RFBPF2012090A1T
RFBPF2012090A1T
    WALSIN(华新科)
    射频器件及定制天线
RFBPF2012090A1T 数据手册
Table of contents INDEX Subject Page ORDERING CODE…………………………....…………………………………………………………………………………..……………1~5 CHIP ANTENNA…………………………....…………………………………………………………………………………………………… 5~12 ■ 1.575GHz GPS BAND WORKING FREQUENCY ■ Bluetooth/WiFi BAND WORKING FREQUENCY ■ WiMAX BAND WORKING FREQUENCY ■ UHF BAND WORKING FREQUENCY HIGH FREQUENCY MULTILAYER BAND PASS FILTER………………………………………………………………………..………13~29 ■ 2.4GHz BAND WORKING FREQUENCY ■ WiMAX BAND WORKING FREQUENCY ■ 5GHz BAND WORKING FREQUENCY ■ 1558 ~ 1606 MHz GNSS Band Applications ■ 860~960MHz/1805~2025 MHz Band Application ■ MoCA / Docsis Application ■ LTE BAND Application HIGH FREQUENCY MULTILAYER BALANCED FILTER……………………………………………………………………..…………30~33 ■ 2.4GHz BAND WORKING FREQUENCY HIGH FREQUENCY MULTILAYER LOW PASS FILTER………………………………………………………………………..…………34~43 ■ GSM850/900GHz BAND WORKING FREQUENCY ■ DCS/PCS BAND WORKING FREQUENCY ■ 2.4GHz BAND WORKING FREQUENCY ■ 5GHz BAND WORKING FREQUENCY ■ LTE BAND APPLICATION ■ MoCA Application HIGH FREQUENCY MULTILAYER HIGH PASS FILTER………………………………………………………………………..…………44~45 ■ 2496 ~ 2690 MHz BAND WORKING FREQUENCY ■ 5GHz BAND WORKING FREQUENCY ■ MoCA Application BALUN TRANSFORMERS………………………………………………………………………………………………………..……………46~55 ■ ISM Band 2.4GHz Application ■ ISM Band 5GHz Application ■ LTE Band Application ■ GSM 850/ GSM 900/ DCS1800/ PCS1900 Application DIPLEXER…………………………………………………………………………………………………………………………..…………… 56~66 ■ ISM Band 2.4GHz/5GHz Application ■ GPS 1.575GHz/ISM 2.4GHz/5GHz Band Application ■ 892 MHz & 1.94GHz Band Working Frequency TRIPLEXER……………………………………………………………………………………………………………………………..……… 67~70 ■ GPS 1.575GHz/ISM 2.4GHz/5GHz Band RF Application COMMON MODE FILTER……………………………………………………………………………………………………………..……………71 ■ DISCRETE CMF for HIGH SPEED TRANSMISSION LINES、USB2.0、IEEE1394、LVDS(mini) COUPLER…………………………………………………………………………………………………………………………..……………72~76 ■ ISM Band 2.4GHz Application ■ ISM Band 2.4/5GHz Application ■ LTE BAND Application SAW FILTER………………………………………………………………………………………………………………………..……………77~85 ANTENNA SWITCH (GPIO) ……………………………………………………………………………………………………..……………86~87 ANTENNA SWITCH (MIPI) …………………………………………………………………………………………………………..………88~89 ANTENNA SWITCH (LTE Antenna Tuner- GPIO)……………….……………………………………………………………..……………90 ANTENNA SWITCH (Network-GPIO)………………………………………………………………………………………….……………….91 Customer made Antenna………………………………………………………………………………………………………..…………92~102 ■ Dipole Antenna (None Cable and With Cable) ■ PCB Antenna ■ FPA Antenna ■ Metal Antenna ■ NFC Antenna ■ Connector *The specifications are subject to change or our products in it may be discontinued without advance notice. Please check with our sales representatives or product engineers before ordering. *This catalog has only typical specifications because there is no space for detailed specifications. Therefore, please approve our product specifications or transact the approval sheet for product specifications before ordering. ORDERING CODE  CHIP ANTENNA RF ANT 321612 0 A 5 T Type code Product code Dimension code Unit of dimension Application Specification Packing RF/RG: device ANT : Antenna FRA : Free Antenna ECA : SMD Antenna Per 2 digits of Length, Width, Thickness 321612 = Length =32 Width = 16 Thickness = 12 0 : 0.1 mm 1 : 1.0 mm A: 2.4GHz ISM Band E : GPS 1.5GHz L : 2.4/5.2/5.8GHz Tri Band W : WiMAX Code from 0~9 dependent on different electrical specification T: 7” Reeled G: 13” Reeled  HIGH FREQUENCY MULTILAYER BAND PASS FILTER RF BPF 322515 0 A 4 T Type code Product code Dimension code Unit of dimension Application Specification Packing RF device BPF : Band Pass Filter Per 2 digits of Length, Width, Thickness 322515 = Length =32 Width = 25 Thickness = 15 0 : 0.1 mm 1 : 1.0 mm A : 2.4GHz ISM Band W : WiMAX K : ISM 5.2/5.8 Dual Band Code from 0~9 dependent on different electrical specification T: 7” Reeled G: 13” Reeled  HIGH FREQUENCY MULTILAYER BALANCED FILTER RF BPB 252009 0 A 7 T Type code Product code Dimension code Unit of dimension Application Specification Packing RF/RG: device BPB : Balanced Type Band Pass Filter Per 2 digits of Length, Width, Thickness 252009 = Length =25 Width = 20 Thickness = 09 0 : 0.1 mm 1 : 1.0 mm A : 2.4GHz ISM Band W : WiMAX Code from 0~9 dependent on different electrical specification T: 7” Reeled G: 13” Reeled  HIGH FREQUENCY MULTILAYER LOW PASS FILTER RF LPF 201211 0 A 0 T Type code Product code Dimension code Unit of dimension Application Specification Packing RF device LPF : Low Pass Filter Per 2 digits of Length, Width, Thickness 201210 = Length =20 Width = 12 Thickness = 11 0 : 0.1 mm 1 : 1.0 mm A : 2.4GHz ISM Band K : ISM 5.2/5.8 Dual Band Code from 0~9 dependent on different electrical specification T: 7” Reeled G: 13” Reeled  HIGH FREQUENCY MULTILAYER HIGH PASS FILTER RF HPF 252009 0 L 0 T Type code Product code Dimension code Unit of dimension Application Specification Packing RF device HPF : High Pass Filter Per 2 digits of Length, Width, Thickness 252009 = Length =2.5 Width = 2.0 Thickness = 0.9 0 : 0.1 mm 1 : 1.0 mm L : 2.4/4.9/5.2/5.8GHz Multiband Application Code from 0~9 dependent on different electrical specification T: 7” Reeled G: 13” Reeled  BALUN TRANSFORMERS RF BLN 201208 0 A 4 T Type code Product code Dimension code Unit of dimension Application Specification Packing Code from 0~9 dependent on different electrical specification T: 7” Reeled G: 13” Reeled RF/RG: device 1 BLN : BALUN Per 2 digits of Length, Width, Thickness 201208 = Length =20 Width = 12 Thickness = 08 0 : 0.1 mm 1 : 1.0 mm A : 2.4GHz ISM Band K : ISM 5.2/5.8 Dual Band ORDERING CODE  DIPLEXER RF DIP Type code Product code RF device 201210 0 L 0 T Dimension code Unit of dimension Application Specification Packing Per 2 digits of Length, Width, Thickness 201210 = Length =20 Width = 12 Thickness = 10 DIP : Diplexer 0 : 0.1 mm 1 : 1.0 mm Code from 0~9 dependent on different electrical specification L : 2.4/4.9/5.2/5.8GHz Multiband Application T : 7” Reeled G:13” Reeled  TRIPLEXER RF TIP 2109 A T M0T63 Type code Product code Dimension code Pin Define Application Specification RF device Per 2 digits of Length, Width, Thickness e.g. : 21 = Length 2.0 mm, Width 1.2 mm, 09= Thickness 0.9 mm TIP : Triplexer Design Code T: GPS/ ISM 2.4GHz/5 GHz Design Code  COMMON MODE FILTER RF CMF Type code Product code RF/RG: device CMF : Common Mode Filter 122010 0 M 3 T Dimension code Unit of dimension Application Specification Packing Code from 0~9 dependent on different electrical specification T : 7” Reeled Per 2 digits of Length, Width. 122010 = Length =12 Width = 20 Thickness = 10 0 : 0.1 mm 1 : 1.0 mm M: USB 2.0/ IEEE1394  COUPLER RF CPL Type code Product code RF device 18 10 B 2450 T Dimension code Coupling Factor Unit Application Packing e.g. : 18 = Length 16, Width 08, 15= Length 10, Width 05, Coupler 10 dB dB 2.4 GHZ ISM Band T : 7” Reeled  SAW FILTER SF 1411 Product code Dimension code Per 2 digits of Length, Width 1411= Length 1.4mm Width 1.1mm SF:SAW Filter DF:SAW DUPLEXER 2595 B38 03 T Frequency Application Serial Number Packing 2595:Center Freq (2595MHz) B38:Band38 Design Code T: 7” Reeled  ANTENNA SWITCH RF ASW D H2418A T Type code Product code Application Serial Number Packing RF device ASW: Antenna Switch D: SP8T Design Code T: 7” Reeled  ANTENNA SWITCH MODULE RM ASM N T1492A T Type code Product code Application Serial Number Packing RM: Walsin RF Module Device ASM: Antenna Switch Module N: SP16T Design Code T: 7” Reeled 2 ORDERING CODE  Dipole Antenna RF DPA 8709 00 S B Type code Product code Dimension code Cable Length code Connector Brand code Type of Connector code RF device DPA: Dipole Antenna Per 2 digits of Length, Width 8709 = Length = 87 Width = 9.95 A: N C:MCX D:IPEX III E: IPEX IV F: IPEX A13 2 digits for cable H: Hirose length I: IPEX 00= K:F None Cable M: MMCX S: SMA T: TNC U:MURATA N: None A B 8 01 Application code Project status code Wire Diameter code Project code 0: 0GHz 5: 5 GHz A: 2.4GHz ISM band A: Reverse Female B: GSM 900/1800 dual B: Reverse Male band F: Female G: GPS band M: Male L: 2.4/5.2/5.8 GHz N: None tri-band T:LTE band U:UHF W: WCDMA band B: MP T:During Test X: Pile Run 0:None 1:∅0.81 2:∅1.32 3:∅1.13 4:Low Loss∅1.13 5:∅0.50 6:RG316 7:∅1.37 8:RG178 9:Low Loss∅1.37 A:RG174 B:1.5C-2V 01~99 series number  PCB Antenna RF PCA 4305 10 N N A B 4 01 Type code Product code Dimension code Cable Length code Connector Brand code Type of Connector code Application code Project status code Wire Diameter code Project code RF device A: N C:MCX D:IPEX III E: IPEX IV Per 2 digits of 2 digits for cable F: IPEX A13 H: Hirose Length, Width length PCA: I: IPEX 4305 = 10= PCB Antenna K:F Length = 43 Cable Length: M: MMCX Width = 5 10cm S: SMA T: TNC U:MURATA N: None 0: 0GHz 5: 5 GHz A: 2.4GHz ISM band A: Reverse Female B: GSM 900/1800 dual B: Reverse Male band F: Female G: GPS band M: Male L: 2.4/5.2/5.8 GHz N: None tri-band T:LTE band U:UHF W: WCDMA band B: MP T:During Test X: Pile Run 0:None 1:∅0.81 2:∅1.32 3:∅1.13 4:Low Loss∅1.13 5:∅0.50 6:RG316 7:∅1.37 8:RG178 9: Low Loss∅1.37 A:RG174 B:1.5C-2V 01~99 series number  FPA Antenna RF FPA 3025 10 I M A B 3 01 Type code Product code Dimension code Cable Length code Connector Brand code Type of Connector code Application code Project status code Wire Diameter code Project code RF device A: N C:MCX D:IPEX III E: IPEX IV Per 2 digits of 2 digits for cable F: IPEX A13 H: Hirose Length, Width length FPA: I: IPEX 3025 = 10= FPA Antenna K:F Length = 30 Cable Length: M: MMCX Width = 25 10cm S: SMA T: TNC U:MURATA N: None 0: 0GHz 5: 5 GHz A: 2.4GHz ISM band A: Reverse Female B: GSM 900/1800 dual band B: Reverse Male G: GPS band F: Female L: 2.4/5.2/5.8 GHz M: Male tri-band N: None T:LTE band U:UHF W: WCDMA band B: MP T:During Test X: Pile Run 0:None 1:∅0.81 2:∅1.32 3:∅1.13 4:Low Loss∅1.13 5:∅0.50 6:RG316 7:∅1.37 8:RG178 9: Low Loss∅1.37 A:RG174 B:1.5C-2V 01~99 series number  Metal Antenna RF MTA 3109 10 I M L B 7 01 Type code Product code Dimension code Cable Length code Connector Brand code Type of Connector code Application code Project status code Wire Diameter code Project code RF device 3 MTA: Metal Antenna A: N C:MCX D:IPEX III E: IPEX IV Per 2 digits of 2 digits for cable F: IPEX A13 H: Hirose Length, Width length I: IPEX 3109 = 10= K:F Length = 31 Cable Length: M: MMCX Width = 9 10cm S: SMA T: TNC U:MURATA N: None 0: 0GHz 5: 5 GHz A: 2.4GHz ISM band A: Reverse Female B: GSM 900/1800 dual B: Reverse Male band F: Female G: GPS band M: Male L: 2.4/5.2/5.8 GHz N: None tri-band T:LTE band U:UHF W: WCDMA band B: MP T:During Test X: Pile Run 0:None 1:∅0.81 2:∅1.32 3:∅1.13 4:Low Loss∅1.13 5:∅0.50 6:RG316 7:∅1.37 8:RG178 9: Low Loss∅1.37 A:RG174 B:1.5C-2V 01~99 series number ORDERING CODE  Cable Assembly RF CBA 1613 10 I M 3 B 7 01 Type code Product code Dimension code Cable Length code Connector Brand code Type of Connector code Application code Project status code Wire Diameter code Project code RF device CBA: Cable Assembly Per 2 digits of Length, Width 1613 = Length = 16.8 Width = 13.7 A: N C:MCX D:IPEX III E: IPEX IV 2 digits for cable F: IPEX A13 H: Hirose length I: IPEX 10= K:F Cable Length: M: MMCX 10cm S: SMA T: TNC U:MURATA N: None A: Reverse Female B: Reverse Male F: Female M: Male N: None 0: 0GHz 3: 3GHz 6: 6GHz B: MP T:During Test X: Pile Run 0:None 1:∅0.81 2:∅1.32 3:∅1.13 4:Low Loss∅1.13 5:∅0.50 6:RG316 7:∅1.37 8:RG178 9: Low Loss∅1.37 A:RG174 B:1.5C-2V 01~99 series number  Connector RF CON 0201 00 D F 6 B 0 01 Type code Product code Dimension code Cable Length code Connector Brand code Type of Connector code Application code Project status code Wire Diameter code Project code RF device CON: Connector Per 2 digits of Length, Width 0201 = Length = 2.05 Width = 1.40 A: N C:MCX D:IPEX III E: IPEX IV F: IPEX A13 2 digits for cable H: Hirose length I: IPEX 00= K:F None Cable M: MMCX S: SMA T: TNC U:MURATA N: None A: Reverse Female B: Reverse Male F: Female M: Male N: None 0: 0GHz 3: 3GHz 6: 6GHz B: MP T:During Test X: Pile Run 0:None 1:∅0.81 2:∅1.32 3:∅1.13 4:Low Loss∅1.13 5:∅0.50 6:RG316 7:∅1.37 8:RG178 9: Low Loss∅1.37 A:RG174 B:1.5C-2V 01~99 series number  NFC Antenna RF NFC 0201 00 N N N B 0 01 Type code Product code Dimension code Cable Length code Connector Brand code Type of Connector code Application code Project status code Wire Diameter code Project code RF device Per 2 digits of NFC:Near Length, Width Field 5339 = Communicati Length = 53.7 on Antenna Width = 39.7 A: N C:MCX D:IPEX III E: IPEX IV F: IPEX A13 2 digits for cable H: Hirose length I: IPEX 00= K:F None Cable M: MMCX S: SMA T: TNC U:MURATA N: None A: Reverse Female B: Reverse Male F: Female M: Male N: None N: NFC B: MP T:During Test X: Pile Run 0:None 1:∅0.81 2:∅1.32 3:∅1.13 4:Low Loss∅1.13 5:∅0.50 6:RG316 7:∅1.37 8:RG178 9: Low Loss∅1.37 A:RG174 B:1.5C-2V 01~99 series number  WPC Antenna RF WPC 5830 00 N N N B 0 01 Type code Product code Dimension code Cable Length code Connector Brand code Type of Connector code Application code Project status code Wire Diameter code Project code RF device WPC: Wireless Power Charging Antenna Per 2 digits of Length, Width 5830 = Length = 58 Width = 30 A: N C:MCX D:IPEX III E: IPEX IV F: IPEX A13 2 digits for cable H: Hirose length I: IPEX 00= K:F None Cable M: MMCX S: SMA T: TNC U:MURATA N: None A: Reverse Female B: Reverse Male F: Female M: Male N: None N: NFC B: MP T:During Test X: Pile Run 0:None 1:∅0.81 2:∅1.32 3:∅1.13 4:Low Loss∅1.13 5:∅0.50 6:RG316 7:∅1.37 8:RG178 9: Low Loss∅1.37 A:RG174 B:1.5C-2V 01~99 series number Remark: 1. Central Frequency should be defined after customers’ application approval. 