RCNL25R0F11R0KTT
RCNL25R0F11R0KTT
    ATC
    RES ARRAY 25 OHM 11PF 0402
RCNL25R0F11R0KTT 数据手册
RC EQUALIZER NETWORK ATC // AVX RC Equalizer Network Features: • EIA 0402 Case Size* • Parallel Configurations • Power Rating: 125 mW • Operating Temperature: -55°C to +125°C • Laser Trimmed Resistors • RoHS Compliant *Contact the factory for other EIA Sizes ATC // AVX Thin Film Technologies is pleased to introduce the Resistor Capacitor Network (RCN). This unique device provides an excellent RC network solution for RF equalization applications. The RCN is built in a single EIA package using our unique Glass wafer Sandwich Flexiterm (GSFT) Technology. It is supplied as a parallel RC combination network. Applications: Markets: • Optical Transceiver Modules • Opto-electronics • Telecom • Broadband Receiver • Broadband Jamming for EW • TOSA / ROSA • Military • Instrumentation and Test Capacitor Material Resistor Material Thin Film Resistors TaN Typical Sheet Resistivity (ohm/sq) 10 to 100 TCR (ppm/°C, -25 to 125°C) -100 to -150 Stability (Change after 1000 hours @ 125°C) 1.0% Specifications Material SiON pF/mm Typical 50 to 100 BDV (v/µm) 600 DF ≤0.1% TCC (ppm/°C, -25 to 125°C) ±60 Kit Values RC Detail Package Size EIA 0402 Part Number Resistance (Ohms) Capacitance (pF) Design Glass wafer sandwich RCNL25R0F00R5KTT 25 0.5 Termination Flexiterm® (Ag/Epoxy), NiSn plated RCNL25R0F01R0KTT 25 1.0 Power Rating 125 mW RCNL25R0F02R0KTT 25 2.0 Operating Temperature Range -55°C to +125°C RCNL25R0F03R0KTT 25 3.0 Resistor: 1-5%; Capacitor: 5-20% RCNL25R0F04R5KTT 25 4.5 Tolerance RCNL25R0F05R0KTT 25 5.0 Resistor Range 10 to 50 Ω (typical) RCNL25R0F06R5KTT 25 6.5 Capacitor Range 1 to 50 pF (typical) RCNL25R0F11R0KTT 25 11 For other RC Combinations consult factory. ATC # 001-1131 Rev B, 7/14 RC EQUALIZER NETWORK Environmental Tests Mechanical Dimensions W L T t Size (EIA) 0402 Length (L) Width (W) .039 ±.004 .020 ±.004 (1.00 ±0.10) (0.50 ±0.10) t Thickness (T) .020 ±.004 (0.50 ±0.10) Terminal (t) .010 ±.006 (0.25 ±0.15) Reliability Test Criteria Life Test 1000 Hrs. @ 125°C @ 50 mW 85/85 Temp./ Humidity Breakdown 1080 Hrs. @ 50 mW Thermal Cycle 100 cycles @ -40 to 125°C Termination Strength 200 g for 50 seconds (Dage Tester) inches (mm) ATC Part Number Code ATC RCN L 25R0 F 50R0 J T T Series Packaging: T = Tape & Reel Case Size - 0402 Termination T = NiSn Plated Resistance Value (Ω) 3 significant digits R= decimal point Capacitance Tolerance J=5%, K=10%, M=20% Capacitance Value (pF) 3 significant digits R= decimal point Resistance Tolerance F= 1% The above part number code refers to an RCN, Case Size L, 25 Ohms, F (1%) resistance tolerance, 50 pF, J (5%) capacitance tolerance, T termination, with tape and reel packaging ATC accepts orders for our parts using designations with or without the “ATC” prefix. Both methods of defining the part number are equivalent, i.e., part numbers referenced with the “ATC” prefix are interchangeable to parts referenced without the “ATC” prefix. Customers are free to use either in specifying or procuring parts from American Technical Ceramics. Sales of ATC products are subject to the terms and conditions contained in American Technical Ceramics Corp. Terms and Conditions of Sale (ATC document #001-992 Rev. A 10/03). Copies of these terms and conditions will be provided upon request. They may also be viewed on ATC's website at www.atceramics.com/productfinder/default.asp. Click on the link for Terms and Conditions of Sale. ATC has made every effort to have this information as accurate as possible. However, no responsibility is assumed by ATC for its use, nor for any infringements of rights of third parties which may result from its use. ATC reserves the right to revise the content or modify its product line without prior notice. © 2013 American Technical Ceramics Corp. All Rights Reserved. ATC # 001-1131, Rev B, 7/14
RCNL25R0F11R0KTT 价格&库存
很抱歉,暂时无法提供与“RCNL25R0F11R0KTT”相匹配的价格&库存,您可以联系我们找货
