51F-714-002
51F-714-002
    APITECHNOLOGIES
    Axial
    FILTERLC(PI)5500PFCHASSIS
51F-714-002 数据手册
The Electromagnetic Spectrum Innovator CONTACT US DATA SHEET Resin Sealed Bolt-in EMI Filters These EMI filters are easily mounted in a tapped hole or through-hole with supplied nut and lock-washer. The rugged case with resin seals at both ends provides excellent environmental protection. Primarily used in filtering signal/data lines, and DC power lines. Features • Wide range of sizes: 4-40 thread through 5/16-24 thread • Voltage ratings to 500 VDC/220 VAC (400 Hz) • MIL-PRF-15733 QPL filters available • Multiple circuit configurations: C, L, and Pi • Metric threaded filters available 4-40 C Circuit www.apitech.com | 855.294.3800 | communications@apitech.com | www.linkedin.com/company/api-technologies-corp-/ 1 The Electromagnetic Spectrum Innovator DATA SHEET Resin Sealed Bolt-in EMI Filters 4-40 C Circuit See Rated Voltage Pg. 1 125°C I for Amp Part Number Figure DC AC † SCI-9110-100 † 9900-381-6004 9900-381-6026 † 9900-381-6006 † 54-790-023 † 54790001X5F101M 54-790-019 9900-381-6013 54-790-020 SCI-9112-273 SCI-9110-273 54-790-022 † SCI-9112-503 SCI-9110-503 54-862-001 54-862-002 54-862-003 † 9900-381-6020 SCI-9122-101 SCI-9120-101 9900-381-6021 SCI-9122-102 SCI-9120-102 † 9900-381-6022 SCI-9122-502 SCI-9120-502 SCI-9122-103 SCI-9120-103 9900-381-6005 † 54-790-018 † 54-790-021 3 2 2 2 1 1 1 2 1 3 3 1 3 3 4 4 4 2 3 3 2 3 3 2 3 3 3 3 2 1 1 50 50 50 50 100 100 100 100 100 100 100 100 100 100 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 300 300 — — — — — — — — — — — — — — — — — — 115 115 — 115 115 — 115 115 115 115 — — — 10 10 10 10 10 10 10 10 10 3 10 10 3 10 10 10 10 10 3 10 10 3 10 10 3 10 3 10 10 10 10 A Min Cap In (mm) 10 pF 5000 pF 0.031 µF 0.045 µF 0.050 µF 100 pF ± 20% 2700 pF 2700 pF 5600 pF 0.027 µF 0.027 µF 0.027 µF 0.05 µF 0.05 µF 10 pF 100 pF 1000 pF 100 pF 100 pF 100 pF 500 pF 1000 pF 1000 pF 1200 pF 5000 pF 5000 pF 0.01 µF 0.01 µF 0.015 µF 1000 pF 0.01 µF 0.032 — — — — — — — — 0.016 0.020 — 0.016 0.020 — — — — 0.016 0.020 — 0.016 0.020 — 0.016 0.020 0.016 0.020 — — — (0.81) — — — — — — — — (0.41)* (0.51) — (0.41)* (0.51) — — — — (0.41)* (0.51) — (0.41)* (0.51) — (0.41)* (0.51) (0.41)* (0.51) — — — Minimum Insertion Loss (dB) 1 3 10 30 100 300 1 10 MHz MHz MHz MHz MHz MHz GHz GHz — — 12 14 15 — — — — 10 10 10 15 15 — — — — — — — — — — — — — — 7 — — — — 20 22 24 — — — — 20 20 20 24 24 — — — — — — — — — — — — 12 12 9 — 9 — 15 25 30 34 — 9 10 15 30 30 30 35 35 — — — — — — — — — 5 15 15 20 20 20 — 20 — 22 35 40 41 — 18 18 24 37 37 37 41 41 — — — — — — — 11 11 9 24 24 29 29 29 9 29 — 30 40 45 45 — 27 25 33 45 45 45 45 45 — 3 15 3 — — 15 20 20 20 33 33 38 38 35 20 38 — 35 45 50 50 10 33 33 37 45 45 50 50 50 — 10 25 10 10 10 20 28 28 28 37 37 45 45 45 28 45 10 45 55 55 60 20 35 40 40 55 55 55 60 60 10 20 