4 CHIP ANTENNA CHIP ANTENNA  STRUCTURE AND PIN ASSOCIATED STRUCTURE A a STRUCTURE B STRUCTURE C STRUCTURE D STRUCTURE F STRUCTURE G STRUCTURE H Mark a W L T STRUCTURE E  STRUCTURE AND DIMENSION Structure\Dimension L W T a 10 ± 0.20 3.2 ± 0.20 0.8 ± 0.10 0.8 ± 0.10 2.0 ± 0.20 1.25 ± 0.20 0.90 ± 0.10 0.25 ± 0.15 0.60 ± 0.10 0.25 ± 0.20 1.20 ± 0.10 3.20 ± 0.20 A Unit: mm 1.60 ± 0.20 b c d 1 2 3 - - - - - - - - - - - - 0.25 ± 0.15 - - - - - - 1.30 ± 0.20 0.40 ± 0.20 - - - - - - 1.15 ± 0.10 0.40 ± 0.25 - - - - - - 1.15 ± 0.15 0.40 ± 0.25 - - - - - - 5.20 ± 0.20 2.00 ± 0.20 5.8 + 0.1 - 0.3 3.0 + 0.1 - 0.3 1.1 + 0.2 - 0.1 0.4 ± 0.25 - - - - - - 8.00 ± 0.20 1.05 ± 0.20 0.80 ± 0.10 0.30 ± 0.20 - - - - - - 9.10 ± 0.20 3.00 ± 0.20 2.00 ± 0.10 0.20 ± 0.20 - - - - - - 9.50 ± 0.20 2.10 ± 0.20 1.15 ± 0.10 0.50 ± 0.30 - - - - - - 1.60 ± 0.20 0.80 ± 0.20 0.50 ± 0.10 0.10 ± 0.05 2.00 ± 0.20 1.20 ± 0.20 0.50 ± 0.10 0.15 ± 0.05 10.40 ± 0.15 12.00 ± 0.15 4.00 ± 0.15 1.60 ± 0.15 4.00 ± 0.15 0.80 ± 0.10 B 5.9 ± 0.3 5.1 ± 0.3 1.1 ± 0.1 0.45 ± 0.2 1.0 ± 0.2 1.0 ± 0.2 2.0 ± 0.2 1.0 ± 0.2 1.0 ± 0.2 1.0 ± 0.2 C 7.6 ± 0.3 3.5 ± 0.2 1.1 ± 0.1 0.8 ± 0.2 0.8 ± 0.2 0.8 ± 0.2 0.5 ± 0.2 0.5 ± 0.2 0.8 ± 0.2 0.50 ± 0.2 Structure\Dimension L W T PW P1 P2 P3 P4 P5 D 9.90±0.15 3.70±0.15 3.80±0.20 3.48±0.10 1.4±0.10 1.9±0.10 2.4±0.15 - - E 19.0±0.15 3.00±0.15 3.80±0.20 3.00±0.10 1.0±0.10 1.0±0.10 1.0±0.10 1.0±0.10 - F 12.8±0.15 3.90±0.15 1.10±0.10 1.00±0.10 2.0±0.10 2.0±0.10 2.0±0.10 2.0±0.10 2.0±0.10 G 12.0±0.15 4.00±0.15 2.00±0.10 3.60±0.10 1.0±0.10 1.0±0.10 1.0±0.10 - - H 9.90±0.15 3.70±0.15 3.80±0.20 3.48±0.10 1.4±0.10 1.9±0.10 2.4±0.15 - - 5 CHIP ANTENNA  ELECTRICAL SPECIFICATION 1.575GHz BAND WORKING FREQUENCY Part Number Frequency Range (GHz) Azimuth Beamwidth ( MHz ) Gain (dBi) VSWR (max.) Impedance (Ω) Polarization Size (mm) Structure RFANT5830110E0T 1.575 Omni-directional 0~2 2.0 50 Linear 5.80x3.00x1.10 A RFECA1003011E0T 1.575 Omni-directional 2~3 2.0 50 Linear 10.0x3.20x0.80 A RFECA3216060E□T 1.575 Omni-directional 3 2.0 50 Linear 3.20x1.60x0.60 A Bluetooth/WiFi BAND WORKING FREQUENCY Part Number Frequency Range (GHz) Azimuth Beamwidth ( MHz ) Gain (dBi) VSWR (max.) Impedance (Ω) Polarization Size (mm) Structure RFECA3216060L1T 2.4~2.5 5.25~5.85 Omni-directional 0.6/2 2.1 50 Linear 3.20x1.60x0.60 A RFANT6050110L0T 2.4~2.5 4.9~5.9 Omni-directional 4 2.0 50 Linear 5.90x5.10x1.10 B RFANT6050110L1T 2.4~2.5 4.9~5.9 Omni-directional 4 2.0 50 Linear 5.90x5.10x1.10 B RFANT2012090A0T 2.4~2.5 Omni-directional 1.72 2.0 50 Linear 2.00x1.25x0.90 A RFANT3216120A1T 2.4~2.5 Omni-directional 2 2.0 50 Linear 3.20x1.60x1.20 A RFANT3216120A3T 2.4~2.5 Omni-directional 2 2.0 50 Linear 3.20x1.60x1.20 A RFANT3216120A5T 2.4~2.5 Omni-directional 2 2.0 50 Linear 3.20x1.60x1.20 A RFANT5220110A0T 2.4~2.5 Omni-directional 2 2.0 50 Linear 5.20x2.00x1.10 A RFANT5220110A2T 2.4~2.5 Omni-directional 2 2.0 50 Linear 5.20x2.00x1.10 A RFANT7635110A1T 2.4~2.5 Omni-directional 0~2 2.0 50 Linear 7.60x3.50x1.10 C RFANT8010080A3T 2.4~2.5 Omni-directional 2 2.0 50 Linear 8.00x1.00x0.80 A RFANT9520120A0T 2.4~2.5 Omni-directional 2 2.0 50 Linear 9.50x2.00x1.20 A RFECA3216060A1T 2.4~2.5 Omni-directional 2 2.1 50 Linear 3.20x1.60x0.60 A RFECA3216060K1T 4.9~5.85 Omni-directional 2.8 2.0 50 Linear 3.20x1.60x0.60 A RFANT9030200A1T 2.4~2.4835 Omni-directional 2 2.1 50 Linear 9.00x 3.00x2.00 A RGFRA1903041A1T 2.4~2.5 Omni-directional 2 2.0 50 Linear 19.0x3.00x3.80 E RGFRA1903041A5T 2.4~2.5 Omni-directional 2 2.0 50 Linear 19.0x3.00x3.80 E RGFRA9937380A3T 2.4~2.55 Omni-directional 2 2.0 50 Linear 9.90x3.70x3.80 D RGFRA1304011A1T 2.4~2.5 Omni-directional 2 2.1 50 Linear 12.8x3.90x1.10 F RGFRA1204021A1T 2.4~2.5 Omni-directional 2 2.0 50 Linear 12.0x4.00x2.00 G RFANT2012090A0T 2.4~2.5 Omni-directional 2 2.0 50 Linear 2.00x1.25x0.90 A RFECA1608050A0T 2.4~2.5 Omni-directional 0.7 3.0 50 Linear 1.60x0.80x0.50 A RFECA2012050A3T 2.4~2.5 Omni-directional 0.29 2.6 50 Linear 2.00x1.20x0.5 A WiMAX BAND WORKING FREQUENCY Part Number Frequency Range (GHz) Azimuth Beamwidth (MHz ) Gain (dBi) VSWR (max.) Impedance (Ω) Polarization Size (mm) Structure RFANT32162G6W0T 2.5~2.69 Omni-directional 1 3.0 50 Linear 3.20x1.60x1.20 A RFANT32163G5W0T 3.3~3.8 Omni-directional 2~3 2.0 50 Linear 3.20x1.60x1.20 A UHF BAND WORKING FREQUENCY Part Number Frequency Range (MHz) Azimuth Beamwidth (MHz ) Gain (dBi) VSWR (max.) Impedance (Ω) Polarization Size (mm) Structure RGFRA1204011DCT 900~930 Omni-directional 1 2.0 50 Linear 12.00x4.00x1.60 A RGFRA1204011DET 855~885 Omni-directional 1 2.0 50 Linear 12.00x4.00x1.60 A  For more information, please contact with local sales representative  All specifications are subject to change without notice 6 CHIP ANTENNA  TYPICAL ELECTRICAL CHARACTERISTICS RFANT5220110A0T X-Z Plane Vertical X-Y Plane Vertical Test Board Y-Z Plane Vertical 3.3mm Empty Area 18x9 mm 1.5mm Empty Area WTC 2.5mm 1mm 18mm 50 Feed line GROUND 30x18 mm Peak Gain= -5.97dBi Average Gain=-3.24 dBi Peak Gain= -5.97dBi Average Gain=-3.12 dBi Return Loss (S11) X-Y Plane Horizontal X-Z Plane Horizontal Peak Gain= 2.66dBi Average Gain=-8.61 dBi Peak Gain= 2.59dBi Average Gain=-9.24 dBi Peak Gain= 1.69dBi Average Gain=-3.22 dBi Y-Z Plane Horizontal Peak Gain= -5.42dBi Average Gain=-8.98 dBi RGFAR1903041A1T Test Board X-Y Plane Vertical Peak Gain= -7.42 dBi Average Gain= -10.48 dBi Return Loss (S11) X-Y Plane Horizontal Peak Gain= 2.0 dBi Average Gain= -2.31 dBi 7 X-Z Plane Vertical Peak Gain= 1.95 dBi Average Gain= -0.81 dBi X-Z Plane Horizontal Peak Gain= -2.65 dBi Average Gain= -8.4dBi Y-Z Plane Vertical Peak Gain= -0.26dBi Average Gain=-5 dBi Y-Z Plane Horizontal Peak Gain = 1.11dBi Average Gain = -4.37 dBi CHIP ANTENNA RFANT8010080A3T Test Board X-Y Plane Vertical X-Z Plane Vertical Peak Gain= 0.76 dBi Average Gain= -5.81dBi Return Loss (S11) Peak Gain= -3.76 dBi Average Gain= -8.72dBi X-Y Plane Horizontal Peak Gain= 1.37 dBi Average Gain= -2.67 dBi X-Z Plane Horizontal Peak Gain= -0.25 dBi Average Gain= -4.24 dBi Y-Z Plane Vertical Peak Gain = 3.03 dBi Average Gain = 0.71 dBi Y-Z Plane Horizontal Peak Gain= -1.37 dBi Average Gain=-8.6 dBi RGFAR9937380A3T Test Board X-Y Plane Vertical Peak Gain= -4.48 dBi Average Gain= -8.02 dBi Return Loss (S11) X-Y Plane Horizontal Peak Gain= 3.19 dBi Average Gain= -2.65 dBi X-Z Plane Vertical Peak Gain= 2.49 dBi Average Gain= -2.47 dBi X-Z Plane Horizontal Peak Gain= 3.05 dBi Average Gain= -4.10dBi Y-Z Plane Vertical Peak Gain= -4.05dBi Average Gain=-8.03 dBi Y-Z Plane Horizontal Peak Gain = 0.95dBi Average Gain = -4.26 dBi 8 CHIP ANTENNA RFECA3216060A1T Test Board X-Y Plane Vertical Peak Gain= 0.83 dBi Average Gain= -1.35 dBi Peak Gain = 3.37 dBi Average Gain = -0.65 dBi Return Loss (S11) X-Z Plane Vertical X-Y Plane Horizontal Peak Gain= -4.62 dBi Average Gain=-10.42 dBi X-Z Plane Horizontal Peak Gain= 0.51 dBi Average Gain= -4.07 dBi Y-Z Plane Vertical Peak Gain= -9.59 dBi Average Gain= -15.40 dBi Y-Z Plane Horizontal Peak Gain= 1.39 dBi Average Gain= -2.07 dBi RFECA1003011E0T Antenna S11 on Test Board X-Y Plane Vertical Peak Gain = 3.12dBi Average Gain = -3.99 dBi Antenna VSWR on Test Board X-Y Plane Horizontal Peak Gain = +0.48dBi Average Gain = -4.59dBi 9 X-Z Plane Vertical Peak Gain= 1.97dBi Average Gain= -1.44 dBi X-Z Plane Horizontal Peak Gain = +4.99dBi Average Gain = -1.31dBi Y-Z Plane Vertical Peak Gain = 3.32dBi Average Gain = 1.02 dBi Y-Z Plane Horizontal Peak Gain = +3.02dBi Average Gain = -0.85dBi CHIP ANTENNA RFECA3216060E1T Land Pattern X-Y Plane Vertical Peak Gain= -5.51 dBi Average Gain= -7.48 dBi Return Loss (S11) X-Z Plane Vertical Peak Gain= -0.85 dBi Average Gain= -5.22 dBi X-Y Plane Horizontal X-Z Plane Horizontal Peak Gain= 4.85 dBi Average Gain= 1.21 dBi Peak Gain= 5.36 dBi Average Gain= 1.25 dBi Y-Z Plane Vertical Peak Gain = 6.74 dBi Average Gain = 4.81 dBi Y-Z Plane Horizontal Peak Gain= -6.99 dBi Average Gain=-14.30 dBi RFECA3216060K1T Land Pattern X-Y Plane Vertical Peak Gain= -7.42 dBi Average Gain= -11.78 dBi Return Loss (S11) X-Y Plane Horizontal Peak Gain= 2.3 dBi Average Gain= -1.1 dBi X-Z Plane Vertical Peak Gain= 2.86 dBi Average Gain= 0.86 dBi X-Z Plane Horizontal Peak Gain=-2.49 dBi Average Gain= -9.61dBi Y-Z Plane Vertical Peak Gain= -0.55dBi Average Gain=-4.9 dBi Y-Z Plane Horizontal Peak Gain = 0.73dBi Average Gain = -2.86 dBi 10 CHIP ANTENNA RFECA1608050A0T Test Board X-Y Plane X-Z Plane Y-Z Plane Peak Gain= -0.65 dBi Average Gain= -2.38 dBi Peak Gain= -2.12 dBi Average Gain= -5.11 dBi Peak Gain= -0.67dBi Average Gain=-2.45 dBi X-Y Plane X-Z Plane Y-Z Plane Peak Gain= --1.07 dBi Average Gain= -3.81 dBi Peak Gain=0.29 dBi Average Gain= 0.89 dBi Peak Gain= -0.03dBi Average Gain=-4.36 dBi X-Y Plane X-Z Plane Y-Z Plane Peak Gain= -0.19 dBi Average Gain= -3.72 dBi Peak Gain= --0.23 dBi Average Gain= -4.23 dBi Peak Gain= -1.29dBi Average Gain=-1.46 dBi Return Loss (S11) RFECA2012050A3T Test Board Return Loss (S11) RFANT2012090A0T Test Board Return Loss (S11) 11 CHIP ANTENNA RGFRA1204011DCT Test Board X-Y Plane X-Z Plane Y-Z Plane Peak Gain= -0.82 dBi Average Gain= -1.11 dBi Peak Gain= 0.56 dBi Average Gain= -3.41 dBi Peak Gain= 0.94dBi Average Gain=-1.48 dBi Return Loss (S11) RGFRA1204011DET Test Board X-Y Plane X-Z Plane Y-Z Plane Peak Gain= -0.85 dBi Average Gain= -0.74 dBi Peak Gain= -1.06 dBi Average Gain= -3.01 dBi Peak Gain= -0.82dBi Average Gain=-1.29 dBi Return Loss (S11) RGFRA1204011DET Test Board X-Y Plane X-Z Plane Y-Z Plane Peak Gain= -0.85 dBi Average Gain= -0.74 dBi Peak Gain= -1.06 dBi Average Gain= -3.01 dBi Peak Gain= -0.82dBi Average Gain=-1.29 dBi Return Loss (S11)  For more information, please contact with local sales representative  All specifications are subject to change without notice 12 HIGH FREQUENCY MULTILAYER BAND PASS FILTER HIGH FREQUENCY MULTILAYER BAND PASS FILTER  STRUCTURE AND PIN ASSOCIATED STRUCTURE A STRUCTURE B STRUCTURE C STRUCTURE D STRUCTURE E STRUCTURE F STRUCTURE K STRUCTURE L V STRUCTURE G STRUCTURE H STRUCTURE I STRUCTURE J V 13 HIGH FREQUENCY MULTILAYER BAND PASS FILTER  STRUCTURE AND DIMENSION Structure\ Dimension A L T A B C D E 0.70±0.10 0.20±0.20 0.55±0.20 0.50±0.20 0.25±0.20 0.90±0.10 0.20±0.20 0.55±0.20 0.50±0.20 0.20±0.20 1.00±0.10 0.20±0.20 0.55±0.20 0.50±0.20 1.05±0.10 0.25±0.20 0.50±0.20 1.20±0.10 0.25±0.20 0.50±0.20 2.05±0.20 0.70±0.20 0.25±0.20 3.20±0.20 2.50±0.10 1.50±0.10 1.00±0.10 0.50±0.10 0.40±0.10 2.50±0.20 1.60±0.15 W 2.00±0.20 0.80±0.15 1.20±015 B 2.00±.15 1.25±0.15 F G H I 0.20±0.20 - - - - 0.20±0.20 - - - - 0.25±0.20 0.20±0.20 - - - - 0.50±0.20 0.25±0.20 0.25±0.20 - - - - 0.50±0.20 0.25±0.20 0.25±0.20 - - - - 0.50±0.20 0.50±0.20 0.25±0.20 0.25±0.20 - - - - 0.20±0.20 0.75±0.20 0.60±0.20 0.20±0.15 0.40±0.20 - - - - 0.35±0.10 0.30±0.10 0.15±0.10 0.15±0.10 0.30±0.10 - - - - 0.50±0.10 0.45±0.15 0.70±0.15 0.20±0.15 0.20±0.15 0.30±0.15 0.25±0.15 - - - 0.60±0.10 0.45±0.15 0.70±0.15 0.20±0.15 0.20±0.15 0.30±0.15 0.25±0.15 - - - 0.70±0.10 0.40±0.15 0.80±0.15 0.20±0.10 0.20±0.10 0.30±0.15 0.25±0.15 - - - 0.70±0.10 0.45±0.15 0.70±0.15 0.20±0.10 0.20±0.10 0.30±0.15 0.25±0.15 - - - 0.50±0.10 0.40±0.15 0.80±0.15 0.20±0.10 0.20±0.10 0.30±0.15 0.45±0.15 - - - 0.20±0.15 1.60±0.15 0.20±0.15 0.20±0.15 0.40±0.15 0.40±0.15 - - - 0.20±0.15 1.60±0.15 0.25±0.15 0.25±0.15 0.30±0.15 0.45±0.15 - - - 0.45±0.15 1.10±0.15 0.25±0.15 0.25±0.15 0.30±0.15 0.45±0.15 - - - 0.50±0.15 1.00±0.15 0.20±0.15 0.20±0.15 0.30±0.15 0.45±0.15 - - - 0.60±0.10 0.50±0.15 1.00±0.15 0.25±0.15 0.25±0.15 0.30±0.15 0.475±0.15 - - - 0.80±0.10 0.50±0.15 1.00±0.15 0.25±0.15 0.25±0.15 0.30±0.15 0.475±0.15 - - - 0.90±0.10 0.50±0.15 1.00±0.15 0.25±0.15 0.25±0.15 0.30±0.15 0.475±0.15 - - - 0.35±0.15 1.30±0.15 0.20±0.15 0.20±0.15 0.30±0.15 0.475±0.15 - - - 0.35±0.15 1.30±0.15 0.25±0.15 0.25±0.15 0.30±0.15 0.475±0.15 - - - 0.50±0.15 1.00±0.15 0.25±0.15 