51F-726-002
51F-726-002
    APITECHNOLOGIES
    Axial
    LC EMI Filter 2nd Order Low Pass 1 Channel C = 0.022µF 10A Axial, Bushing, 1 Turret Lead
51F-726-002 数据手册
The Electromagnetic Spectrum Innovator CONTACT US DATA SHEET Resin Sealed Bolt-in EMI Filters These EMI filters are easily mounted in a tapped hole or through-hole with supplied nut and lock-washer. The rugged case with resin seals at both ends provides excellent environmental protection. Primarily used in filtering signal/data lines, and DC power lines. Features • Wide range of sizes: 4-40 thread through 5/16-24 thread • Voltage ratings to 500 VDC/220 VAC (400 Hz) • MIL-PRF-15733 QPL filters available • Multiple circuit configurations: C, L, and Pi • Metric threaded filters available 4-40 C Circuit www.apitech.com | 855.294.3800 | communications@apitech.com | www.linkedin.com/company/api-technologies-corp-/ 1 The Electromagnetic Spectrum Innovator DATA SHEET Resin Sealed Bolt-in EMI Filters 4-40 C Circuit See Rated Voltage Pg. 1 125°C I for Amp Part Number Figure DC AC † SCI-9110-100 † 9900-381-6004 9900-381-6026 † 9900-381-6006 † 54-790-023 † 54790001X5F101M 54-790-019 9900-381-6013 54-790-020 SCI-9112-273 SCI-9110-273 54-790-022 † SCI-9112-503 SCI-9110-503 54-862-001 54-862-002 54-862-003 † 9900-381-6020 SCI-9122-101 SCI-9120-101 9900-381-6021 SCI-9122-102 SCI-9120-102 † 9900-381-6022 SCI-9122-502 SCI-9120-502 SCI-9122-103 SCI-9120-103 9900-381-6005 † 54-790-018 † 54-790-021 3 2 2 2 1 1 1 2 1 3 3 1 3 3 4 4 4 2 3 3 2 3 3 2 3 3 3 3 2 1 1 50 50 50 50 100 100 100 100 100 100 100 100 100 100 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 300 300 — — — — — — — — — — — — — — — — — — 115 115 — 115 115 — 115 115 115 115 — — — 10 10 10 10 10 10 10 10 10 3 10 10 3 10 10 10 10 10 3 10 10 3 10 10 3 10 3 10 10 10 10 A Min Cap In (mm) 10 pF 5000 pF 0.031 µF 0.045 µF 0.050 µF 100 pF ± 20% 2700 pF 2700 pF 5600 pF 0.027 µF 0.027 µF 0.027 µF 0.05 µF 0.05 µF 10 pF 100 pF 1000 pF 100 pF 100 pF 100 pF 500 pF 1000 pF 1000 pF 1200 pF 5000 pF 5000 pF 0.01 µF 0.01 µF 0.015 µF 1000 pF 0.01 µF 0.032 — — — — — — — — 0.016 0.020 — 0.016 0.020 — — — — 0.016 0.020 — 0.016 0.020 — 0.016 0.020 0.016 0.020 — — — (0.81) — — — — — — — — (0.41)* (0.51) — (0.41)* (0.51) — — — — (0.41)* (0.51) — (0.41)* (0.51) — (0.41)* (0.51) (0.41)* (0.51) — — — Minimum Insertion Loss (dB) 1 3 10 30 100 300 1 10 MHz MHz MHz MHz MHz MHz GHz GHz — — 12 14 15 — — — — 10 10 10 15 15 — — — — — — — — — — — — — — 7 — — — — 20 22 24 — — — — 20 20 20 24 24 — — — — — — — — — — — — 12 12 9 — 9 — 15 25 30 34 — 9 10 15 30 30 30 35 35 — — — — — — — — — 5 15 15 20 20 20 — 20 — 22 35 40 41 — 18 18 