9053F-100-0001
9053F-100-0001
    APITECHNOLOGIES
    Axial
    FILTERLC1.4UFCHASSIS
9053F-100-0001 数据手册
Hermetically Sealed Threaded Case Filters This series of filters features hermetic glass seals and high EMI filtering performance. They are excellent for critical applications that demand high reliability in the toughest environmental conditions and provide broadband high performance EMI filtering from 10 KHz to over 10 GHz. Features ■ ■ ■ ■ ■ ■ ■ MIL-F-15733 and MIL-F-28861, DSCC 84084 QPL filters available Popular .375", .410" and .690" case diameters Voltage ratings from 50 V to 400 VDC/240 AC, 400 Hz Impervious to high moisture environments, solvents and severe environmental conditions High temperature terminal construction D-slotted bushings High reliability testing available Thread length: A - 0.187 (4.76) B - 0.312 (7.92) L .200 (5.08) A/B .160 (4.064) Max. ø .385 Max. (9.78) 1/4–28 Unf–2A Thd. .050 (1.27) x .070 (1.78) Slot, both ends .176 (4.47) L Figure 1 A/B .160 (4.064) Max. ø .385 Max. (9.78) .115 Ref. (2.92) #12–32 Unef–2A Thd. Note: ø .410 Max. for M28861 parts .050 (1.27) x .070 (1.78) Slot, both ends Figure 2 Dimensions in inches (mm) API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 LP27 Hermetically Sealed Threaded Case Filters .375 ø C Circuit Standard See Pg. MIL LP26 No for Fig. — 1 Rated Voltage 85°C 125°C DC AC DC AC 80 — 50 — 54-370-007 — 1 80 — 50 — 15 2.800 0.005 0.576 (14.630) A 20 34 39 50 60 70 70 54-371-001 — 1 80 — 50 — 15 4.000 0.005 0.688 (17.475) A 26 40 46 55 60 70 70 54-367-005 — 1 150 — 100 — 15 0.450 0.005 0.387 (9.830) A 6 19 25 36 55 70 70 — 1 200 — 150 125 15 0.150 0.005 0.387 (9.830) A — 6 15 26 42 55 70 Part Number ✝ 54-367-008 ✝ 9920-100-6002 Minimum Insertion Loss (dB) DCR Max Max Thd 30 150 300 L 1 1 10 100 Ohms In (mm) Lgth KHz KHz KHz MHz MHz MHz GHz 0.005 0.387 (9.830) A 15 28 33 44 70 60 70 54-367-007 — 1 250 — 200 125 15 0.015 0.005 0.387 (9.830) A — — — 6 25 45 50 ✝ 54-367-006 — 1 250 — 200 125 15 0.250 0.005 0.387 (9.830) A — 14 19 30 50 65 70 54-370-006 — 1 250 — 200 125 15 0.500 0.005 0.630 (16.002) A 7 20 28 39 55 70 70 9923-100-6004 — 1 400 — 400 240 15 0.060 0.005 0.415 (10.541) A — 5 10 18 38 55 70 .375 ø C Circuit MIL Qualified M15733 See Pg. M28861◊ LP26 Part Number MIL No for Fig. 1 54-367-054 1-012◊ Rated Voltage 85°C 125°C DC AC DC AC 50 — — — (See MIL index on pages CF9-11 for complete MIL part number listing) Min Cap I Amp µF 15 1.200 Minimum Insertion Loss (dB) DCR Max Thd 30 150 300 Max L 1 1 10 100 Ohms In (mm) Lgth KHz KHz KHz MHz MHz MHz GHz 0.008 0.410 (10.414) B 70 40 70 33 28 15 40 1-002◊ 1 — — 50 — 15 1.200 0.008 0.410 (10.414) A 15 28 33 40 40 70 70 54-370-032 49-0008 1 — — 50 — 15 2.100 0.010 0.576 (14.630) A 20 33 40 50 65 70 70 1-014◊ 1 — — 70 — 15 0.700 0.008 0.410 (10.414) B 10 24 30 40 40 64 70 54-367-049 54-367-055 ✝ Min Cap I Amp µF 15 1.400 54-370-030 34-0035 2 — — 100 — 10 0.300 0.004 0.474 (12.040) A 7 19 25 35 55 70 70 54-367-051 1-006◊ 1 — — 100 — 15 0.450 0.008 0.410 (10.414) A 6 19 25 36 40 60 70 54-367-056 1-016◊ 1 — — 100 — 15 0.450 0.008 0.410 (10.414) B 6 19 25 36 40 60 70 54-367-057 1-018◊ 1 — — 150 — 15 0.250 0.008 0.410 (10.414) B — 14 20 31 40 56 70 54-367-053 1-010◊ 1 — — 200 125 15 0.150 0.008 0.410 (10.414) A — 10 16 26 40 52 70 54-367-058 1-020◊ 1 — — 200 125 15 0.150 0.008 0.410 (10.414) B — 10 16 26 40 52 70 54-370-034 49-0010 1 — — 330 — 15 0.062 0.004 0.680 (17.272) A — 2 7 17 37 55 70 Also available through API’s authorized distributors. API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 LP28 L-C Filter LT Threaded End Hermetically Sealed Threaded Case Filters L-C Filter LB Threaded End .375 ø L Circuit Thread length: A - 0.187 (4.76) B - 0.312 (7.92) .200 (5.08) L A/B 1/4–28 Unf–2A Thd. .160 (4.064) Max. .200 (5.08) .347 (8.814) ø .385 Max. (9.78) .050 (1.27) x .070 (1.78) Slot, both ends .080 (2.032) Max. 1/4–28 Unf–2A Thd. 1/4–28 Unf–2A Thd. Figure 1 .200 (5.08) .467 (11.86) Max. Note: ø .410 Max. for M28861 parts ø .040 ± .001 (1.02 ± .025) ø .410 (10.41) Max. A/B L Figure 2 Resin Sealed Not Hermetically Sealed ø .040 ± .001 (1.02 ± .025) Typ. L Figure 3 .200 (5.08) 1/4–28 Unf–2A Thd. ø .410 (10.41) Max. A/B .200 (5.08) 1/4–28 Unf–2A Thd. #16Awg, .051 (1.30) ø ø .040 (1.02) A/B L ø .385 (9.78) Max. .343 (8.712) Max. L A/B .250 ± .030 (6.35 ± 0.8) ø .385 (9.78) Max. Figure 5 Dimensions in inches (mm) Figure 4 .375 ø L Standard Low Profile Part Number ✝ 9051-100-0000 Rated Voltage Min I Cap 85°C 125°C MIL µF No Figure DC AC DC AC Amp 50 — — 80 — 15 1.200 1 Minimum Insertion