0.25±0.15 0.30±0.15 0.475±0.15 - - - 0.55±0.10 0.40±0.20 0.40±0.20 0.40±0.20 0.20±0.10 - - - - - 0.60±0.10 0.40±0.20 0.40±0.20 0.40±0.20 0.20±0.10 - - - - - 0.80±0.10 0.40±0.20 0.40±0.20 0.40±0.20 0.20±0.10 - - - - - 0.60±0.10 0.55±0.10 0.25±0.10 0.23±0.10 0.40±0.10 0.12±0.10 0.125±0.10 - - - 0.45±0.10 0.95±0.10 0.275±0.20 0.25±0.10 0.60±0.10 0.175±0.10 0.15±0.10 - - - 0.70 max 0.95±0.10 0.275±0.10 0.25±0.10 0.60±0.10 0.175±0.10 0.15±0.10 - - - 0.80±0.10 0.95±0.10 0.275±0.10 0.25±0.10 0.60±0.10 0.175±0.10 0.15±0.10 - - - 0.90±0.10 0.95±0.10 C D E F G Unit: mm 2.00±.15 1.20±0.20 1.60±0.15 0.80±0.15 2.00±.15 1.25±0.10 1.10±0.10 0.90±0.10 0.60±0.10 0.25±0.10 0.18±0.10 0.205±0.10 0.25±0.10 - - - - - 1.40±0.15 1.10±0.10 0.60±0.10 0.325±0.10 0.25±0.10 0.25±0.10 0.25±0.10 - - - - - 1.40±0.15 1.10±0.15 0.70±0.10 0.325±0.10 0.25±0.10 0.25±0.10 0.25±0.10 - - - - - 2.00±0.20 1.25±0.20 1.60±0.15 0.80±0.15 1.60±0.10 0.80±0.10 2.00±0.15 1.25±0.10 1.00 max. 0.325±0.10 0.25±0.10 0.25±0.10 0.25±0.10 - - - - - 0.40±0.10 0.55±0.15 0.50±0.15 0.35±0.15 0.50±0.15 0.20±0.15 - - - - 0.60±0.10 0.55±0.15 0.50±0.15 0.35±0.15 0.50±0.15 0.20±0.15 - - - - 0.70 max. 0.55±0.10 0.25±0.10 0.23±0.10 0.40±0.10 0.12±0.10 0.195±0.10 0.21±0.10 0.125±0.10 - 0.80±0.10 0.95±0.10 0.40±0.10 0.30±0.10 0.30±0.10 0.15±0.10 0.30±0.10 0.35±0.10 0.15±0.10 - 0.90±0.10 0.95±0.10 0.40±0.10 0.30±0.10 0.30±0.10 0.15±0.10 0.30±0.10 0.35±0.10 0.15±0.10 - 2.50±0.20 2.00±0.20 0.90±0.10 1.70±0.20 0.60±0.20 0.30±0.20 0.40±0.20 0.15±0.10 0.60±0.10 0.50±0.10 0.15±0.10 - H 1.60±0.15 0.80±0.10 0.60 max. 0.25±0.10 0.23±0.05 0.40±0.10 0.30±0.10 0.55±0.10 0.60±0.10 - - - I 2.00±0.15 1.25±0.10 1.00 max. 1.80±0.10 0.35±0.10 0.25±0.10 0.25±0.10 0.275±0.10 0.35±0.10 0.25±0.10 0.25±0.10 0.275±0.10 J 2.50±0.15 2.00±0.15 0.90±0.10 0.30±0.10 0.40±0.10 0.55±0.10 0.40±0.10 0.90±0.10 0.30±0.10 - - - 2.00±0.15 1.25±0.15 1.05±0.15 0.475±0.15 0.30±0.15 0.20±0.15 0.50±0.15 0.60±0.15 0.95±0.15 - - - 3.20±0.20 2.50±0.20 1.80±0.20 0.95±0.20 0.60±0.20 0.30±0.15 0.70±0.15 1.20±0.15 2.00±0.15 - - - 2.00±0.15 1.25±0.10 1.05 max. 0.20±0.10 0.35±0.10 0.30±0.10 0.65±0.10 0.20±0.10 0.20±0.10 0.475±0.10 0.30±0.10 K L 14 HIGH FREQUENCY MULTILAYER BAND PASS FILTER  ELECTRICAL SPECIFICATION 2.4GHz BAND WORKING FREQUENCY Part Number Frequency Range(GHz) Insertion Loss (dB) Attenuation (dB min. ) VSWR (max.) Impedance (Ω) Size(mm) STRUCTURE RBBPF1005040A1T 2.4~2.5 2.5 25(824~960MHz) 20(1710~1910MHz) 20(4800~5000MHz) 15(7200~7500MHz) 2.0 50 1.00x0.50x0.40 B 2.4~2.5 1.5max.(25℃) 1.7max.(-40~+85℃) 13(824~915MHz) 5(1545~1605MHz) 34(4800~5000MHz) 27(7200~7500MHz) 2.1 50 1.00x0.50x0.40 B 2.0 50 1.10x 0.90x0.60 E 2.0 50 1.40x1.10x0.60 E 2.0 50 1.40x1.10x0.60 E RFBPF1005040A3T RFBPF1109060A0T 2.4~2.5 1.8 RFBPF1411060A1T 2.4~2.5 1.8max.(25℃) 2.1max.(-40~+85℃) 35(824~960MHz) 38(1545~1605MHz) 20(1710~1990MHz) 8(2110~2170MHz) 35(3600MHz) 35(4800~5000MHz) 35(7200~7500MHz) 40(824~960MHz) 40(1545~1605MHz) 20(1710~1990MHz) 8(2110~2170MHz) 35(3600MHz) 35(4800~5000MHz) 35(7200~7500MHz) RFBPF1411060A2T 2.4~2.5 1.5 30(500~960MHz) 25(1500~1650MHz) 19(3200~3300MHz) 40(4800~5000MHz) 30(7200~7500MHz) RBBPF1411060A3T 2.4~2.5 1.1 20( 50~960MHz) 10( 1710~1990MHz) 9( 3600MHz) 22( 4800~7200MHz) 2.0 50 1.40x1.10x0.60 E RBBPF1411060A8T 2.4~2.5 1.0max.(25℃) 1.2max.(-40~+85℃) 15(50~960MHz) 10(1710~1990MHz) 15(3600MHz) 25(4800~7200MHz) 2.0 50 1.40x1.10x0.60 E RFBPF1608060AA7M1U 2.4~2.5 0.95max.(25℃) 1.25max.(-40~+85℃) 20(500~960MHz) 23(3200MHz) 30(4800~5000MHz) 32(7200~7500MHz) 2.0 50 1.60x0.80x0.60 H 2.0 50 1.60x0.80x0.60 B RFBPF1608060ADT 2.4~2.5 1.8max.(25℃) 2.1max.(-40~+85℃) 25(800~1000MHz) 22.5(1200~1300MHz) 5.5(2000MHz) 10.5(3000MHz) 23.5(3600~3800MHz) 35(4800~5000MHz) 35(7200~7500MHz) RFBPF1608060AET 2.4~2.5 1.7max.(25℃) 2.0max.(-40~+85℃) 25(880MHz) 20(3200MHz) 35(4800~5000MHz) 25(7200~7500MHz) 2.0 50 1.60x0.80x0.60 F 2.4~2.5 2.4max.(25℃) 2.7max.(-40~+85℃) 24.5(880~960MHz) 20(1710~1990MHz) 8.5(2170MHz) 15(4800~5000MHz) 20(7200~7500MHz) 2.0 50 1.60x0.80x0.70 B 2.4~2.5 2.0max.(25℃) 2.2max.(-40~+85℃) 30 (960MHz) 25(1910MHz) 20(1990MHz) 25(4800MHz) 15(7200MHz) 2.0 50 1.60x0.80x0.70 B 2.4~2.5 2.0max.(25℃) 2.2max.(-40~+85℃) 20(960MHz) 20(1910MHz) 15(1990MHz) 18(4800MHz) 25(7200MHz) 2.0 50 1.60x0.80x0.50 B 2.8 25(695~800MHz) 20(1910MHz) 35(3200MHz) 20(4800~5000MHz) 20(7200~7500MHz) 2.0 50 1.60x0.80x0.60 B 3.0 25(695~800MHz) 20(1910MHz) 35(3200MHz) 20(4800~5000MHz) 20(7200~7500MHz) 2.0 50 1.60x0.80x0.60 B RFBPF1608070AFT RFBPF1608070AWT RFBPF1608050A0T RFBPF1608060A1T RFBPF1608060A7T 15 2.4~2.5 2.4~2.5 HIGH FREQUENCY MULTILAYER BAND PASS FILTER 2.4GHz BAND WORKING FREQUENCY Part Number Frequency Range(GHz) Insertion Loss (dB) Attenuation (dB min. ) VSWR (max.) Impedance (Ω) Size(mm) STRUCTURE RFBPF1608070A3T 2.4~2.5 1.8max.(25℃) 2.1max.(-40~+85℃) 27(800~900MHz) 25(4800~5000MHz) 30(7200~7500MHz) 2.0 50 1.60x0.80x0.70 B 2.4~2.5 1.8max.(25℃) 2.0max.(-40~+85℃) 30(860~960MHz) 30(1545~1605MHz) 35(1710~1990MHz) 30(2170MHz) 30(4800~5000MHz) 2.0 50 2.00x1.20x0.80 D 2.4~2.5 1.80max.(25℃) 2.00max.(-40~+85℃) 30(860~960MHz) 30(1545~1605MHz) 35(1710~1990MHz) 30(2170MHz) 30(4800~5000MHz) 2.0 50 2.00x1.25x0.80 G 2.0 50 2.00x1.25x0.90 G RFBPF2012080AM0T62 RFBPF2008A38T RFBPF2012090AS1T35 2.4~2.5 0.9max.(25℃) 1.1max.(-40~+85℃) 28(824~960MHz) 30(1570~1580MHz) 15(1710~1910MHz) 9.5(1910~1990MHz) 25(4800~5000MHz) 25(7200~7500MHz) RFBPF2012060AAT 2.4~2.5 1.5max.(25℃) 1.8max.(-40~+85℃) 30(880~960MHz) 25(1710~1910MHz) 25(4800~5000MHz) 30(7200~7500MHz) 2.0 50 2.00x1.20x0.60 C 2.0 50 2.00x1.20x0.40 D RFBPF2012040ABT 2.4~2.5 2.5 30(824~849MHz) 30(880~915MHz) 30(1545~1605MHz) 30(1565~1585MHz) 35(1710~1785MHz) 40(1850~1910MHz) 32(1920~1980MHz) 7(3168~4752MHz) 11(3300~3800MHz) 35(4800~4967MHz) 26(5150~6000MHz) 23(7200~7450MHz) RFBPF2012050ACT 2.4~2.5 2.5 35(824~960MHz) 38(1710~1910MHz) 25(4880~5000MHz) 20(7200~7500MHz) 2.0 50 2.00x1.20x0.55 C 2.4~2.5 1.5max.(25℃) 1.7max.(-40~+85℃) 30(860~960MHz) 30(1545~1605MHz) 30(1710~1990MHz) 30(2170MHz) 30(4800~5000MHz) 2.0 50 2.00x1.25x0.80 D 1.8max.(25℃) 2.0max.(-40~+85℃) 30(824~915MHz) 30(1545~1605MHz) 35(1710~1990MHz) 30(2170MHz) 30(4800~4967MHz) 25(5150~6000MHz) 20(7200~7450.5MHz) 2.0 50 2.00x1.25x0.80 D 1.8max.(25℃) 2.0max.(-40~+85℃) 35(824~960MHz) 28(1540~1605MHz) 30(1710~1990MHz) 30(2170MHz) 6(3200MHz) 30(4800~4967MHz) 20(5150~6000MHz) 18(7200~7450MHz) 2.0 50 2.00x1.25x0.80 D 2.5 25(746~764MHz) 30(824~849MHz) 26(869~960MHz) 28(1570~1580MHz) 28(1710~1785MHz) 30(1850~1910MHz) 30(1930~1990MHz) 30(2110~2170MHz) 15(3300~3800MHz) 35(4800~5000MHz) 20(7200~7450.5MHz) 2.0 50 2.00x1.25x0.45 D 2.5max.(typ.2.2) 25(746~764MHz) 30(824~849MHz) 26(869~960MHz) 28(1570~1580MHz) 28(1710~1785MHz) 30(1850~1910MHz) 30(1930~1990MHz) 25(2110~2170MHz) 15(3300~3800MHz) 35(4800~5000MHz) 2.0 50 2.00x1.25x0.45 D RFBPF2012080ADT RFBPF2008A40T RFBPF2008A39T RFBPF2012040AHT RBBPF2012050AHT 2.4~2.5 2.4~2.5 2.4~2.5 2.4~2.5 16 HIGH FREQUENCY MULTILAYER BAND PASS FILTER 2.4GHz BAND WORKING FREQUENCY Part Number RFBPF2012090ALT RFBPF2012090AMT Insertion Loss (dB) Attenuation (dB min. ) VSWR (max.) Impedance (Ω) Size(mm) STRUCTURE 2.4~2.5 1.0max.(25℃) 1.2max.(-40~+85℃) 28(824~960MHz) 28(1570~1580MHz) 23(1710~1910MHz) 17(1920~1990MHz) 25(4800~5000MHz) 2.0 50 2.00x1.25x0.90 G 2.6 40(880~960MHz) 38(1710~1990MHz) 16(2170MHz) 30(4800~5000MHz) 30(7200~7500MHz) 2.0 50 2.00x1.20x0.90 B 2.0 50 2.00x1.20x1.00 I 2.4~2.5 RFBPF2012100ANT 2.4~2.5 2.3max.(25℃) 2.6max.(-40~+85℃) 40(699~960MHz) 40(1428~1448MHz) 40(1476~1607MHz) 40(1710~1785MHz) 33(1805~1880MHz) 30(1880~1915MHz) 30(1920~1990MHz) 22(2110~2170MHz) 25(4800~5000MHz) 35(7200~7500MHz RFBPF2012090AQT 2.4~2.5 1.2 20(1600MHz) 25(3200MHz) 20(4800~5000MHz) 2.0 50 2.00x1.20x0.90 B RFBPF2012090ART 2.4~2.5 1.0 20(1600MHz) 25(3200MHz) 2.0 50 2.00x1.20x0.90 B 2.4~2.5 1.5max.(25℃) 1.7max.(-40~+85℃) 40(699~960MHz) 40(1428~1448MHz) 40(1476~1607MHz) 40(1710~1785MHz) 33(1805~1880MHz) 30(1880~1915MHz) 30(1920~1990MHz) 25(4800~5000MHz) 30(7200~7500MHz 2.0 50 2.00x1.20x1.00 I 2.4~2.5 1.3max.(25℃) 1.5max.(-40~+85℃) 38(50~960MHz) 17(1710~1910MHz) 5(3200MHz) 30(4800~5000MHz) 25(7200~7500MHz) 2.0 50 2.00x1.20x0.90 E 2.4~2.5 1.0max.(25℃) 1.2max.(-40~+85℃) 28(824~960MHz) 28(1570~1580MHz) 23(1710~1910MHz) 17 (1920~1990MHz) 4(2100~2170MHz) 25(4800~5000MHz) 25(7200~7500MHz) 2.0 50 2.00x1.25x0.90 G RBBPF2010A16T 2.4~2.5 1.3max.(25℃) 1.5max.(-40~+85℃) 38(50~960MHz) 17(1710~1990MHz) 20(3200MHz) 30(4800~5000MHz) 25(7200~7500MHz) 2.0 50 2.00x1.25x1.00 E RFBPF2009A25T 2.4~2.5 1.7max.(25℃) 1.9max.(-40~+85℃) 30(900MHz) 20(1850MHz) 30(4800MHz) 2.0 50 2.00x1.20x0.90 B 2.4~2.5 1.4max.(25℃) 1.6max.(-40~+85℃) 30(824~960MHz) 30(1710~1910MHz) 20(1920~1990MHz) 6(2110~2170MHz) 20(4800~5000MHz) 2.0 50 2.00x1.20x0.90 B 2.0max.(25℃) 2.2max.(-40~+85℃) 25(746~764MHz) 30(824~849MHz) 26(869~960MHz) 28(1570~1580MHz) 28(1710~1785MHz) 30(1850~1910MHz) 30(1930~1990MHz) 25(2110~2170MHz0 15(3300~3800MHz) 35(4800~5000MHz) 20(7200~7450.5MHz) 2.0 50 2.00x1.25x0.45 D RFBPF2012100AVT RBBPF2010A108Q1C RFBPF2009A12T RFBPF2009A26T RFBPF2012040A3T 17 Frequency Range(GHz) 2.4~2.5 HIGH FREQUENCY MULTILAYER BAND PASS FILTER 2.4GHz BAND WORKING FREQUENCY Part Number Frequency Range(GHz) Insertion Loss (dB) Attenuation ( dB min. ) VSWR (max.) Impedance (Ω) Size(mm) STRUCTURE 2.0 50 2.00x1.20x0.80 C RFBPF2012080A6T 2.4~2.5 3.5 30(880~960MHz) 30(1710~1990MHz) 20(2110~2170MHz) 30(4800~5000MHz) 30(7200~7500MHz) RFBPF2012100A6T 2.4~2.5 1.0max.(25℃) 1.2max.(-40~+85℃) 21(902~928MHz) 26(4800~5000MHz) 34(7200~7500MHz) 29(9600~10000MHz) 2.0 50 2.00x1.20x1.00 L 2.8 (typ.2.5) 40(DC~1600MHz) 35(1710MHz) 25(1900MHz) 12(2100MHz) 8(2170MHz) 30(3100MHz) 40(4800~5000MHz) 20(7200~7500MHz) 2.0 50 2.00x1.20x0.80 B 2.8 30(960MHz) 30(1600MHz) 20(1990MHz) 35(3200MHz) 40(4800MHz) 25(7200MHz) 2.0 50 2.00x1.20x0.60 B 2.1max.(25℃) 2.3max.(-40~+85℃) 43(806~960MHz) 43(1570~1580MHz) 43(1710~1990MHz) 20(2110~2170MHz) 30(4800~5000MHz) 25(7200~7500MHz) 2.0 50 2.50x2.00x0.90 G 2.0max.(25℃) 2.2max.(-40~+85℃) 45(824~960MHz) 45(1570~1580MHz) 45(1710~1785MHz) 40(1805~1850MHz) 35(1850~1910MHz) 35(1920~1990MHz) 25(2110~2170MHz) 5(2750~3000MHz) 15(3000~4800MHz) 30(4800~5000MHz) 30(5150~5850MHz) 20(7200~7500MHz) 2.0 50 2.50x2.00x0.70 A 2.2 30(900MHz) 30(1850MHz) 33(2170MHz) 35(4800MHz) 25(7200MHz) 2.0 50 2.50x2.00x0.70 A 2.0 50 2.50x2.00x1.20 A RFBPF2012080A7T RFBPF2012060A9T RFBPF2520090ACT RFBPF2520070AMT RFBPF2520080AUT 2.4~2.5 2.4~2.5 2.4~2.5 2.4~2.5 2.4~2.5 RFBPF2520120A1T 2.4~2.5 1.7 30(900MHz) 30(1850MHz) 20(2100MHz) 40(4800MHz) 25(7200MHz) RFBPF2520120A2T 2.4~2.5 2.1 30(900MHz) 30(1850MHz) 30(4800MHz) 2.0 50 2.50x2.00x1.20 A RFBPF2520120A3T 2.4~2.5 ≦1.2(25℃) 30(900MHz) 30(1850MHz) 25(4800MHz) 2.0 50 2.50x2.00x1.20 A RFBPF2520120A4T 2.4~2.5 ≦1.7(25℃) 30(900MHz) 30(1850MHz) 25(4800MHz) 2.0 50 2.50x2.00x1.20 A RFBPF2520100A6T 2.4~2.5 1.4 35(1900/4800 MHz) 2.0 50 2.50x2.00x1.00 A 18 HIGH FREQUENCY MULTILAYER BAND PASS FILTER 5GHz BAND WORKING FREQUENCY Part Number Frequency Range(GHz) Insertion Loss (dB) Attenuation (dB min. ) VSWR (max.) Impedance (Ω) Size(mm) STRUCTURE RFBPF1608060K2T 4.9~5.84 1.5max.(25℃) 1.7max.(-40~+85℃) 33(100~2170MHz) 29(2170~2500MHz) 32(9800~12000MHz) 2.0 50 1.60x0.80x0.70 B 2.0 50 1.60x0.80x0.60 D RFBPF1608060K68Q1C 4.9~5.9 1.3max.(25℃) 1.5max.(-40~+85℃) 38(30~2700MHz) 16(3453~3547MHz) 33(3667~3883MHz) 9(6900~7093MHz) 32(7333~7750MHz) 40(10600~11650MHz) 18(15540~17760MHz) RFBPF1608060K78Q1C 5.15~5.95 0.8max.(25℃) 1.0max.(-40~+85℃) 40(30~2700MHz) 45(3400~3800MHz) 20(7250~7800MHz) 20(10300~11700MHz) 1.5 50 1.60x0.80x0.60 D RFBPF1608060K88Q1C 5.15~5.95 0.7max.(25℃) 0.85max.(-40~+85℃) 35(30~2700MHz) 30(3400~3800MHz) 12(7250~7800MHz) 20(10300~11700MHz) 1.5 50 1.60x0.80x0.60 D 1.67 50 1.60x0.80x0.60 D 2.0 50 1.60x0.80x0.60 D 40(30~2700MHz) 45(3400~3800MHz) 20(6900MHz) 20(7250~7800MHz) 20(10300~11700MHz) 38(10~2700MHz) 20(2700~3550MHz) 15(3550~4000MHz) 3(4000~4500MHz) 5(4400MHz) 3(6500~7000MHz) 11(7000~7400MHz) 13(7400~9750MHz) 30(9750~10300MHz) 27(10300~12750MHz) 10(15540~17775MHz) RFBPF1608060KG8D1T 5.15~5.95 0.8 RFBPF1606K12T 5.15~5.925 1.1max.(25℃) 1.3max.(-40~+85℃) RFBPF2012100KST 4.9~5.9 1.5(4.90GHz) 1.5(5.25GHz) 1.5(5.85GHz) 30(3450MHz) 20(11000MHz) 2.0 50 2.00x1.20x1.00 B RFBPF2012100K0T 4.9~5.9 1.7(4.90GHz) 1.5(5.25GHz) 1.5(5.85GHz) 30(3450MHz) 20(11000MHz) 2.0 50 2.00x1.20x1.00 B RFBPF2012090K5T 4.9~5.85 2.2max.(25℃) 2.5max.(-40~+85℃) 35(340~1195MHz) 19(2140~3580MHz) 25(6855~7150MHz) 20(8570~8930MHz) 2.0 50 2.00x1.20x0.90 B 4.9~5.85 1.8max.(25℃) 2.1max.(-40~+85℃) 30(500MHz) 35(3450MHz) 30(4000MHz) 20(4200MHz) 15(9800MHz) 15(11700MHz) 2.0 50 2.00x1.20x0.95 B 5.15~5.85 1.6max.(25℃) 1.8max.