Query: SPAN? into dBm by using calculation formula in “9.8 Relation between reference level and Setting reference level ATT/AMP”. Command : REF* * * 4) (* * * = -60 to 10 [1 step, unit : dBm] ) Example: REF 5 Query: REF? 5) Setting reference level unit Command : UNIT * * * * (* * * * = DBM, DBUV, DBMV, DBV) Example: UNITDBUV 65 Command Unit DBM DBUV DBMV DBV dBm dBμV dBmV dBV 6) Setting RBW Command : RBW* * * 2650A, 2652A, 2658A : ( * * * * = 3K, 10K, 30K, 100K, 300K, 1M, 3M, AUTO, ALL [ unit : Hz ]) 2651 : ( * * * * = 3K, 9K, 30K, 120K, 300K, 1M, 3M, AUTO, ALL [ unit : Hz ]) * ALL : The optimum RBW, VBW, and sweep time are set based on the frequency span. * AUTO : The optimum RBW is set based on the frequency span. Example: RBW3M Query: RBW? 7) Setting VBW Command : VBW* * * * ( * * * * = 100, 300, 1K, 3K, 10K, 30K, 100K, 300K, 1M, AUTO, ALL [ unit : Hz ] ) * ALL : The optimum RBW, VBW and sweep time are set based on the frequency span. * AUTO : The optimum RBW is set based on the frequency span. Example: VBW300 Command Measuring function Query: VBW? CP Channel power measurement ACP Adjacent channel power measurement 8) Selecting Measuring Function OBW Occupied bandwidth measurement Command : MEAS* * * EF Electric field strength measurement (* * * = CP, ACP, OBW, EF, MF, MF Magnetic field strength measurement FC, OFF) FC Frequency counter (factory option) Example: MEASOBW OFF OFF (To change measuring function when in a different measurement mode, set function OFF first by sending MEASOFF) Query: MEAS? 9) Request measuring result Command : MEASRES * Example of measuring result Channel power measurement ----- POW: - 25.5 dBm Adjacent channel power measurement ----- L: - 47.7 dBc U: - 48.3 dBc Occupied bandwidth measurement ----- C: 1.45 G W: 20.00 k Frequency counter ----- FC: 2400.0000 M * If the frequency counter is not installed, “Invalid for F/C” is responded. * If the level of spectrum is low and unmeasurable, “Non Signal” is responded. 66 10) Setting mode for channel power measurement Command : CPMODE* * * * * * * ( * * * * * * * = TOTAL, BAND) Example: CPMODETOTAL Query: CPMODE? Command TOTAL BAND Mode The sum of power on the screen is measured. The sum of power in the band specified is measured. 11) Setting zone center frequency for channel power measurement Command : CPCNTR* * * * * * * ( * * * * * * *: = 0-500: screen position, center = 250) Example: CPCNTR300 Query: CPCNTR? 12) Setting zone width for channel power measurement Command : CPWIDTH* * * * * * * ( * * * * * * *: = 0-500: screen position, center = 250) Example: CPWIDTH200 Query: CPWIDTH? 13) Setting mode for adjacent channel power measurement Command : ACPMODE* * * * * Command (* * * * * = TOTAL, BAND, PEAK) TOTAL Example: ACPMODEPEAK BAND Query: ACPMODE? PEAK Mode TOTAL (total power method) BAND (in-band method) PEAK (reference level method) 14) Setting band offset for adjacent channel power measurement Command : ACPOFS* * * * * * * ( * * * * * * *: = 0-500: screen position, center = 250) Example: ACPOFS100 Query: ACPOFS? 15) Setting bandwidth for adjacent channel power measurement Command : ACPCHBW* * * * * * * ( * * * * * * *: = 0-500: screen position, center = 250) Example: ACPCHBW30 Query: ACPCHBW? 16) Setting reference band center frequency for adjacent channel power measurement Command : ACPREF* * * * * * * 67 ( * * * * * * *: = 0-500: screen position, center = 250) Example: ACPREF250 Query: ACPREF? 17) Setting reference bandwidth for adjacent channel power measurement Command : ACPREFBW* * * * * * * ( * * * * * * *: = 0-500: screen position, center = 250) Example: ACPREFBW50 Query: ACPREFBW? 18) Setting mode for occupied bandwidth measurement Command Command : OBWMODE* * ( * * : N%, DB) N% DB Example: OBWMODEN% Query: OBWMODE? 