24 37 37 37 41 41 — — — — — — — 11 11 9 24 24 29 29 29 9 29 — 30 40 45 45 — 27 25 33 45 45 45 45 45 — 3 15 3 — — 15 20 20 20 33 33 38 38 35 20 38 — 35 45 50 50 10 33 33 37 45 45 50 50 50 — 10 25 10 10 10 20 28 28 28 37 37 45 45 45 28 45 10 45 55 55 60 20 35 40 40 55 55 55 60 60 10 20 35 20 20 20 35 28 28 35 40 40 50 50 50 28 50 10 55 60 60 60 25 35 50 40 60 60 60 60 60 10 28 40 28 20 20 40 40 40 45 50 50 55 55 60 40 50 * Tinned, steel leads. † Also available through APITech’s authorized distributors. www.apitech.com | 855.294.3800 | communications@apitech.com | www.linkedin.com/company/api-technologies-corp-/ 2 The Electromagnetic Spectrum Innovator DATA SHEET Resin Sealed Bolt-In EMI Filters 4-40 L and Pi Circuit Rated Voltage 125°C Part Number Figure DC AC † 51-729-305 † 51-729-312 SCI-3102-002 SCI-3102-000 SCI-3102-007 t 51-729-304 † SCI-3112-002 † SCI-3112-000 SCI-3112-007 SCI-3112-102 SCI-3112-100 SCI-3112-107 † 51-729-303 SCI-3122-002 SCI-3122-000 SCI-3122-007 50 50 50 50 50 100 100 100 100 100 100 100 200 200 200 200 — — — — — — — — — — — — — 115 115 115 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 A I Amp CKT 3 3 3 5 10 3 5 5 10 3 5 10 3 3 5 10 Pi Pi LB LB LB LB LB LB LB LB LB LB Pi LB LB LB Min Cap In (mm) 5500 pF 7000 pF 0.075 µF 0.075 µF 0.075 µF 0.022 µF 0.027 µF 0.027 µF 0.027 µF 0.05 µF 0.05 µF 0.05 µF 1500 pF 0.01 µF 0.01 µF 0.01 µF 0.018 0.018 0.016 0.016 0.025 0.018 0.016 0.016 0.025 0.016 0.016 0.025 0.018 0.016 0.016 0.025 (0.46) (0.46) (0.41)* (0.41) (0.64) (0.46) (0.41)* (0.41) (0.64) (0.41)* (0.41) (0.64) (0.46) (0.41)* (0.41) (0.64) Minimum Insertion Loss (dB) 1 3 10 30 100 300 1 10 MHz MHz MHz MHz MHz MHz GHz GHz — — 18 18 18 7 10 10 10 15 15 15 — — — — 7 8 25 25 25 17 20 20 20 24 24 24 — 12 12 12 14 15 37 37 37 27 30 30 30 35 35 35 5 21 21 21 40 40 42 42 42 34 38 38 38 42 42 42 15 30 30 30 60 65 52 52 52 43 45 45 45 54 54 54 42 41 41 41 70 70 55 55 55 47 45 45 45 56 56 56 65 45 45 45 70 70 70 70 70 55 65 65 65 70 70 70 70 70 70 70 70 70 70 70 70 55 70 70 70 70 70 70 70 70 70 70 * Tinned, steel leads. † Also available through APITech’s authorized distributors. www.apitech.com | 855.294.3800 | communications@apitech.com | www.linkedin.com/company/api-technologies-corp-/ 3 The Electromagnetic Spectrum Innovator DATA SHEET Resin Sealed Bolt-In EMI Filters 6-32 C, L, Pi/6-40 Pi Rated Voltage 125°C Part Number † 51-726-008 51-726-017 54-779-019 † 54779001X5F100M † 54779001X5U102P € 54-779-014 54-779-016 † 51-726-002 54-779-017 54-779-018 † 51-726-001 † 1289-001 † 1289-004 54-779-015 Figure DC AC 1 1 1 1 1 1 1 3 1 1 1 2 2 1 50 50 50 100 100 100 100 100 100 100 200 200 