(-40~+85℃) 30(500MHz) 40(2000MHz) 35(3450MHz) 30(4000MHz) 20(4200MHz) 2.0 50 2.00x1.20x0.95 B 2.0 50 2.00x1.20x0.95 B RFBPF2012100K3T RFBPF2012100K6T RFBPF2012090K9T 5.725~5.85 2.0 30(500MHz) 30(4000MHz) 20(4200MHz) 32(5000MHz) 15(9800MHz) 15(11750MHz) RFBPF2520090K1T 4.9~5.85 1.2max.(25℃) 1.5max.(-40~+85℃) 50(824~1910MHz) 15(9880~11700MHz) 2.0 50 2.50x2.00x0.90 A 3.5 50(1000MHz) 35(2500MHz) 20(3500MHz) 7(4250MHz) 15(5150MHz) 20(57500MHz) 2.0 50 2.50x2.00x0.80 A KFBPF25204G7W09S5K 19 4.4~4.94 HIGH FREQUENCY MULTILAYER BAND PASS FILTER WiMAX BAND WORKING FREQUENCY Part Number RFBPF16082G3W0T Frequency Range(GHz) 2.3~2.39 Insertion Loss (dB) Attenuation (dB min. ) VSWR (max.) Impedance (Ω) Size(mm) STRUCTURE 2.0 29(880~915MHz) 29(1710~1785MHz) 21(1850~1910MHz) 15(1920~1980MHz) 18(4600~4780MHz) 23(6900~7170MHz) 2.0 50 1.60x0.80x0.70 B Insertion Loss (dB) Attenuation (dB min. ) VSWR (max.) Impedance (Ω) Size(mm) STRUCTURE 1.9max. 25(960MHz) 8(1850MHz) 15(1990MHz) 20(2170MHz) 35(2400~2500MHz) 35(3400~3800MHz) 2.0 50 1.10x0.90x0.60 E 30(824~849MHz) 30(880~915MHz) 10(1880~1910MHz) 22(1920~1980MHz) 30(2400MHz) 2.0 50 1.40x1.10x0.70 E Attenuation (dB min. ) VSWR (max.) Impedance (Ω) Size(mm) STRUCTURE 0.7max.(25℃) 0.75max.(-40~+85℃) 25(430~490MHz) 10(1700~1900MHz) 20(2400~2500MHz) 20(4905~5845MHz) 1.9 50 2.50x2.00x0.90 J 1.1max.(25℃) 1.2max.(-40~+85℃) 25(900~1015MHz) 15(2400~2500MHz) 15(3610~3980MHz) 20(4905~5845MHz) 2.0 1558 ~ 1606 MHz GNSS Band Applications Part Number RFBPF1109060E0T RFBPF1411070E0T Frequency Range (MHz) 1550~1610 1558~1606 1.8max.(25℃) 2.0max.(-40~+85℃) 860~960MHz/1805~2025 MHz Band Application Part Number Frequency Range (MHz) 869~960 Insertion Loss (dB) RFBPF2520090B08Q1C 1805~2025 MoCA / Docsis Application Part Number Frequency Range(MHz) Insertion Loss (dB) Attenuation ( dB min. ) VSWR (max.) Impedance (Ω) Size(mm) STRUCTURE RFBPF3225180Y1T 975~1025 3.0 30(54~870MHz) 30(1125~1675MHz) 30(2300MHz) 2.0 75 3.20x2.50x1.80 K 2.0 75 3.20x2.50x1.80 K RFBPF3225200Y07B1U 475~675 2.5max.(25℃) 2.7max.(-40~+85℃) 60(2.5MHz) 40(2.5~100MHz) 35(100~200MHz) 35(200~300MHz) 8(300~400MHz) 57(950MHz) 47(950~2025MHz) 41(2025~2500MHz) 35(2500~3000MHz) RBBPF3225180Y27B1U 400~700 2.0 42(1~200MHz) 30(950~2150MHz) 35(2150~3000MHz) 27(3000~5900MHz) 2.0 50 3.20x2.50x1.80 K KFBPF2012100C67B1U 1125~1675 2.5 35(1~900MHz) 20(900~1002MHz) 35(2000~2500MHz) 20(2500~5900MHz) 2.0 50 2.00x1.25x1.05 K RFBPF3225180C07B1U 1125~1675 1.8max.(25℃) 2.0max.(-40~+85℃) 30(5~864MHz) 34(864~1002MHz) 32(2300~3000MHz) 2.0 75 3.20x2.50x1.80 K RBBPF3225180C67B1U 1125~1675 2.0 40(1~900MHz) 25(900~1002MHz) 35(2000~2500MHz) 27(2500~5900MHz) 2.0 50 3.20x2.50x1.80 K 20 HIGH FREQUENCY MULTILAYER BAND PASS FILTER LTE Band Application Part Number Frequency Range(MHz) Insertion Loss (dB) Attenuation ( dB min. ) VSWR (max.) Impedance (Ω) Size(mm) STRUCTURE RFBPF1109B101T 2110~2170 1.7 25(4280MHz) 2 50 1.10x0.90x0.60 E RFBPF1109B201T 1930~1990 1.7 25(3920MHz) 2 50 1.10x0.90x0.60 E RFBPF1109B301T 1805~1880 1.4 25(3685MHz) 2 50 1.10x0.90x0.60 E RFBPF1109B501T 869~894 0.9 12(1763MHz) 2 50 1.10x0.90x0.60 E RFBPF1109B701T 2620~2690 1.2 25(5310MHz) 2 50 1.10x0.90x0.60 E RFBPF1109B801T 925~960 0.9 12(1885MHz) 2 50 1.10x0.90x0.60 E 2 50 1.60x0.80x0.70 G RFBPF16081G9DM1T79 1805~2025 1.6max.(25℃) 1.8max.(-40~+85℃) 25(700~950MHz) 15(950~1050MHz) 25(2400~2500MHz) 35(2700~5150MHz) 40(5150~5850MHz) 25(5850~12750MHz ) RFBPF16081G9DMAT79 1880~2025 2.0max.(25℃) 2.2max.(-40~+85℃) 20(1545~1610MHz) 25(2400~2500MHz) 25(5150~5850MHz) 2 50 1.60x0.80x0.70 G 1.6 30(700~950MHz) 15(950~1050MHz) 25(2400~2500MHz) 35(2700~5400MHz) 35(5500~6200MHz) 35(9350~10150MHz) 20(10500~12750MHz 2 50 1.60x0.80x0.70 G RFBPF16081G9DS8T60 1805~2025  TYPICAL ELECTRICAL CHARACTERISTICS 21 RBBPF1005040A1T RFBPF1005040A3T RFBPF1109060A0T RFBPF1411060A1T HIGH FREQUENCY MULTILAYER BAND PASS FILTER TYPICAL ELECTRICAL CHARACTERISTICS RFBPF1411060A2T RBBPF1411060A3T RBBPF1411060A8T RFBPF1608060AA7M1U RFBPF1608060ADT RFBPF1608060AET RFBPF1608070AFT RFBPF1608070AWT RFBPF1608050A0T RFBPF1608060A1T 22 HIGH FREQUENCY MULTILAYER BAND PASS FILTER TYPICAL ELECTRICAL CHARACTERISTICS 23 RFBPF1608060A7T RFBPF2008A38T RFBPF2012080AC2T00 RFBPF2012090AS1T35 RFBPF2012060AAT RFBPF2012040ABT RFBPF2012050ACT RFBPF2012080ADT RFBPF2008A40T RFBPF2008A39T HIGH FREQUENCY MULTILAYER BAND PASS FILTER TYPICAL ELECTRICAL CHARACTERISTICS RFBPF2012040AHT RBBPF2012050AHT RFBPF2012090ALT RFBPF2012090AMT RFBPF2012100ANT RFBPF2012090AQT RFBPF2012090ART RFBPF2012100AVT RBBPF2010A108Q1C RFBPF2009A12T 24 HIGH FREQUENCY MULTILAYER BAND PASS FILTER TYPICAL ELECTRICAL CHARACTERISTICS 25 RBBPF2010A16T RFBPF2009A25T RFBPF2009A26T RFBPF2012040A3T RFBPF2012080A6T RFBPF2012100A6T RFBPF2012080A7T RFBPF2520090ACT RFBPF2520070AMT RFBPF2520080AUT HIGH FREQUENCY MULTILAYER BAND PASS FILTER TYPICAL ELECTRICAL CHARACTERISTICS RFBPF2520120A1T RFBPF2520100A6T RFBPF1608060K2T RFBPF1608060K68Q1C RFBPF1608060K788Q1C RFBPF1608060K88Q1C RFBPF1608060KG8D1T RFBPF1606K12T RFBPF2012100KST RFBPF2012100K0T 26 HIGH FREQUENCY MULTILAYER BAND PASS FILTER TYPICAL ELECTRICAL CHARACTERISTICS RFBPF2012090K5T RFBPF2012100K3T RFBPF2012100K6T RFBPF2012090K9T RFBPF2520090K1T RFBPF16082G3W0T RFBPF1109060E0T RFBPF1411070E0T RFBPF2520090B08Q1C Low Band 27 High Band HIGH FREQUENCY MULTILAYER BAND PASS FILTER TYPICAL ELECTRICAL CHARACTERISTICS RFBPF3225180Y1T RFBPF3225200Y07B1U RBBPF3225180Y27B1U KFBPF2012100C67B1U RFBPF3225180C07B1U RBBPF3225180C67B1U RFBPF1109B101T RFBPF1109B201T RFBPF1109B301T RFBPF1109B501T 28 HIGH FREQUENCY MULTILAYER BAND PASS FILTER TYPICAL ELECTRICAL CHARACTERISTICS   29 RFBPF1109B701T RFBPF1109B801T RFBPF16081G9DM1T79 RFBPF16081G9DMAT79 For more information, please contact with local sales representative All specifications are subject to change without notice HIGH FREQUENCY MULTILAYER BALANCED FILTER HIGH FREQUENCY MULTILAYER BALANCED FILTER  STRUCTURE AND PIN ASSOCIATED STRUCTURE A STRUCTURE A-1 STRUCTURE A-2 STRUCTURE B  STRUCTURE AND DIMENSION Structure\ Dimension A B Unit: mm L W T A B C D E F G 1.60±0.15 0.80±0.15 0.60±0.10 0.175±0.15 0.25±0.15 0.25±0.15 0.50±0.15 0.20±0.15 0.20±0.15 0.30±0.15 1.20±0.10 0.40±0.10 0.175±0.10 0.35±0.15 0.30±0.15 0.65±0.10 0.20±0.10 0.20±0.15 0.50±0.10 0.50±0.10 0.20±0.15 0.30±0.15 0.35±0.15 0.65±0.15 0.20±0.15 0.20±0.15 0.30±0.15 0.60±0.10 0.20±0.15 0.30±0.10 0.35±0.10 0.65±0.10 0.20±0.15 0.20±0.15 0.50±0.10 0.90±0.10 0.20±0.15 0.30±0.10 0.35±0.10 0.65±0.10 0.20±0.15 0.20±0.15 0.30±0.10 0.63±0.10 0.20±0.15 0.20±0.15 0.50±0.10 1.00±0.10 0.20±0.15 0.30±0.10 0.35±0.10 0.65±0.10 0.20±0.10 0.20±0.15 0.50±0.10 1.10±0.10 0.20±0.15 0.30±0.10 0.35±0.10 0.65±0.10 0.20±0.15 0.20±0.15 0.55±0.10 0.50±0.10 0.35±0.10 0.65±0.10 0.20±0.15 0.20±0.15 0.50±0.10 2.00±0.15 1.25±0.15 2.50±0.20 2.00±0.20 0.85±0.10 0.35±0.20 0.40±0.10 0.30±0.10 0.70±0.20 0.15(Typical) 0.15(Typical) 1.20±0.20 1.95±0.15 1.25±0.15 0.80±0.10 0.175±0.15 0.30±0.15 0.35±0.15 0.65±0.15 0.25±0.15 - - 2.00±0.15 1.25±0.10 0.60±0.10 0.20±0.10 0.30±0.15 0.35±0.15 0.65±0.10 0.25±0.10 - - 30 HIGH FREQUENCY MULTILAYER BALANCED FILTER  ELECTRICAL SPECIFICATION 2.4GHz BAND WORKING FREQUENCY Part Number RFBPB2012090A1T Impedance(Ω) Frequency Range Unbalance Balance (MHz) 2.4~2.5 Insertion Loss (dB) Attenuation ( dB min. ) VSWR (Max.) 50 Conjugate match to BC series of Bluetooth chipset 3.5 35(880~960MHz) 30(1710~1880MHz) 20(1880~1990MHz) 30(4800~5000MHz) 2.1 180°± 10 2.8 35(880~960MHz) 30(1575MHz) 25(1710~1880MHz) 30(4800~5000MHz) 2.1 3.5 35(880~960MHz) 30(1710~1880MHz) 20(1880~1990MHz) 30(4800~5000MHz) Phase Amplitude Difference Difference Size (mm) STRUCTURE 2 2.00x1.25x0.90 A-1 180°± 10 2 2.00x1.25x0.90 A-1 2.1 180°± 10 2 2.00x1.25x0.90 A-1 RFBPB2012090A9T 2.4~2.5 50 Conjugate match to BC series of Bluetooth chipset RFBPB2012090AAT 2.4~2.5 50 Conjugate match to CSR BC03/ 04 series 50 Impedance match to T.I. CC253X,CC25 1.5max.(25℃) 4X, CC257X, 1.7max. CC853X and (-40~+85℃) CC852X Chipsets 12(1000MHz) 15(4800~5000MHz) 20(7200~7500MHz) 2.0 180°± 15 2 2.00x1.25x0.60 B 50 Impedance match to: Atmel AT86RF232, AT86RF233, ATMega256RF R2, Zigbit 1.5max.(25℃) 256RFR2, 1.7max. Zigbit RF233, (-40~+85℃) ZigBit RF233+FEM, Extension RF233, USB RF233 20(4800~5000MHz) 20(7200~7500MHz) 2.0 180°± 10 2 1.95x1.25x0.80 B 3.5 30(880~960MHz) 30(1710~1880MHz) 20(1880~1990MHz) 30(4800~5000MHz) 2.0 180°± 10 2 2.00x1.25x0.90 A-1 2.0 180°± 10 2 2.00x1.25x0.95 A-1 RFBPB2012060ABT RFBPB2012080AET RFBPB2012090AHT RFBPB2012090AM1T59 RFBPB2012090AM1T61 2.4~2.5 2.4~2.5 2.4~2.5 2.4~2.5 2.4~2.5 50 100 50 Conjunction to MT5931/MT66 28 Chipset 2.5 (typ.2.2) 35( 824~960 MHz) 32(1990 MHz) 18(2170 MHz) 40(4800~5000MHz) 25(7200~7500MHz) 50 Conjugate match to MTK MT6611 Bluetooth chipset 2.8 35(880~960MHz) 30(1710~1880MHz) 20(1880~1900MHz) 30(4800~5000MHz) 2.1 180°± 10 2 2.00x1.25x0.90 A-1 3.5 35(880~960MHz) 30(1710~1880MHz) 20(1880~1900MHz) 40(4800~5000MHz) 2.0 180°± 10 2 2.00x1.25x1.00 A-1 RFBPB2012100A6T 2.4~2.5 50 Conjugate match to BC series of Bluetooth chipset RFBPB2012110A5T 2.4~2.5 50 50 2.8 30(880~960 MHz) 30(1710~1880 MHz) 20(1880~1990 MHz) 30(4800~5000 MHz) 2.0 180°± 10 2 2.00x1.25x1.10 A-1 RFBPB2520090A7T 2.4~2.5 50 Conjugate match to TI BRF6150 3.5 35(880~960MHz) 30(1710~1880MHz) 25(1880~1990MHz) 25(4800~5000MHz) 2.0 180°± 15 1.5 2.50x2.00x0.90 A-2 31 HIGH FREQUENCY MULTILAYER BALANCED FILTER  TYPICAL ELECTRICAL CHARACTERISTICS RFBPB2012090A1T RFBPB2012090A9T RFBPB2012060ABT RFBPB2012080AET RFBPB2012090AHT 32 HIGH FREQUENCY MULTILAYER BALANCED FILTER TYPICAL ELECTRICAL CHARACTERISTICS RFBPB2012090AM1T59 RFBPB2012090AM1T61 RFBPB2012100A6T RFBPB2012090AM1T61   33 For more information, please contact with local sales representative All specifications are subject to change without notice HIGH FREQUENCY MULTILAYER LOW PASS FILTER HIGH FREQUENCY MULTILAYER LOW PASS FILTER  STRUCTURE AND PIN ASSOCIATED STRUCTURE A STRUCTURE A-1 STRUCTURE A-3 STRUCTURE C STRUCTURE A-2 STRUCTURE A-4 STRUCTURE B STRUCTURE B-1 STRUCTURE D STRUCTURE E STRUCTURE F STRUCTURE B-2 STRUCTURE G STRUCTURE H STRUCTURE I 34 HIGH FREQUENCY MULTILAYER LOW PASS FILTER  STRUCTURE AND DIMENSION Structure\Dimension A B C D E L 1.60±0.15 Unit: mm W 0.80±0.15 A B C D E 0.20±0.10 0.24±0.10 0.24±0.10 0.50±0.10 0.15±0.10 F - 0.60±0.10 0.175±0.15 0.25±0.15 0.25±0.15 0.50±0.15 0.20±0.15 - 0.65±0.10 0.175±0.15 0.25±0.15 0.25±0.15 0.50±0.15 0.20±0.15 - 0.70max. 0.175±0.15 0.25±0.15 0.25±0.15 0.50±0.15 0.20±0.15 - 0.90±0.10 0.20±0.10 0.30±0.10 0.35±0.10 0.65±0.10 0.20±0.10 0.20±0.10 0.95±0.10 0.20±0.10 0.30±0.10 0.35±0.10 0.65±0.10 0.20±0.10 0.20±0.10 1.05±0.10 0.20±0.10 0.30±0.10 0.35±0.10 0.65±0.10 0.20±0.10 0.20±0.10 1.00±0.20 0.10min. 0.55±0.15 0.45±0.15 1.00±0.15 0.30±0.15 0.70±0.20 2.00±0.15 1.25±0.10 3.20±0.20 2.50±0.20 1.00±0.10 0.50±0.10 0.40±0.10 0.35±0.10 0.30±0.10 0.15±0.10 0.15±0.10 0.30±0.10 - 1.60±0.15 0.80±0.15 0.50max. 0.45±0.15 0.70±0.15 0.20±0.15 0.20±0.15 0.30±0.15 0.25±0.15 0.65±0.10 0.50±0.10 0.40max. 0.225±0.10 0.20±0.05 0.10±0.05 0.25±0.05 0.025±0.25 - 0.65max. 0.23±0.05 0.40±0.10 0.30±0.10 0.65±0.10 0.20±0.05 0.23±0.05 1.60±0.15 1.60±0.10 0.80±0.15 0.80±0.10 F G T 0.50max. 2.00±0.15 1.25±0.10 1.00±0.10 0.50±0.10 H 3.20±0.20 2.50±0.20 I 1.60±0.15 0.80±0.10 0.60±0.10 0.23±0.05 0.40±0.10 0.30±0.10 0.65±0.10 0.20±0.05 0.23±0.05 0.70max. 0.25±0.10 0.40±0.10 0.23±0.10 0.55±0.10 0.21±0.10 0.195±0.10 0.55±0.10 0.25±0.10 00.230.10 0.40±0.10 0.12±0.10 0.125±0.10 0.60±0.10 0.25±0.10 0.25±0.10 0.40±0.10 0.10±0.05 0.10±0.05 0.90±0.10 0.95±0.10 0.275±0.10 0.25±0.10 0.60±0.10 0.175±0.10 0.15±0.10 0.15±0.10 0.65max. 1.00max. 0.95±0.10 0.275±0.10 0.25±0.10 0.60±0.10 0.175±0.10 0.40 max. 0.18±0.05 0.18±0.05 0.05±0.05 0.125±0.05 0.15±0.05 0.05±0.05 1.00±0.20 0.95±0.20 0.60±0.20 0.30±0.15 0.70±0.15 1.20±0.15 2.00±0.15 1.80±0.20 0.95±0.20 0.60±0.20 0.30±0.15 0.70±0.15 1.20±0.15 2.00±0.15 0.70±0.10 0.20±0.10 0.50±0.10 0.35±0.10 0.15±0.10 - -  ELECTRICAL SPECIFICATION GSM850/900GHz BAND WORKING FREQUENCY Part Number Frequency Range (MHz) Insertion Loss (dB) Attenuation ( dB min. ) VSWR (max.) Impedance (Ω) Size(mm) Structure RFLPF06050G9D0T 824~915 0.5max.(25℃) 0.7max.(-40~+85℃) 20(2400~2750MHz) 2.0 50 0.65x0.50x0.40 D RFLPF06050G9D2T 699~960 0.5max.(25℃) 0.7max.(-40~+85℃) 20(2400~2750MHz) 2.0 50 1.00x0.50x0.40 D RFLPF10050G9D0T 824~915 0.6 25(1648~1830MHz) 25(2472~2745MHz) 25(3296~3660MHz) 2.0 50 1.00x0.50x0.40 C RFLPF10050G9D3T 824~915 0.5max.(25℃) 0.7max.(-40~+85℃) 25(1648~1830MHz) 25(2472~2745MHz) 25(3296~3660MHz) 2.0 50 1.00x0.50x0.40 C RFLPF10050G9D4T 699~915 0.5max.(25℃) 0.7max.(-40~+85℃) 25(1648~1830MHz) 25(2472~2745MHz) 25(3296~3660MHz) 2.0 50 1.00x0.50x0.40 C RFLPF10050G9D58Q1C 814~915 0.5max.(25℃) 0.65max.(-40~+85℃) 18(1648~1830MHz) 17(2472~2745MHz) 2.0 50 1.00x0.50x0.40 C RFLPF16080G9D4T 698~960 0.60(698~830MHz) 0.70(830~900MHz) 0.75(900~915MHz) 0.90(915~960MHz) 30(1554~1830MHz) 35(2097~2745MHz) 1.6 50 1.60x0.80x0.65 A-3 RFLPF16080G9DET 698~960 0.4max.