19) Setting N% RATIO for occupied bandwidth measurement Command : OBWRATIO* * * (* * *: 80.0 to 99.9 [ 0.1 step , unit : %] ) Example: OBWRATIO85.6 Query: OBWRATIO? 20) Setting XdB DOWN for occupied bandwidth measurement Command : OBWDB* * * ( * * *: 0.1 to 99.0 [ 0.1 step , unit : dB] ) Example: OBWDB45.3 Query: OBWDB? 21) Setting antenna for electric field strength measurement Command : EFANT* * * * Command ( * * * *: M401 / M402 / M403 M401 / M404 / M405 / M406 / USER) M402 Example: EFANTM405 M403 Query: EFANT? M404 22) Mode N% POWER mode XdB DOWN mode Antenna Setting data for M401 Setting data for M402 Setting data for M403 Setting data for M404 M405 Setting data for M405 M406 Setting data for M406 USER Setting data for user’s original antenna Transfer user-compensation data for electric field strength measurement Command : EFUSER* * * * * (Refer to “25.8 Writing of Original Compensation Data” for the details.) Example: EFUSER300M:0.0DBI,350M:1.0DBI 68 23) Setting probe for magnetic field strength measurement Command : MFPROBE* * * * ( * * * *: CP2S / USER) Example: MFPROBECP2S Query: MFPROBE? 24) Transfer user-compensation data for magnetic field strength measurement Command : MFUSER* * * * * (Refer to “25.8 Writing of Original Compensation Data” for the details.) Example: MFUSER300M:0.0DBI,350M:1.0DBI 25) Start and Stop calculation function Command : CALC* * * (* * *: OFF / MAX / MIN / AVE / OVR) Example: CALCMIN Query: CALC? Command Calculation OFF MAX MIN AVR OVR OFF MAX HOLD MIN HOLD AVERAGE OVER WRITE 26) Setting number of times to sweep for MAX HOLD Command : MAXNO* * * * ( * * * * : 2 / 4 / 8 / 16 / 32 / 64 / 128 / 256 / 512 / 1024 / 0) * 0 = unlimited) Example: MAXNO1024 Query: MAXNO? 27) Setting number of times to sweep for MIN HOLD Command : MINNO* * * * ( * * * *: 2 / 4 / 8 / 16 / 32 / 64 / 128 / 256 / 512 / 1024 / 0) * 0 = unlimited) Example: MINNO512 Query: MINNO? 28) Setting number of times to sweep for AVERAGE Command : AVENO* * * * ( * * * *: 2 / 4 / 8 / 16 / 32 / 64 / 128 / 256 / 512 / 1024 / 0) * 0 = unlimited) Example: AVENO16 Query: AVENO? 29) Setting number of times to sweep for OVERWRITE Command : OVWNO* * * * ( * * * *: 2 / 4 / 8 / 16 / 32 / 64 / 128 / 256 / 512 / 1024 / 0) * 0 = unlimited) Example: OVWNO128 Query: OVWNO? 69 30) 31) Setting display scale Command : SCALE* * ( * *: 2 / 5 / 10 ) Example: SCALE10 Query: SCALE? Command Display scale 2 5 10 2dB/div 5dB/div 10dB/div Setting sweep time Command : SWEEP* * * * ( * * * * : 10M / 30M / 0.1S / 0.3S / 1S / 3S / 10S / 30S / AUTO / ALL) Command Sweep time Command Sweep time 10M 30M 0.1S 0.3S 1S 10ms 30ms 0.1s 0.3s 1s 3S 10S 30S AUTO ALL 3s 10s 30s AUTO ALL AUTO Example: SWEEP0.1S Query: SWEEP? 32) 33) 34) Setting detection mode Command : DET* * * ( * * *: POS / NEG / SMP ) Example: DETPOS Query: DET? Setting trigger source Command : TRG* * * ( * * *: INT / EXT) Example: TRGEXT Query: TRG? Request AUTOTUNE Command : AUTO 35) Hold/Run function Command : HOLD Command : RUN 36) Request marker information Command : MKRRES Query: MKRRES? Command Detection mode POS NEG SMP QP AVG Positive peak mode Negative peak mode Sample mode QP mode (only for MSA438E) AVG mode (only for MSA438E) Command Trigger source INT EXT Internal External * The response is returned after tuning. * Example of returned data : 1.42G -15dBm 70 37) Setting marker mode Command : MKR* * * * * ( * * * * *: NORM / DELTA) Example: MKRDELTA Query: MKR? Command Marker mode NORM DELTA Normal marker Delta marker 38) Setting marker position by frequency The position of active marker is set by frequency. Command : NORMMKR* * * * * * ( * * * * * * *: Refer to “25.6 Input of Frequency”) Query: NORMMKR? 