Loss (dB) DCR Max Thd 30 150 300 Max L 1 1 10 100 Ohms CKT In (mm) Lgth KHz KHz KHz MHz MHz MHz GHz A 0.005 LB 0.370 (9.398) 70 70 15 25 34 44 60 ✝ 51-359-001 € — 1 80 — 50 — 15 1.400 0.005 LB 0.370 (9.398) A 15 28 33 44 60 70 70 SCI-1021-000 — 2* 80 — 50 — 15 1.400 0.003 LB 0.280 (7.112) A 15 28 33 44 60 70 70 ✝ 9053-100-0001 — 1 80 — 50 — 15 1.400 0.005 LB 0.370 (9.398) A 15 25 34 44 60 70 70 ✝ 51-717-001 € — 2* 80 — 50 — 15 1.400 0.005 LB 0.325 (8.255) A 15 28 33 44 60 70 70 51-344-006 — 4 80 — 50 — 15 1.400 0.005 LB 0.330 (8.382) A 15 28 33 44 60 70 70 ✝ SCI-1020-000 — 1 80 — 50 — 15 1.400 0.003 LB 0.370 (9.398) A 15 28 33 44 60 70 70 SCI-1021-020 — 2 ◊* 80 — 50 — 15 1.400 0.003 LB 0.280 (7.112) B 15 28 33 44 60 70 70 ✝ SCI-1020-020 — 1 80 — 50 — 15 1.400 0.003 LB 0.370 (9.398) B 15 28 33 44 60 70 70 SCI-1150-001 — 1 80 — 50 — 15 2.800 0.003 LB 0.450 (11.430) B 20 34 40 49 60 70 70 9051-101-0018 — 5 80 — 50 — 25 1.400 0.001 LB 0.450 (11.430) A 15 25 34 44 60 70 70 ✝ 9053-100-0008 — 1 100 — 70 — 15 0.700 0.005 LB 0.370 (9.398) A 9 20 29 39 52 70 70 * Part is resin sealed, this is not a hermetic part. Also available through API’s authorized distributors. Also available through API’s authorized European distributors/agents. ✝ € ◊ Note: 0.462" (11.73mm) length from mounting surface to end of lead — not 0.347" (8.8mm). API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 LP29 L-C Filter LT Threaded End Hermetically Sealed Threaded Case Filters L-C Filter LB Threaded End .375 ø L Standard Low Profile continued Rated Voltage Min See Pg. I Cap 85°C 125°C MIL LP28 Part Number µF No for Fig DC AC DC AC Amp 100 — 70 — 2* 15 0.750 ✝ 9050-100-0008 — Minimum Insertion Loss (dB) DCR Max Max Thd 30 150 300 L 1 1 10 100 Ohms CKT In (mm) Lgth KHz KHz KHz MHz MHz MHz GHz A 0.005 LB 0.325 (8.255) 9 20 70 29 70 39 52 ✝ 9053-100-0002 — 1 150 — 100 — 15 0.500 0.005 LB 0.370 (9.398) A 4 12 21 31 48 70 70 SCI-1250-001 — 1 150 — 100 — 15 0.500 0.003 LB 0.450 (11.430) B 8 20 25 34 50 64 70 €SCI-2150-000 — 1 150 — 100 — 15 1.000 0.003 LB 0.450 (11.430) A 10 25 30 41 56 70 70 SCI-2150-001 — 100 — — 1 150 15 1.000 0.003 LB 0.450 (11.430) B 10 25 30 41 56 70 70 ✝ 51-717-007 — 2* 250 125 200 125 15 0.015 0.005 LB 0.325 (8.255) A — — — 6 25 38 45 ✝ 51-359-007 — 1 250 125 200 125 15 0.012 0.005 LB 0.370 (9.398) A — — — 6 25 38 50 — 2 350 125 300 125 15 0.150 0.008 LB 0.325 (8.255) A — 10 15 25 40 52 60 €SCI-2350-000 — 1 300 125 300 125 15 0.250 0.003 LB 0.450 (11.430) A 4 15 21 31 50 70 70 SCI-2350-001 — 1 300 125 300 125 15 0.250 0.003 LB 0.450 (11.430) B 4 15 21 31 50 70 70 9050-100-0011 * Part is resin sealed, this is not a hermetic part. (See MIL index on pages CF9-11 for complete MIL part number listing) .375 ø L Circuit MIL Qualified Low Profile Rated Voltage Min M15733 See Pg. I Cap 85°C 125°C M28861◊ LP28 Part Number MIL No for Fig DC AC DC AC Amp µF — 50 — 1 10 1.400 ✝ 51-359-021 38-0004 ✝ € Minimum Insertion Loss (dB) DCR Max Thd 30 150 300 Max L 1 1 10 100 Ohms CKT In (mm) Lgth KHz KHz KHz MHz MHz MHz GHz A 0.008 LB 0.370 (9.398) 60 70 44 70 33 28 15 ✝ 51-359-024 38-0005 1 80 — 50 — 10 1.400 0.008 LB 0.370 (9.398) A 15 28 33 44 60 70 70 ✝ 51-359-051 58-0001 1 80 — 50 — 10 1.400 0.008 LB 0.545 (13.843) A 15 28 33 44 60 70 70 51-359-105 58-0004 1 80 — 50 — 10 1.400 0.008 LT 0.545 (13.843) B 15 28 33 44 60 70 70 ✝ 51-359-044 49-0006 1 100 — 50 — 15 1.200 0.010 LB 0.370 (9.398) A 15 28 33 44 60 70 70 ✝ 51-359-055 49-0007 3 100 — 50 — 15 1.200 0.010 LB 0.450 (11.43) A 15 28 33 44 60 70 70 51-359-081 1-001◊ 1 — — 50 — 15 1.400 0.008 LB 0.410 (10.414) A 15 28 33 40 40 70 70 51-359-086 1-011◊ 1 — — 50 — 15 1.400 0.008 LB 0.410 (10.414) B 15 28 33 40 40 70 70 ✝ 51-359-053 49-0001 4 100 — 50 — 15 0.680 0.010 LB 0.319 (8.103) A 8 20 28 38 55 70 70 51-359-082 1-003◊ 1 — — 70 — 15 0.700 0.008 LB 0.410 (10.414) A 10 24 30 40 40 64 70 51-359-083 1-005◊ 1 — — 100 — 15 0.450 0.008 LB 0.410 (10.414) A 6 19 25 36 40 60 70 51-359-088 1-015◊ 1 — — 100 — 15 0.450 0.008 LB 0.410 (10.414) B 6 19 25 36 40 60 70 51-359-084 — 1-007◊ 1 — — 150 15 0.250 0.008 LB 0.410 (10.414) A — 14 20 31 40 56 70 51-359-050 38-0008 1 — — 200 125 15 0.150 0.008 LB 0.370 (9.398) A — — — 6 25 42 60 51-359-085 1-009◊ 1 — — 200 125 15 0.150 0.008 LB 0.410 (10.414) A — 10 16 26 40 52 70 51-359-090 1-019◊ 1 — — 200 125 15 0.150 0.008 LB 0.410 (10.414) B — 10 16 26 40 52 70 Also available through API’s authorized distributors. Also available through API’s authorized European distributors/agents. API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 LP30 L-C Filter