(25℃) 0.45max.(-40~+85℃) 15(1574~1605MHz) 23(1648~1830MHz) 23(1805~1850MHz) 23(4944~5850MHz) 2.0 50 1.60x0.80x0.60 E RFLPF16080G9DJT 434~960 0.6max.(25℃) 0.8max.(-40~+85℃) 25(1554~1610MHz) 30(1710~2700MHz) 2.0 50 1.60x0.80x0.65 A-1 RFLPF16080G9DM1T58 698~960 0.8 16(1565~1610MHz) 32(2110~2155MHz) 2.0 50 1.60x0.80x0.50 A-4 RFLPF10050G9DM1T76 698~960 0.6max.(25℃) 0.65max.(-40~+85℃) 13 (1554~1610MHz) 35(1805~1830MHz) 35(2110~2170MHz) 30(1710~2700MHz) 2.0 50 1.00x0.50x0.40 G RFLPF20120G9D0T 890~915 0.6max.(25℃) 0.75max.(-40~+85℃) 30(1780~1830MHz) 30(2670~2745MHz) 2.0 50 2.00x1.25x0.95 B-2 RFLPF20120G9D1T 890~915 0.6max.(25℃) 0.75max.(-40~+85℃) 40(1720~1765MHz) 30(1780~1830MHz) 30(2670~2745MHz) 2.0 50 2.00x1.25x0.95 B-2 35 HIGH FREQUENCY MULTILAYER LOW PASS FILTER DCS/PCS BAND WORKING FREQUENCY Part Number Frequency Range (MHz) Insertion Loss (dB) RFLPF10051G8D0T 1710~1910 0.8 RFLPF10051G8DM5T51 1710~1910 0.6 RFLPF10051G8D8T 1880~2025 RFLPF16081G8D3T RFLPF16081G8D78Q1C Attenuation ( dB min. ) 35(3420~3570MHz) 35(3700~3820MHz) 35(5130~5730MHz) VSWR (max.) Impedance (Ω) Size(mm) Structure 2.0 50 1.00x0.50x0.40 C 26(3420~3570MHz) 21(3700~3820MHz) 21(5130~5730MHz) 2.0 50 1.00x0.50x0.40 C 1.4max.(25℃) 1.6max.(-40~+85℃) 10(2400~2500MHz) 22(3760~4050MHz) 22(5150~5850MHz) 22(5640~6075MHz) 2.0 50 1.00x0.50x0.40 G 1710~1910 0.45max.(25℃) 0.55max.(-40~+85℃) 30(3420~3570MHz) 25(3700~3820MHz) 25(5130~5730MHz) 2.0 50 1.60x0.80x0.50 C 1880~2025 1.4 25(2400~2500MHz) 18(4020~4045MHz) 25(6030~6075MHz) 2.0 50 1.60x0.80x0.60 F RFLPF16081G8DC8Q1C 1880~2170 0.60(1880~1920MHz) 0.70(1920~1980MHz) 0.80(2010~2170MHz) 2.00(2025~2170MHz) 15(2400~2500MHz) 20(3760~4050MHz) 12(5150~5850MHz) 12(5640~6075MHz) 5(7520~8100MHz) 2.0 20 1.60x0.80x0.60 E RFLPF16081G8DHT 1710~1990 0.6max.(25℃) 0.8max.(-40~+85℃) 30.5(3420~3980MHz) 28.5(5130~5970MHz) 25.0(5970~12500MHz) 2.0 50 1.60x0.80x0.70 I RFLPF20121G8D1T 1880~2025 1.35max.(25℃) 1.50max.(-40~+85℃) 38(2400~2500MHz) 25(4020~4045MHz) 27(6030~6075MHz) 1.9 50 2.00x1.20x0.90 F VSWR (max.) Impedance (Ω) Size(mm) Structure 1.7 50 1.00x0.50x0.40 C 2.4GHz BAND WORKING FREQUENCY Part Number Frequency Range (MHz) RFLPF1005040A0T 2450±50 RFLPF1005040A1T RFLPF1005040A2T Insertion Loss (dB) 0.45max.(25℃) 0.55max.(-40~+85℃) Attenuation ( dB min. ) 21(4800~5000MHz) 21(7200~7500MHz) 2450±50 0.75 33(4800~5000MHz) 37(7200~7500MHz) 2.0 50 1.00x0.50x0.40 C 2450±50 0.75max.(25℃) 0.90max.(-40~+85℃) 32(4800~5000MHz) 35(7200~7500MHz) 2.0 50 1.00x0.50x0.40 C 2.0 50 1.60x0.80x0.70 A-1 RFLPF1608060AAT 2450±50 0.65 20(3603~3720MHz) 30(4804~4960MHz) 10(6005~6200MHz) 20(7206~7440MHz) 10(8407~8680MHz) 20(9608~9920MHz) 10(10809~11160MHz) 10(12010~12400MHz) 10(13211~13640MHz) 15(14412~14880MHz) 10(15613~16120MHz) 10(16814~17360MHz) RFLPF1608060ABT 2450±50 0.50 35(4800~5000MHz) 25(7200~7500MHz) 2.0 50 1.60x0.80x0.60 A-1 RFLPF1608060A0T 2450±50 0.65 (typ.0.48) 35(4800MHz(typ.40)) 27(7200MHz(typ.40)) 1.5 50 1.60x0.80x0.60 A-1 RFLPF1608060A1T 2450±50 0.6 27(4800~5000MHz) 30(7200~7500MHz) 2.0 50 1.60x0.80x0.60 A-2 1.5 50 1.60x0.80x0.60 A-1 RFLPF1608060A2T 2450±50 0.42 25(4800MHz) 18(7200MHz) RFLPF1608060A9T 2450±50 0.50max.(25℃) 0.60max.(-40~+85℃) 20(3400MHz) 20(3600MHz) 30(4800~5000MHz) 30(7200~7500MHz) 2.0 50 1.60x0.80x0.60 E RFLPF2012110A0T 2450±50 0.7 30(2x(fo±BW/2)) 20(3x(fo±BW/2)) 1.5 50 2.00x1.25x1.05 B-1 Insertion Loss (dB) Attenuation ( dB min. ) VSWR (max.) Impedance (Ω) Size(mm) Structure 2.0 50 1.60x0.85x0.50 C 2.0 50 2.00x1.25x0.90 B-1 5GHz BAND WORKING FREQUENCY Part Number Frequency Range (MHz) RFLPF1608050K0T 5400±500 0.60(25℃) 0.70(-40~+85℃) 25(9800MHz) 30(11900MHz) 20(17850MHz) (for reference) RFLPF2012090K0T 5400±500 0.55(25℃) 0.65(-40~+85℃) 30(9800MHz) 30(11800MHz) 20(17550MHz (for reference) 36 HIGH FREQUENCY MULTILAYER LOW PASS FILTER LTE BAND APPLICATION Part Number Frequency Range (MHz) Insertion Loss (dB) Attenuation (dB min. ) VSWR (max.) Impedance (Ω) Size(mm) Structure RFLPF1005040YM1T76 746~878 0.60(25℃) 0.65(-40~+85℃) 30(1554~1610MHz) 25(2238~2361MHz) 2.0 50 1.00x0.50x0.40 G RFLPF1608060Y08Q1C 470~787 0.65(25℃) 0.71(-40~+85℃) 26(1429~1501MHz) 30(1565~1607MHz) 35(1570~1580MHz) 18(1920~1980MHz) 2.0 50 1.60x0.85x0.65 A-3 RFLPF1608060Y18Q1C 698~960 0.60(698~830MHz) 0.70(830~900MHz) 0.75(900~915MHz) 0.90(915~960MHz) 30(1554~1830MHz) 35(2097~2745MHz) 1.6 50 1.60x0.85x0.65 A-3 RFLPF2012090Y2T 400~470 0.50(25℃) 0.65(-40~+85℃) 33(800~940MHz) 2.0 50 2.00x1.25x0.90 F RFLPF2012090Y3T 500~700 0.65(25℃) 0.80(-40~+85℃) 33(1000~1400MHz) 2.0 50 2.00x1.25x0.90 F RFLPF2012100Y0T DC~500 0.70 9(824~960MHz) 25(1710~1990MHz) 25(2400~4000MHz) 2.0 50 2.00x1.25x0.95 B-2 RFLPF1608060E0T 1400~2690 0.25(25℃) 0.30(-40~+85℃) 25(4905~5845MHz) 1.92 50 1.60x0.85x0.65 F RFLPF1608060F0T 600~2700 0.50 30(4800~8000MHz) 25(8500~12500MHz) 2.0 50 1.60x0.85x0.65 F 0.50 35(4950~6000MHz) 35(6000~7500MHz) 35(7500~8100MHz) 35(8100~10500MHz) 27(10500~12500MHz) 2.0 50 1.60x0.85x0.65 F RFLPF1608060F18Q1C 673~2690 RFLPF1608060F88Q1C 10~2700 0.5 30(4900~5950MHz) 2.0 50 1.60x0.85x0.65 E 673~2690 0.25(25℃) 0.35(-40~+85℃) 25(4905~5845MHz) 1.92 50 1.60x0.85x0.65 F 1.30(25℃) 1.50(-40~+85℃) 15(2400~2500MHz) 25(3250~3350MHz) 25(3420~3570MHz) 23(3700~3820MHz) 23(3840~3960MHz) 23(4100~4600MHz) 25(4905~5845MHz) 23(5850~6400MHz) 20(6600~7350MHz) 1.56 50 2.00x1.25x1.00 B-2 10(2400~2500MHz) 23(3250~3350MHz) 20(3420~3570MHz) 18(3700~3820MHz) 18(3840~3960MHz) 18(4100~4600MHz) 20(4905~5845MHz) 18(5850~6400MHz) 5(6600~7350MHz) 2.0 50 2.00x1.25x1.00 F 2.0 50 1.60x0.80x0.60 A-2 2.0 50 1.60x0.80x0.60 A-2 RFLPF1608060FAT RFLPF2012100F18Q1C 1710~2170 RFLPF2012100F28Q1C DC~2170 0.75(25℃) 0.85(-40~+85℃) RFLPF16082G6W0T 2400~2690 0.6 RFLPF16082G6W2T 2300~2700 0.40(25℃) 0.43(-40~+85℃) RFLPF16082G5W0T 2300~2700 0.90(25℃) 1.00(-40~+85℃) 30(4600~5400MHz) 30(6900~8100MHz) 20(9200~10800MHz) 15(11500~13500MHz) 1.8 50 1.60x0.80x0.60 A-1 RFLPF16082G5WM0T29 2300~2690 0.80 (typ.0.40) 25(4600~5400MHz) 25(6900~8070MHz) 2.0 50 1.60x0.80x0.60 A-1 1.9 50 1.60x0.80x0.60 A-3 26(4800~5390MHz) 23(7200~8085MHz) 21(4600~5400MHz) 22(6900~8100MHz) RFLPF16083G5W7T 3300~3800 0.55 17(6600~7600MHz) 20(9900~11400MHz) RFLPF2012090BM0T29 800~1000 1700~1910 2010~2025 0.5(800~1000MHz) 0.8(1700~1910MHz) 1.5(2010~2025MHz) 20(2300~3700MHz) 30(3700~4100MHz) 20(4100~6100MHz) 10(6100~8000MHz) 2.0 50 2.00x1.25x0.90 F Part Number Frequency Range (MHz) Insertion Loss (dB) Attenuation ( dB min. ) VSWR (max.) Impedance (Ω) Size(mm) Structure RFLPF3225180Y1T 54~870 2.5 35(975~1675MHz) 2.0 75 3.20x2.50x1.80 H RFLPF3225100Q07B1U 5~1002 2.4(25℃) 2.6(-40~+85℃) 36(1125~1675MHz) 2.0 75 3.20x2.50x1.00 H RFLPF3225100Q2T 5~1002 2.4(25℃) 2.6(-40~+85℃) 28(1125~1675MHz) 1.9 75 3.20x2.50x1.00 B-1 RFLPF3225200Q5T 5~1002 1.8(25℃) 2.05(-40~+85℃) 33(1125~1400MHz) 26(1400~1675MHz) 2.0 75 3.20x2.50x1.80 H MoCA APPLICATION 37 HIGH FREQUENCY MULTILAYER LOW PASS FILTER  TYPICAL ELECTRICAL CHARACTERISTICS RFLPF06050G9D0T RFLPF06050G9D2T RFLPF10050G9D0T RFLPF10050G9D3T RFLPF10050G9D4T RFLPF10050G9D58Q1C RFLPF16080G9D4T RFLPF16080G9DET RFLPF16080G9DJT RFLPF16080G9DM1T58 38 HIGH FREQUENCY MULTILAYER LOW PASS FILTER TYPICAL ELECTRICAL CHARACTERISTICS 39 RFLPF10050G9D8T RFLPF20120G9D0T RFLPF20120G9D1T RFLPF10051G8D0T RFLPF10051G8DM5T51 RFLPF10051G8D8T RFLPF16081G8D3T RFLPF16081G8D78Q1C RFLPF16081G8DC8Q1C RFLPF20121G8D1T HIGH FREQUENCY MULTILAYER LOW PASS FILTER TYPICAL ELECTRICAL CHARACTERISTICS RFLPF1005040A0T RFLPF1005040A1T RFLPF1005040A2T RFLPF1608060AAT RFLPF1608060ABT RFLPF160806A0T RFLPF1608060A1T RFLPF1608060A2T RFLPF1608060A9T RFLPF1608050K0T 40 HIGH FREQUENCY MULTILAYER LOW PASS FILTER TYPICAL ELECTRICAL CHARACTERISTICS 41 RFLPF2012090K0T RFLPF1005040YM1T76 RFLPF1608060Y08Q1C RFLPF1608060Y18Q1C RFLPF2012090Y2T RFLPF2012090Y3T RFLPF2012100Y0T RFLPF1608060E0T RFLPF1608060F0T RFLPF1608060F18Q1C HIGH FREQUENCY MULTILAYER LOW PASS FILTER TYPICAL ELECTRICAL CHARACTERISTICS RFLPF1608060F88Q1C RFLPF1608060FAT RFLPF2012100F18Q1C RFLPF2012100F28Q1C RFLPF16082G6W0T RFLPF16082G6W2T RFLPF16082G5W0T RFLPF16082G5WM0T29 RFLPF16083G5W7T RFLPF2012090BM0T29 42 HIGH FREQUENCY MULTILAYER LOW PASS FILTER TYPICAL ELECTRICAL CHARACTERISTICS   43 RFLPF3225180Y1T RFLPF3225100Q07B1U RFLPF3225100Q2T RFLPF3225200Q5T For more information, please contact with local sales representative All specifications are subject to change without notice HIGH FREQUENCY MULTILAYER HIGH PASS FILTER HIGH FREQUENCY MULTILAYER HIGH PASS FILTER  STRUCTURE AND PIN ASSOCIATED STRUCTURE A STRUCTURE B STRUCTURE C STRUCTURE D  STRUCTURE AND DIMENSION Structure\ Dimension L W A 0.65 ± 0.10 B 1.60 ± 0.15 C D Unit: mm T A B C D E F 0.50 ± 0.10 0.4 max. 0.225 ± 0.10 0.20 ± 0.05 0.10 ± 0.10 0.20 ± 0.05 0.05 ± 0.05 - 0.80 ± 0.15 0.60 ± 0.1.0 0.23 ± 0.05 0.40 ± 0.10 0.30 ± 0.10 0.65 ± 0.10 0.20 ± 0.05 0.23 ± 0.05 1.60 ± 0.10 0.80 ± 0.10 0.65 max. 0.65 ± 0.10 0.25 ± 0.10 0.275 ± 0.10 0.40 ± 0.10 0.075 ± 0.05 0.075 ± 0.05 3.20 ± 0.20 2.50 ± 0.20 1.7 max. 0.95 ± 0.20 0.60 ± 0.20 0.30 ± 0.15 0.70 ± 0.15 1.20 ± 0.15 2.00 ± 0.15  ELECTRICAL SPECIFICATION 2496 ~ 2690 MHz BAND WORKING FREQUENCY Part Number Frequency Range (MHz) Insertion Loss (dB) Attenuation (dB min. ) VSWR (max.) Size (mm) Structure RFHPF16082G5W0T 2496~2690 1.2max.(25℃) 1.3max.(-40~+85℃) 25(1710~1995MHz) 2.0 1.6 X 0.8 X 0.6 B RFHPF16082G5W1T 2496~2690 0.9max.(25℃) 1.2max.(-40~+85℃) 22(1710~2010MHz) 2.0 1.6 X 0.8 X 0.6 C 5GHz BAND WORKING FREQUENCY Part Number Frequency Range (MHz) Insertion Loss (dB) Attenuation (dB min. ) VSWR (max.) Size (mm) Structure RFHPF0605040K0T 4900~5840 0.60max.(25℃) 0.65max.(-40~+85℃) 14(2400~2500MHz) 1.6 0.65 X 0.5 X 0.4 A RFHPF0605040K1T 4900~5850 0.65 20(2450~2500MHz) 2.0 0.65 X 0.5 X 0.4 A Part Number Frequency Range (MHz) Insertion Loss (dB) Attenuation (dB min. ) VSWR (max.) Size (mm) Structure RFHPF3225170F07B1U 950~2150 2.00max.(25℃) 2.2max.(-40~+85℃) 50(475~675MHz) 2.0 3.2 X 2.5 X 1.7 D MoCA Application 44 HIGH FREQUENCY MULTILAYER HIGH PASS FILTER  TYPICAL ELECTRICAL CHARACTERISTICS RFHPF16082G5W0T RFHPF16082G5W1T RFHPF0605040K0T RFHPF0605040K1T RFHPF3225170F07B1U   45 For more information, please contact with local sales representative All specifications are subject to change without notice BALUN TRANSFORMERS BALUN TRANSFORMERS  STRUCTURE AND PIN ASSOCIATED STRUCTURE A STRUCTURE A-1 STRUCTURE A-2 STRUCTURE A-3 STRUCTURE A-4 STRUCTURE B STRUCTURE B-1 STRUCTURE B-2 STRUCTURE C STRUCTURE D STRUCTURE C-1 STRUCTURE C-2 STRUCTURE E STRUCTURE F 46 BALUN TRANSFORMERS  STRUCTURE AND DIMENSION Structure\ Dimension L 1.60±0.10 1.60±0.15 A W T 0.85±0.10 0.70±0.10 0.20±0.10 0.20±0.10 0.30±0.10 0.50±0.05 0.50±0.05 - - - 0.80±0.10 0.50±0.10 0.175±0.15 0.25±0.15 0.25±0.15 0.50±0.15 0.20±0.15 - - - 0.85±0.10 A C D E F G H 0.40 max. 0.175±0.15 0.25±0.15 0.25±0.15 0.50±0.15 0.20±0.15 - - - 0.175±0.15 0.25±0.15 0.25±0.15 0.50±0.15 0.20±0.15 - - - 0.175±0.15 0.25±0.15 0.25±0.15 0.50±0.15 - - - - 0.65±0.10 1.25±0.15 B 0.60±0.10 0.70±0.10 0.85±0.15 2.00±0.15 Unit: mm 0.80±0.10 0.20±0.20 0.30±0.20 0.35±0.20 0.65±0.20 - - - - 0.85±0.10 0.20±0.20 0.30±0.20 0.35±0.20 0.65±0.20 - - - - 0.80±0.10 0.20±0.15 0.30±0.20 0.35±0.20 0.65±0.20 - - - - 0.95±0.10 0.20±0.20 0.30±0.20 0.35±0.20 0.65±0.20 - - - - 1.00±0.10 0.50±0.10 0.37±0.10 0.10±0.10 0.30±0.10 0.20±0.10 0.50±0.10 0.125±0.10 - - - 1.00±0.10 0.50±0.10 0.40±0.10 0.10±0.10 0.30±0.10 0.20±0.10 0.50±0.10 0.125±0.10 - - - C 2.00±0.10 1.25±0.15 0.90±0.10 0.125±0.10 0.25±0.10 0.25±0.10 0.50±0.10 0.475±0.10 0.30±0.10 0.20±0.15 0.20±0.15 D 1.60±0.15 0.80±0.15 0.50±0.10 0.175±0.10 0.25±0.10 0.25±0.10 0.50±0.10 0.25±0.10 - - - E 0.65±0.10 0.50±0.10 0.40±0.10 0.20±0.05 0.20±0.05 0.025±0.025 0.10±0.05 0.25±0.05 0.025±0.025 - - F 1.00±0.10 0.50±0.10 0.5 max. 0.35±0.10 0.30±0.10 0.15±0.10 0.15±0.10 0.30±0.10 - - - B  ELECTRICAL SPECIFICATION ISM Band 2.4GHz APPLICATION Impedance(Ω) Part Number Frequency Range (MHz) Balance Return Loss (dB) Min. Insertion Loss (dB) Amplitude Difference (dB) Max. Unbalance Phase Difference Size(mm) Structure RFBLN1005040A6T 2400~2500 50 50 10 0.8 2.0 180± 10 1.00x0.50x0.40 B-2 RFBLN1608050AAT 2400~2500 50 Conjugate match to AR6003 chipset 10 1.2 2.0 180± 10 1.60x0.80x0.50 D RFBLN1608050AM8T62 2400~2500 50 50 10 1.2 2.0 180± 10 1.60x0.80x0.50 A-2 RFBLN1608050AM0T63 2400~2500 50 50 10 1.0 1.0 180± 10 1.60x0.80x0.55 A-2 RFBLN1608050AM6T30 2400~2500 50 35 10 1.0 1.0 180± 10 1.60x0.80x0.55 A-2 RFBLN1608060AC6T40 2400~2500 50 Conjugate match to TI CC26XX Chipset 10 1.6(25℃) 1.8(-40~+85℃) 2.3 180± 18 1.60x0.80x0.60 A-3 RGBLN1608070A1T 2400~2500 50 100 10 1.5 2.0 180± 15 1.60x0.85x0.70 A-1 RGBLN1608070A5T 2400~2500 50 100 10 1.2 2.0 180± 10 1.60x0.80x0.70 A-2 RGBLN2012080A5T 2400~2500 50 50 12 1.0 1.0 180± 10 2.00x1.25x0.85 A-2 RFBLN2012080A7T 2400~2500 50 100 