39) Setting marker position by number of points on horizontal axis The position of active marker is set by number of points on horizontal axis. Command : MKRPOSI* * * ( * * *: 0 to 500 ; 0 = far left, 500 = far right) Example: MKRPOSI40 40) Setting peak search mode Command : PEAK* * * * ( * * * * : NORM / ZONE) Example: PEAKZONE Query: PEAK? 41) Request peak search Command : PKSEARCH* * ( * *: 01 / 02 / 03 / 04 / 05 / 06 / 07 / 08 / 09 / 10 / 11) Example: PKSEARCH09 Command Peak search mode NORM ZONE Normal peak search Zone peak search Command Destination of marker 01 02 The maximum peak on the screen The 2nd peak on the screen ··· ··· 11 The 11th peak on the screen 42) Setting zone center frequency for peak search Command : PKCNTR* * * * * * * ( * * * * * * *: Refer to “25.6 Input of Frequency”) Example: PKCNTR1.345G Query: PKCNTR? 43) Setting zone width for peak search Command : PKWIDTH* * * * * * * ( * * * * * * *: Refer to “25.6 Input of Frequency”) Example: PKWIDTH256M Query: PKWIDTH? 71 44) Setting unit of marker Command : CONV* * * ( * * *: DBM / W / DBV / V / DBUVM / VM) Example: CONVDBUVM Query: CONV? 45) Request print on printer Command : PRTSIW USB printer connected to USB A plug prints. 46) Request for transfer of spectrum Command : SRS* * * * ( * * * *: CURR / 000 to 199) Example: SRSCURR Command Unit of marker DBM dBm W W DBV dBV V V DBUVM dBμV/m VM V/m Command Transferred spectrum CURR 000 Current spectrum Spectrum data of 000 ··· ··· 199 Spectrum data of 199 *The number of the commands is given to the saved file. *Refer to “25.7 Transfer of Spectrum Data” for the returned data. 47) Request for transfer of spectrum in USB memory Command : SRSU* * * * Command ( * * * *: 000 to 199) 000 Example: SRSU111 ··· 199 Transferred spectrum Spectrum data of 000 in USB memory ··· Spectrum data of 199 in USB memory * The number of the command is given to the saved file. * Refer to “25.7 Transfer of Spectrum Data” for the returned data. 48) Request for transfer of spectrum data of 1001 points Command : SRSF * Refer to “25.7 Transfer of Spectrum Data” for the returned data. 49) Request preset Command : PRESET Command ON OFF 50) Setting remote control Command : REMOTE* * * ( * * *: ON / OFF) Example: REMOTEON Query: REMOTE? 72 Remote control Operation by function key and encoder cannot be done. Control the unit with USB commands. Operation by function key and encoder can be done. USB commands are available * When the remote control is ON, “REMOTE” is displayed in the operating information area on the screen. ( Refer to “4. Explanation of Screen” for the details.) 51) 52) 53) 54) Single sweep Command : CAPT * It sweeps only once and will be in a HOLD state. Setting offset level Command : OFFSET* * * * * (* * * * *: -50.0 to 50.0 [0.1 step, unit: dB] ) Example: OFFSET-25.6 Query: OFFSET? Command Offset level 50 Offset level is set to 0dB. Setting input impedance 75 Offset level is set to 5.7dB. Command : IMP* * (* * : 50 / 75) Example: IMP75 Query: IMP? * When the input impedance is selected, the offset level is set as described above. Clearing spectrum data and parameter Command : MCLR* * * ( * * *: ALL / 000 to 199) Example: MCLRWALL Command * For internal memory only. ALL 000 Cleared data All of spectrum data Spectrum data of 000 ··· ··· 199 Spectrum data of 199 55) Setting character for label Command : LBL* * * ( * * *: The number of characters is 16 or less) Example: LBLsample_spectrum Query: LBL? 56) Setting clock Command : CLC * * * * * * * * ( * * * * * * * * : aabbccdd ; aa: two last digits of year, bb: month (01 to 12), cc: hour (00 to 23), dd: minute (00 to 59) Example: CLC0902111103 Query: CLC? 73 57) Setting tracking generator Command : TG* * * ( * * *: ON / OFF) Example: TGON Query: TG? 58) Setting normalizing function Command : NORM* * * ( * * *: ON / OFF) Example: NORMOFF