RFBPF1608060A1T
RFBPF1608060A1T
    WALSIN(华新科)
    1608封装2.4GHZ ISM频段带通滤波器
RFBPF1608060A1T 数据手册
Approval sheet RFBPF Series – 1608(0603)- RoHS Compliance MULTILAYER CERAMIC BAND PASS FILTER Halogens Free Product 2.4 GHz ISM Band Working Frequency P/N: RFBPF1608060A1T *Contents in this sheet are subject to change without prior notice. Page 1 of 7 ASC_RFBPF1608060A1T_V05 Apr. 2016 Approval sheet FEATURES 1. Miniature footprint: 1.6 X 0.8 X 0.6 mm 2. Low Profile Thickness 3. Low Insertion loss 4. High Rejection Rate 5. High attenuation on 2 6. LTCC process nd 3 harmonic suppressed APPLICATIONS 1. 2.4GHz ISM band RF applications 2. Bluetooth, Wireless LAN 802.11b/g, HomeRF CONSTRUCTION Top view P2 P1 P3 PIN Connection 1 Input port 2 GND 3 Output port 4 GND P4 DIMENSIONS Figure Symbol Dimension (mm) L 1.60 ± 0.15 W 0.80 ± 0.15 T 0.60 ± 0.10 A 0.70 ± 0.15 B 0.30 ± 0.15 C 0.45 ± 0.15 D 0.20 ± 0.10 E 0.20 ± 0.10 Top view Bottom view Side view Side view Page 2 of 7 ASC_RFBPF1608060A1T_V05 Apr. 2016 Approval sheet ELECTRICAL CHARACTERISTICS RFBPF1608060A1T Specification Frequency range 2400 ~ 2500 MHz Insertion Loss 2.8 dB max. 25 dB min. @ 695 ~ 800 MHz 20 dB min. @ 1910 MHz Attenuation 35 dB min. @ 3200 MHz 20 dB min. @ 4800 ~ 5000 MHz 20 dB min. @ 7200 ~ 7500 MHz VSWR 2.0 max. Impedance 50 Ω Operation Temperature Range -40C ~ +85C Moisture sensitivity levels MSL is LEVEL 1 (Refer to : IPC/JEDEC J-STD-020) Typical Electrical Chart Return Loss Insertion Loss SOLDER LAND PATTERN Figure Unit : mm Line width to be designed to match 50 Ω characteristic impedance, depending on PCB material and thickness. Page 3 of 7 ASC_RFBPF1608060A1T_V05 Apr. 2016 Approval sheet RELIABILITY TEST Test condition / Test method Test item Solderability *Solder bath temperature:235  5C Specification At least 95% of a surface of each terminal JIS C 0050-4.6 *Immersion time:2  0.5 sec electrode must be covered by fresh solder. JESD22-B102D Solder:Sn3Ag0.5Cu for lead-free Leaching *Solder bath temperature:260  5C (Resistance to *Leaching immersion time:30  0.5 sec dissolution of Loss of metallization on the edges of each electrode shall not exceed 25%. Solder : SN63A metallization) IEC 60068-2-58 Resistance to soldering *Preheating temperature:120~150℃, No mechanical damage. 1 minute. Electrical specification shall satisfy the *Solder temperature:2705C descriptions in electrical characteristics under heat JIS C 0050-5.4 *Immersion time:101 sec the operational temperature range within -40 ~ 85°C. Solder:Sn3Ag0.5Cu for lead-free Loss of metallization on the edges of each Measurement to be made after keeping at electrode shall not exceed 25%. room temperature for 242 hrs Drop Test JIS C 0044 *Height:75 cm No mechanical damage. Customer’s specification. *Test Surface:Rigid surface of concrete or Electrical specification shall satisfy the steel. *Times:6 surfaces for each units;2 times for each side. Vibration JIS C 0040 descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. *Frequency:10Hz~55Hz~10Hz(1min) No mechanical damage. *Total amplitude:1.5mm Electrical specification shall satisfy the *Test times:6hrs.(Two hrs each in three mutually perpendicular directions) descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. Adhesive Strength of Termination JIS C 0051- 7.4.3 Bending test JIS C 0051- 7.4.1 *Pressurizing force: 5N(≦0603);10N(>0603) No remarkable damage or removal of the termination. *Test time:10±1 sec The middle part of substrate shall be No mechanical damage. pressurized by means of the pressurizing rod Electrical specification shall satisfy the at a rate of about 1 mm/s per second until the descriptions in electrical characteristics under deflection becomes 1mm/s and then pressure the operational temperature range within -40 ~ shall be maintained for 51 sec. 85°C. Measurement to be made after keeping at room temperature for 242 hours Page 4 of 7 ASC_RFBPF1608060A1T_V05 Apr. 2016 Approval sheet Temperature cycle JIS C 0025 1. 303 minutes at -40C3C, No mechanical damage. 2. 10~15 minutes at room temperature, Electrical specification shall satisfy the 3. 303 minutes at +85C3C, 4. 