LT Threaded End Hermetically Sealed Threaded Case Filters L-C Filter LB Threaded End .375 ø L Circuit L .200 (5.08) A/B .160 (4.064) Max. .200 (5.08) L .190 Max. (3.81) ø .385 Max. (9.78) .050 (1.27) x .070 (1.78) Slot, both ends 1/4–28 Unf–2A Thd. .150 (3.81) Max. A/B ø .385 Max. (9.78) Figure 1 .115 Ref. (2.92) Thread length: A - 0.187 (4.76) B - 0.312 (7.92) Note: ø .410 Max. for M28861 parts 1/4–28 Unf–2A Thd. ø .060 (1.524) Ref. Both ends F Dimensions in inches (mm) .375 ø L Circuit Standard Product Part Number 51-353-007 51-353-095 — 1 80 — 50 — 0.15 1.400 12.000 LT 0.960 (24.384) A 21 52 64 70 70 70 70 51-353-003 — 1 80 — 50 — 0.45 1.400 1.200 LB 0.770 (19.558) A 16 31 37 55 70 70 70 51-353-099 — 1 80 — 50 — 1.00 1.400 0.250 LT 0.770 (19.558) A 16 33 44 70 70 70 70 LT 0.770 (19.558) A 15 28 33 46 70 70 70 LB 0.450 (11.430) A 15 28 33 44 60 70 70 51-353-100 ✝ 9200-300-0025 ✝ Rated Voltage Minimum Insertion Loss (dB) DCR Max Min Max Thd 30 150 300 I L Cap 85°C 125°C MIL 1 1 10 100 Ohms CKT µF No Figure DC AC DC AC Amp In (mm) Lgth KHz KHz KHz MHz MHz MHz GHz — 80 — 50 — 0.06 1.400 70.000 LB 0.770 (19.558) A 44 70 70 70 70 70 70 1 — 1 80 — 50 — 1.400 0.015 — 1 80 — 50 — 10.00 1.200 0.010 5.00 Also available through API’s authorized distributors. API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 LP31 L-C Filter LT Threaded End Hermetically Sealed Threaded Case Filters L-C Filter LB Threaded End .375 ø L Circuit Standard Product continued Rated Voltage Min See Pg. I Cap 85°C 125°C MIL LP30 Part Number µF No for Fig DC AC DC AC Amp 80 — 50 — 10.00 1.200 1 ✝ 9200-303-0095 — Minimum Insertion Loss (dB) DCR Max Max Thd 30 150 300 L 1 1 10 100 Ohms CKT In (mm) Lgth KHz KHz KHz MHz MHz MHz GHz 0.010 LB 0.450 (11.430) B 70 70 44 60 15 28 33 51-353-101 — 1 80 — 50 — 10.00 1.400 0.010 LT 0.450 (11.430) A 14 28 33 44 60 70 70 51-353-109 — 1 80 — 50 — 10.00 1.400 0.010 LT 0.450 (11.430) B 15 28 33 44 60 70 70 51-353-120 — 1 150 — 100 — 1.00 0.750 0.250 LB 0.758 (19.253) A 9 27 36 57 70 70 70 5.00 9000-103-0019 — 1 150 — 100 — 0.450 0.015 LT 0.758 (19.253) B 6 20 26 37 68 70 70 SCI-2120-014 — 1 150 — 100 — 10.00 1.000 0.003 LB 0.450 (11.430) B 14 28 34 44 52 70 70 51-353-110 — 1 250 — 200 125 1.00 0.250 0.250 LT 0.758 (19.253) A — 17 29 50 70 70 70 ✝ 51-353-111 — 1 250 — 200 125 1.00 0.250 0.250 LB 0.758 (19.253) A — 17 29 50 70 70 70 51-353-112 — 1 250 — 200 125 3.00 0.250 0.050 LT 0.758 (19.253) A — 13 20 35 70 70 70 ✝ 51-353-113 — 1 250 — 200 125 3.00 0.250 0.050 LB 0.758 (19.253) A — 13 20 35 70 70 70 51-353-114 — 1 250 — 200 125 5.00 0.250 0.015 LT 0.758 (19.253) A — 12 20 30 62 70 70 51-353-116 — 1 250 — 200 125 10.00 0.250 0.010 LT 0.450 (11.430) A — 15 20 30 50 70 70 SCI-2320-010 — 1 300 — 300 125 0.50 0.150 1.000 LB 0.758 (19.253) B — 23 35 56 70 70 70 SCI-2320-004 — 1 300 — 300 125 1.00 0.150 0.250 LB 0.758 (19.253) A — 10 21 41 70 70 70 SCI-2320-005 — 1 300 — 300 125 2.00 0.150 0.063 LB 0.758 (19.253) A — 8 14 30 70 70 70 SCI-2320-006 — 1 300 — 300 125 3.00 0.150 0.027 LB 0.758 (19.253) A — 8 14 26 64 70 70 SCI-2320-007 — 1 300 — 300 125 10.00 0.150 0.003 LB 0.450 (11.430) A — 8 14 25 45 52 70 SCI-2320-014 — 1 300 — 300 125 10.00 0.150 0.003 LB 0.450 (11.430) B — 8 14 25 45 52 70 (See MIL index on pages CF9-11 for complete MIL part number listing) .375 ø L Circuit MIL Qualified Profile Rated Voltage Min M15733 See Pg. I Cap LP30 85°C 125°C MIL Part Number µF for Fig DC AC DC AC Amp No 50 — 0.50 1.400 — — 1 51-390-018 23-0026 ✝ Minimum Insertion Loss (dB) DCR Max Thd 30 150 300 Max L 1 1 10 100 Ohms CKT In (mm) Lgth KHz KHz KHz MHz MHz MHz GHz 0.360 LB 0.630 (16.002) A 70 70 70 48 36 12 69 51-390-026 23-0038 1 — — 50 — 1.00 1.400 0.140 LB 0.630 (16.002) A 11 26 36 55 70 70 70 51-390-034 23-0050 1 — — 50 — 2.00 1.400 0.070 LB 0.630 (16.002) A 10 24 32 48 70 70 70 ✝ 51-353-067 24-0006 1 80 — 50 — 10.00 1.400 0.010 LB 0.760 (19.304) B 15 28 31 42 56 70 70 51-353-207 34-0007 1 — — 50 — 10.00 1.400 0.010 LB 0.760 (19.304) A 15 28 31 42 56 70 70 51-444-072 58-0002 1 80 — 50 — 10.00 1.400 0.008 LT 0.545 (13.843) A 15 28 33 44 60 70 70 ✝ 51-353-066 24-0005 1 80 — 50 — 10.00 1.400 0.010 LB 0.760 (19.304) A 15 28 31 42 56 70 70 51-353-287 39-0014 1 — — 50 — 10.00 1.400 0.003 LT 0.760 (19.304) B 14 28 34 44 52 70 70 ✝ 51-444-060 24-0008 1 80 — 50 — 10.00 1.400 0.010 LT 0.740 (18.796) B 15 28 31 42 56 70 70 ✝ 51-343-028 38-0002 1 — — 50 — 15.00 1.400 0.008 LB 0.481 (12.217) A 15 28 33 44 64 70 70 ✝ 51-343-034 38-0006 1 — — 50 — 15.00 1.400 51-353-053 25-0003 1 — — 100 — ✝ 51-353-054 25-0005 1 — — 100 ✝ 