Query: NORM? 59) Save/Load function Command : DEV*** ( * * *: MEN/USB) 60) Request On/Off of Offset Level Command: OFFSETOF? *Returned data: ON or OFF. 61) Request firmware version Command: VER 25.6 Input of Frequency The frequency is input as follows. ******* : 0.0k to 999.9k (0.1 step, unit: Hz) : 0.0M to 999.9M (0.1 step, unit: Hz) : 0.0000G to 3.3G (0.0001 step, unit: Hz) ---- 2650A, 2652A, 2651 : 0.0000G to 8.5G (0.0001 step, unit: Hz) ---- 2658A * The offset frequency and the zone width can be input only in the range decided by the center frequency and frequency span. If the value out of the range is input, an error occurs. * The offset frequency and the zone width change when the frequency span is changed. 25.7 Transfer of Spectrum Data 74 The spectrum data outputs as a numeric string separated by commas “,”. [**.**, **.**, ……, **.**] The unit is dBm, and it is available up to two decimal places. • Description String Explanation Example SPECT The data which follows the string "SPECT" is the spectrum data. SPECT * *, * *, · · · It is the spectrum data. This string consists of all data points separated by a comma “,” after each data value, and the string can have a total of ten data points per line. For example, transferring spectrum data of 1001 points require a total of 101 lines. -102.01, -102.03, · · ·, · · ·, -110.12, 25.8 Writing of Original Compensation Data When antennas or probes other than the option is used in electric field strength measurement or magnetic field strength measurement, it is necessary to write each original compensation data into the unit. Please write the data into the unit according to the following description. There are two methods for writing. Either use the 2650A PC Software or write a custom program using interface commands. 1) Preparation items * Windows PC (with USB interface) [The writing can be done with 2650A/2651 series unit only.] * 2650A PC software (Refer to 3) below) 2) Example of writing data As an example, the compensation data (antenna gain) of antenna M405 and the compensation data (compensation coefficient) of magnetic field probe CP-2S are shown below. * Compensation data (antenna gain) of antenna M405 Frequency Antenna gain 300MHz 0.0dBi 350MHz 1.0dBi 400MHz 1.4dBi 450MHz 1.4dBi 500MHz 0.0dBi * Compensation data (compensation coefficient) of magnetic field probe CP-2S Frequency Compensation coefficient 10MHz 100MHz 1GHz 2GHz 3GHz 86.7dB 69.2dB 50.7dB 44.9dB 40.1dB * Data of ten points or less can be written. 0Hz is not valid as a data point. 3) Using 2650A PC software for writing 1. Create the text file of compensation data. 75 Create a new text file, and open it with a text editor. Write the frequency and compensation data in the following format. * Format “frequency”: ”compensation data”, “frequency”: “compensation data”, · · · Example of M405 300M:0.0DBI,350M:1.0DBI,400M:1.4DBI,450M:1.4DBI,500M:0.0DBI * Write the unit with a capital letter as it is case sensitive. G (GHz) is also available. 2. Write the text file into the unit with 2650A PC software. Connect the personal computer to 2650A series with the included USB cable and turn on the power of the 2650A/2651 series. From the upper menu of the PC software, select [File] → [Write E/F User Data] in case of electric field strength measurement, or select [File] → [Write M/F User Data] in case of magnetic field strength measurement. When the text file created beforehand is selected, the data is written. * Install the specified USB driver in the personal computer prior to using the PC software. (Refer to “25.3 Installation of Driver”) 4) Method of using original program for writing 1. Prepare the USB communication software. Connect the personal computer to the 2650A/2651 series with the included USB cable and turn on the power of the 2650A/2651 series. 