SSM1F-202P-10T1
SSM1F-202P-10T1
    APITECHNOLOGIES
    FILTERLC(PI)2000PFSMD
SSM1F-202P-10T1 数据手册
The Electromagnetic Spectrum Innovator CONTACT US DATA SHEET Square Surface Mount (SSM) & Round Surface Mount (RSM) Filters Low Pass EMI Filters Pi Insertion Loss Typical SMT Applications SSM Series 100 I I Pi - 4000 pf - 2500 pf ,3 50 ~ C 0 7f 40 ~ - 1500 pf 1000 pl 820 pf 470 pf 130pf 100 pf 68 pf 80 !g 70 ~ i 60 _ . w .!: 30 ~ Ground I 11 11111 * See note 90 - 20 Working Voltage 100 VDC Test Voltage 250 VDC Current Max. 10 Amps Insulation Resistance Min. 104 MΩ Terminations Silver Ni-Tin Plated Soldering Conditions Max. 250°C -5 sec. Marking None Packaging Bulk or tape and reel 1111 11111 10 1111 11111 0 0.0 1 0. 1 I I 1,,- .k 1 v/ ~~ · [::;:: 10 I ,,Y I 1000 3000 100 Frequency (MHz) Shielded or Partition Applications 100 90 I 111 11111 I •- * See11ote - 4000 pf 2500 pf _ 70 - - 1500 pf ,_ - 1000 pf - 820 pf 470 pf 135 pf 100pf 68 pf 80 m i 60 50 ~ ~ 40 .E 30 ~ ~ C i 0 20 1111 11111 10 0 Note: Insertion loss shown for the following SSM values* only: [7'7 V / 1111 11111 0. 1 V I /; / IVV vii , 0.0, 101Z, 501P, and 202P '/, ~~ I l!.1/ V; / / l% / ~ I I 1,,- · •~ t;:::-- 1 10 Frequency (MHz) / V/1 ' 100 ~ I 1000 3000 *Capacitance values for IL curves are displayed left to right in the order shown. Additional IL charts available by request. RSM Series SSM Pi Input ~ O u t p u t TIT Ground Working Voltage 100 VDC Test Voltage 250 VDC Current Max. 10 Amps Insulation Resistance Min. 104 MΩ Terminations Silver Ni-Tin Plated Soldering Conditions Max. 250°C -5 sec. Marking None Packaging Bulk or tape and reel Note: Insertion loss shown for the following RSM values only: 152P and 402Z www.apitech.com | 855.294.3800 | communications@apitech.com | RSM NI/SN OVER AG PLATED TUBE .315 (8.00) Max . .083±.004 (2.1 ± 1.0) j ~ SOO)M,.1.1l+;'olf{.ll:J 1.100,0 012/ 040 (0 3/1 OJ+I + (>O>! M;o + I+ 012/.040 (0.3/1 .0) Dimensions in inches (111111 ) www.linkedin.com/company/api-technologies-corp-/ 1 The Electromagnetic Spectrum Innovator DATA SHEET Square Surface Mount (SSM) & Round Surface Mount (RSM) Filters Low Pass EMI Filters SSM & RSM Ordering Information Example: SSM1-101Z-05T SSM 1 101Z 05 T 1 Tape and Reel 1 = 1,000 pieces 6 = 6,000 pieces Current Rating 05 - 5 Amps 10 - 10 Amps Circuit Confguration 1 - Pi Note: Tape and reel packaging - 1,000 pieces (7”) and 6,000 pieces (13”) Style SSM (Square) RSM (Round) Code 101Z 501P 152P 202P 402E 402Z Value 100pF 500pF 1500pF 2000pF 4000pF 4000pF Tolerance +80/-20% +100/-0% +100/-0% 100/-0% ±25 +80/-20% Packaging T = Tape and reel packaging R = Bulk packaging † Also available through APITech’s authorized distributors. € Also available through APITech’s authorized European distributors/agents. † SSM1-152P-05-T1 € SSM/RSM Tape and Reel Packaging .157 .295 (4.00) (7.50) SSM Recommended Board Pattern .043 (1.1) 1 -i I r- .043 (1.1) 7 .093 (2.36) -----r­ Min . .315 ~~_J (8.00) ___i_ 1-- .102 (2 6) -I Dimensions in inches (mm) www.apitech.com | 855.294.3800 | communications@apitech.com | APPROVED FOR PUBLIC RELEASE 052521ED www.linkedin.com/company/api-technologies-corp-/ 2
SSM1F-202P-10T1
1. 物料型号:文档中提到了两种类型的滤波器,分别是方形表面贴装(SSM)和圆形表面贴装(RSM)滤波器。例如,SSM1-101Z-05T是SSM系列的一个型号,其中1代表Pi电路配置,101Z是特定的电容值,05代表5安培的电流等级,T代表胶带和卷轴包装。
2. 器件简介:这些滤波器用于抑制电磁干扰,适用于表面贴装技术(SMT)应用。
3. 引脚分配:SSM系列的引脚分配为输入、输出和地,而RSM系列则为输入、输出和地,且有屏蔽或分区应用的选项。
4. 参数特性:包括工作电压(100VDC)、测试电压(250VDC)、最大电流(10安培)、最小绝缘电阻(10^4 MΩ)、端子镀层(银镍锡)、最大工作温度(250°C持续5秒)。
5. 功能详解:文档提供了插入损耗(Insertion Loss)的典型曲线,展示了不同电容值的滤波器在不同频率下的插入损耗。
6. 应用信息:适用于屏蔽或分区应用,文档中还提供了SSM和RSM的典型SMT应用图。
7. 封装信息:提供了SSM和RSM滤波器的尺寸信息,以及推荐的PCB布局图案。
SSM1F-202P-10T1 价格&库存
很抱歉,暂时无法提供与“SSM1F-202P-10T1”相匹配的价格&库存,您可以联系我们找货