35 20 20 20 35 28 28 35 40 40 50 50 50 28 50 10 55 60 60 60 25 35 50 40 60 60 60 60 60 10 28 40 28 20 20 40 40 40 45 50 50 55 55 60 40 50 * Tinned, steel leads. † Also available through APITech’s authorized distributors. www.apitech.com | 855.294.3800 | communications@apitech.com | www.linkedin.com/company/api-technologies-corp-/ 2 The Electromagnetic Spectrum Innovator DATA SHEET Resin Sealed Bolt-In EMI Filters 4-40 L and Pi Circuit Rated Voltage 125°C Part Number Figure DC AC † 51-729-305 † 51-729-312 SCI-3102-002 SCI-3102-000 SCI-3102-007 t 51-729-304 † SCI-3112-002 † SCI-3112-000 SCI-3112-007 SCI-3112-102 SCI-3112-100 SCI-3112-107 † 51-729-303 SCI-3122-002 SCI-3122-000 SCI-3122-007 50 50 50 50 50 100 100 100 100 100 100 100 200 200 200 200 — — — — — — — — — — — — — 115 115 115 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 A I Amp CKT 3 3 3 5 10 3 5 5 10 3 5 10 3 3 5 10 Pi Pi LB LB LB LB LB LB LB LB LB LB Pi LB LB LB Min Cap In (mm) 5500 pF 7000 pF 0.075 µF 0.075 µF 0.075 µF 0.022 µF 0.027 µF 0.027 µF 0.027 µF 0.05 µF 0.05 µF 0.05 µF 1500 pF 0.01 µF 0.01 µF 0.01 µF 0.018 0.018 0.016 0.016 0.025 0.018 0.016 0.016 0.025 0.016 0.016 0.025 0.018 0.016 0.016 0.025 (0.46) (0.46) (0.41)* (0.41) (0.64) (0.46) (0.41)* (0.41) (0.64) (0.41)* (0.41) (0.64) (0.46) (0.41)* (0.41) (0.64) Minimum Insertion Loss (dB) 1 3 10 30 100 300 1 10 MHz MHz MHz MHz MHz MHz GHz GHz — — 18 18 18 7 10 10 10 15 15 15 — — — — 7 8 25 25 25 17 20 20 20 24 24 24 — 12 12 12 14 15 37 37 37 27 30 30 30 35 35 35 5 21 21 21 40 40 42 42 42 34 38 38 38 42 42 42 15 30 30 30 60 65 52 52 52 43 45 45 45 54 54 54 42 41 41 41 70 70 55 55 55 47 45 45 45 56 56 56 65 45 45 45 70 70 70 70 70 55 65 65 65 70 70 70 70 70 70 70 70 70 70 70 70 55 70 70 70 70 70 70 70 70 70 70 * Tinned, steel leads. † Also available through APITech’s authorized distributors. www.apitech.com | 855.294.3800 | communications@apitech.com | www.linkedin.com/company/api-technologies-corp-/ 3 The Electromagnetic Spectrum Innovator DATA SHEET Resin Sealed Bolt-In EMI Filters 6-32 C, L, Pi/6-40 Pi Rated Voltage 125°C Part Number † 51-726-008 51-726-017 54-779-019 † 54779001X5F100M † 54779001X5U102P € 54-779-014 54-779-016 † 51-726-002 54-779-017 54-779-018 † 51-726-001 † 1289-001 † 1289-004 54-779-015 Figure DC AC 1 1 1 1 1 1 1 3 1 1 1 2 2 1 50 50 50 100 100 100 100 100 100 100 200 200 200 200 — — — — — — — — — — — — — — A I Amp CKT 3 3 10 10 10 10 10 10 10 10 3 10 10 10 Pi Pi C C C C C LB C C Pi Pi Pi C Min Cap In (mm) 5500 pF 9000 pF 0.10 µF 10 pF ± 20% 1000 pF 2700 pF 0.01 µF 0.022 µF 0.027 µF 0.050 µF 1500 pF 1500 pF 3000 pF 5600 pF 0.018 0.018 0.032 0.032 0.032 0.032 0.032 0.032 0.032 0.032 0.018 0.032 0.032 0.032 (0.46) (0.46) (0.81) (0.81) (0.81) (0.81) (0.81) (0.81) (0.81) (0.81) (0.46) (0.81) (0.81) (0.81) Minimum Insertion Loss (dB) 1 3 10 30 100 300 1 10 MHz MHz MHz MHz MHz MHz