200 200 — — — — — — — — — — — — — — A I Amp CKT 3 3 10 10 10 10 10 10 10 10 3 10 10 10 Pi Pi C C C C C LB C C Pi Pi Pi C Min Cap In (mm) 5500 pF 9000 pF 0.10 µF 10 pF ± 20% 1000 pF 2700 pF 0.01 µF 0.022 µF 0.027 µF 0.050 µF 1500 pF 1500 pF 3000 pF 5600 pF 0.018 0.018 0.032 0.032 0.032 0.032 0.032 0.032 0.032 0.032 0.018 0.032 0.032 0.032 (0.46) (0.46) (0.81) (0.81) (0.81) (0.81) (0.81) (0.81) (0.81) (0.81) (0.46) (0.81) (0.81) (0.81) Minimum Insertion Loss (dB) 1 3 10 30 100 300 1 10 MHz MHz MHz MHz MHz MHz GHz GHz — — 22 — — — — 7 10 15 — — — — 7 8 31 — — — 9 17 20 24 — — — — 14 18 40 — — 9 20 27 30 34 5 5 8 15 30 45 44 — 10 18 29 34 37 41 15 15 15 24 55 65 47 — 21 27 38 43 45 45 42 40 50 33 70 70 55 — 28 33 45 50 50 50 65 60 65 37 70 70 65 10 28 35 50 60 55 60 70 60 70 40 70 70 65 10 28 35 50 60 60 60 70 60 70 40 † Also available through APITech’s authorized distributors. € Also available through APITech’s authorized European distributors/agents. www.apitech.com | 855.294.3800 | communications@apitech.com | www.linkedin.com/company/api-technologies-corp-/ 4 The Electromagnetic Spectrum Innovator DATA SHEET Resin Sealed Bolt-In EMI Filters 8-32 C Circuit Rated Voltage 125°C Part Number Figure SCI-9200-503 9950-381-6009 54-785-017 9950-381-6008 † 54713001X5F101M † 54713001X5U102P 54-785-013 SCI-9210-103 SCI-9210-273 † 54-785-005 54-785-016 54-785-011 54-785-012 SCI-9220-101 SCI-9220-102 SCI-9220-502 2 3 1 3 4 4 1 2 2 1 1 1 1 2 2 2 DC AC I Amp 50 50 50 70 100 100 100 100 100 100 100 150 150 200 200 200 — — — — — — — — — — — — — 115 115 115 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 Min Cap 0.05 µF 0.12 µF 0.21 µF 0.08 µF 80 pF 1000 pF 0.01 µF 0.01 µF 0.027 µF 0.05 µF 0.1 µF 2000 pF 5000 pF 100 pF 1000 pF 5000 pF Minimum Insertion Loss (dB) 1 3 10 30 100 300 1 10 MHz MHz MHz MHz MHz MHz GHz GHz 15 20 28 15 — — — — 10 15 20 — — — — — 24 30 37 24 — — 9 12 20 24 29 — 6 — — 6 35 43 45 37 — — 20 20 30 34 38 8 15 — — 15 41 45 50 41 — 11 29 29 36 41 44 17 24 — 11 24 45 55 55 51 — 20 38 38 45 45 47 26 33 — 20 33 50 55 60 51 10 28 45 45 50 50 55 32 37 10 28 37 60 55 70 55 20 28 50 50 55 60 65 34 40 20 28 40 60 55 70 55 20 28 55 50 60 60 65 35 40 25 28 40 † Also available through APITech’s authorized distributors. www.apitech.com | 855.294.3800 | communications@apitech.com | www.linkedin.com/company/api-technologies-corp-/ 5 The Electromagnetic Spectrum Innovator DATA SHEET Resin Sealed Bolt-In EMI Filters 8-32 L & Pi Circuit MIL-PRF15733 Number Part Number Fig. 51-712-069 € † 51-712-065 † 1250-054 † 1293-001 51-712-055 † 51-712-014 51-712-028 † 51-712-063* † 51-712-003 ◊ 51-712-060 ◊ † 51-712-067 