10~15 minutes at room temperature, Total 100 continuous cycles descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. Measurement to be made after keeping at room temperature for 242 hrs High temperature JIS C 0021 *Temperature:85C2C No mechanical damage. *Test duration:1000+24/-0 hours Electrical specification shall satisfy the Measurement to be made after keeping at room temperature for 242 hrs descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. Humidity (steady conditions) *Humidity:90% to 95% R.H. No mechanical damage. *Temperature:402C Electrical specification shall satisfy the JIS C 0022 *Time:1000+24/-0 hrs. Measurement to be made after keeping at room temperature for 242 hrs descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. ※ 500hrs measuring the first data then 1000hrs data Low temperature JIS C 0020 *Temperature:-40C2C No mechanical damage. *Test duration:1000+24/-0 hours Electrical specification shall satisfy the Measurement to be made after keeping at room temperature for 242 hrs descriptions in electrical characteristics under the operational temperature range within -40 ~ 85°C. Page 5 of 7 ASC_RFBPF1608060A1T_V05 Apr. 2016 Approval sheet SOLDERING CONDITION Typical examples of soldering processes that provide reliable joints without any damage are given in Fig 2, Fig 2. Infrared soldering profile ORDERING CODE RF BPF 160806 0 Walsin Product Code Dimension code RF device BPF : Band Pass Filter Per 2 digits of Length, Width, Thickness : A Unit of dimension 0 : 0.1 mm 1 T Application Specification Packing A : 2.4GHZ ISM Band Code from 0 ~ 9 dependent on different electrical specification T : Reeled 1 : 1.0 mm e.g. : 160807 = Length 16, Width 08, Thickness06 Minimum Ordering Quantity: 4000 pcs per reel. PACKAGING Paper Tape specifications (unit :mm) Index Dimension (mm) Index Dimension (mm) Page 6 of 7 Ao Bo D T W 0.975  0.05 1.76  0.05 1.55 + 0.05 0.75  0.03 8.0  0.10 E F Po P1 P2 1.75  0.10 3.50  0.05 4.00  0.10 4.00  0.10 2.00  0.05 ASC_RFBPF1608060A1T_V05 Apr. 2016 Approval sheet Reel dimensions C Index A Φ178.0 Dimension (mm) B Φ60.0 A B C Φ13.0 Taping Quantity: 4000 pieces per 7” reel CAUTION OF HANDLING Limitation of Applications Please contact us before using our products for the applications listed below which require especially high reliability for the prevention of defects, which might directly cause damage to the third party’s life, body or property. (1) (2) (3) (4) (5) (6) (7) (8) Aircraft equipment Aerospace equipment Undersea equipment Medical equipment Disaster prevention / crime prevention equipment Traffic signal equipment Transportation equipment (vehicles, trains, ships, etc.) Applications of similar complexity and /or reliability requirements to the applications listed in the above. Storage condition (1) Products should be used in 6 months from the day of WALSIN outgoing inspection, which can be confirmed. (2) Storage environment condition.        Page 7 of 7 Products should be storage in the warehouse on the following conditions. Temperature : -10 to +40℃ Humidity : 30 to 70% relative humidity Don’t keep products in corrosive gases such as sulfur. Chlorine gas or acid or it may cause oxidization of electrode, resulting in poor solderability. Products should be storage on the palette for the prevention of the influence from humidity, dust and son on. Products should be storage in the warehouse without heat shock, vibration, direct sunlight and so on. Products should be storage under the airtight packaged condition. ASC_RFBPF1608060A1T_V05 Apr. 2016
RFBPF1608060A1T
物料型号:RFBPF1608060A1T
器件简介:华新科技股份有限公司生产的多层陶瓷带通滤波器,符合RoHS标准,无卤产品,工作频率为2.4GHz ISM频段。
引脚分配:有4个引脚,其中1号引脚为输入端口,2号和4号引脚为地(GND),3号引脚为输出端口。
参数特性: - 工作频率范围:2400~2500 MHz - 插入损耗:最大2.8 dB - 抑制损耗:在不同频率有不同最小值,例如695~800 MHz为25 dB,1910 MHz为20 dB - 回波损耗:最大2.0 - 阻抗:50欧姆 - 工作温度范围:-40°C~+85°C - 湿度敏感等级:MSL 1级
功能详解:该滤波器具有微型尺寸、低轮廓厚度、低插入损耗、高抑制率、高2次谐波抑制和LTCC工艺等特点,适用于2.4GHz ISM频段的射频应用,如蓝牙、无线局域网802.11b/g、HomeRF等。
应用信息:适用于2.4GHz ISM频段的射频应用,包括蓝牙、无线局域网802.11b/g、HomeRF等。
封装信息:封装尺寸为1.6mm x 0.8mm x 0.6mm,提供了详细的尺寸图和焊接盘图案,以及焊接条件和订购代码。
可靠性测试包括焊接性、耐焊接热性、跌落测试、振动测试、端子粘接强度和弯曲测试等。
RFBPF1608060A1T 价格&库存
很抱歉,暂时无法提供与“RFBPF1608060A1T”相匹配的价格&库存,您可以联系我们找货
RFBPF1608060A1T
    • 1+0.71378
    • 200+0.27627
    • 500+0.26655
    • 1000+0.26180
