TBF-1608-245-R1N
TBF-1608-245-R1N
    SUSUMU
    FILTER BAND PASS BLUETOOTH 0603
TBF-1608-245-R1N 数据手册
TBF-1608-245-R1N THIN FILM BAND PASS FILTER 1. Feature 1-1 Thin Film Band Pass Filter 1-2 WLAN Band Application. 1-3 Ultra Low Profile 1-4 Lead Free, RoHS compliance 2. Part Number TBF — 1608 — (1) (2) Where 245 (3) — R1N (4) (1) TBF : Thin Film Band Pass Filter (2) Size : 4 digits of number ––1608 = 1.6×0.8 mm (3) Center Frequency : 245 = 2.45 GHz (4) Type Refer to Table 3-1 3. Ratings 3-1 Specifications Part Number TBF-1608-245-R1N Nominal Characteristics Impedance Nominal Center Frequency 50 Ω 2450MHz Bandwidth Insertion Loss 2400~2500MHz 1.7dB Max. at +25℃ 1.9dB max. at –40 ~ +85℃ 0.5dB max. Ripple in BW Attenuation 20.0dB min. at 1710 ~ 1910MHz 30.0dB min. at 4800 ~ 5000MHz 30.0dB min. at 7200 ~ 7500MHz VSWR in BW Power Capacity 2.0 Max. 500mW Max. 3-2 Operation Temperature: −40℃ to +85℃ 3-3 Storage Temperature: +15℃ to +35℃ UNLESS OTHERWISE SPECIFIED RELEASED BY ﹕2006-10-26 TOLERANCES ON ﹕ DESIGNED BY ﹕ X = ± CHECKED BY ﹕ X.X = ± APPROVED BY ﹕ X.XX = ± ANGLES ± HOLE DIA. ± SCALE ﹕ X UNIT ﹕ X TITLE : The Engineering Spec. for TBF-1608-245-R1N Band Pass Filter 乾坤科技股份有限公司 CYNTEC CO., LTD. THIS DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF CYNTEC CO., LTD. AND SHALL NOT BE REPRODUCED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS OR DEVICES WITHOUT PERMISSION DOCUMENT NO. TBFC245R1N-001 PAGE PAGE REV. A0 1 OF 8 4. Outline Dimension TOP VIEW BACK VIEW 0.4 MAX. 0.4 ± 0.1 0.2 ± 0.05 0.5 ± 0.15 (3) 0.6 ± 0.1 0.6 ± 0.1 (2) (1) 0.8 ± 0.1 (4) 0.25 ± 0.1 0.4 ± 0.1 0.2 ± 0.05 Terminal Configuration: 0.4 ± 0.1 Unit : mm 1.6 ± 0.1 Terminal No. Terminal Name (1) GND (2) GND (3) Input (4) Output 5. Electrical Performance UNLESS OTHERWISE SPECIFIED RELEASED BY ﹕2006-10-26 TOLERANCES ON ﹕ DESIGNED BY ﹕ X = ± CHECKED BY ﹕ X.X = ± APPROVED BY ﹕ X.XX = ± ANGLES ± HOLE DIA. ± UNIT ﹕ X SCALE ﹕ X TITLE : The Engineering Spec. for TBF-1608-245-R1N Band Pass Filter 乾坤科技股份有限公司 CYNTEC CO., LTD. THIS DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF CYNTEC CO., LTD. AND SHALL NOT BE REPRODUCED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS OR DEVICES WITHOUT PERMISSION DOCUMENT NO. TBFC245R1N-001 PAGE 2 PAGE REV. A0 OF 8 6. Recommended Land Pattern GND 50Ω I/P O/P 50Ω e f GND a bc φ0.3 0.20 0.13 0.12 0.30 0.40 Unit : mm d UNLESS OTHERWISE SPECIFIED RELEASED BY ﹕2006-10-26 TOLERANCES ON ﹕ DESIGNED BY ﹕ X = ± CHECKED BY ﹕ X.X = ± APPROVED BY ﹕ X.XX = ± ANGLES ± HOLE DIA. ± SCALE ﹕ X UNIT ﹕ X TITLE : a b c d e The Engineering Spec. for TBF-1608-245-R1N Band Pass Filter 乾坤科技股份有限公司 CYNTEC CO., LTD. THIS DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF CYNTEC CO., LTD. AND SHALL NOT BE REPRODUCED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS OR DEVICES WITHOUT PERMISSION DOCUMENT NO. TBFC245R1N-001 PAGE PAGE REV. A0 3 OF 8 7. Reliability Test 7-1 Electrical ITEM Temperature Characteristics Specification and Requirement Satisfy electrical characteristics Test Method Solder the sample on PCB. Exposure at each