51-762-006 † 1250-059 † 51-762-005 1250-062 † 51-744-003* † SCI-3223-000 † 1250-003 € † 51-712-001* 1250-049 † 51-744-002 ◊ † 1293-000 — /61-0014 — — /43-0002 /28-0001 /28-0002 /61-0008 — /28-0004 /61-0013 /44-0003 — /44-0002 — /44-0001 — — — — — — 2 4 2 3 2 2 5 2 2 2 2 6 6 6 1 1 2 2 2 2 2 3 Rated Voltage 125°C DC AC 50 50 70 70 100 100 100 100 100 100 100 125 125 125 125 125 200 200 200 200 200 200 — — — — 70 70 70 70 — 70 — 85 — 85 — 85 115 — — — — — H I Amp CKT 10 20 10 10 10 10 10 10 10 10 10 15 15 15 15 15 10 10 10 10 10 10 Pi Pi Pi Pi Pi Pi Pi Pi LB LB LB Pi Pi Pi Pi Pi Pi Pi Pi Pi Pi Pi Min Cap 0.012 µF 0.012 µF 5000 pF 0.028 µF 3000 pF 3000 pF 3000 pF 5500 pF 0.022 µF 0.022 µF 0.031 µF 65 pF 1500 pF 1500 pF 3000 pF 3000 pF 2000 pF 3000 pF 3000 pF 3000 pF 5500 pF 0.012 µF † Also available through APITech’s authorized distributors. L In (mm) In 0.265 0.310 0.312 — 0.312 0.312 — 0.312 0.280 0.312 0.280 — — — — — 0.312 0.312 0.312 0.312 0.265 — (6.73) (7.87) (7.92) — (7.92) (7.92) — (7.92) (7.11) (7.92) (7.11) — — — — — (7.92) (7.92) (7.92) (7.92) (6.73) — 0.413 0.490 0.500 — 0.578 0.890 — 0.500 0.850 0.890 0.890 — — — — — 0.890 0.890 0.890 0.578 0.413 — Minimum Insertion Loss (dB) 1 3 10 30 100 300 1 10 (mm) MHz MHz MHz MHz MHz MHz GHz GHz (10.49) (12.45) (12.70) — (14.68) (22.61) — (12.70) (21.59) (22.61) (22.61) — — — — — (22.61) (22.61) (22.61) (14.68) (10.49) — 5 — — 10 — — — — 7 10 10 — — — — — — — — — — 5 9 10 — 14 — — — — 17 17 20 — — — — — — — — — 7 10 18 20 20 38 5 5 5 15 27 28 30 — 5 5 5 10 8 5 5 5 14 28 45 30 30 65 15 15 15 35 34 34 38 — 15 15 15 15 10 15 15 15 30 40 65 65 65 75 45 45 45 65 43 41 42 — 35 25 45 30 48 45 45 45 55 65 70 70 65 75 50 60 60 70 50 50 52 — 45 35 45 40 50 65 65 65 70 70 70 70 70 75 50 60 60 70 60 60 60 16 60 50 70 65 70 70 70 65 70 70 70 70 70 75 50 60 60 70 60 60 60 42 60 50 70 65 70 70 70 60 70 70 * Denotes parts with turret lead. € Also available through APITech’s authorized European distributors/agents. ◊ Supplied with .040” (1.02mm) diameter lead. www.apitech.com | 855.294.3800 | communications@apitech.com | www.linkedin.com/company/api-technologies-corp-/ 6 The Electromagnetic Spectrum Innovator DATA SHEET Resin Sealed Bolt-In EMI Filters 10-32 C & Pi Circuit Rated Voltage 125°C Part Number Figure 51-761-002 † 54-786-013 54-786-028 † 54-786-014 51-761-001 54-786-027 1 1 1 2 1 1 DC AC 50 50 50 50 100 200 — — — — — — A I Amp CKT 10 10 10 10 10 10 Pi C C C Pi C Min Cap In (mm) 0.018 µF 0.3 µF 0.56 µF 0.8 µF 0.01 µF 0.1 µF 0.032 0.040 0.040 0.040 0.032 0.040 (0.81) (1.02) (1.02) (1.02) (0.81) (1.02) Minimum Insertion Loss (dB) 1 3 10 30 100 300 1 10 MHz MHz