51-353-055 25-0008 1 — — 100 51-353-155 39-0008 1 — — 100 51-444-039 25-0017 1 — — 100 0.008 LB 0.481 (12.217) B 15 28 33 44 64 70 70 1.00 0.450 0.250 LB 0.738 (18.745) A 6 23 34 55 70 70 70 — 5.00 0.450 0.015 LT 0.758 (19.253) A 6 17 23 35 69 70 70 — 5.00 0.450 0.015 LB 0.738 (18.745) A 6 17 23 35 69 70 70 — 5.00 0.450 0.015 LB 0.760 (19.304) A 6 20 26 35 60 60 70 — 5.00 0.450 0.015 LT 0.758 (19.253) B 6 17 23 35 69 70 70 Also available through API’s authorized distributors. API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 LP32 L-C Filter LT Threaded End Hermetically Sealed Threaded Case Filters L-C Filter LB Threaded End .375 ø L Circuit MIL Qualified Profile Rated Voltage Min M15733 See Pg. I Cap LP30 85°C 125°C MIL Part Number µF for Fig DC AC DC AC Amp No — — 100 5.00 0.450 1 51-444-040 25-0020 ✝ continued (See MIL index on pages CF9-11 for complete MIL part number listing) Minimum Insertion Loss (dB) DCR Max Thd 30 150 300 Max L 1 1 10 100 Ohms CKT In (mm) Lgth KHz KHz KHz MHz MHz MHz GHz 0.015 LB 0.738 (18.745) B 70 70 69 6 17 23 35 51-353-156 39-0009 1 — — 100 10.00 0.450 0.003 LT 0.760 (19.304) A 6 20 26 35 56 60 70 51-353-157 39-0010 1 — — 100 10.00 0.450 0.003 LB 0.760 (19.304) A 6 20 26 35 56 60 70 ✝ 51-353-076 26-0001 1 — — 150 125 1.00 0.250 0.250 LT 0.758 (19.253) A — 13 24 45 80 70 70 ✝ 51-353-077 26-0003 1 — — 150 125 1.00 0.250 0.250 LB 0.738 (18.745) A — 13 24 45 80 70 70 51-444-043 26-0013 1 — — 150 125 1.00 0.250 0.250 LT 0.758 (19.253) B — 13 24 45 80 70 70 51-444-044 26-0015 1 — — 150 125 1.00 0.250 0.250 LB 0.738 (18.745) B — 13 24 45 80 70 70 51-390-040 23-0058 1 — — 150 2.00 0.250 0.070 LT 0.630 (16.002) A 3 15 23 38 60 70 60 51-390-039 23-0057 1 — — 150 2.00 0.250 0.070 LT 0.630 (16.002) B 3 15 23 38 60 70 60 51-444-005 34-0015 1 — — 150 125 3.00 0.150 0.050 LT 0.758 (19.253) B — 8 15 30 68 70 70 ✝ 51-353-078 26-0004 1 — — 150 125 3.00 0.250 0.050 LT 0.758 (19.253) A — 8 15 30 68 70 70 ✝ 51-353-079 26-0006 1 — — 150 125 3.00 0.250 0.050 LB 0.738 (18.745) A — 8 15 30 68 70 70 ✝ 51-444-046 26-0018 1 — — 150 125 3.00 0.250 0.050 LB 0.738 (18.745) B — 8 15 30 68 70 70 51-444-047 26-0019 1 — — 150 125 5.00 0.250 0.015 LT 0.758 (19.253) B — 8 14 25 58 70 70 ✝ 51-353-080 26-0007 1 — — 150 125 5.00 0.250 0.015 LT 0.758 (19.253) A — 8 14 25 58 70 70 51-353-081 26-0010 1 — — 150 125 5.00 0.250 0.015 LB 0.738 (18.745) A — 8 14 25 58 70 70 51-444-027 34-0030 1 — — 200 125 5.00 0.250 0.150 LB 0.900 (22.860) A 2 15 21 32 60 70 70 51-444-117 54-0018 2 — — 300 125 1.00 0.150 0.250 LB 0.740 (18.796) A — 10 21 41 70 70 70 Also available through API’s authorized distributors. API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 LP33 Hermetically Sealed Threaded Case Filters .375 ø Pi Circuit Thread length: A - 0.187 (4.76) B - 0.312 (7.92) L A/B .160 (4.064) Max. .200 (5.08) ø .385 Max. (9.779) .115 Ref. (2.921) .050 (1.27) x .070 (1.78) Slot, both ends A/B L .200 (5.08) Max. .150 (3.81) Max. 1/4–28 Unf–2A Thd. Figure 1 ø .385 Max. (9.779) .062 (1.52) ø Hole Both ends 1/4–28 Unf–2A Thd. .115 Ref. (2.92) Figure 2 Dimensions in inches (mm) .375 ø Pi Circuit Standard Product MIL No Figure — 2 Rated Voltage 85°C 125°C DC AC DC AC — 50 80 — Min Cap I Amp µF 0.50 1.500 Minimum Insertion Loss (dB) DCR Max Thd 30 150 300 Max L 1 1 10 100 Ohms In (mm) Lgth KHz KHz KHz MHz MHz MHz GHz 1.000 0.758 (19.253) B 70 70 70 70 70 66 24 SCI-2030-004 — 2 80 — 50 — 1.00 1.500 0.250 0.758 (19.253) A 15 54 70 70 70 70 70 SCI-2030-005 — 2 80 — 50 — 2.00 1.500 0.063 0.758 (19.253) A — 45 62 70 70 70 70 SCI-2030-006 — 2 80 — 50 — 3.00 1.500 0.027 0.758 (19.253) A — 35 55 70 70 70 70 SCI-2030-013 — 2 80 — 50 — 3.00 1.500 0.027 0.758 (19.253) B — 35 55 70 70 70 70 Part Number SCI-2030-010 ✝ 9001-100-1080 — 1 80 — 50 — 5.00 2.800 0.015 0.758 (19.253) A — 18 60 70 70 70 70 ✝ 9001-100-1081 — 1 80 — 50 — 10.0 2.800 0.005 0.758 (19.253) A 21 32 40 35 68 70 70 SCI-2130-009 — 1 150 — 100 — 0.25 1.000 4.000 0.758 (19.253) B 28 70 70 70 70 70 70 51-311-319 — 1 150 — 100 — 0.50 1.000 0.600 0.758 (19.253) A — 51 69 70 70 70 70 — 1 150 — 100 — 0.50 1.000 0.600 0.758 (19.253) A 6 39 68 70 70 70 70 — 1 150 — 100 — 1.00 1.000 0.250 0.758 (19.253) A — 41 60 70 70 70 70 — 1 150 — 100 — 1.00 1.000 0.250 0.758 (19.253) A — 28 59 70 70 70 70 51-311-321 — 1 150 — 100 — 3.00 1.000 0.060 0.758 (19.253) A — 16 41 70 70 70 70 ✝ 51-311-322 — 1 150 — 100 — 5.00 1.000 0.015 0.758 (19.253) A — — 28 65 70 70 70 SCI-2130-007 — 1 150 — 100 — 10.0 1.000 0.003 0.758 (19.253) A 9 24 29 40 70 70 70 SCI-2130-014 — 1 150 — 100 — 10.0 1.000 0.005 