GHz GHz — — 22 — — — — 7 10 15 — — — — 7 8 31 — — — 9 17 20 24 — — — — 14 18 40 — — 9 20 27 30 34 5 5 8 15 30 45 44 — 10 18 29 34 37 41 15 15 15 24 55 65 47 — 21 27 38 43 45 45 42 40 50 33 70 70 55 — 28 33 45 50 50 50 65 60 65 37 70 70 65 10 28 35 50 60 55 60 70 60 70 40 70 70 65 10 28 35 50 60 60 60 70 60 70 40 † Also available through APITech’s authorized distributors. € Also available through APITech’s authorized European distributors/agents. www.apitech.com | 855.294.3800 | communications@apitech.com | www.linkedin.com/company/api-technologies-corp-/ 4 The Electromagnetic Spectrum Innovator DATA SHEET Resin Sealed Bolt-In EMI Filters 8-32 C Circuit Rated Voltage 125°C Part Number Figure SCI-9200-503 9950-381-6009 54-785-017 9950-381-6008 † 54713001X5F101M † 54713001X5U102P 54-785-013 SCI-9210-103 SCI-9210-273 † 54-785-005 54-785-016 54-785-011 54-785-012 SCI-9220-101 SCI-9220-102 SCI-9220-502 2 3 1 3 4 4 1 2 2 1 1 1 1 2 2 2 DC AC I Amp 50 50 50 70 100 100 100 100 100 100 100 150 150 200 200 200 — — — — — — — — — — — — — 115 115 115 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 Min Cap 0.05 µF 0.12 µF 0.21 µF 0.08 µF 80 pF 1000 pF 0.01 µF 0.01 µF 0.027 µF 0.05 µF 0.1 µF 2000 pF 5000 pF 100 pF 1000 pF 5000 pF Minimum Insertion Loss (dB) 1 3 10 30 100 300 1 10 MHz MHz MHz MHz MHz MHz GHz GHz 15 20 28 15 — — — — 10 15 20 — — — — — 24 30 37 24 — — 9 12 20 24 29 — 6 — — 6 35 43 45 37 — — 20 20 30 34 38 8 15 — — 15 41 45 50 41 — 11 29 29 36 41 44 17 24 — 11 24 45 55 55 51 — 20 38 38 45 45 47 26 33 — 20 33 50 55 60 51 10 28 45 45 50 50 55 32 37 10 28 37 60 55 70 55 20 28 50 50 55 60 65 34 40 20 28 40 60 55 70 55 20 28 55 50 60 60 65 35 40 25 28 40 † Also available through APITech’s authorized distributors. www.apitech.com | 855.294.3800 | communications@apitech.com | www.linkedin.com/company/api-technologies-corp-/ 5 The Electromagnetic Spectrum Innovator DATA SHEET Resin Sealed Bolt-In EMI Filters 8-32 L & Pi Circuit MIL-PRF15733 Number Part Number Fig. 51-712-069 € † 51-712-065 † 1250-054 † 1293-001 51-712-055 † 51-712-014 51-712-028 † 51-712-063* † 51-712-003 ◊ 51-712-060 ◊ † 51-712-067 51-762-006 † 1250-059 † 51-762-005 1250-062 † 51-744-003* † SCI-3223-000 † 1250-003 € † 51-712-001* 1250-049 † 51-744-002 ◊ † 1293-000 — /61-0014 — — /43-0002 /28-0001 /28-0002 /61-0008 — /28-0004 /61-0013 /44-0003 — /44-0002 — /44-0001 — — — — — — 2 4 2 3 2 2 5 2 2 2 2 6 6 6 1 1 2 2 2 2 2 3 Rated Voltage 125°C DC AC 50 50 70 70 100 100 100 100 100 100 100 125 125 125 125 125 200 200 200 200 200 200 — — — — 70 70 70 70 — 70 — 85 — 85 — 85 115 — — — — — H I Amp CKT 10 20 10 10 10 10 10 10 10 10 10 15 15 15 15 15 10 10 10 10 10 10 Pi Pi Pi Pi Pi Pi Pi Pi LB LB LB Pi Pi Pi Pi Pi Pi Pi Pi Pi Pi Pi Min Cap 0.012 µF 0.012 µF 5000 pF 0.028 µF 3000 pF 3000 pF 3000 pF 5500 pF 0.022 µF 0.022 µF 0.031 µF 65 pF 1500 pF 1500 pF 3000 pF 3000 