MHz MHz MHz MHz GHz GHz 7 30 35 40 — 20 14 38 43 46 10 29 30 47 50 52 20 38 55 50 52 54 45 44 70 55 60 70 65 47 70 60 65 70 70 55 70 70 70 70 70 65 70 70 70 70 70 65 † Also available through APITech’s authorized distributors. www.apitech.com | 855.294.3800 | communications@apitech.com | www.linkedin.com/company/api-technologies-corp-/ 7 The Electromagnetic Spectrum Innovator DATA SHEET Resin Sealed Bolt-In EMI Filters 12-28 C /12-32 C Circuit Rated Voltage 125°C Part Number Figure 9910-381-6004 9910-381-6003 SCI-9310-273 9910-381-6002 54804002X5R101M † 54804002X5R471M † 54804002X5V102P 54743001X5U102Z 4 4 3 4 2 2 2 1 DC AC 35 50 100 100 250 250 250 250 — — — — — — — — I Amp CKT 15 15 10 15 10 10 10 15 C C C C C C C C Min Cap 1 µF 0.75 µF 0.027 µF 0.30 µF 100 pF ± 20% 470 pF ± 20% 1000 pF 1000 pF Minimum Insertion Loss (dB) 1 3 10 30 100 300 1 10 MHz MHz MHz MHz MHz MHz GHz GHz 38 35 10 28 — — — — 40 37 20 30 — — — — 52 51 30 45 — — — — 52 51 37 50 — — 10 — 70 61 45 55 — 12 21 20 70 61 50 55 10 22 28 28 78 65 55 60 20 25 28 28 80 70 60 65 25 28 28 28 † Also available through APITech’s authorized distributors. www.apitech.com | 855.294.3800 | communications@apitech.com | www.linkedin.com/company/api-technologies-corp-/ 8 The Electromagnetic Spectrum Innovator DATA SHEET Resin Sealed Bolt-In EMI Filters 12-28 C /12-32 C Circuit www.apitech.com | 855.294.3800 | communications@apitech.com | www.linkedin.com/company/api-technologies-corp-/ 9 The Electromagnetic Spectrum Innovator DATA SHEET Resin Sealed Bolt-In EMI Filters 12-28 C /12-32 C Circuit MIL-PRF15733 Part Number Number 51-709-013 SCI-3303-000* 51-709-015 † 1216-001 † 1270-016* † 1270-025 † 1201-066 51-714-055* 51-714-054* 51-714-053* 51-714-058* 51-714-056 † SCI-3313-000* 51-719-022 † 1201-052 † 1201-054 51-714-001* † 1270-024 51-714-003* † 1270-009 51-719-053** 51-719-054* 51-714-051* 51-719-023* 51-714-052* 51-714-004* † 51-719-021 €51-714-002* † SCI-3323-000* † 1221-001 † 51-709-004 1201-086 † 51-719-011 € — — /61-0009 — — — — /61-0011 /61-0010 /61-0007 — /61-0012 — — — — — — — — /61-0001 /61-0002 /61-0005 /43-0001 /61-0006 — — — — — /46-0001 — — See Pg. 9 for Fig. 3 2 3 3 2 2 1 2 2 2 2 6 2 1 5 1 2 2 2 2 5 1 2 5 2 2 1 2 2 4 4 1 1 Rated Voltage 125°C A DC AC I Amp 50 50 70 70 100 100 100 100 100 100 100 100 100 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 300 300 350 500 — — — — — — — — — 70 — — — — — — — — — — 140 140 140 140 140 — — — 115 — — — — 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 B Min Cap In (mm) In 0.1 µF 0.15 µF 0.012 µF 0.050 µF 5500 pF 5500 pF 5500 pF 5500 pF 5500 pF 5500 pF 0.025 µF 0.025 µF 0.10 µF 1300 