0.758 (19.253) B 9 24 29 40 70 70 70 51-311-316 — 1 250 125 200 125 1.00 0.300 0.250 0.758 (19.253) A — 20 40 70 70 70 70 51-311-317 — 1 250 125 200 125 3.00 0.300 0.050 0.758 (19.253) A — — 20 55 70 70 70 ✝ 9001-100-1025 — 1 250 125 200 125 5.00 0.300 0.015 0.758 (19.253) A — — 12 50 70 70 80 SCI-2330-009 — 1 300 125 300 125 0.25 0.300 4.000 0.758 (19.253) B 8 50 66 70 70 70 70 SCI-2330-010 — 1 300 125 300 125 0.50 0.300 1.000 0.758 (19.253) B — 40 56 70 70 70 70 SCI-2330-012 — 1 300 125 300 125 2.00 0.300 0.063 0.758 (19.253) B — 18 33 63 70 70 70 SCI-2330-007 — 1 300 125 300 125 10.0 0.300 0.003 0.758 (19.253) A — 14 20 30 70 70 70 ✝ 9001-100-1010 51-311-320 ✝ 9001-100-1013 ✝ Also available through API’s authorized distributors. API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 LP34 Hermetically Sealed Threaded Case Filters (See MIL index on pages CF9-11 for complete MIL part number listing) .375 ø Pi Circuit MIL Qualified Product See Pg. M15733 LP33 Part Number MIL No for Fig. 1 51-390-305 23-0017 ✝ Rated Voltage 85°C 125°C DC AC DC AC 50 — — — Min Cap I Amp µF 0.30 2.800 Minimum Insertion Loss (dB) DCR Max Thd 30 150 300 Max L 1 1 10 100 Ohms In (mm) Lgth KHz KHz KHz MHz MHz MHz GHz 0.770 0.730 (18.542) B 80 80 80 80 73 29 80 51-390-314 23-0042 1 — — 50 — 1.00 2.800 0.140 0.730 (18.542) A 8 52 71 80 80 80 80 ✝ 51-390-318 23-0054 1 — — 50 — 2.00 1.500 0.070 0.730 (18.542) A — 46 65 80 80 80 80 ✝ 51-390-317 23-0053 1 — — 50 — 2.00 1.500 0.070 0.730 (18.542) B — 46 65 80 80 80 80 51-311-311 25-0010 1 — — 100 — 0.25 0.900 1.500 0.793 (20.142) A — 48 66 80 80 80 70 ✝ 51-311-308 25-0002 1 — — 100 — 1.00 0.500 0.250 0.793 (20.142) A — 33 52 80 80 80 70 ✝ 51-311-309 25-0004 1 — — 100 — 3.00 0.660 0.050 0.793 (20.142) A — 17 34 68 80 80 70 ✝ 51-311-310 25-0006 1 — — 100 — 5.00 0.900 0.015 0.793 (20.142) A — — 17 57 80 80 70 51-353-344 39-0011 1 — — 100 — 10.0 0.990 0.003 0.760 (19.304) A 9 24 29 40 70 70 70 51-353-345 39-0012 1 — — 100 — 10.0 0.990 0.003 0.760 (19.304) A 9 24 29 40 70 70 70 ✝ 51-311-314 26-0011 1 — — 150 125 0.25 0.300 1.500 0.793 (20.142) A — 29 47 70 80 80 70 51-390-312 23-0036 1 — — 150 — 0.50 0.500 0.360 0.730 (18.542) A — 48 66 70 70 70 70 51-390-311 23-0035 1 — — 150 — 0.50 0.500 0.360 0.730 (18.542) B — 48 66 70 70 70 70 ✝ 51-353-336 26-0002 1 — — 150 125 1.00 0.300 0.250 0.793 (20.142) A — 11 32 63 80 80 70 51-390-315 23-0047 1 — — 150 — 1.00 0.500 0.140 0.730 (18.542) B — 32 51 70 70 70 70 51-311-312 26-0005 1 — — 150 125 3.00 0.300 0.050 0.793 (20.142) A — 5 6 47 80 80 70 51-311-408 54-0005 2 — — 300 115 1.00 0.300 0.250 0.761 (19.329) A — 23 43 70 70 70 70 Also available through API’s authorized distributors. Transient Suppression Pi Filters Transient Suppressor* Minimum Insertion Loss (dB) Max See Pg. Rated Max DCR Min Thd 30 300 Length LP33 Volt. 1 RDC VR* Min Cap I BV* IT* IPP* 1 10 100 for Fig. VDC Amp In (mm) Lgth KHz KHz MHz MHz MHz GHz µF Mohms Ohms (VDC) (VDC) (MA) (A) 70 70 70 57 1 5 23 51-570-300 0.50 1.400 0.500 0.600 6.5 7.22/7.98 10 44.7 1.179 (29.947) A 70 Part Number 51-570-301 1 5 1.00 1.400 0.500 0.350 6.5 7.22/7.98 10 44.7 1.179 (29.947) A 3 47 70 70 70 70 51-570-302 1 5 3.00 1.400 0.500 0.060 6.5 7.22/7.98 10 44.7 1.179 (29.947) A — 23 58 70 70 70 51-570-303 1 5 5.00 1.400 0.500 0.015 6.5 7.22/7.98 10 44.7 1.179 (29.947) A — 17 48 70 70 70 51-570-304 1 5 10.00 1.400 0.500 0.005 6.5 7.22/7.98 10 44.7 1.179 (29.947) A 16 26 35 40 60 70 51-570-310 1 28 0.50 1.400 30.000 0.600 33.0 36.7/40.6 1 9.4 1.179 (29.947) A 23 57 70 70 70 70 51-570-311 1 28 1.00 1.400 30.000 0.350 33.0 36.7/40.6 1 9.4 1.179 (29.947) A 3 47 70 70 70 70 51-570-312 1 28 3.00 1.400 30.000 0.060 33.0 36.7/40.6 1 9.4 1.179 (29.947) A — 23 58 70 70 70 51-570-313 1 28 5.00 1.400 30.000 0.015 33.0 36.7/40.6 1 9.4 1.179 (29.947) A — 17 48 70 70 70 51-570-314 1 28 10.00 1.400 30.000 0.005 33.0 36.7/40.6 1 9.4 1.179 (29.947) A 16 26 35 40 60 70 51-570-320 1 50 0.50 1.400 50.000 0.600 58.0 64.4/71.2 1 5.3 1.179 (29.947) A 23 57 70 70 70 70 51-570-321 1 50 1.00 1.400 50.000 0.350 58.0 64.4/71.2 1 5.3 1.179 (29.947) A 3 47 70 70 70 70 51-570-322 1 50 3.00 1.400 50.000 0.060 58.0 64.4/71.2 1 5.3 1.179 (29.947) A — 23 58 70 70 70 51-570-323 1 50 5.00 1.400 50.000 0.015 58.0 64.4/71.2 1 5.3 1.179 (29.947) A — 17 48 70 70 70 51-570-324 1 50 10.00 1.400 50.000 0.005 58.0 64.4/71.2 1 5.3 1.179 (29.947) A 16 26 35 40 60 70 * Transient Suppression definitions and ratings VR = Reverse standoff voltage BV = Breakdown voltage IPP = Max. peak pulse current IT = Test current API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 