pF 2000 pF 3000 pF 3000 pF 3000 pF 5500 pF 0.012 µF † Also available through APITech’s authorized distributors. L In (mm) In 0.265 0.310 0.312 — 0.312 0.312 — 0.312 0.280 0.312 0.280 — — — — — 0.312 0.312 0.312 0.312 0.265 — (6.73) (7.87) (7.92) — (7.92) (7.92) — (7.92) (7.11) (7.92) (7.11) — — — — — (7.92) (7.92) (7.92) (7.92) (6.73) — 0.413 0.490 0.500 — 0.578 0.890 — 0.500 0.850 0.890 0.890 — — — — — 0.890 0.890 0.890 0.578 0.413 — Minimum Insertion Loss (dB) 1 3 10 30 100 300 1 10 (mm) MHz MHz MHz MHz MHz MHz GHz GHz (10.49) (12.45) (12.70) — (14.68) (22.61) — (12.70) (21.59) (22.61) (22.61) — — — — — (22.61) (22.61) (22.61) (14.68) (10.49) — 5 — — 10 — — — — 7 10 10 — — — — — — — — — — 5 9 10 — 14 — — — — 17 17 20 — — — — — — — — — 7 10 18 20 20 38 5 5 5 15 27 28 30 — 5 5 5 10 8 5 5 5 14 28 45 30 30 65 15 15 15 35 34 34 38 — 15 15 15 15 10 15 15 15 30 40 65 65 65 75 45 45 45 65 43 41 42 — 35 25 45 30 48 45 45 45 55 65 70 70 65 75 50 60 60 70 50 50 52 — 45 35 45 40 50 65 65 65 70 70 70 70 70 75 50 60 60 70 60 60 60 16 60 50 70 65 70 70 70 65 70 70 70 70 70 75 50 60 60 70 60 60 60 42 60 50 70 65 70 70 70 60 70 70 * Denotes parts with turret lead. € Also available through APITech’s authorized European distributors/agents. ◊ Supplied with .040” (1.02mm) diameter lead. www.apitech.com | 855.294.3800 | communications@apitech.com | www.linkedin.com/company/api-technologies-corp-/ 6 The Electromagnetic Spectrum Innovator DATA SHEET Resin Sealed Bolt-In EMI Filters 10-32 C & Pi Circuit Rated Voltage 125°C Part Number Figure 51-761-002 † 54-786-013 54-786-028 † 54-786-014 51-761-001 54-786-027 1 1 1 2 1 1 DC AC 50 50 50 50 100 200 — — — — — — A I Amp CKT 10 10 10 10 10 10 Pi C C C Pi C Min Cap In (mm) 0.018 µF 0.3 µF 0.56 µF 0.8 µF 0.01 µF 0.1 µF 0.032 0.040 0.040 0.040 0.032 0.040 (0.81) (1.02) (1.02) (1.02) (0.81) (1.02) Minimum Insertion Loss (dB) 1 3 10 30 100 300 1 10 MHz MHz MHz MHz MHz MHz GHz GHz 7 30 35 40 — 20 14 38 43 46 10 29 30 47 50 52 20 38 55 50 52 54 45 44 70 55 60 70 65 47 70 60 65 70 70 55 70 70 70 70 70 65 70 70 70 70 70 65 † Also available through APITech’s authorized distributors. www.apitech.com | 855.294.3800 | communications@apitech.com | www.linkedin.com/company/api-technologies-corp-/ 7 The Electromagnetic Spectrum Innovator DATA SHEET Resin Sealed Bolt-In EMI Filters 12-28 C /12-32 C Circuit Rated Voltage 125°C Part Number Figure 9910-381-6004 9910-381-6003 SCI-9310-273 9910-381-6002 54804002X5R101M † 54804002X5R471M † 54804002X5V102P 54743001X5U102Z 4 4 3 4 2 2 2 1 DC AC 35 50 100 100 250 250 250 250 — — — — — — — — I Amp CKT 15 15 10 15 10 10 10 15 C C C C C C C C Min Cap 1 µF 0.75 µF 0.027 µF 0.30 µF 100 pF ± 20% 470 pF ± 20% 1000 pF 1000 pF Minimum Insertion Loss (dB) 1 3 10 30 100 300 1 10 MHz MHz MHz MHz MHz MHz GHz GHz 38 35 10 28 — — — — 40 37 20 30 — — — — 52 51 30 45 — — — — 52 51 37 