10 1.0 2.0 180± 10 2.00x1.25x0.80 A-2 RGBLN2012090A0T 2400~2500 50 50 10 1.2 2.0 180± 10 2.00x1.25x0.95 A-2 RFBLN2012090A1T 2400~2500 50 100 10 1.0 2.0 180± 10 2.00x1.25x0.95 A-2 Insertion Loss (dB) Amplitude Difference (dB) Max. Phase Difference Size (mm) Structure ISM Band 5GHz APPLICATION 47 Part Number Frequency Range (MHz) Unbalance Balance Return Loss (dB) Min RFBLN1005040K1T 4900~5950 50 50 10 1.2 2.0 180± 10 1.00x0.50x0.40 B-2 RFBLN1005040K5T 4900~5950 50 100 10 0.55(25℃) 0.75(-40~+85℃) 2.5 180± 10 1.00x0.50x0.40 B-2 RFBLN1005040K6T 4900~5950 50 50 10 0.60(25℃) 0.80(-40~+85℃) 2.5 180± 15 1.00x0.50x0.40 B-2 RFBLN2012090K1T 4900~5900 50 100 10 1.2 2.0 180± 10 2.00x1.25x0.95 A-4 Impedance(Ω) BALUN TRANSFORMERS LTE Band APPLICATION Part Number Frequency Range (MHz) Unbalance Balance Return Loss (dB)Min Amplitude Difference (dB) Max. Phase Difference Size (mm) Structure RFBLN0605040Y1T 717~821 50 100 15 2.0 180± 10 0.65x0.50x0.40 E RFBLN0605040YM9T16 729~821 50 100 10 2.0 180± 10 0.65x0.50x0.40 E RFBLN1005040YM1T69 703~803 50 100 10 2.0 180± 12 1.00x0.50x0.40 F RFBLN06050G9D0T 729~960 50 100 15 4.8 180± 10 0.65x0.50x0.40 E RFBLN16080G9D2T 699~960 50 100 10 2.5 180± 15 1.60x0.80x0.70 A-4 RFBLN16080G9D3T 824~894 50 50 10 1.2 1.0 180± 10 1.60x0.80x0.60 A-2 RFBLN20120G9D0T 824~894 50 100 10 1.2 1.0 180± 10 2.00x1.25x0.90 A-2 RFBLN20120G9D5T 880~960 50 100 10 1.1 1.0 180± 10 2.00x1.25x0.90 A-2 RFBLN20120G9D8T 800~1000 50 50 10 1.2 2.0 180± 10 2.00x1.25x0.90 A-2 1.8 180± 10 0.65x0.50x0.40 E 3.0 180± 15 0.65x0.50x0.40 E 2.0 180± 10 2.00x1.25x0.95 A-2 2.0 180± 10 1.00x0.50x0.40 B-2 2.2 180± 12 1.00x0.50x0.40 B-2 1.2 180± 15 1.00x0.50x0.40 F 1.5 180± 17 1.60x0.80x0.70 A-4 2.0 180± 10 1.60x0.80x0.60 A-2 Impedance(Ω) RFBLN06051G8DM1T69 1805~1990 50 100 10 RFBLN06051G8D1T 1805~2170 50 100 10 RFBLN20121G8D1T 1700~2000 50 100 10 Insertion Loss (dB) 0.55(25℃) 0.65(-40~+85℃) 0.55(25℃) 0.65(-40~+85℃) 0.8 0.85(25℃) 0.95(-40~+85℃) 1.05(25℃) 1.15(-40~+85℃) 0.60(25℃) 0.65(-40~+85℃) 0.65(25℃) 0.70(-40~+85℃) 1.0 0.65(25℃) 0.75(-40~+85℃) 0.60(25℃) 0.70(-40~+85℃) 0.70(25℃) 0.80(-40~+85℃) 1.7(25℃) 2.0(-40~+85℃) 1.20(25℃) 1.40(-40~+85℃) RFBLN10051G9D0T 1805~2020 50 100 10 RFBLN10051G9D1T 1805~1990 50 100 10 RFBLN1005040F0T 1805~2170 50 100 10 RFBLN1608070F48Q1C 673~2700 50 100 10 RFBLN1608060FET 1710~2200 50 50 10 RFBLN2012090F0T 1920~1980 2110~2170 50 50 10 1.0 2.0 180± 10 2.00x1.25x0.95 A-2 RFBLN0605040E0T 2000~2500 50 100 10 0.60(25℃) 0.70(-40~+85℃) 3.5 180± 10 0.65x0.50x0.40 E RFBLN2012090E0T 1500~3000 50 100 10 1.0 2.0 180± 10 2.00x1.25x0.90 A-4 2.5 180± 10 0.65x0.50x0.40 E 2.5 180± 10 1.00x0.50x0.40 B-1 2.5 180± 10 1.00x0.50x0.40 B-2 2.0 180± 10 1.60x0.80x0.70 A-2 0.55(25℃) 0.65(-40~+85℃) 0.55(25℃) 0.65(-40~+85℃) 0.65(25℃) 0.75(-40~+85℃) RFBLN06052G5WM9T16 2300~2690 50 100 10 RFBLN10052G5WM9T16 2300~2690 50 100 10 RFBLN10052G5W37N2T 2300~2690 50 100 10 RFBLN16082G5W0T 2300~2700 50 100 10 1.1 1.0 180± 10 1.60x0.80x0.40 A-4 2.0 180± 10 1.60x0.80x0.50 A-2 RFBLN16082G5W38Q1C 2300~2700 50 100 10 0.55(25℃) 0.65(-40~+85℃) RFBLN16082G5W4T 2300~2700 50 50 10 1.2 GSM 850/ GSM 900/ DCS1800/ PCS1900 APPLICATION Part Number Frequency Range (MHz) Unbalance Balance Return Loss (dB) Min Insertion Loss (dB) Amplitude Difference (dB) Max 869~960 50 200 10 1.1 2.0 1805~2025 50 200 10 1.8 2.0 869~960 50 200 10 1.1(25℃) 1.3(-40~+85℃) 2.0 1805~1990 50 200 10 1.6(25℃) 1.8(-40~+85℃) 2.0 869~960 50 200 10 1.1(25℃) 1.3(-40~+85℃) 2.0 1805~2025 50 200 10 1.8(25℃) 2.0(-40~+85℃) 2.0 RFBLN2012090BM5T25 RFBLN2012090BS0T53 RFBLN2012090BS0T50 Attenuation (dB min.) 10(1738~1920MHz) 20(2400~2500MHz) 20(2607~2880MHz) 15(2400~2500MHz) 20(3610~3980MHz) 20(5415~5970MHz) 10(1738~1920MHz) 20(2400~2500MHz) 20(2607~2880MHz) 15(2400~2500MHz) 15(3610~3980MHz) 20(5415~5970MHz) 10(1738~1920MHz) 20(2400~2500MHz) 20(2607~2880MHz) 15(2400~2500MHz) 15(3610~3980MHz) 20(5415~5970MHz) Phase Difference Size(mm) Structure 2.00x1.25x0.95 C-1 2.00x1.25x0.95 C-1 2.00x1.25x0.95 C-2 180± 10 180± 15 180± 15 180± 15 180± 15 180± 15 48 BALUN TRANSFORMERS  TYPICAL ELECTRICAL CHARACTERISTICS RFBLN1005040A6T RFBLN1608050AAT RFBLN1608050AM8T62 RFBLN1608050AM0T63 RFBLN2012080A7T 49 BALUN TRANSFORMERS TYPICAL ELECTRICAL CHARACTERISTICS RGBLN2012090A0T RFBLN1005040K1T RFBLN1005040K5T RFBLN0605040Y1T RFBLN0605040YM9T16 50 BALUN TRANSFORMERS TYPICAL ELECTRICAL CHARACTERISTICS RFBLN1005040YM1T69 RFBLN06050G9D0T RFBLN16080G9D2T RFBLN16080G9D3T RFBLN20120G9D0T 51 BALUN TRANSFORMERS TYPICAL ELECTRICAL CHARACTERISTICS RFBLN20120G9D5T RFBLN20120G9D8T RFBLN06051G8DM1T69 RFBLN06051G8D1T RFBLN20121G8D1T 52 BALUN TRANSFORMERS TYPICAL ELECTRICAL CHARACTERISTICS RFBLN10051G9D0T RFBLN10051G9D1T RFBLN1005040F0T RFBLN1608070F48Q1C RFBLN2012090F0T 53 BALUN TRANSFORMERS TYPICAL ELECTRICAL CHARACTERISTICS RFBLN0605040E0T RFBLN2012090E0T RFBLN06052G5WM9T16 RFBLN10052G5WM9T16 RFBLN10052G5W37N2T 54 BALUN TRANSFORMERS TYPICAL ELECTRICAL CHARACTERISTICS RFBLN16082G5W0T RFBLN16082G5W38Q1C RFBLN2012090BM5T25 Low Band High Band RFBLN2012090BS0T53 Low Band   55 For more information, please contact with local sales representative All specifications are subject to change without notice High Band DIPLEXER DIPLEXER  STRUCTURE AND PIN ASSOCIATED STRUCTURE A STRUCTURE A-1 STRUCTURE A-2 STRUCTURE A-3 STRUCTURE A-4 STRUCTURE B STRUCTURE C STRUCTURE D STRUCTURE E STRUCTURE B-1 STRUCTURE C-1 STRUCTURE D-1 STRUCTURE E-1 STRUCTURE B-2 STRUCTURE C-2 STRUCTURE D-2 STRUCTURE E-2 STRUCTURE F STRUCTURE G STRUCTURE H 56 DIPLEXER  STRUCTURE AND DIMENSION Structure\ Dimension A B Unit: mm L W T A B C D E F 1.60±0.15 0.80±0.15 0.60±0.10 0.175±0.15 0.25±0.15 0.25±0.15 0.50±0.15 0.20±0.15 - 2.00±0.10 1.25±0.20 0.55±0.15 0.20±0.15 0.30±0.15 0.35±0.15 0.65±0.15 0.20±0.10 - 2.00±0.15 1.25±0.15 0.95±0.10 0.20±0.20 0.30±0.20 0.35±0.20 0.65±0.20 - - 1.60±0.15 0.80±0.15 0.60±0.10 0.65±0.15 0.30±0.15 0.20±0.15 0.20±0.15 0.25±0.15 0.30±0.15 0.70±0.10 0.35±0.10 0.30±0.10 0.65±0.10 0.60±0.10 0.275±0.10 - 0.90±0.10 0.35±0.10 0.30±0.10 0.65±0.10 0.60±0.10 0.275±0.10 - 2.00±0.15 1.25±0.15 2.50±0.15 2.00±0.15 0.80±0.15 0.30±0.15 0.35±0.15 0.65±0.15 0.75±0.15 0.525±0.15 D 1.60±0.15 0.80±0.15 0.60±0.10 0.175±0.15 0.25±0.15 0.25±0.15 0.50±0.15 0.20±0.15 - E 2.50±0.15 2.00±0.15 0.70±0.10 0.30±0.10 0.40±0.10 0.60±0.10 1.10±0.10 - - C F 2.50±0.15 2.00±0.15 1.0max. 0.375±0.15 0.25±0.15 0.25±0.15 0.50±0.15 0.20±0.15 - G 1.60±0.15 0.80±0.15 0.60±0.10 0.65±0.15 0.30±0.15 0.20±0.15 0.20±0.15 0.25±0.15 0.30±0.15 H 1.00±0.10 0.50±0.10 0.40max. 0.10±0.10 0.30±0.10 0.20±0.10 0.50±0.10 0.125±0.10 -  ELECTRICAL SPECIFICATION ISM Band 2.4GHz/5GHz APPLICATION Part Number Frequency (MHz) Impedance Insertion Loss (Ω) (dB) 2400~2500 50 0.5(25℃) 0.6(-40~+85℃) 25(4800~6000MHz) 25(7200~7500MHz) 4900~5900 50 0.8(25℃) 1.3(-40~+85℃) 27(30~2400MHz) 30(2400~2500MHz) 24(2500~2690MHz) 20(9800~11900MHz) 2400~2500 50 0.6 20(4800~5000MHz) 20(7200~7500MHz) RFDIP1004L10AT RFDIP1608060LCT 4900~5900 50 1.4 28(30~2700MHz) 10(9800~11900MHz) 2400~2500 50 0.6 18(4800~5000MHz) 18(7200~7500MHz) 4900~5900 50 1.4 20(3700~3900MHz) 20(1800~2500MHz) 10(9800~11800MHz)) 2400~2500 50 0.6 18(4800~5000MHz) 18(7200~7500MHz) 4900~5900 50 1.4 20(3700~3900MHz) 20(1800~2500MHz) 10(9800~11800MHz) 0.5 10(3600~3750MHz) 20(4800~5000MHz) 20(5000~5950MHz) 10(7200~7500MHz) 10(9600~10000MHz) RFDIP1608060LET RFDIP1608060LFT 2400~2500 50 RFDIP160806BLM6T25 4900~5950 50 0.6 2400~2500 50 0.5 25(860~960MHz) 25(1545~1605MHz) 25(1710~1990MHz) 30(2170 MHz) 10(8100~8800MHz) 15(8820~9800MHz) 25(9800~11900MHz) 10(3600~3750MHz) 20(4800~5000MHz) 20(5000~5950MHz) 10(7200~7500MHz) 10(9600~10000MHz) 4900~5950 50 0.6 25(860~960MHz) 25(1545~1605MHz) 25(1710~1990MHz) 30(2170MHz) 10(8100~8800MHz) 15(8820~9800MHz) 25(9800~11900MHz) 2400~2500 50 0.75(25℃) 0.95(-40~+85℃) 20(4800~5000MHz) 20(7200~7500MHz) 4900~5950 50 1.0(25℃) 1.3(-40~+85℃) 20(1800~2500MHz 20(9800~11800MHz RFDIP160806ALM6T30 RFDIP1608060LM0T60 57 Attenuation ( dB ) Return Loss (dB) Min Isolation Size (mm) Structure 10 - 1.00x0.50x0.40 H 10 28(30~2700 MHz) 26(4900~5950 MHz) 1.60x0.80x0.60 A-4 10 - 1.60x0.80x0.60 A-1 10 - 1.60x0.80x0.60 A-2 1.60x0.80x0.60 A-1 1.60x0.80x0.60 A-2 1.60x0.80x0.60 A-2 - 10 25(4800~5000 MHz) - 10 25(4800~5000 MHz) 10 - DIPLEXER ISM Band 2.4/5GHz Application Part Number Frequency (MHz) Impedance (Ω) Insertion Loss (dB) Attenuation (dB) 2400~2500 50 0.50(25℃) 0.65(-40~+85℃) 21(4800~5000MHz) 21(5000~5950MHz) 25(7200~7500MHz) 4900~5950 50 0.60(25℃) 0.75(-40~+85℃) 27(824~2170MHz) 30(2400~2500MHz 20(9800~11900MHz 2400~2500 50 0.6 - RFDIP160806BLM6T68 RFDIP1608060LVT 4900~5950 50 0.8 32(30~2700MHz) 15(9800~11900MHz) 11(14700~17850MHz) 2400~2500 50 0.5(25℃) 0.6(-40~+85℃) 22(4800~5000MHz) 24(7200~7500MHz) 5100~5900 50 1.1(25℃) 1.3(-40~+85℃) 25(1800~2500MHz) 24(3700~3900MHz) 22(9800~11900MHz) 2400~2496 50 0.5 35(4800~5000MHz) 15(7200~7500MHz) RFDIP1608060LST 5150~5950 50 1.0 30(70~2000MHz) 30(2400~2690MHz 12(7250~7800MHz 25(10300~12000MHz) 10(15000~18000MHz) 2400~2500 50 0.55(25℃) 0.60(-40~+85℃) 29(4800~5000MHz) 24(7200~7500MHz) 4900~5950 50 0.70(25℃) 0.80(-40~+85℃) 32(30~2700MHz) 15(9800~11900MHz) 11(14700~17850MHz) 2400~2500 50 0.6 23(4800~5000MHz) 30(7200~7500MHz) 25(2400~2500MHz) 15(3400~3600MHz) 10(3600~3900MHz) 20(6900~7550MHz) 30(10600~11700MHz) 20(15300~16200MHz) RFDIP1608060LY8Q1C RFDIP1606L168M1U RFDIP1606L23T 5150~5850 50 1.5 2400~2500 50 0.5 5150~5850 50 0.6 2400~2500 50 0.75(25℃) 0.95(-40~+85℃) 23(4800~5000MHz) 30(7200~7500MHz) 25(2400~2500MHz) 15(3400~3600MHz) 10(3600~3900MHz) 20(6900~7550MHz) 30(10600~11700MHz) 20(15300~16200MHz) 25(4800~5000MHz) 20(7200~7500MHz) 4900~5950 50 1.10(25℃) 1.30(-40~+85℃) 20(1800~2500MHz) 15(9800~11900MHz) 2400~2500 50 0.35(25℃) 0.45(-40~+85℃) 20(4800~5000MHz) 22(5000~5950MHz) 20(7200~7500MHz) 4900~5850 50 0.50(25℃) 0.60(-40~+85℃) 26(824~2170MHz) 30(2400~2500MHz) 25(9500~11900MHz) 2400~2500 50 0.40(25℃) 0.45(-40~+85℃) 21(4800~5000MHz) 23(5000~5500MHz) 28(5500~5950MHz) 21(7200~7500MHz) 0.50(25℃) 0.60(-40~+85℃) 27(824~2170MHz) 31(2400~2500MHz) 26(9800~11900MHz) 0.5 10(3600~3750MHz) 20(4800~5000MHz) 20(5000~5950MHz) 10(7200~7500MHz) 10(9600~10000MHz) 0.6 25(860~960MHz) 25(1545~1605MHz) 25(1710~1990MHz) 30(2170MHz) 25(2400~2500MHz) 10(8100~8800MHz) 15(8820~9800MHz) 25(9800~11900MHz) RFDIP1606L24T RFDIP1606L29T RFDIP1606L51T RFDIP1606L52T 4900~5850 2400~2500 50 50 RFDIP1606L53T 5150~5850 50 Return Loss (dB) Min Isolation Size (mm) Structure 10 32(2400~2500MHz) 25(4900~6000MHz) 10 A-2 10 32 (30~2700 MHz) 28(4900~5950 MHz) 1.60x0.80x0.60 A-4 10 - 1.60x0.80x0.60 G 12 - 1.60x0.80x0.60 A-3 10 32(30~2700MHz) 28(4900~5950 MHz) 1.60x0.80x0.60 A-3 10 - 1.60x0.80x0.60 A-3 10 - 1.60x0.80x0.60 A-4 10 - 1.60x0.80x0.60 A-2 10 - 1.60x0.80x0.60 B-2 10 - 1.60x0.80x0.60 B-1 10 - 1.60x0.80x0.60 A-3 58 DIPLEXER ISM Band 2.4/5GHz Application Part Number Frequency (MHz) 2400~2500 Impedance (Ω) 50 Insertion Loss (dB) Attenuation (dB) 0.5 10(3600~3750MHz) 20(4800~5000MHz) 20(5000~5950MHz) 10(7200~7500MHz) 10(9600~10000MHz) 25(860~960MHz) 25(1545~1605MHz) 25(1710~1990MHz) 30(2170MHz) 25(2400~2500MHz) 10(8100~8800MHz) 15(8820~9800MHz) 25(9800~11900MHz) RFDIP1606L54T 4900~5950 50 0.6 2400~2500 50 0.90(25℃) 1.05(-40~+85℃) RFDIP1607L898D1T 4900~5950 50 0.80(25℃) 0.95(-40~+85℃) 2400~2500 50 0.48(25℃) 0.58(-40~+85℃) 4900~5950 50 0.68(25℃) 0.78(-40~+85℃) 26(824~2170MHz) 30(2400~2500MHz) 25(9800~11900MHz) 20(15450~17550MHz) 2400~2500 50 0.60(25℃) 0.65(-40~+85℃) 32(4800~4992MHz) 24(7200~7488MHz) 4900~5950 50 0.70(25℃) 0.80(-40~+85℃) 32(30~2700MHz) 15(9800~11900MHz) 11(14700~17850MHz) 2400~2500 50 0.5 10(3600MHz) 20(4800~5000MHz) 20(7200~7500MHz) RFDIP1606L110C8Q1C RFDIP1608060LS3T55 KFDIP2004L157B1U 4900~5950 50 1.0 2400~2500 50 0.5 20(824~915MHz) 20(1800~2500MHz) 10(3000~3900MHz) 4(7250MHz) 20(9800~11900MHz) 20(14700~17850MHz) 10(3600MHz) 20(4800~5000MHz) 20(7200~7500MHz) 4900~5950 50 1.0 20(824~915MHz) 20(1800~2500MHz) 10(3000~3900MHz) 4(7250MHz) 20(9800~11900MHz) 20(14700~17850MHz) 2400~2500 50 0.6 15(3600MHz) 25(4800~5000MHz) 20(7200~7500MHz) KFDIP2004L167B1U 4900~5950 50 1.0 20(824~915MHz) 18(1800~2500MHz) 14(3000~3900MHz) 20(9800~11900MHz) 20(14700~17850MHz) 2400~2500 50 0.7 18(4800~6000MHz) 18(7200~7500 MHz) 4900~5900 50 1.0 19(1800~2500MHz) 25(10300~10700MHz) 2400~2500 50 0.7 18(4800~6000MHz) 18(7200~7500MHz) 4900~5900 50 1.0 19(1800~2500MHz) 25(10300~10700MHz) 2300~2500 50 0.65(25℃) 0.8(-40~+85℃) 20(4600~5000MHz) 20(6900~7500MHz) 4900~5950 50 1.0 19(1800~2500MHz) 25(10300~10700MHz) KFDIP2004L197B1U RFDIP2012050L5T RFDIP2012050L7T RFDIP2012050L8T 59 15(700~1300MHz) 25(4800~5000MHz) 30(7000~7500MHz) 27(1200~1500MHz) 26(1500~2000MHz) 20(2300~3000MHz) 25(9800~11900MHz) 15(14700~17850MHz) 20(4800~5000MHz) 22(5000~5950MHz) 20(7200~7500MHz) Return Loss (dB)Min Isolation Size (mm) Structure 