temperature, -40℃, -20℃, 0℃, +25℃, +50℃, +85℃ for 30minutes 7-2 Mechanical ITEM Specification and Requirement Test Method Solderability The Surface of terminal immersed shall Solder bath : be minimum of 95% covered with a new After immersing in flux, dip in 245 ± coating of solder 5℃ molten solder bath for 2 ± 0.5 seconds Resistance to solder Heat Satisfy electrical characteristics without (1) Pre-heat : 100 ~ 110℃ for 30 distinct deformation in appearance seconds (2) Immersed at solder bath of 270 ± 5 ℃ for 20 ± 1 seconds Satisfy electrical characteristics without Vibrate as apply 20 to 2,000Hz, 186m/s2 Mechanical damage such as break (19G) acceleration 1.5mm amplitude for 2 hours in each of three (X, Y, Z) axis (total 6 hours). Satisfy electrical characteristics without (1) Break value : 490 N mechanical damaged such as break (2) Duration of pulse : 11ms (3) 3 times in each positive and negative direction of 3 mutual perpendicular directions. Vibration Shock Bending Test Satisfy electrical characteristics without Bending value : 3mm for mechanical damage such as break 30 ± 1 seconds Solvent Resistant Marking should be legible without (1) Solvent : Trichloroethane or Isopropyl mechanical and distinct damage in alcohol. appearance (2) Immersed in solvent at room temperature for 90 seconds Satisfy electrical characteristics without Drop the sample from a height of 1m to mechanical damage concrete ground for 10 times Drop Test UNLESS OTHERWISE SPECIFIED RELEASED BY ﹕2006-10-26 TOLERANCES ON ﹕ DESIGNED BY ﹕ X = ± CHECKED BY ﹕ X.X = ± APPROVED BY ﹕ X.XX = ± ANGLES ± HOLE DIA. ± SCALE ﹕ X UNIT ﹕ X TITLE : The Engineering Spec. for TBF-1608-245-R1N Band Pass Filter 乾坤科技股份有限公司 CYNTEC CO., LTD. THIS DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF CYNTEC CO., LTD. AND SHALL NOT BE REPRODUCED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS OR DEVICES WITHOUT PERMISSION DOCUMENT NO. TBFC245R1N-001 PAGE PAGE REV. A0 4 OF 8 7-3 Load Life ITEM Rapid change of temperature Humidity Test Specification and Requirement Satisfy Electrical Characteristics. Without distinct damage. Resistance Satisfy Electrical Characteristics. Without distinct damage. Low Temperature Store Satisfy Electrical Characteristics. Without distinct damage. High Temperature Store Satisfy Electrical Characteristics. Without distinct damage. UNLESS OTHERWISE SPECIFIED RELEASED BY ﹕2006-10-26 TOLERANCES ON ﹕ DESIGNED BY ﹕ X = ± CHECKED BY ﹕ X.X = ± APPROVED BY ﹕ X.XX = ± ANGLES ± HOLE DIA. ± SCALE ﹕ X UNIT ﹕ X TITLE : The Engineering Spec. for TBF-1608-245-R1N Band Pass Filter Test Method Perform 5 cycles as follows : −55℃ for 30minutes → room temperature for 3 minutes→ +125℃ for 30minutes → room temperature for 3 minutes. (Dwell time : 5 to 8 minutes) Precondition at +25℃ for 1hour. Let stand at temperature +40 ± 3℃, 90~95% relative humidity for 1,000 hours before taking final measurements. Solder the sample on PCB. Exposure at −55 ± 3℃ for 1,000 hours. 1~2 hours exposure at room temperature and humidity, prior to measurement. Solder the sample on PCB. Exposure at +85 ± 3℃ for 1,000 hours. 