LC760
LC760
    B&K
    ALUMCASEW/FOAMPADDING
LC760 数据手册
Model 760DX Intelligent PH Meter Data Sheet ATC PROBE Model 760ATC PH electrode Model 760PH • Plug in the 760 to be a PH electrode Meter. • Range: 0 to 14 PH • Measuring Temp.: 0ºC to 100ºC DISSOLVED OXYGEN PROBE Model 760DOP • Plug in the 760 to be a professional Dissolved Oxygen Meter. • Range: 0 - 20.0 mg/L, 0.1 mg/L. • With automatic temperature: 0 - 50.0 ºC, 0.1 ºC/0.1 ºF. • Diaphragms & electrolyte included. • Plug in the 760 to be a ATC (Automatic Temp. Compensation) probe to gain the Max. possible accuracy. • Temperature range: 0 to 65 ºC, 32 to 149 ºF. CONDUCTIVITY PROBE Model 760CP • plug in the 760 to be a professional Conductivity Meter, • Conductivity : 2/20 mS, 2 ranges • Temperature : 0 to 60.0 ºC/0.1 ºF. • ATC & variable temp. compensation factor adjustment (0 to 5.0% per ºC). INTELLIGENT PH METER Model 760 • PH Meter with mV and “plug and play” function. • pH (0.00 to 14.00 pH), mV (± 1999 mV). • manual temp. compensation adj. or ATC via the optional temp. probe (760 ATC). • Be plugged with “plug and play” probes:760CP, 760DOP, 760ATC to be a professional Conductivity Meter, ATC Meter, Dissolved Oxygen Meter. • RS-232, Hold, Memory record, ºC/ºF, 0.1 degree. • Patent obtained. SOFTWARE W/RS-232 CABLE Model AK 760 • For windows 95 & 98 • Data logging system, data recorder B&K Precision Corporation 22820 Savi Ranch Parkway, Yorba Linda, CA 92887 Tel: 714-921-9095, Fax: 714-921-6422 www.bkprecision.com PROTECTIVE CARRYING CASE Model LC 760 • Dimensions: (HxWxD) 2.75” x 15” x 10” Specifications subject to change without notice
LC760 价格&库存
很抱歉,暂时无法提供与“LC760”相匹配的价格&库存,您可以联系我们找货
