T-4000
T-4000
    AMPROBE(安博)
    AT-4000SERIESTRANSMITTER
T-4000 数据手册
Data Sheet AT-4000 CON Series Advanced Wire Tracer Amprobe’s reputation for out-performing circuit tracers has just gotten better. These new and improved advanced tracers combine features and functions to make your job easier. AT-4001 CON AT-4003 CON AT-4004 CON AT-4005 CON ■■ Extremely Advanced Wire Tracer with Soft Case Advanced Wire Tracer Advanced Wire Tracer w/Clamp-On Attachment Advanced Wire Tracer w/Clamp-On Attachment, Battery Booster & Charger easy to use ■■ One universal transmitter - automatically switches to work with either energized or non-energized systems ■■ Receiver not position sensitive - does not need to be rotated in order to provide accurate readings No hassle warranty ■■ Precise ■■ Traces live wires buried or hidden behind walls No waiting. ■■ Traces energized and non-energized (open, broken) wires No shipping charges. ■■ Performs Our commitment to high-quality products and customer service is demonstrated by our industry exclusive “No Hassle” warranty. In the unlikely event that an Amprobe Test Tool requires warranty service, any of our local dealers are authorized to replace it, on the spot. (note: $500 MSLP limit) sensitivity adjustment ■■ Locates tests without having to interrupt power breakers, neutrals, and ground lines ■■ Locates & traces wires in walls, floors, conduit, computer cables, etc. ■■ Pinpoints shorts, ground faults and broken wires ■■ Does not interfere with sensitive electronic equipment ■■ Battery Booster strengthens signal for open tracing ■■ Clamp-on attachment injects signal for non-contact operation ■■ No hassle one-year warranty Patent #6,940,289 Amprobe® Test Tools www.Amprobe.com Data Sheet AT-4000 CON Series Advanced Wire Tracer General Specifications Transmitter Operating Voltage: Operating Frequency: Receiver Range Short Mode (in air): Receiver Range Open Mode (in air): Operating Temperature: Storage temperature: Case Material: Case Size: Weight (AT-4005 CON): R-4000 CON Receiver Detectors: Sensitivity: Short Mode performance: Open Mode performance: 50HZ, 60HZ, and 400HZ Rejection: Power Source: Display: Case: Weight: T-4000 Transmitter Operating voltage: Operating frequency: Duty Cycle: Case: Display: Weight: Current Output of the Signal: Fuse: Signal Output (9V supply): Battery: A2202 Clamp-on Transmitter Accessory Operating Frequency: Case Breakdown Voltage: Maximum Wire size: Battery: T-4000 B2024 Battery Pack Type: Capacity: Rechargeable Time: Fuse: B2025 Recharger/Converter Input: Output: Amprobe® Test Tools 9-600 VAC 32.786 kHz 20’ in air from the traced wire under test conditions 12’ in air from the traced wire under test conditions -18°C to 49°C (0 to 120°F) -40° to 66°C (-40° to 150°F) ABS 14x6.7mm) 0.55” x 0.26”) 8.20 lbs. Electromagnetic Coil Array pick up for short mode. Electrostatic plate pick up for open mode. Low, Mid, High gain with precise sensitivity adjustment (thumbwheel). Over 20’ in air from the traced wire under test conditions. Over 12’ from the traced wire in air under test conditions. 120db 9V alkaline battery 10 LEDs Flame retardant ABS 0.5 Lb. (113g) 9-600 volts 32.768 KHZ Transmit 2 pulses with a duration of 0.0625S each, every 0.5 seconds Flame retardant ABS LCD (Liquid Crystal Display) 0.32 LB (143.5g) Low Mode: 11 mA average, 30 mA peak Medium Mode: 12 mA average, 36 mA peak High Mode: 13 mA average, 63 mA peak Fast acting 250 mA @ 1000V (6X46mm) P/N: FA6X46MM High setting: 0.74 VAC Medium setting: 0.61 VAC Low setting: 0.53 VAC 9V alkaline- 24V jack will accept battery pack accessory (B2024 or B2025) 32.768KHZ as supplied by T-4000 3000 volts 2000 MCM or 2” dia. Cable None, power is supplied by T-4000 B2024 Battery Pack Nickel-Cadmium rechargeable (20 AA cells) 24-Volt, 600 mah 14 hours internal self-resetting 115VAC 24 VDC @350 mah www.Amprobe.com Data Sheet AT-4000 CON Series Advanced Wire Tracer Optional Accessories ATGC-1 MTL-90B, MTL-500, MTL-501 and TL36A Ground Coil Accessory Test Lead Accessories Included Accessories Model AT-4001 CON Model AT-4003 CON Model AT-4004 CON Model AT-4005 CON Carrying Case Soft SV-1000 Hard CC-AT-4000 Hard CC-AT-4000 Hard CC-AT-4000 n n n n Receiver R-4000 CON Transmitter T-4000 n n n n Carrying Case CC-AT-4000 n n n n 110V Pigtail - Banana Plug Cord Set C2901 n n n n Alligator Clip - Banana Plug Cord Set C902 n n n n Ground Test Lead 25-ft. MTL-G n n n n Alligator Clip for Ground Lead TL36A n n n n n n Clamp-On Transmitter Accessory A2202 Rechargeable Battery Pack B2024 n Battery Pack Recharger B2025 n www.Amprobe.com AT-4000 CON Series Advanced Wire Tracer Data Sheet Amprobe® Test Tools website: www.Amprobe.com email: info@amprobe.com Everett, WA 98203 tel: 877-AMPROBE Amprobe® Test Tools Europe In den Engematten 14 79286 Glottertal, Germany Tel.: +49 (0) 7684 8009 - 0 Amprobe® Test Tools ©2007 Amprobe Test Tools. All rights reserved. 9/2007 3128839 Rev A www.Amprobe.com Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: AMPROBE: B2024 B2025 T-4000
T-4000 价格&库存
很抱歉,暂时无法提供与“T-4000”相匹配的价格&库存,您可以联系我们找货