pF 3000 pF 3000 pF 3000 pF 3000 pF 3000 pF 3000 pF 3000 pF 1500 pF 1500 pF 3000 pF 3000 pF 5500 pF 5500 pF 5500 pF 0.012 µF 5500 pF 5500 pF 2500 pF 3000 pF 0.040 0.032 0.032 0.032 0.032 0.032 0.032 0.032 0.032 0.032 0.032 0.032 0.032 0.040 0.032 0.032 0.032 0.032 0.032 0.032 0.032 0.032 0.032 0.032 0.032 0.032 0.040 0.032 0.032 0.032 0.032 0.040 0.040 (1.02) (0.81) (0.81) (0.81) (0.81) (0.81) (0.81) (0.81) (0.81) (0.81) (0.81) (0.81) (0.81) (1.02) (0.81) (0.81) (0.81) (0.81) (0.81) (0.81) (0.81) (0.81) (0.81) (0.81) (0.81) (0.81) (1.02) (0.81) (0.81) (0.81) (0.81) (1.02) (1.02) 0.437 0.250 0.470 0.468 0.250 0.235 — 0.235 0.250 0.250 0.250 0.235 0.250 — — — 0.250 0.235 0.235 0.250 — — 0.250 — 0.235 0.235 — 0.250 0.250 0.437 0.437 — — Minimum Insertion Loss (dB) 1 3 10 30 100 300 (mm) MHz MHz MHz MHz MHz MHz (11.10) (6.35) (11.94) (11.89) (6.35) (5.97) — (5.97) (6.35) (6.35) (6.35) (5.97) (6.35) — — — (6.35) (5.97) (5.97) (6.35) — — (6.35) — (5.97) (5.97) — (6.35) (6.35) (11.10) (11.10) — — 10 12 — 15 — — — — — — 10 — 10 — — — — — — — — — — — — — — — — — — — — 40 43 — 20 7 7 7 7 7 7 15 — 40 — — — — — — — — — — — — 7 7 7 — — — — — 52 68 — 60 20 20 20 20 20 — 40 — 65 5 5 5 5 5 5 5 — — — — — 14 14 14 27 15 — 5 12 70 70 — 65 35 35 40 — — — 60 — 70 10 15 15 15 15 15 15 — — — — — 35 30 35 30 30 — 10 20 70 70 65 75 65 65 68 65 65 65 70 65 70 35 45 45 43 45 43 45 45 45 45 — 45 60 50 60 70 65 65 50 45 70 70 65 75 70 70 70 70 70 70 70 65 70 60 45 45 60 45 60 45 — 45 45 45 45 70 65 70 70 70 70 50 60 † Also available through APITech’s authorized distributors. € Also available through APITech’s authorized European distributors/agents. * Denotes parts supplied with lead as shown in Figure 7. ** Bushing housing will have 1 1/2 imperfect threads at hex to thread interface. www.apitech.com | 855.294.3800 | communications@apitech.com | www.linkedin.com/company/api-technologies-corp-/ 10 The Electromagnetic Spectrum Innovator DATA SHEET Resin Sealed Bolt-In EMI Filters 5/16-24 & 5/16-32 C & Pi Circuit MIL-PRF15733 Part Number Number Fig. SCI-9510-503 — SCI-3513-000 — SCI-3523-000 — SCI-3543-000 — SCI-9550-102 — † 1202-052 — † 1202-054 — 51-702-020* /61-0003 51-702-021 /61-0004 SCI-9550-332 — SCI-3553-000 — † 1202-005 — 1 1 1 1 1 1 2 3 3 1 1 2 Rated Voltage 125°C DC AC 100 100 200 400 500 500 500 500 500 500 500 700 — — 115 220 115 — — 350 350 115 220 — I Amp CKT 25 25 25 25 25 25 25 25 25 25 25 25 C Pi Pi Pi C Pi Pi Pi Pi C Pi Pi Minimum Insertion Loss (dB) 1 3 10 30 100 300 1 10 MHz MHz MHz MHz MHz MHz GHz GHz Min Cap 0.05 µF 0.1 µF 0.02 µF 6000 pF 1000 pF 3000 pF 3000 pF 3000 pF 3000 pF 3300 pF 0.012 µF 2000 pF 15 10 — — — — — — — — — — 24 18 — — — — — — — — — — 35 28 25 15 — 10 10 — 10 12 18 5 41 37 50 35 11 35 35 35 35 20 28 20 45 70 66 54 20 55 55 55 55 30 52 50 60 70 66 65 28 55 55 55 55 33 52 55 60 70 70 70 28 70 70 70 70 40 70 70 60 70 70 70 28 70 70 70 70 40 70 70 † Also available through APITech’s authorized distributors. * Denotes parts with 5/16-24 Threads www.apitech.com | 855.294.3800 | communications@apitech.com | www.linkedin.com/company/api-technologies-corp-/ 11 The Electromagnetic Spectrum Innovator DATA SHEET Metric Resin Sealed Bolt-in EMI Filters M3 Pi Circuit & M4 C Circuit Rated Voltage 125°C Part Number* Figure 51-831-004 51-831-011 51-831-012 51-831-013 51-831-014 51-831-015 54-863-004 54-863-005 54-863-007 54-863-008 54-863-010 1 1 1 1 1 1 2 2 2 2 2 DC I Amp CKT Min Cap 100 100 100 100 70 100 100 100 100 100 100 3 10 10 10 10 10 10 10 10 10 10 Pi Pi Pi Pi Pi Pi C C C C C 1000 pF 100 pF 1500 pF 3000 pF 5500 pF 12000 pF 10000 pF 100 pF 1000 pF 2000 pF 4700 pF Temperature Range -55°C to +125°C -55°C to +125°C -55°C to +125°C -55°C to +125°C -55°C to +125°C -55°C to +125°C -55°C to +125°C -55°C to +125°C -55°C to +125°C -55°C to +125°C -55°C to +125°C RoHS available. www.apitech.com | 855.294.3800 | communications@apitech.com | APPROVED FOR PUBLIC RELEASE 063021ED www.linkedin.com/company/api-technologies-corp-/ 12 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: API Technologies: 54-785-005 SCI-3313-000 51-719-011 1289-001 1289-004 51-712-001 1217-000 1250-003 51-712-063 1216001 54779001X5U102P 54-713-074 54713001X5U102P SCI-3112-002 SCI-3112-000 51-744-002 51-750-302 51729-305 1221-001 54713001X5F101M 54-785-011B 54-786-027 54804002X5R471M 9900-381-6021 9900F-3816004 9900F-381-6020 9900F-381-6022 51-702-020 51-702-021 51-712-065 51-714-002 51-714-052 51-719-021 51-729-312 51-762-006 SCI-3102-000 SCI-3102-007 SCI-3223-000 SCI-9120-103B SCI-9200-503 SCI-9220-102 SCIF-3102-007 SCIF-3112-002 SCIF-3313-000 SCIF-3513-000 54F-790-018 54F-790-021 54F-790-023 54F-804023 51F-750-302 51F-729-303 51F-729-305 51F-744-002 54-779-018 51-729-303 9900-381-6022 9900-381-6020 1250-054 1202-052 1293-000 1202-005 54-779-019 1201-052 1270-025 51-726-008 51-726-002 54-786-014 54-786-013 9910-381-6003 1201-054 51-709-004 1250-003M 1201F-052 1202F-054 1250F-003 1250F-054 54F713-074 SCIF-9112-503 54F-848-005 54F-713-104 54F-874-017 54F-874-018 54F-779-072 54F-779-019 54F786-013 54F-786-014 51F-726-008 54F-853-004 SCI-3122-007 54-790-020 51-831-013 51-831-015 51-726-017 SCI-9112-102 51-712-003 51-729-304 51-714-051 51-714-055 51-714-053 54-863-007
51F-726-002 价格&库存
很抱歉,暂时无法提供与“51F-726-002”相匹配的价格&库存,您可以联系我们找货