LP35 Hermetically Sealed Threaded Case Filters .375 ø T Circuit Thread length: A - 0.187 (4.76) B - 0.312 (7.92) L .200 (5.08) A/B .160 (4.064) Max. ø .385 Max. (9.78) .115 Ref. (2.92) .050 (1.27) x .070 (1.78) Slot, both ends 1/4–28 Unf–2A Thd. Figure 1 Dimensions in inches (mm) Note: Max. O.D. is ø .416" for Military QPL Filters. .375 ø T Circuit Standard Product Part Number SCI-2040-012 ✝ MIL No Figure — 1 Rated Voltage 85°C 125°C DC AC DC AC 80 — 50 — Min Cap I Amp µF 2.00 1.400 Minimum Insertion Loss (dB) DCR Max Max Thd 30 150 300 L 1 1 10 100 Ohms In (mm) Lgth KHz KHz KHz MHz MHz MHz GHz 0.126 1.071 (27.203) B 55 70 70 70 30 8 22 SCI-2040-013 — 1 80 — 50 — 3.00 1.400 0.054 1.071 (27.203) B 8 22 28 43 70 70 70 ✝ 9004-100-2017 — 1 80 — 50 — 15.0 1.400 0.005 1.179 (29.947) A 17 27 34 44 60 70 70 SCI-2140-004 — 1 150 — 100 — 1.00 0.500 0.500 1.070 (27.178) A 4 25 40 70 70 70 70 SCI-2140-006 — 1 150 — 100 — 3.00 0.500 0.054 1.071 (27.203) A 4 19 24 39 70 70 70 SCI-2140-007 — 1 150 — 100 — 10.0 0.500 0.010 1.071 (27.203) A 4 19 24 34 57 70 70 SCI-2340-009 — 1 300 — 300 125 0.25 0.150 8.000 1.071 (27.203) B 11 57 70 70 70 70 70 SCI-2340-004 — 1 300 — 300 125 1.00 0.150 0.500 1.071 (27.203) A — 13 29 59 70 70 70 SCI-2340-013 — 1 300 — 300 125 3.00 0.150 0.054 1.071 (27.203) B — 8 14 29 70 70 70 SCI-2340-014 — 1 300 — 300 125 10.0 0.150 0.010 1.071 (27.203) B — 8 14 24 47 70 70 Also available through API’s authorized distributors. (See MIL index on pages CF9-11 for complete MIL part number listing) .375 ø T Circuit MIL Qualified Product M15733 MIL Part Number No Figure 1 51-382-609 25-0024 ✝ Rated Voltage 85°C 125°C DC AC DC AC — — 100 — Min Cap I Amp µF 2.00 0.750 Minimum Insertion Loss (dB) DCR Max Max Thd 30 150 300 L 1 1 10 100 Ohms In (mm) Lgth KHz KHz KHz MHz MHz MHz GHz 0.100 1.179 (29.947) B 70 70 31 80 22 10 55 51-382-603 25-0007 1 — — 100 — 4.00 0.750 0.063 1.345 (34.163) A 10 22 28 43 80 70 70 ✝ 51-351-604 26-0012 1 — — 150 125 2.00 0.250 0.100 1.179 (29.947) A — 13 21 43 80 70 70 51-351-603 26-0008 1 — — 150 125 4.00 0.250 0.063 1.345 (34.163) A — 11 18 33 80 70 70 Also available through API’s authorized distributors. API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 LP36 Hermetically Sealed Threaded Case Filters .375 ø TT Circuit Standard Product See Pg. MIL LP35 No for Fig. — 1 Rated Voltage 85°C 125°C DC AC DC AC — — 50 — Minimum Insertion Loss (dB) DCR Max Min Max Thd 30 150 300 L Cap I 1 1 10 100 Ohms Amp µF In (mm) Lgth KHz KHz KHz MHz MHz MHz GHz 70 70 70 70 0.25 1.500 12.000 1.241 (31.521) B 70 70 70 SCI-2060-013 — 1 — — 50 — 3.00 1.500 0.081 1.241 (31.521) B — 33 54 70 70 70 70 SCI-2060-007 — 1 — — 50 — 10.0 1.500 0.006 1.241 (31.521) A 15 29 35 42 55 70 70 SCI-2060-014 — 1 — — 50 — 10.0 1.500 0.006 1.241 (31.521) B 15 29 35 42 55 70 70 SCI-2160-011 — 1 — — 100 — 1.00 1.500 0.750 1.241 (31.521) B 12 52 70 70 70 70 70 SCI-2160-012 — 1 — — 100 — 2.00 1.500 0.189 1.241 (31.521) B — 33 56 70 70 70 70 SCI-2160-013 — 1 — — 100 — 3.00 1.500 0.081 1.241 (31.521) B — 24 54 70 70 70 70 SCI-2160-014 — 1 — — 100 — 10.0 1.400 0.006 1.241 (31.521) B 12 25 32 42 70 70 70 SCI-2360-011 — 1 — — 300 125 1.00 0.500 0.750 1.241 (31.521) B — 48 70 70 70 70 70 Part Number SCI-2060-009 SCI-2360-006 — 1 — — 300 125 3.00 0.500 0.080 1.241 (31.521) A — 12 38 70 70 70 70 SCI-2360-007 — 1 — — 300 125 10.0 0.500 0.006 1.241 (31.521) A 5 18 24 34 55 70 70 SCI-2360-014 — 1 — — 300 125 10.0 0.500 0.006 1.241 (31.521) B 5 18 24 34 55 70 70 API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 LP37 Hermetically Sealed Threaded Case Filters .690 ø C Circuit L .560 Max. (14.22) .250 (6.35) .312 (7.92) ø .687 ± .015 (17.45 ± .38) .735 Max. (18.62) L 5/16–24 Unf–2A Thd. .062 (1.57) x .125 (3.17) Slot, both ends .115 ± .005 (2.92 ± .127) .250 (6.35) .312 (7.92) Figure 1 ø .687 ± .015 (17.45 ± .38) .093 (2.36) ø Hole, both ends 5/16–24 Unf–2A Thd. Figure 2 Dimensions in inches (mm) .690 ø C Circuit Standard Product Part Number ✝ 9932-100-6004 54-310-001 MIL No Figure — 1 Rated Voltage 85°C 125°C DC AC DC AC 150 200 — — 300 1 — 300 125 Min Cap I Amp µF 15 2.600 DCR Max Ohms 0.005 In 0.702 (mm) (17.831) 0.500 0.005 0.560 (14.224) 15 Max L Minimum Insertion Loss (dB) 1 30 150 300 1 10 100 KHz KHz KHz MHz MHz MHz GHz 70 60 70 50 39 29 10 6 19 25 36 50 70 70 54-310-005 — 2 250 — 200 125 25 0.500 0.005 0.750 (19.050) 6 19 25 36 50 70 70 54-310-009 — 1 450 240 400 240 15 0.250 0.005 0.560 (14.224) — 14 19 30 45 60 70 — 1 450 240 400 240 15 0.250 0.005 0.560 (14.224) — 14 19 30 50 70 70 ✝ 9932-100-6005 .690 ø C Circuit MIL Qualified Product M15733 MIL Figure Part Number No 1 54-310-039 34-0037 Rated Voltage 85°C 125°C DC AC DC AC — — 275 125 Min Cap I Amp µF 15 0.200 DCR Max Ohms 0.005 Max L In 0.575 (mm) (14.605) Minimum Insertion Loss (dB) 1 30 150 300 1 10 100 KHz KHz KHz MHz MHz MHz GHz 5 15 21 31 51 70 70 .690 ø C Circuit DSCC 84084 Product 84084 Part Number No Figure -001 1 54-310-042 ✝ Rated Voltage 85°C 125°C DC AC DC AC — — 400 230 Min Cap I Amp µF 15 0.150 DCR Max Ohms 0.005 Max L In 0.700 (mm) (17.780) Minimum Insertion Loss (dB) 1 30 150 300 1 10 100 KHz KHz KHz MHz MHz MHz GHz — 10 16 26 40 52 70 Also available through API’s authorized distributors. API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 LP38 Hermetically Sealed Threaded Case Filters .690 ø L Circuit L .560 Max. (14.22) .250 (6.35) .312 (7.92) ø .687 ± .015 (17.45 ± .38) 5/16–24 Unf–2A Thd. .062 (1.57) x .125 (3.17) Slot, both ends .115 ± .005 (2.92 ± .127) L .735 Max. (18.62) .250 (6.35) .312 (7.92) Figure 1 ø .687 ± .015 (17.45 ± .38) .093 (2.36) ø Hole, both ends 5/16–24 Unf–2A Thd. Figure 2 Dimensions in inches (mm) .690 ø L Circuit Standard Product MIL No Figure — 1 Rated Voltage 85°C 125°C DC AC DC AC 150 — 100 — Min Cap I Amp µF 10.0 1.400 Minimum Insertion Loss (dB) DCR Max Max L 1 30 150 300 1 10 100 Ohms CKT In (mm) KHz KHz KHz MHz MHz MHz GHz 0.005 LT 0.905 (22.987) 16 44 60 70 24 34 70 SCI-6120-008 — 1 150 — 100 — 10.0 2.600 0.006 LB SCI-6120-009 — 1 150 — 100 — 20.0 2.600 0.001 51-320-041 — 1 250 — 200 125 10.0 0.500 0.008 51-320-024 — 1 450 240 400 240 1.00 0.360 51-320-100 — 1 450 240 400 240 ✝ 51-320-026 — 1 450 240 400 51-320-103 — 1 450 240 51-322-007 — 1 450 51-322-015 — 2 450 51-322-036 — 2 9010-100-0054 — SCI-6320-004 — Part Number 9010-100-0049 ✝ 0.959 (24.359) 18 32 39 49 70 70 70 LB 0.560 (22.987) 18 32 39 49 60 70 70 LT 0.905 (22.987) 5 19 25 35 50 70 70 0.210 LT 0.905 (22.987) 5 30 38 60 70 70 70 1.00 0.250 0.210 LT 0.905 (22.987) — 21 33 55 70 70 70 240 3.00 0.360 0.030 LT 0.905 (22.987) 5 19 25 45 70 70 70 400 240 5.00 0.360 0.010 LB 0.905 (22.987) — 12 18 30 60 70 70 240 400 240 15.0 0.360 0.007 LB 0.650 (16.510) 5 19 25 35 48 62 70 240 400 240 25.0 0.360 0.007 LT 0.750 (19.050) 5 17 23 34 48 62 70 450 240 400 240 25.0 0.250 0.007 LB 0.750 (19.050) — 10 16 29 45 60 70 1 450 240 300 240 1.00 0.150 0.250 LT 0.905 (22.987) — 14 32 52 70 70 70 1 300 — 300 125 1.00 0.400 0.300 LB 0.959 (24.359) 6 24 35 56 70 70 70 Also available through API’s authorized distributors. API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 LP39 L-C Filter LT Threaded End Hermetically Sealed Threaded Case Filters L-C Filter LB Threaded End (See MIL index on pages CF9-11 for complete MIL part number listing) .690 ø L Circuit MIL Qualified Product M15733 See Pg. LP38 MIL Part Number No for Fig. 1 ✝ 51-320-015 27-0005 Rated Voltage 85°C 125°C DC AC DC AC 200 125 — — Min Cap I Amp µF 3.00 0.250 Minimum Insertion Loss (dB) DCR Max Max L 1 30 150 300 1 10 100 Ohms CKT In (mm) KHz KHz KHz MHz MHz MHz GHz LT 0.900 (22.860) — 0.033 80 70 70 21 14 39 51-320-017 27-0008 1 — — 200 125 5.00 0.250 0.016 LT 0.900 (22.860) — 13 19 32 69 70 70 51-320-018 27-0009 1 — — 200 125 5.00 0.250 0.016 LB 0.900 (22.860) — 13 19 32 69 70 70 51-323-003 27-0011 1 — — 200 125 10.0 0.250 0.005 LT 1.031 (26.187) — 13 19 30 61 70 70 51-323-004 27-0012 1 — — 200 125 10.0 0.250 0.005 LB 1.031 (26.187) — 13 19 30 61 70 70 ✝ 51-322-009 27-0014 2 — — 200 125 15.0 0.250 0.007 LT 1.763 (44.780) — 19 25 36 60 70 70 51-322-017 34-0002 2 — — 200 125 20.0 0.360 0.050 LB 1.763 (44.780) — 19 25 35 57 70 70 .690 ø L Circuit DSCC 84084 Product See Pg. 84084 LP38 Part Number No for Fig. -004 1 51-320-162 ✝ Rated Voltage 85°C 125°C DC AC DC AC — — 400 230 Min Cap I Amp µF 1.00 0.150 Minimum Insertion Loss (dB) DCR Max Max L 1 30 150 300 1 10 100 Ohms CKT In (mm) KHz KHz KHz MHz MHz MHz GHz 0.150 LT 0.905 (22.987) — 60 30 70 70 19 46 51-320-163 -005 1 — — 400 230 1.00 0.150 0.150 LB 0.905 (22.987) — 19 30 51-320-164 -006 1 — — 400 230 3.00 0.150 0.026 LT 0.905 (22.987) — 11 19 51-320-165 -007 1 — — 400 230 3.00 0.150 0.026 LB 0.905 (22.987) — 11 19 46 60 70 70 36 60 70 70 36 60 70 70 51-320-166 -008 1 — — 400 230 5.00 0.150 0.013 LT 0.905 (22.987) — 10 16 28 54 70 70 51-320-167 -009 1 — — 400 230 5.00 0.150 0.013 LB 0.905 (22.987) — 10 16 28 54 70 70 51-320-168 -010 1 — — 400 230 10.0 0.150 0.008 LT 0.905 (22.987) — 10 16 25 48 70 70 51-320-169 -011 1 — — 400 230 10.0 0.150 0.008 LB 0.905 (22.987) — 10 16 25 48 70 70 Also available through API’s authorized