2. Write the data into the unit. Transfer the data in the following format with the USB communication software. * Format In case of electric field strength measurement; EFUSER “frequency”: ”compensation data”, “frequency”: “compensation data”, · · · In case of magnetic field strength measurement; MFUSER “frequency”: ”compensation data”, “frequency”: “compensation data”, · · · Example of CP-2S MFUSER10M:86.7DB,100M:69.2DB,1G:50.7DB,2G:44.9DB,3G:40.1DB * Write the unit with a capital letter as it is case sensitive. G (GHz) is also available. 3. When the writing ends correctly, “OK” is returned. 5) How to use Set the measuring function of the 2650A/2651 series to electric field strength measurement mode or magnetic field strength measurement mode. By pushing [MEAS] → [E/F ANT], electric field strength measurement mode is set. By pushing [MEAS] → [M/F PROBE], magnetic field strength measurement mode is set. Select “USER” from antennas or probes on the display by pushing [F1]. Then, the measurement by the written data will begin. * The written data remains even if power is turned off. * The measuring mode returns to a usual measurement mode when turning off power. 6) About antenna gain 76 In the following context, the antenna gain means an absolute gain. When the antenna gain is a relative gain, it can change into an absolute gain by adding +2.15 dB. Absolute gain [dBi] = Relative gain [dBd] + 2.15 dB As a reference, the conversion formula to electric field strength is indicated below: E = √(480π2 x Pa) / (Ga x λ2)) E: Electric field strength [V/m] Pa: Received electric power [W] Ga: Antenna gain [times] = 10(antenna gain [dBi] ÷ 10) λ : Wavelength [m] = (3 × 108) ÷ frequency [Hz] 26. Option  Dipole antenna M401 to M406 Connector : N (P) Refer to “19.4 Electric Field Strength Measurement” for the details.  Magnetic field probe CP-2S. Refer to “19.5 Magnetic Field Strength Measurement” for the details. Specification  USB printer Specification  Roll printer (10 rolls) Frequency range Space resolution Dimensions : : : Connectors : 10 MHz to 3 GHz approx.0.25 mm (depending on objects) outside 12 φ ×135 mm probe tip 2 mm(W)×1 mm(T) SMA(P) With AC adaptor and one roll of paper Refer to “23. Storage / Print of Screen Image” for the details. Printing method Paper Power source : : : Dimensions Weight : : For USB printer 77 Thermal line dot method 80 mm width thermal paper internal : AA-sized alkaline battery (4 pcs) external : 7.5 VDC/3 A (dedicated AC adapter) 134(W)×60(H)×180(D) mm approx.450 g (mainframe only) 27. Basic Performance Test (2650A/2651/2652A/2658A) To keep the quality of the unit, regular performance testing is recommended. This section describes a method and specification of basic performance testing. If a problem is found in the results of basic performance testing, or formal testing is required,please contact B&K Precision. [Connection diagram] Receiver for calibration Spectrum analyzer calibration unit 2650A/2651 series 27.1 Frequency Characteristics Adjust the output level of the spectrum analyzer calibration unit (thereafter, “calibration unit”) so that the displayed power value is -15dBm at each frequency for this unit, and measure the absolute value with a receiver for calibration (microwave power meter, etc.). Setting of 2650A/2652A/2651/2658A Center frequency Frequency span RBW *1) 50 kHz 200 kHz 10 kHz 100 kHz 200 kHz 30 kHz 1 MHz 2 MHz 100 kHz 10 MHz 10 MHz 3 MHz 100 MHz 10 MHz 3 MHz 1 GHz 10 MHz 3 MHz 2 GHz 10 MHz 3 MHz 3.3 GHz 10 MHz 3 MHz 6.2 GHz *2) 10 MHz 3 MHz 8.5 GHz *2) 10 MHz 3 MHz Measurement value Specifications Judgment Within Reference±2.6 dB±1dot Within Reference±2.6 dB±1dot Within Reference±2.6 dB±1dot Within Reference±2.0 dB±1dot