10 - 1.60x0.80x0.60 A-4 10 30(2400~2500MHz) 25(4900~5950MHz) 1.60x0.80x0.70 A-4 10 - 1.60x0.80x0.60 A-3 10 32(30~2700MHz) 28(4900~5950MHz) 1.60x0.80x0.60 A-4 10 20(DC~2500MHz) 20(4900~5950MHz) 2.00x1.25x0.40 A-3 10 20(DC~2500MHz) 20(4900~5950MHz) 2.00x1.25x0.40 A-4 10 20(DC~2500MHz) 20(4900~5950MHz) 2.00x1.25x0.40 A-3 10 - 2.00x1.25x0.55 A-1 10 - 2.00x1.25x0.55 A-2 10 - 2.00x1.25x0.55 A-3 DIPLEXER ISM Band 2.4/5GHz Application Part Number RFDIP2012100L0T RFDIP2012100L3T Frequency (MHz) Impedance (Ω) Insertion Loss (dB) Attenuation (dB) Return Loss (dB) Min Isolation Size (mm) Structure 2400~2500 50 0.7 20(4900MHz) 25(5200MHz) 25(5800MHz) 10 - 2.00x1.25x0.95 A-3 4900~5900 50 0.9 25(2450MHz) 2400~2500 50 0.7 20(4900MHz) 25(5200MHz) 25(5800MHz) 10 - 2.00x1.25x0.95 A-2 4900~5900 50 0.9 25(2450MHz) 2400~2500 50 0.5(25℃) 0.55(-40~+85℃) 23(4800~6000MHz) 20(7200~7500MHz) 20(800~2500MHz) 15(9800~11900MHz) - 2.00x1.25x055 A-1 50 0.65(25℃) 0.75(-40~+85℃) 10 4900~5950 2400~2500 50 0.5(25℃) 0.55(-40~+85℃) 23(4800~6000MHz) 20(7200~7500MHz) 20(800~2500MHz) 15(9800~11900MHz) - 2.00x1.25x0.55 A-2 50 0.65(25℃) 0.75(-40~+85℃) 10 4900~5950 2.2(25℃) 2.4(-40~+85℃) 30(824~915MHz) 30(1545~1610MHz) 30(1710~1990MHz) 25(2110~2170MHz) 8(3200~3600MHz) 12(3700~3900MHz) 28(4800~5000MHz) 25(7200~7500MHz) 10 - 2.00x1.25x0.80 A-1 1.2(25℃) 1.5(-40~+85℃) 20(1545~1610MHz) 20(1710~1990MHz) 20(2110~2170MHz) 23(2400~2500MHz) 8(3450~3900MHz) 8(7250~7800MHz) 20(9800~11700MHz) 2.2(25℃) 2.4(-40~+85℃) 30(824~915MHz) 30(1545~1610MHz) 30(1710~1990MHz) 25(2110~2170MHz) 8(3200~3600MHz) 12(3700~3900MHz) 28(4800~5000MHz) 25(7200~7500MHz) 10 - 2.00x1.25x0.80 A-2 1.2(25℃) 1.5(-40~+85℃) 20(1545~1610MHz) 20(1710~1990MHz) 20(2110~2170MHz) 23(2400~2500MHz) 8(3450~3900MHz) 8(7250~7800MHz) 20(9800~11700MHz) 2.4(25℃) 2.7(-40~+85℃) 30(824~915MHz) 30(1545~1610MHz) 24(1710~1990MHz) 15(2110~2170MHz) 30(4800~5000MHz) 20(7200~7500MHz) 2.50x2.00x0.70 E-1 2.00x1.25x0.80 E-2 RFDIP2012050LPT RFDIP2012050LQT 2400~2500 50 RFDIP2008L107N3T 5150~5850 2400~2500 50 50 RFDIP2008L117N3T 5150~5850 2400~2500 50 50 AMDIP2520070L3T 5150~5850 2400~2500 50 50 1.2(25℃) 1.5(-40~+85℃) 25(1545~1610MHz) 25(2400~2500MHz) 15(10300~11700MHz) 2.4(25℃) 2.7(-40~+85℃) 30(824~915MHz) 30(1545~1610MHz) 24(1710~1990MHz) 15(2110~2170MHz) 30(4800~5000MHz) 20(7200~7500MHz) AMDIP2520070L4T 5150~5850 50 1.2(25℃) 1.5(-40~+85℃) - 10 - 10 25(1545~1610MHz) 25(2400~2500MHz) 15(10300~11700MHz) 60 DIPLEXER GPS 1.575GHz/ISM 2.4GHz/5GHz Band Application Part Number RFDIP1608060T1T RFDIP1608060TM7T62 RFDIP1608060TAT RFDIP1608060TCT RFDIP1608060TDT RFDIP2012090T2T RFDIP2520080T1T Frequency (MHz) Impedance (Ω) Insertion Loss (dB) Attenuation (dB) 1574~1577 50 0.65 20(2400~2500MHz) 2400~2500 50 0.8 20(1574~1577MHz) 1570~1610 50 0.6(typ.0.5) 20(2400~2500MHz) 20(4900~5900MHz) 2400~2500 4900~5900 50 0.65(typ.0.55) 20(1570~1610MHz) 698~960 1427~1511 1560~1607 50 0.40 0.55 0.65 20(2400~2500MHz) 20(2620~2690MHz) 20(5150~5850MHz) 2400~2500 2620~2690 5150~5850 50 0.70 0.60 0.80 20(698~960MHz) 20(1427~1511MHz) 20(1560~1607MHz) 1570~1610 50 0.6(typ.0.5) 20(2400~2500MHz) 20(4900~5900MHz) 2400~2500 4900~5900 50 0.65(typ.0.55) 20(1570~1610MHz) 1570~1610 50 0.65(25℃) 0.75(-40~+85℃) 13(2170MHz) 20(2400~2500MHz) 2400~2500 50 0.80(25℃) 0.90(-40~+85℃) 20(1565~1616MHz) 15(1710MHz) 1572.5~1578.5 1597~1607 50 0.40 0.50 13(2400~2500MHz) 2400~2500 50 0.55(25℃) 0.65(-40~+85℃) 22(1572.5~1578.5MHz) 20(1597~1607MHz) 1710~1990 1990~2110 2110~2170 50 1.00 1.50 2.50 5(2300~2350MHz) 10(2350~2500MHz) 10(2500~2690MHz) 50 2.65 1.50 0.65 8(1710~1990MHz) 8(1990~2110MHz) 5(2110~2170MHz) 2300~2350 2350~2500 2500~2690 Return Loss (dB)Min. Size (mm) Structure 10 1.60x0.80x0.60 B-1 10 1.60x0.80x0.60 A-4 10 1.60x0.80x0.60 B-1 10 1.60x0.80x0.60 A-4 10 1.60x0.80x0.60 B-2 10 2.00x1.25x0.90 A-3 10 2.50x2.00x0.80 C-2 Return Loss (dB)Min. Size (mm) Structure 10 1.60x0.80x0.60 D-2 10 2.00x1.25x0.70 C-1 10 2.00x1.25x0.90 A-4 10 2.00x1.25x0.90 C-1 10 2.50x2.00x1.00 F 892 MHz & 1.94GHz Band Working Frequency Part Number Frequency (MHz) Impedance (Ω) Insertion Loss (dB) Attenuation (dB) 0.8(typ.0.45) 25(1710~2700MHz) 0.7(typ.0.50) 20(698~960MHz) 20(5150~5850MHz) 0.75 20(1427~2700MHz) 0.85 20(570~960MHz) 0.65 15(1554~1580MHz) 20(1710~2700MHz) 1710~2700 0.65 20(824~960MHz) 698~960 0.4(25℃) 0.45(-40~+85℃ 13(1710~2690MHz) 1710~2690 0.55(25℃) 0.65(-40~+85℃ 19(698~960MHz) 698~960 0.35(25℃) 0.45(-40~+85℃ 20(1710~2690MHz) 0.55(25℃) 0.65(-40~+85℃ 25(698~960MHz) 5(3420~3820MHz) 698~960 RFDIP1608070GM1T76 RFDIP2012070G5T RFDIP2012090G77N2T 1710~2700 570~960 1427~2700 698~960 RFDIP2012090GM1T58 50 50 50 RFDIP2520100G2T 50 1710~2690 61 50 DIPLEXER  TYPICAL ELECTRICAL CHARACTERISTICS RFDIP1004L10T RFDIP1608060LCT RFDIP1608060LET RFDIP1608060LFT RFDIP160806BLM6T25 RFDIP160806ALM6T30 RFDIP1608060LM0T60 RFDIP160806BLM6T68 RFDIP1608060LVT RFDIP1608060LST 62 DIPLEXER TYPICAL ELECTRICAL CHARACTERISTICS RFDIP1608060LY8Q1C RFDIP1606L168M1U RFDIP1606L23T RFDIP1606L24T RFDIP1606L29T RFDIP1606L51T RFDIP1606L52T RFDIP1606L53T RFDIP1606L54T RFDIP1607L898D1T -5 -15 -35 63 DIPLEXER TYPICAL ELECTRICAL CHARACTERISTICS RFDIP1606L110C8Q1C RFDIP1608060LS3T55 KFDIP2004L157B1U KFDIP2004L167B1U KFDIP2004L197B1U RFDIP2012050L5T RFDIP2012050L7T RFDIP2012050L8T RFDIP2012050LPT RFDIP2012050LQT 64 DIPLEXER TYPICAL ELECTRICAL CHARACTERISTICS RFDIP2008L107N3T RFDIP2008L117N3T AMDIP2520070L3T AMDIP2520070L4T RFDIP1608060T1T RFDIP1608060TM7T62 0 0 S-parameter (dB) S-parameter (dB) -20 dB(S(2,1)) dB(S(1,1)) dB(S(3,1)) -30 -40 0.5 dB(S(2,1)) dB(S(1,1)) dB(S(3,1)) -10 -10 1.5 2.5 3.5 Frequency (GHz) 4.5 5.5 -20 -30 -40 6.5 -50 0.5 1.5 RFDIP1608060TAT 5.5 6.5 -10 S-parameter (dB) S-parameter (dB) 4.5 0 -10 -20 -30 dB(S(2,1)) dB(S(1,1)) dB(S(3,1)) -40 1.5 2.5 3.5 Frequency (GHz) 4.5 RFDIP1608060TDT 65 3.5 Frequency (GHz) RFDIP1608060TCT 0 -50 0.5 2.5 -20 -30 -40 dB(S(2,1)) dB(S(1,1)) dB(S(3,1)) -50 5.5 6.5 -60 0.5 1.5 2.5 3.5 Frequency (GHz) 4.5 RFDIP2012090T2T 5.5 6.5 DIPLEXER TYPICAL ELECTRICAL CHARACTERISTICS RFDIP2520080T1T RFDIP1608070GM1T76 RFDIP2012070G5T RFDIP2012090G77N2T RFDIP2012090GM1T58 RFDIP2520100G2T 0 -10 -20 -30 dB(S(2,1)) dB(S(1,1)) dB(S(3,1)) -40 -50 0.5   1 1.5 2 2.5 Frequency (GHz) 3 3.5 4 For more information, please contact with local sales representative All specifications are subject to change without notice 66 TRIPLEXER TRIPLEXER  STRUCTURE AND PIN ASSOCIATED STRUCTURE A STRUCTURE A-1 STRUCTURE A-2 STRUCTURE A-3 STRUCTURE B  STRUCTURE AND DIMENSION Unit: mm Structure\ Dimension L W T A B C D E F G A 2.00±0.15 1.25±0.15 0.90±0.10 0.20±0.20 0.30±0.20 0.35±0.20 0.65±0.20 0.20±0.20 0.20±0.20 0.30±0.20 B 2.50±0.15 2.00±0.15 0.90±0.10 0.30±0.10 0.40±0.10 0.55±0.10 0.40±0.10 0.90±0.10 0.30±0.10 0.30±0.10  ELECTRICAL SPECIFICATION GPS 1.575GHz/ISM 2.4GHz/5GHz band RF application Part Number Frequency (MHz) Impedance (Ω) Insertion Loss (dB) Attenuation ( dB ) Return Loss (dB) Min Isolation 1560~1606 50 0.6 15(2400~2500 MHz) 15(4800~6000 MHz) 10 - 0.7 10(860~960 MHz) 15(1545~1605 MHz) 10(3600~3750 MHz) 20(4800~6000 MHz) 10(7200~7500 MHz) 10(9600~10000 MHz) 10 20(1559~1606 MHz) 25(4800~5000 MHz) 25(860~960 MHz) 25(1545~1605 MHz) 25(1710~1990 MHz) 30(2170 MHz) 10(8100~8800 MHz) 15(8820~9800 MHz) 25(9800~11900 MHz) 10 2400~2500 50 RFTIP2012090T18Q1C 4900~5950 67 50 0.8 20(1559~1606 MHz) Size (mm) Structure 2.00x1.25x0.90 A-1 TRIPLEXER  ELECTRICAL SPECIFICATION GPS 1.575GHz/ ISM 2.4GHz/5GHz band RF application Part Number Frequency (MHz) Impedance (Ω) Insertion Loss (dB) Attenuation ( dB ) Return Loss (dB) Min Isolation 1560~1606 50 0.65(25℃) 0.70(-40~+85℃) 20(2400~2500 MHz) 20(4900~6000 MHz) 10 - 0.70(25℃) 0.85(-40~+85℃) 10(860~960 MHz) 15(1545~1610 MHz) 10(3600~3750 MHz) 20(4800~6000 MHz) 10(7200~7500 MHz) 10(9600~10000 MHz) 10 20(1559~1606 MHz) 20(4800~5000 MHz) 10 2400~2500 50 RFTIP2012090T27N3T 4900~5950 50 0.80(25℃) 0.95(-40~+85℃) 25(1559~1606 MHz) 35(2400~2500 MHz) 12(3400~3600 MHz) 12(3600~3900 MHz) 10(6900~7200 MHz) 10(7200~7800 MHz) 25(10300~11700 MHz) 15(15300~16200 MHz) 1560~1606 50 0.7 15(2400~2500 MHz) 15(4800~6000 MHz) 10 0.8 10(860~960 MHz) 15(1545~1605 MHz) 8(3600~3750 MHz) 20(4800~5000 MHz) 10(7200~7500 MHz) 10(9600~10000 MHz) 10 10 2400~2500 50 RFTIP2012090T9T 4900~5950 50 0.9 25(860~960 MHz) 25(1545~1605 MHz) 25(1710~1990 MHz) 30(2170 MHz) 38(2400~2500 MHz) 8(8100~8800 MHz) 15(8820~9800 MHz) 22(9800~11900 MHz) 1560~1606 50 0.70(25℃) 0.80(-40~+85℃) 14(2400~2500 MHz) 15(4800~6000 MHz) 10 0.80(25℃) 0.95(-40~+85℃) 10(860~960 MHz) 10(1545~1605 MHz) 8(3600~3750 MHz) 20(4800~5000 MHz) 10(7200~7500 MHz) 5(9600~10000 MHz)) 10 10 2400~2500 50 RFTIP2012090TLT Size (mm) Structure 2.00x1.25x0.90 A-2 - 2.00x1.25x0.90 A-3 - 2.00x1.25x0.90 A-1 2.00x1.25x0.90 A-1 20(1559~1606 MHz) 4900~5950 50 0.90(25℃) 1.10(-40~+85℃) 24(860~960 MHz) 24(1545~1605 MHz) 25(1710~1990 MHz) 25(2170 MHz) 0.2(3920~4720 MHz) 10(8100~8800 MHz) 14(8820~9800 MHz) 20(9800~11900 MHz) 1560~1606 50 0.60(25℃) 0.80(-40~+85℃) 15(2400~2500 MHz) 15(4800~6000 MHz) 10 - 0.70(25℃) 0.90(-40~+85℃) 10(860~960 MHz) 15(1545~1605 MHz) 10(3600~3750 MHz) 20(4800~5000 MHz) 10(7200~7500 MHz) 10(9600~10000 MHz) 10 20(1559~1606 MHz) 25(4800~5000 MHz) 25(860~960 MHz) 25(1545~1605 MHz) 25(1710~1990 MHz) 30(2170 MHz) 10(8100~8800 MHz) 15(8820~9800 MHz) 25(9800~11900 MHz) 10 2400~2500 50 RFTIP2109ATM0T63 4900~5950 50 0.80(25℃) 1.00(-40~+85℃) 25(1559~1606 MHz) 68 TRIPLEXER GPS 1.575GHz/ ISM 2.4GHz/5GHz band RF application Part Number Frequency (MHz) Impedance (Ω) Insertion Loss (dB) Attenuation ( dB ) Return Loss (dB )Min Isolation 1560~1606 50 0.60(25℃) 0.80(-40~+85℃) 15(2400~2500 MHz) 15(4800~6000 MHz) 10 - 0.70(25℃) 0.90(-40~+85℃) 10(860~960 MHz) 15(1545~1605 MHz) 10(3600~3750 MHz) 20(4800~5000 MHz) 10(7200~7500 MHz) 10(9600~10000 MHz) 10 20(1559~1606 MHz) 25(4800~5000 MHz) 10 25(1559~1606 MHz) 2400~2500 50 RFTIP2109BTM5T62 RFTIP2520090T3T 4900~5950 50 0.80(25℃) 1.00(-40~+85℃) 25(860~960 MHz) 25(1545~1605 MHz) 25(1710~1990 MHz) 30(2170 MHz) 10(8100~8800 MHz) 15(8820~9800 MHz) 25(9800~11900 MHz) 698~960 50 0.70(25℃) 0.80(-40~+85℃) 20(1710~2200 MHz) 20(2500~2690 MHz) 10 20(1710~2200 MHz) 20(2500~2690 MHz) 1710~2200 50 1.40(25℃) 1.60(-40~+85℃) 20(698~960 MHz) 15(2500~2690 MHz) 10 18(698~960 MHz) 18(2500~2690 MHz) 2500~2690 50 1.80(25℃) 2.00(-40~+85℃) 15(698~960 MHz) 15(1710~2200 MHz) 10 20(698~960 MHz) 20(1710~2200 MHz) Size (mm) Structure 2.00x1.25x0.90 A-2 2.50x2.00x0.90 C  TYPICAL ELECTRICAL CHARACTERISTICS RFTIP2012090T18Q1C Low band Middle band High band RFTIP2012090T27N3T Low band Middle band High band RFTIP2012090T9T Low band 69 Middle band High band TRIPLEXER TYPICAL ELECTRICAL CHARACTERISTICS RFTIP2012090TLT Low band Middle band High band RFTIP2109ATM0T63 Low band Middle band High band RFTIP2109BTM5T62 Low band Middle band High band RFTIP2520090T3T Low band   Middle band High band For more information, please contact with local sales representative All specifications are subject to change without notice 70 COMMON MODE FILTER COMMON MODE FILTER  STRUCTURE AND PIN ASSOCIATED STRUCTURE A  STRUCTURE AND DIMENSION Unit: mm Structure\ Dimension A L W T a b c 1.20+0.40 -0.20 2.00+0.40 -0.20 1.00±0.20 0.45±0.20 0.40±0.20 0.80±0.10 1.60±0.20 3.20±0.20 0.95±0.20 0.60±0.20 0.50±0.20 1.10±0.20 1.00±0.20 0.60±0.20 0.50±0.20 1.10±0.20  ELECTRICAL SPECIFICATION DISCRETE CMF for HIGH SPEED TRANSMISSION LINES Part Number Characteristic Impedance (Differential) RFCMF1220100M3T RFCMF1220100M4T USB2.0 IEEE1394 LVDS(mini) Common Mode Attenuation (Min. ) DC Resistance (Ω) max. Rated Current (mA) Size(mm) Structure 90 ohm 9.0(240MHz ~ 1GHz) 1.5 300 1.20x2.00x1.00 A 90 ohm 9.0(130 MHz ~ 1GHz) 2.5 200 1.20x2.00x1.00 A RFCMF1632090M1T 90 ohm 9.0(140 MHz ~ 1.0 GHz) 1.5 300 1.60x3.20x0.95 A RFCMF1632100M3T 90 ohm 9.0(240 MHz ~ 1.0 GHz) 1.5 300 1.60x3.20x1.00 A  TYPICAL ELECTRICAL CHARACTERISTICS RFCMF1220100M3T RFCMF1220100M4T TYPICAL ELECTRICAL CHARACTERISTICS Impedance vs Frequency Characteristic: 0 -10 -10 -20 -20 dB dB 0 -30 -30 -40 -40 Common Mode Attenuation Differential Mode Loss -50 0 0.24 0.48 Fre uenc 0.72 GHz 0.96 1. -50 0 0.24 0.48 Fre uenc 0.72 GHz 0.96 RFCMF1632090M1T RFCMF1632100M3T TYPICAL ELECTRICAL CHARACTERISTICS TYPICAL ELECTRICAL CHARACTERISTICS  For more information, please contact with local sales representative  All specifications are subject to change without notice 71 Common Mode Attenuation Differential Mode Loss 1. COUPLER COUPLER  STRUCTURE AND PIN ASSOCIATED STRUCTURE A STRUCTURE A-1 STRUCTURE A-2 STRUCTURE B STRUCTURE A-3 STRUCTURE C  STRUCTURE AND DIMENSION Unit: mm Structure\ Dimension A L W T A B C D E F 1.60±0.10 0.80±0.10 0.60±0.10 0.10±0.10 0.30±0.10 0.25±0.10 0.55±0.10 0.20±0.10 - 1.60±0.10 0.80±0.10 0.60±0.10 0.175±0.10 0.25±0.10 0.25±0.10 0.50±0.10 0.20±0.10 - B 