50 — — 10 — 70 61 45 55 — 12 21 20 70 61 50 55 10 22 28 28 78 65 55 60 20 25 28 28 80 70 60 65 25 28 28 28 † Also available through APITech’s authorized distributors. www.apitech.com | 855.294.3800 | communications@apitech.com | www.linkedin.com/company/api-technologies-corp-/ 8 The Electromagnetic Spectrum Innovator DATA SHEET Resin Sealed Bolt-In EMI Filters 12-28 C /12-32 C Circuit www.apitech.com | 855.294.3800 | communications@apitech.com | www.linkedin.com/company/api-technologies-corp-/ 9 The Electromagnetic Spectrum Innovator DATA SHEET Resin Sealed Bolt-In EMI Filters 12-28 C /12-32 C Circuit MIL-PRF15733 Part Number Number 51-709-013 SCI-3303-000* 51-709-015 † 1216-001 † 1270-016* † 1270-025 † 1201-066 51-714-055* 51-714-054* 51-714-053* 51-714-058* 51-714-056 † SCI-3313-000* 51-719-022 † 1201-052 † 1201-054 51-714-001* † 1270-024 51-714-003* † 1270-009 51-719-053** 51-719-054* 51-714-051* 51-719-023* 51-714-052* 51-714-004* † 51-719-021 €51-714-002* † SCI-3323-000* † 1221-001 † 51-709-004 1201-086 † 51-719-011 € — — /61-0009 — — — — /61-0011 /61-0010 /61-0007 — /61-0012 — — — — — — — — /61-0001 /61-0002 /61-0005 /43-0001 /61-0006 — — — — — /46-0001 — — See Pg. 9 for Fig. 3 2 3 3 2 2 1 2 2 2 2 6 2 1 5 1 2 2 2 2 5 1 2 5 2 2 1 2 2 4 4 1 1 Rated Voltage 125°C A DC AC I Amp 50 50 70 70 100 100 100 100 100 100 100 100 100 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 300 300 350 500 — — — — — — — — — 70 — — — — — — — — — — 140 140 140 140 140 — — — 115 — — — — 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 B Min Cap In (mm) In 0.1 µF 0.15 µF 0.012 µF 0.050 µF 5500 pF 5500 pF 5500 pF 5500 pF 5500 pF 5500 pF 0.025 µF 0.025 µF 0.10 µF 1300 pF 3000 pF 3000 pF 3000 pF 3000 pF 3000 pF 3000 pF 3000 pF 1500 pF 1500 pF 3000 pF 3000 pF 5500 pF 5500 pF 5500 pF 0.012 µF 5500 pF 5500 pF 2500 pF 3000 pF 0.040 0.032 0.032 0.032 0.032 0.032 0.032 0.032 0.032 0.032 0.032 0.032 0.032 0.040 0.032 0.032 0.032 0.032 0.032 0.032 0.032 0.032 0.032 0.032 0.032 0.032 0.040 0.032 0.032 0.032 0.032 0.040 0.040 (1.02) (0.81) (0.81) (0.81) (0.81) (0.81) (0.81) (0.81) (0.81) (0.81) (0.81) (0.81) (0.81) (1.02) (0.81) (0.81) (0.81) (0.81) (0.81) (0.81) (0.81) (0.81) (0.81) (0.81) (0.81) (0.81) (1.02) (0.81) (0.81) (0.81) (0.81) (1.02) (1.02) 0.437 0.250 0.470 0.468 0.250 0.235 — 0.235 0.250 0.250 0.250 0.235 0.250 — — — 0.250 0.235 0.235 0.250 — — 0.250 — 0.235 0.235 — 0.250 0.250 0.437 0.437 — — Minimum Insertion Loss (dB) 1 3 10 30 100 300 (mm) MHz MHz MHz MHz MHz MHz (11.10) (6.35) (11.94) (11.89) (6.35) (5.97) — (5.97) (6.35) (6.35) (6.35) (5.97) (6.35) — — — (6.35) (5.97) (5.97) (6.35) — — (6.35) — (5.97) (5.97) — (6.35) (6.35) (11.10) (11.10) — — 10 12 — 15 — — — — — — 10 — 10 — — — — — — — — — — — — — — — — — — — — 40 43 — 20 7 7 7 7 7 7 15 — 40 — — — — — — — — — — — — 7 7 7 — — — — — 52 68 — 60 20 20 20 20 20 — 40 — 65 5 