Reference Within Reference±1.0 dB±1dot Within Reference±1.0 dB±1dot Within Reference±1.0 dB±1dot Within Reference±1.0 dB±1dot Within Reference±1.0 dB±1dot *1) RBW switching error is included at RBW other than 3 MHz. *2) 2658A only · Setting of 2650A/2652A/2651/2658A Reference level VBW Sweep time Detection mode Display scale : : : : : · Setting of calibration unit -15 dBm 1 MHz 1s SMPL 2 dB/div 78 Frequency : Same as a center frequency of 2650A/2652A/2651/2658A. Output power : Adjust the power indication of 2650A/2652A/2651/2658A to -15 dBm. 27.2 Accuracy of Reference Level Adjust the output level of the calibration unit so that the displayed value of this unit is the 0th div from the top, and calibrate the absolute value with the receiver for calibration (microwave power meter, etc.). Setting of 2650A/2652A/2651/2658A Reference level Specifications +10 dBm 0 dBm -10 dBm -15 dBm -20 dBm -30 dBm -40 dBm within ±1.4 dB±1dot within ±1.4 dB±1dot within ±1.4 dB±1dot within ±0.8 dB±1dot within ±1.4 dB±1dot within ±1.4 dB±1dot within ±1.4 dB±1dot Measurement value Judgment * Input attenuator switching error is included at the reference level other than -15 dBm. ·Setting of 2650A/2652A/2651/2658A Center frequency Frequency span RBW : : : 100 MHz 10 MHz 3 MHz VBW Sweep time Detection mode Display scale : : : : 1 MHz 1s SMPL 2 dB/div · Setting of calibration unit Frequency Output power : : 100 MHz Adjust it so that the indicated value of 2650A/2652A/2651/2658A is at the 0th div from the top. 27.3 Display Accuracy of Center Frequency Measure the frequency with the peak search function of 2650A/2652A/2651/2658A. Setting of 2650A/2652A/2651/2658A Center frequency Frequency span RBW 100 MHz 100 MHz 100 MHz 100 MHz 1 GHz 2 GHz 3.3 GHz *1 6.1 GHz *2 8.5 GHz *2 200 kHz 10 MHz 20 MHz 200 MHz 20 MHz 20 MHz 20 MHz 20 MHz 20 MHz 3 kHz 30 kHz 100 kHz 100 kHz 100 kHz 100 kHz 100 kHz 100 kHz 100 kHz *1 2650A/2652A/2651 only · Setting of 2650A/2652A/2651/2658A Reference level VBW Sweep time Detection mode Display scale : : : : : Measurement value Center frequency Specifications Judgment Frequency span within ±50 kHz±1dot ±RBW x 6% within ±360 kHz±1dot ±RBW x 20% *2 2658A only · Setting of calibration unit -15 dBm AUTO 1s SMPL 10 dB/div Frequency Same as a center frequency of 2650A/2652A/2651/2658A. Output power : -15 dBm * However, calibrate the signal generator in advance. 79 : 27.4 Display Accuracy of Frequency Span Adjust the frequency of the calibration equipment so that the peaks are at the positions of f1 and f9, and measure the frequencies of f1 and f9. Calculate from f1 and f9 the display accuracy of the frequency span. * f1: 1st div from the left on the spectrum display Setting of 2650A/2652A/2651/2658A f1 Measurement value Specifications Frequency span Center Frequency RBW 200 kHz 100 MHz 3 kHz within ±180 kHz ×3%±1dot 10 MHz 100 MHz 100 kHz within ±8 MHz ×3%±1dot 20 MHz 100 MHz 300 kHz within ±18 MHz ×3%±1dot 200 MHz 100 MHz 3 MHz within ±180 MHz ×3%±1dot 500 MHz 1 GHz 3 MHz within ±400 MHz ×3%±1dot 2 GHz 1 GHz 3 MHz within ±1.8 GHz ×3%±1dot FULL(3.3 GHz)*1 1.65 GHz 3 MHz within ±2.64GHz ×3%±1dot 2 GHz *2 4.8 GHz 3 MHz within ±1.8 GHz ×3%±1dot 2 GHz *2 7.4 GHz 3 MHz within ±1.8 GHz ×3%±1dot FULL(8.5 GHz)*2 4.25 GHz 3 MHz within ±7.65 GHz ×3%±1dot *1 2650A/2652A/2651 only · Setting of 2650A/2652A/2651/2658A Reference level VBW Sweep time Detection mode Display scale : : : : : f9: 9th div from the left on the spectrum display f9 Measurement value (f9 - f1) Judgment *2 2658A only · Setting of calibration unit -15 dBm AUTO 1s SMPL 10 dB/div Frequency : Output power : Adjust it to the positions of f1 and f9. -15 dBm 27.5 Linearity of Amplitude Axis Adjust the level of the calibration unit so that the peak is at the top of the