distributors. API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 LP40 Hermetically Sealed Threaded Case Filters .690 ø Pi Circuit L .250 (6.35) .560 Max. (14.22) .312 (7.92) L .555 Max. (14.10) ø .687 ± .015 (17.45 ± .38) .250 (6.35) .312 (7.92) .115 ± .005 (2.921 ± .127) .062 (1.57) x .125 (3.18) Slot, both ends ø .687 ± .015 (17.45 ± .38) 5/16–24 Unf–2A Thd. .140 Max. (3.56) Figure 1 .062 (1.57) x .125 (3.18) Slot, both ends 5/16–24 Unf–2A Thd. Figure 2 Dimensions in inches (mm) .690 ø Pi Circuit Standard Product MIL No Figure — 1 Rated Voltage 85°C 125°C DC AC DC AC 150 — 100 — Min Cap I Amp µF 1.00 2.800 DCR Max Ohms 0.210 In 1.195 (mm) (30.353) SCI-6130-009 — 1 150 — 100 51-321-317 — 1 450 240 400 ✝51-321-318 — 1 450 240 ✝51-321-319 — 1 450 240 Part Number 51-321-322 Max L Minimum Insertion Loss (dB) 1 30 150 300 1 10 100 KHz KHz KHz MHz MHz MHz GHz 35 69 70 70 70 70 70 20.0 5.200 0.001 1.195 (30.353) 23 31 35 35 70 70 70 *240 1.00 0.720 0.400 1.195 (30.353) — 53 70 70 70 70 70 400 *240 3.00 0.720 0.030 1.195 (30.353) — 31 51 70 70 70 70 400 *240 5.00 0.720 0.020 1.195 (30.353) — 11 30 65 70 70 70 — * 0-60 Hz (See MIL index on pages CF8-10 for complete MIL part number listing) .690 ø Pi Circuit MIL Qualified Product M15733 MIL Figure Part Number No 1 51-321-312 27-0004 Rated Voltage 85°C 125°C DC AC DC AC — — 200 125 Min Cap I Amp µF 1.00 0.500 DCR Max Ohms 0.250 In 1.195 (mm) (30.353) Max L Minimum Insertion Loss (dB) 1 30 150 300 1 10 100 KHz KHz KHz MHz MHz MHz GHz 70 70 — 47 65 80 80 51-323-313 27-0003 1 — — 200 125 1.00 0.500 0.270 1.031 (26.187) — 43 61 80 80 70 70 51-321-313 27-0010 1 — — 200 125 5.00 0.500 0.024 1.195 (30.353) — 10 28 64 80 70 70 ✝ 51-321-314 27-0013 1 — — 200 125 10.0 0.500 0.008 1.195 (30.353) — 16 18 48 80 70 70 51-321-329 34-0005 1 — — 200 125 10.0 0.500 0.075 1.195 (30.353) — 16 18 48 80 70 70 .690 ø Pi Circuit DSCC 84084 Product Min Cap I Amp µF 1.00 0.200 DCR Max Ohms 0.150 In 1.200 (mm) (30.480) 2 — — 400 230 3.00 0.200 0.026 1.200 (30.480) — — 30 60 80 80 80 2 — — 400 230 5.00 0.200 0.013 1.200 (30.480) — — 12 50 80 80 80 2 — — 400 230 10.0 0.200 0.008 1.200 (30.480) — — — 30 80 80 80 51-321-398 Figure 2 51-321-399 -014 51-321-400 -015 51-321-401 -016 Part Number ✝ Rated Voltage 85°C 125°C DC AC DC AC — — 400 230 84084 No -013 Max L Minimum Insertion Loss (dB) 1 30 150 300 1 10 100 KHz KHz KHz MHz MHz MHz GHz — 27 46 74 80 80 80 Also available through API’s authorized distributors. API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 LP41 Hermetically Sealed Threaded Case Filters .690 ø T Circuit .560 Max. (14.22) L .250 (6.35) .312 (7.92) ø .687 ± .015 (17.45 ± 0.38) .115 ± .005 (2.92 ± .127) .062 (1.57) x .125 (3.18) Slot, both ends 5/16–24 Unf–2A Thd. .591 Max. (15.01) L .250 (6.35) .312 (7.92) Figure 1 ø .680 Max. (17.272) .125 Ref. (3.175) 5/16–24 Unf–2A Thd. .062 (1.57) x .125 (3.18) Slot, both ends Figure 2 Dimensions in inches (mm) .690 ø T Circuit Standard Product MIL No Figure — 1 Rated Voltage 85°C 125°C DC AC DC AC 150 — 100 — Min Cap I Amp µF 1.00 2.600 DCR Max Ohms 0.600 In 1.195 (mm) (30.353) SCI-6140-006 — 1 150 — 100 — 3.00 2.600 0.100 1.195 (30.353) 21 35 46 70 70 70 70 SCI-6140-007 — 1 150 — 100 — 5.00 2.600 0.060 1.195 (30.353) 21 34 41 58 70 70 70 SCI-6140-009 — 1 150 — 100 — 20.0 2.600 0.002 1.195 (30.353) 21 35 41 50 60 70 70 51-321-649 — 1 250 125 200 125 2.00 0.360 0.090 1.195 (30.353) — 24 38 65 70 70 70 ✝ 51-321-610 — 1 450 240 400 240 1.00 0.360 0.600 1.195 (30.353) 7 43 60 70 70 70 70 Part Number SCI-6140-004 Max L (See MIL index on pages CF8-10 for complete MIL part number listing) .690 ø T Circuit MIL Qualified Product M15733 MIL Figure Part Number No 1 51-321-607 27-0017 ✝ Minimum Insertion Loss (dB) 1 30 150 300 1 10 100 KHz KHz KHz MHz MHz MHz GHz 23 54 70 70 70 70 70 Rated Voltage 85°C 125°C DC AC DC AC — — 200 125 Min Cap I Amp µF 1.50 0.250 DCR Max Ohms 0.133 In 1.195 (mm) (30.353) Max L Minimum Insertion Loss (dB) 1 30 150 300 1 10 100 KHz KHz KHz MHz MHz MHz GHz — 19 32 62 70 70 70 51-321-608 27-0018 1 — — 200 125 4.00 0.250 0.025 1.195 (30.353) — 14 21 36 70 70 70 51-321-670 54-0017 2 — — 300 115 10.0 0.500 0.006 1.177 (29.896) 5 20 23 35 60 70 60 Also available through API’s authorized distributors. API TECHNOLOGIES • 8061 Avonia Rd. • Fairview, PA 16415 • Ph: 814-474-1571 • Fax: 814-474-3110 • eis.apitech.com API TECHNOLOGIES’ SPECTRUM CONTROL GmbH • Hansastrasse 6 • 91126 Schwabach, Germany • Phone: (49)-9122-795-0 • Fax: (49)-9122-795-58 LP42
9053F-100-0001 价格&库存
很抱歉,暂时无法提供与“9053F-100-0001”相匹配的价格&库存,您可以联系我们找货