0.65±0.04 0.50±0.04 0.35±0.10 0.20±0.04 0.20±0.04 0.025±0.025 0.10±0.04 0.25±0.04 0.025±0.025 C 0.65±0.10 0.50±0.10 0.35±0.05 0.225±0.10 0.20±0.05 0.10±0.05 0.25±0.05 0.025±0.025 -  ELECTRICAL SPECIFICATION ISM Band 2.4GHz Application Part Number Frequency (MHz) Insertion Loss (dB) Coupling in BW Directivity in BW dB (min.) Isolation in BW dB (min.) VSWR Dimension ( mm³) Structure RFCPL1806B2450T 2400~2500 1.83 6.5 ± 1.0 dB - 21.0 dB min 1.5 1.60x1.80x0.60 A-1 RFCPL1810B2450T 2400~2500 0.74 10.0 ±1.0 dB - 22.0 dB min 1.8 1.60x1.80x0.60 A-1 TFCPL0605B24508Q1C 2400~2500 0.32(25℃) 0.40(-40~+85℃) 14.6 ± 1.0 dB 20.0 dB min. - 1.3 0.60x0.50x0.35 B Dimension ( mm³) Structure 0.65x0.50x0.35 B 0.65x0.50x0.35 B 0.65x0.50x0.35 C ISM Band 2.4/5GHz Application Part Number TFCPL0605030L18A1U TFCPL0605030L28Q1C RFCPL0605030L58Q1C Frequency (MHz) Insertion Loss (dB) Coupling in BW Directivity in BW dB (min.) Isolation in BW dB (min.) VSWR 2400~2500 0.5 19.0±1.5dB 15 dB min. - 1.3 4900~5850 0.5 12.5±1.5dB 15 dB min. - 1.3 2400~2500 0.2 19.3±0.7dB 15 dB min. - 1.3 5150~5850 0.5 13.0±1.5dB 15 dB min. - 1.3 2400~2500 0.3 19.0±1.5dB 14.5 dB min. - 1.3 4900~5850 0.6 13.0±2.0dB 13.5dB min. - 1.8 72 COUPLER ISM Band 2.4/5GHz Application Part Number Frequency (MHz) Insertion Loss (dB) Coupling in BW Directivity in BW dB (min.) Isolation in BW dB (min.) VSWR 2400~2500 0.40(25℃) 0.45(-40~+85℃) 21.5±1.5dB 15 dB min. - 1.3 4900~5850 0.40(25℃) 0.45(-40~+85℃) 15.0±1.5dB 15 dB min. - 1.3 2400~2500 0.20(25℃) 0.25(-40~+85℃) 19.3±0.7dB 15 dB min. - 1.3 4900~5850 0.50(25℃) 0.55(-40~+85℃) 13.0±1.5dB 15 dB min. - 1.3 2400~2500 0.22(25℃) 0.24(-40~+85℃) 21.5±1.0dB 14 dB min. - 1.3 4900~5850 0.32(25℃) 0.35(-40~+85℃) 15.0±1.2dB 14 dB min. - 1.3 2400~2500 0.40(25℃) 0.45(-40~+85℃) 21.5±1.5dB 15 dB min. - 1.3 4900~5850 0.40(25℃) 0.45(-40~+85℃) 15.0±1.5dB 15 dB min. - 1.3 RFCPL0605030L6T RFCPL0605030L9T RFCPL0605030LFT RFCPL0605030LHT Dimension ( mm³) Structure 0.65x0.50x0.35 C 0.65x0.50x0.35 C 0.65x0.50x0.35 C 0.65x0.50x0.35 C LTE BAND APPLICATION Part Number Frequency (MHz) Insertion Loss (dB) Coupling in BW Directivity in BW dB (min.) Isolation in BW dB (min.) VSWR Dimension ( mm³) Structure RFCPL1608070P08Q1C 698~2690 0.20(698~960MHz) 0.22(1427.9~2170MHz) 0.25(2300~2690MHz) 23.0~27.0(698~915MHz) 21.5~26.5(1427.9~2025MHz) 22.5~27.5(2300~2620MHz) 20. - 1.5 1.60x1.80x0.60 A-2 RFCPL1608070P28Q1C 698~2690 0.20(698~960MHz) 0.22(1427.9~2170MHz) 0.25(2300~2690MHz) 23.0~27.0(698~915MHz) 21.5~26.5(1427.9~2025MHz) 22.5~27.5(2300~2620MHz) 20 - 1.5 1.60x1.80x0.60 A-2 RFCPL1608070P38Q1C 698~2690 0.20(698~960MHz) 0.22(1710~2170MHz) 0.25(2300~2690MHz) 23.0~27.0(698~915MHz) 21.5~26.5(1710~2025MHz) 22.5~27.5(2300~2620MHz) 20 - 1.45 1.60x1.80x0.60 A-3 700~2700 0.2(700~790MHz) (Typ.0.07) 0.2(820~900MHz) (Typ.0.07) 0.3(1701~2100MHz) (Typ.0.15) 0.3(2300~2700MHz) (Typ.0.15) 24~27(700~790MHz) 24~27(820~900MHz) 20~23(1701~2100MHz) 20~23(2300~2700MHz) - 40(700~790MHz) 40(820~900MHz) 35(1701~2100MHz ) 35(2300~2700MHz ) 1.45 1.60x1.80x0.60 A-1 RFCPL1608070PM9T16  TYPICAL ELECTRICAL CHARACTERISTICS RFCPL1806B2450T RFCPL1810B2450T 73 COUPLER TYPICAL ELECTRICAL CHARACTERISTICS TFCPL0605B24508Q1C FCPL0605030L28Q1C TFCPL0605030L28Q1C RFCPL0605030L58Q1C RFCPL0605030L6T 74 COUPLER TYPICAL ELECTRICAL CHARACTERISTICS RFCPL0605030L9T RFCPL0605030LFT RFCPL0605030LHT RFCPL1608070P08Q1C RFCPL1608070P28Q1C 75 COUPLER TYPICAL ELECTRICAL CHARACTERISTICS RFCPL1608070P38Q1C RFCPL1608070PHT RFCPL1608070PKT RFCPL1608070PM9T16   For more information, please contact with local sales representative All specifications are subject to change without notice 76 SAW Filter SAW Filter  STRUCTURE AND PIN ASSOCIATED STRUCTURE A STRUCTURE B STRUCTURE B-2 STRUCTURE B-1 STRUCTURE C STRUCTURE C-1 STRUCTURE C-2  STRUCTURE AND DIMENSION Unit: mm Structure\ Dimension A 77 L W T A B C D E F G H I 1.10±0.10 0.90±0.10 0.50max. 0.40 0.40 0.25 0.20 0.05 0.075 0.25 - - 1.40±0.13 1.10±0.13 0.65max. 0.50 0.50 0.325 0.25 0.075 0.10 0.25 - - B 1.80±0.10 1.40±0.10 0.65max. 0.65 0.30 0.50 0.25 0.35 0.25 - - - C 1.50±0.10 1.10±0.10 0.60max. 0.18 0.18 0.39 0.49 0.075 0.21 0.07 0.21 0.15 SAW Filter  ELECTRICAL SPECIFICATION Application GPS/Wifi FDD LTE FDD LTE TDD LTE TDD LTE TDD LTE Type Part Number Band Frequency(MHz) Package (mm) STRUCTURE GPS SAW 3 Mode SF11091582GC2T GPS+G+C 1559.05~1605.89 1.1 x 0.9 A GPS SAW 3 Mode SF14111582GC01T GPS+G+C 1559.05~1605.66 1.4 x 1.1 A SAW SF11092450A04T WLAN 2400~2500 1.1 x 0.9 A SAW SF14112450A03T WLAN 2400~2500 1.4 x 1.1 A SAW SF14112442A01T WLAN 2400~2484 1.4 x 1.1 A SAW SF14112442A03T WLAN 2401~2483 1.4 x 1.1 A SAW Duplexer DF18141950B104T B1 1920~1980/2110~2170 1.8 x 1.4 B-1 SAW Duplexer DF18140836B511T B5 824~849/869~894 1.8 x 1.4 B-1 SAW Duplexer DF18141880B203T B2 1850.48~1909.52/1930.48~1989.52 1.8 x 1.4 B-1 SAW Duplexer DF18141747B303T B3 1712.5~1782.5/1807.5~1877.5 1.8 x 1.4 B-1 SAW Duplexer DF18142535B705T B7 2500~2570/2620~2690 1.8 x 1.4 B-1 SAW Duplexer DB18142140B102T B1 1920~1980/2110~2170 1.8 x 1.4 B-2 SAW Duplexer DB18140881B507T B5 824~849/869~894 1.8 x 1.4 B-2 SAW Duplexer DB18140942B801T B8 880~915/925~960 1.8 x 1.4 B-2 RX SAW SF11092140B102T B1 2110~2170 1.1 x 0.9 A RX SAW SF11091960B201T B2 1930~1990 1.1 x 0.9 A RX SAW SF11091842B305T B3 1805~1880 1.1 x 0.9 A RX SAW SF11090881B506T B5 869~894 1.1 x 0.9 A RX SAW SF11092655B702T B7 2620~2690 1.1 x 0.9 A RX SAW SF11090942B805T B8 925~960 1.1 x 0.9 A Rx Dual SAW BF1511B394101AT B39/B41 1880~1920/2550~2655 1.5 x 1.1 C-2 Rx Dual SAW BF1511B394101BT B39/B41 1880~1920/2550~2655 1.5 x 1.1 C-1 TRx SAW SF14112595B3803T B38 2570~2620 1.4 x 1.1 A TRx SAW SF14112350B4001T B40 2300~2400 1.4 x 1.1 A TRx SAW SF14112605B41S4T B41 2550~2655 1.4 x 1.1 A TRx SAW SF14112593B4102T B41 2496~2690 1.4 x 1.1 A TRx SAW SF14112017B3402T B34 2010~2025 1.4 x 1.1 A TRx SAW SF14111900B3906T B39 1880~1920 1.4 x 1.1 A TRx SAW SF11092595B3804T B38 2570~2620 1.1 x 0.9 A TRx SAW SF11092350B4004T B40 2300~2400 1.1 x 0.9 A TRx SAW SF11092595B4108T B41 2535~2655 1.1 x 0.9 A TRx SAW SF11092017B3403T B34 2010~2025 1.1 x 0.9 A TRx SAW SF11091900B3907T B39 1880~1920 1.1 x 0.9 A Rx SAW SF11092595B3805T B38 2570~2620 1.1 x 0.9 A Rx SAW SF11092350B4005T B40 2300~2400 1.1 x 0.9 A Rx SAW SF11092602B41W9T B41 2550~2655 1.1 x 0.9 A  TYPICAL ELECTRICAL CHARACTERISTICS SF11091582GC2T 78 SAW Filter TYPICAL ELECTRICAL CHARACTERISTICS SF14111582GC01T SF11092450A04T SF14112450A03T SF14112442A01T SF14112442A03T 79 SAW Filter TYPICAL ELECTRICAL CHARACTERISTICS DF18141950B104T DF18140836B511T DF18141880B203T DF18141747B303T DF18142535B705T 80 SAW Filter TYPICAL ELECTRICAL CHARACTERISTICS DB18142140B102T DB18140881B507T DB18140942B801T SF11092140B102T SF11091960B201T 81 SAW Filter TYPICAL ELECTRICAL CHARACTERISTICS SF11091842B305T SF11090881B506T SF11092655B702T SF11090942B805T SF14112595B3803T 82 SAW Filter TYPICAL ELECTRICAL CHARACTERISTICS SF14112350B4001T SF14112605B41S4T SF14112593B4102T SF14112017B3402T SF14111900B3906T 83 SAW Filter TYPICAL ELECTRICAL CHARACTERISTICS SF11092595B3804T SF11092350B4004T SF11092595B4108T SF11092017B3403T SF11091900B3907T 84 SAW Filter TYPICAL ELECTRICAL CHARACTERISTICS SF11092595B3805T SF11092350B4005T SF11092602B41W9T   85 For more information, please contact with local sales representative All specifications are subject to change without notice ANTENNA SWITCH ANTENNA SWITCH  Application Circuit (GPIO) RFASWA630PTF06 RFASWA697ATF09 RFASWAM3489ATF09 SPDT SPDT SPDT RFC 1 C1 5 C1 RF1 1 5 C RF 3 RF1 RFC 3 C RF RFASWMT2628PTF09 RFASWMT2628BTF09 RFASWMH6373ATF09 SP3T SP3T SP3T RFC C C1 C3 C1 C 1 11 7 RF3 RF1 1 RF3 3 RF 7 5 RF1 3 RF 5 1 C3 C C1 RFASWKH4414PTF06 RFASWK626ATF09 RFASWHH1416PTF06 SP4T SP4T SP6T C C1 N/C C3 N/C 13 N/C 1 11 RF3 2 10 RF1 3 1 N/C 7 N/C N/C 13 RF5 1 11 RF RF3 2 10 RF RF1 3 N/C 5 C C1 C 3 7 5 N/C 5 C 7 C1 C C C3 C3 C RF RF C1 C3 RF C3 C1 C C1 RFASWDH2418PTF06 SP8T RF RF7 13 RF5 1 11 RF3 2 10 RF1 3 RF RF RF N/C 5 C 7 C1 C C3 C3 C C1 86 ANTENNA SWITCH ANTENNA SWITCH  Application Circuit (GPIO) RFASWB643ATF09 RFASWB646BTF09 RFASWB438ATF09 DPDT DPDT DPDT RF1 RF3 C1 11 1 10 3 3 12 3 VDD 13 23 C 83 1 11 RF3 VC 2 GND 3 Vc1 3 6 1 3 3 5 C1 RF RF1 73 4 3 C2 Ant 2 1 6 2 5 3 4 Ant 1 RF4 93 5 RX 7 C2 VC 1 TX C1 RF2 RF RFASWB022ATF09 RFASWCM0624ATF09 DPDT DP4T 3_N C 3_P 1 1_N 7 3 1_P 5 C1 _N _P  ELECTRICAL SPECIFICATION Part Number Description RFASWA630PTF06 RFASWA697ATF09 SPDT Frequency (GHz )Max. Insertion loss Isolation (dB) (dB) 0.1 6 0.25~1.1dB 0.4 6 0.35~1.00dB VSWR Package (mm) 14~35 1.20 1.1 x 0.7 15~32 1.50 1.0 x 1.0 RFASWAM3489ATF09 0.7 2.7 0.38~0.50dB 21~33 1.25 1.1 x 0.7 RFASWMT2628PTF09 0.5 2.7 0.30~0.60dB 20~35 1.43 1.0 x 1.0 0.8 2.7 0.30~0.70dB 14~26 1.50 1.0 x 1.0 RFASWMT2628BTF09 SP3T RFASWMH6373ATF09 0.5 6 0.32~0.80dB 15~32 1.40 2.0 x 2.0 RFASWKH4414PTF06 0.1 2.7 0.45~0.65dB 24~38 1.22 2.0 x 2.0 RFASWK626ATF09 SP4T 0.7 2.7 0.30~0.50dB 27~38 1.60 1.1 x 1.1 RFASWHH1416PTF06 SP6T 0.1 2.7 0.4~0.65dB 24~38 1.22 2.0 x 2.0 RFASWDH2418PTF06 SP8T 0.1 2.7 0.30~0.80dB 18~35 1.50 2.0 x 2.0 RFASWB643ATF09 0.7 2.7 0.40~0.55dB 22~30 1.28 2.0 x 2.0 RFASWB646BTF09 0.7 3.8 0.40~0.70dB 25~33 1.20 1.83 x 1.83 0.1 6 0.50~1.20dB 13~28 1.43 1.5 x 1.5 1.1 x 1.5 RFASWB438ATF09 DPDT RFASWB022ATF09 RFASWCM0624ATF09 87 Frequency (GHz )Min. DP4T 0.6 6 0.40~1.05dB 16~33 1.30 0.824 0.96 0.25dB 28~38 1.50 1.71 2.17 0.35dB 23~30 1.50 0.698 0.792 0.25dB 28~38 1.50 2.3 2.69 0.40dB 20~24 1.50 1.1 x 1.5 ANTENNA SWITCH  Application Circuit (MIPI) RFASWH656FTF03 RFASWD658FTF03 SP6T SP6T SP8T 3 RFASWH526BTF03 N/C N/C C1 13 13 5 C 1 11 1 1 11 3 5 3 1 3 5 7 N/C 5 7 7 RMASME494ATF03 RFASWE660DTF03 RFASWF662DTF03 SP10T SP10T SP12T 7 17 1 7 15 5 13 11 3 13 1 15 7 1 7 5 5 15 3 3 3 17 3 1 5 7 11 N/C N/C 3 5 13 11 5 17 1 NC 7 1 C1 C1 C1 C C C 11 RMASMF496ATF03 RMASMP491ATF03 RMASMNT1492ATF03 SP12T SP14T SP16T 1 1 1 17 7 7 15 7 17 3 3 3 5 13 1 5 5 11 11 13 1 5 3 7 15 3 7 11 5 3 13 C C1 C 11 15 1 7 11 C1 17 5 13 C1 C RMASMU532ATF03 RMASMU890ATF03 RMASMS535ATF03 DP14T (SP8T+SP6T) DP14T (SP7T+SP7T) DP21T (SP12T+SP9T) 88 ANTENNA SWITCH  ELECTRICAL SPECIFICATION Part Number RFASWH526BTF03 RFASWH656FTF03 RFASWD658FTF03 RMASME494ATF03 RFASWE660DTF03 RFASWF662DTF03 RMASMF496ATF03 Description SP6T SP8T SP10T SP12T Frequency (GHz) Min. Frequency (GHz) Max. Insertion loss (dB) TRXx ports Isolation (TRXx to any off TRXx port) [non-adjacent ports] Isolation (TRXx to any off TRXx port) [adjacent ports] VSWR Package (mm) 0.4 2.7 0.40~0.76dB(400~2690MHz) 20~30 17~26 2 2.0 x 2.0 0.4 2.7 0.40~0.76dB(704~2690MHz) 20~30 17~26 2 2.0 x 2.0 0.4 2.7 0.40~0.76dB(704~2690MHz) 20~30 17~26 2 2.0 x 2.0 0.4 2.7 0.60~0.85dB(824~2690MHz) 23~30 20~26 2 2.5 x 2.5 2.4 x 2.4 0.7 2.7 0.45~0.75dB(700~2700MHz) 18~26 18~26 2 0.4 2.7 0.50~0.72dB(700~2690MHz) 20~30 16~23 2 2.5 x 2.5 0.4 2.7 0.60~0.85dB(824~2690MHz) 23~30 20~26 2 2.5 x 2.5 RMASMP491ATF03 SP14T 0.4 2.7 0.70~1.15dB(700~2690MHz) 20~30 16~20 2 2.5 x 2.9 RMASMNT1492ATF03 SP16T 0.4 2.7 0.60~1.00dB(824~2690MHz) 20~30 16~20 2 2.5 x 3.3 RMASMU532ATF03 DP14T (SP8T+SP6T) 0.4 2.7 0.65~1.15dB(704~2690MHz) 17~23 14~21 1.5 2.8 x 2.8 RMASMU890ATF03 DP14T (SP7T+SP7T) 0.4 2.7 0.60~0.85dB(600~2690MHz) 18~25 15~23 1.5 3.2 x 2.8 RMASMS535ATF03 DP21T (SP12T+SP9T) 0.7 3.0 0.65~1.10dB(824~2690MHz) 15~23 14~21 2 3.6 x 2.8 89 ANTENNA SWITCH  Application Circuit (LTE Antenna Tuner-GPIO) RFASWA141ATF09 RFASWK119ATF09 SPDT SP4T RFC RF1 1 RFC RF 7 RF1 1 RF3 11 RF RF 3 3 5 5 C EN C1 EN C3 7 C C1 1 C3 C RFASWK694BTF09 RFASWK014ATF09 SP4T SP4T  ELECTRICAL SPECIFICATION Part Number Description Frequency (GHz) Min. Frequency (GHz) Max. Insertion loss (dB) Isolation VSWR Package (mm) RFASWA141ATF09 SPDT 0.4 3.0 0.20~0.35dB(700~2700MHz) 11~21 1.22 1.67 x 1.47 RFASWK119ATF09 SP4T 0.4 3.0 0.40~0.75dB(1000~2700MHz) 14~24 1.78 1.6 x 1.6 RFASWK694BTF09 SP4T 0.5 2.7 0.30~0.67dB(615~2700MHz) 16~22 1.58 1.1 x 1.5 RFASWK014ATF09 SP4T 0.1 2.7 0.25~1.05 dB (700~2700MHz) 16~25 1.28 1.1 x 1.5 90 ANTENNA SWITCH  Application Circuit (Network-GPIO) RFASWA351ATF06 RFASWA370ATF06 SPDT SPDT C4 C2 VC1 1 6 ANT 2 5 VC2 3 4 RF1 C1 RF2 C3 C5 RFASWM617BTF06 SP3T  ELECTRICAL SPECIFICATION 91 Part Number Description Frequency (GHz) Min. Frequency (GHz) Max. Insertion loss (dB) Isolation VSWR Package (mm) RFASWA351ATF06 SPDT 0.5 6.0 0.35~0.70dB(500~6000MHz) 15~25 2 1.0 x 1.0 RFASWA370ATF06 SPDT 0.5 6.0 0.50~0.90dB(500~5850MHz) 23~28.5 1.67 1.5 x 1.5 RFASWM617BTF06 SP3T 0.5 6.0 0.35~0.65dB(500~6000MHz) 15~30 1.92 1.5 x 1.5 DIPOLE ANTENNA (N/SMA) DIPOLE ANTENNA (N/SMA)  ELECTRICAL SPECIFICATION Series 8709 1313 1513 1713 3913 1310 1413 Size(mm) L Ø 87 9.95 137.5 157.5 172.5 392 135.7 148.5 12.5 10 13 1913 196.6 13 2520 4358 220 25 43.1 Return Loss 2.4~2.5 GHz 2dBi
RFBPF2012090A1T 价格&库存
很抱歉,暂时无法提供与“RFBPF2012090A1T”相匹配的价格&库存,您可以联系我们找货