amplitude axis (0th div), and regard the point set at that time as the reference. Gradually lower the output, starting from the reference, and measure the amplitude value of 2650A/2652A/2651/2658A. Setting of 2650A/2652A/2651/2658A Output of calibration unit Specifications XdBm (adjust it to the 0th div) Reference(-15 dBm) X-10 dBm Within -25 dBm±0.8 dB±1dot XdBm (adjust it to the 0th div) Reference(-15 dBm) X-5 dBm Within -20 dBm±0.4 dB±1dot XdBm (adjust it to the 0th div) Reference(-15 dBm) X-2 dB Within -17 dBm±0.2 dB±1dot Display scales 10 dB/div 5 dB/div 2 dB/div ·Setting of 2650A/2652A/2651/2658A · Setting of calibration unit 80 Measurement value Judgment Center frequency Reference level Frequency span RBW VBW Sweep time Detection mode : : : : : : 100 MHz -15 dBm 10 MHz 3 MHz 1 MHz 1s SMPL Frequency 81 : 100 MHz SERVICE INFORMATION Warranty Service: Please go the support and service section on our website www.bkprecision.com to obtain a RMA #. Return the product in the original packaging with proof of purchase to the address below. Clearly state on the RMA the performance problem and return any leads, probes, connectors and accessories that you are using with the device. Non-Warranty Service: Please go the support and service section on our website www.bkprecision.com to obtain a RMA #. Return the product in the original packaging to the address below. Clearly state on the RMA the performance problem and return any leads, probes, connectors and accessories that you are using with the device. Customers not on an open account must include payment in the form of a money order or credit card. For the most current repair charges please refer to the service and support section on our website. Return all merchandise to B&K Precision Corp. with pre-paid shipping. The flat-rate repair charge for Non-Warranty Service does not include return shipping. Return shipping to locations in North America is included for Warranty Service. For overnight shipments and non-North American shipping fees please contact B&K Precision Corp. B&K Precision Corp. 22820 Savi Ranch Parkway Yorba Linda, CA 92887 www.bkprecision.com 714-921-9095 Include with the returned instrument your complete return shipping address, contact name, phone number and description of problem. LIMITED THREE-YEAR WARRANTY B&K Precision Corp. warrants to the original purchaser that its products and the component parts thereof, will be free from defects in workmanship and materials for a period of three years from date of purchase. B&K Precision Corp. will, without charge, repair or replace, at its option, defective product or component parts. Returned product must be accompanied by proof of the purchase date in the form of a sales receipt. To obtain warranty coverage in the U.S.A., this product must be registered by completing a warranty registration form on our website www.bkprecision.com within fifteen (15) days of purchase. Exclusions: This warranty does not apply in the event of misuse or abuse of the product or as a result of unauthorized alterations or repairs. The warranty is void if the serial number is altered, defaced or removed. B&K Precision Corp. shall not be liable for any consequential damages, including without limitation damages resulting from loss of use. Some states do not allow limitations of incidental or consequential damages. So the above limitation or exclusion may not apply to you. This warranty gives you specific rights and you may have other rights, which vary from state-to-state. B&K Precision Corp. 22820 Savi Ranch Parkway Yorba Linda, CA 92887 www.bkprecision.com 714-921-9095 82 22820 Savi Ranch Parkway Yorba Linda, CA 92887 www.bkprecision.com © 2009 B&K Precision Corp. Printed in Japan 83
很抱歉,暂时无法提供与“M402”相匹配的价格&库存,您可以联系我们找货