5 5 5 5 5 5 — — — — — 14 14 14 27 15 — 5 12 70 70 — 65 35 35 40 — — — 60 — 70 10 15 15 15 15 15 15 — — — — — 35 30 35 30 30 — 10 20 70 70 65 75 65 65 68 65 65 65 70 65 70 35 45 45 43 45 43 45 45 45 45 — 45 60 50 60 70 65 65 50 45 70 70 65 75 70 70 70 70 70 70 70 65 70 60 45 45 60 45 60 45 — 45 45 45 45 70 65 70 70 70 70 50 60 † Also available through APITech’s authorized distributors. € Also available through APITech’s authorized European distributors/agents. * Denotes parts supplied with lead as shown in Figure 7. ** Bushing housing will have 1 1/2 imperfect threads at hex to thread interface. www.apitech.com | 855.294.3800 | communications@apitech.com | www.linkedin.com/company/api-technologies-corp-/ 10 The Electromagnetic Spectrum Innovator DATA SHEET Resin Sealed Bolt-In EMI Filters 5/16-24 & 5/16-32 C & Pi Circuit MIL-PRF15733 Part Number Number Fig. SCI-9510-503 — SCI-3513-000 — SCI-3523-000 — SCI-3543-000 — SCI-9550-102 — † 1202-052 — † 1202-054 — 51-702-020* /61-0003 51-702-021 /61-0004 SCI-9550-332 — SCI-3553-000 — † 1202-005 — 1 1 1 1 1 1 2 3 3 1 1 2 Rated Voltage 125°C DC AC 100 100 200 400 500 500 500 500 500 500 500 700 — — 115 220 115 — — 350 350 115 220 — I Amp CKT 25 25 25 25 25 25 25 25 25 25 25 25 C Pi Pi Pi C Pi Pi Pi Pi C Pi Pi Minimum Insertion Loss (dB) 1 3 10 30 100 300 1 10 MHz MHz MHz MHz MHz MHz GHz GHz Min Cap 0.05 µF 0.1 µF 0.02 µF 6000 pF 1000 pF 3000 pF 3000 pF 3000 pF 3000 pF 3300 pF 0.012 µF 2000 pF 15 10 — — — — — — — — — — 24 18 — — — — — — — — — — 35 28 25 15 — 10 10 — 10 12 18 5 41 37 50 35 11 35 35 35 35 20 28 20 45 70 66 54 20 55 55 55 55 30 52 50 60 70 66 65 28 55 55 55 55 33 52 55 60 70 70 70 28 70 70 70 70 40 70 70 60 70 70 70 28 70 70 70 70 40 70 70 † Also available through APITech’s authorized distributors. * Denotes parts with 5/16-24 Threads www.apitech.com | 855.294.3800 | communications@apitech.com | www.linkedin.com/company/api-technologies-corp-/ 11 The Electromagnetic Spectrum Innovator DATA SHEET Metric Resin Sealed Bolt-in EMI Filters M3 Pi Circuit & M4 C Circuit Rated Voltage 125°C Part Number* Figure 51-831-004 51-831-011 51-831-012 51-831-013 51-831-014 51-831-015 54-863-004 54-863-005 54-863-007 54-863-008 54-863-010 1 1 1 1 1 1 2 2 2 2 2 DC I Amp CKT Min Cap 100 100 100 100 70 100 100 100 100 100 100 3 10 10 10 10 10 10 10 10 10 10 Pi Pi Pi Pi Pi Pi C C C C C 1000 pF 100 pF 1500 pF 3000 pF 5500 pF 12000 pF 10000 pF 100 pF 1000 pF 2000 pF 4700 pF Temperature Range -55°C to +125°C -55°C to +125°C -55°C to +125°C -55°C to +125°C -55°C to +125°C -55°C to +125°C -55°C to +125°C -55°C to +125°C -55°C to +125°C -55°C to +125°C -55°C to +125°C RoHS available. www.apitech.com | 855.294.3800 | communications@apitech.com | APPROVED FOR PUBLIC RELEASE 063021ED www.linkedin.com/company/api-technologies-corp-/ 12
51F-714-002 价格&库存
很抱歉,暂时无法提供与“51F-714-002”相匹配的价格&库存,您可以联系我们找货