1~2 hours exposure at room temperature and humidity, prior to measurement. 乾坤科技股份有限公司 CYNTEC CO., LTD. THIS DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF CYNTEC CO., LTD. AND SHALL NOT BE REPRODUCED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS OR DEVICES WITHOUT PERMISSION DOCUMENT NO. TBFC245R1N-001 PAGE PAGE REV. A0 5 OF 8 8. Packaging 8-1 Material : Paper Carrier Tape 8-2 Dimensions 8-2-1 Tape packaging dimensions t D0 P Code Sprocket hole P1 C A D B P T Carrier cavity Pull Direction W Dimensions (mm) A 1.10 ±0.10 B C 1.90 ±0.10 1.75 ±0.1 D W 3.5 ±0.05 8.0 ±0.3 P P1 4.0 ±0.1 2.0 ±0.05 T t 0.65 ±0.10 0.6 ±0.10 D0 φ1.5 +0.1 −0.0 8-2-2 Setting Direction Direction mark UNLESS OTHERWISE SPECIFIED RELEASED BY ﹕2006-10-26 TOLERANCES ON ﹕ DESIGNED BY ﹕ X = ± CHECKED BY ﹕ X.X = ± APPROVED BY ﹕ X.XX = ± ANGLES ± HOLE DIA. ± SCALE ﹕ X UNIT ﹕ X TITLE : The Engineering Spec. for TBF-1608-245-R1N Band Pass Filter 乾坤科技股份有限公司 CYNTEC CO., LTD. THIS DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF CYNTEC CO., LTD. AND SHALL NOT BE REPRODUCED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS OR DEVICES WITHOUT PERMISSION DOCUMENT NO. TBFC245R1N-001 PAGE PAGE REV. A0 6 OF 8 8-2-3 Reel dimensions( Material : Polystyrene ) 2.0 ±0.5 13.0 ± 0.5 A N 21 ± 0.8 Label W1 W2 A N W1 W2 φ178 ± 2 φ60 ± 2 9.0 ± 0.3 11.4 ± 1.0 Unit : mm UNLESS OTHERWISE SPECIFIED RELEASED BY ﹕2006-10-26 TOLERANCES ON ﹕ DESIGNED BY ﹕ X = ± CHECKED BY ﹕ X.X = ± APPROVED BY ﹕ X.XX = ± ANGLES ± HOLE DIA. ± SCALE ﹕ X UNIT ﹕ X TITLE : The Engineering Spec. for TBF-1608-245-R1N Band Pass Filter 乾坤科技股份有限公司 CYNTEC CO., LTD. THIS DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF CYNTEC CO., LTD. AND SHALL NOT BE REPRODUCED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS OR DEVICES WITHOUT PERMISSION DOCUMENT NO. TBFC245R1N-001 PAGE PAGE REV. A0 7 OF 8 8-3 Peel force of top cover tape The peel speed shall be about 300 mm/minute The peel force of top cover tape shall be between 10 to 70g Top Cover Tape 165 ~ 180° 10 ~ 70g 8-4 Numbers of taping 4,000 pieces/reel 8-5 Label marking The following items shall be marked on the production and shipping Label on the reel. 8-5-1 Production Label (1) Part No. (2) Description (3) Quantity (4) Taping No. 8-5-2 Shipping Label (1) *Customer's name (2) *Customer's part No. (3) Manufacturer's part No. (4) Manufacturer's name (5) Manufacturer's country *Note : Item (1) and (2) are listed by request UNLESS OTHERWISE SPECIFIED RELEASED BY ﹕2006-10-26 TOLERANCES ON ﹕ DESIGNED BY ﹕ X = ± CHECKED BY ﹕ X.X = ± APPROVED BY ﹕ X.XX = ± ANGLES ± HOLE DIA. ± SCALE ﹕ X UNIT ﹕ X TITLE : The Engineering Spec. for TBF-1608-245-R1N Band Pass Filter 乾坤科技股份有限公司 CYNTEC CO., LTD. THIS DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF CYNTEC CO., LTD. AND SHALL NOT BE REPRODUCED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS OR DEVICES WITHOUT PERMISSION DOCUMENT NO. TBFC245R1N-001 PAGE PAGE REV. A0 8 OF 8
TBF-1608-245-R1N 价格&库存
很抱歉,暂时无法提供与“TBF-1608-245-R1N”相匹配的价格&库存,您可以联系我们找货
