DATA SHEET
WWIRELESS COMPONENTS
Band Pass Filter
BPF2012LL01R5000A
5GHz
Product Specification – January 30, 2013 V.0
2012 Series
Product specification
WIRELESS COMPONENTS
2
5
Band Pass Filter
FEATURES
z Compact size design
z RoHS compliant
ORDERING INFORMATION
APPLICATIONS
z WLAN, 802.11a/b/g/n
z ISM Band
PART NUMBER
All part numbers are identified by the series, packing type, material, size,
antenna type, working frequency and packing quantity.
BPF
2012 LL 01 R 5000A
(1)
(2)
(3)
(4)
(5)
(6)
(1) PRODUCT
BPF = Band Pass Filter
(2) SIZE
2012 = 2.0 × 1.2
(3) MATERIALS
Material Code LL
(4) TYPE
01= Type 01
(5) PACKING STYLE
R = Tape and Reel
(6) WORKING FREQUENCY
5000 = 5 GHz
PHYCOMP CTC
CFL4111714015004K
12NC
411171401500
www.yageo.com
Jan. 30, 2013 V.0
WIRELESS COMPONENTS
Band Pass Filter
3
5
SPECIFICATION
Table 1
VALUE
DESCRIPTION
Pass Band
4900 ~ 5950 MHz
50Ω
Impedance
1.5 dB (Max.) at 25℃
Insertion Loss
1.8 dB (Max.) at -40~85℃
VSWR
2.0 (Max)
Ripple
0.6 dB(Max)
30dB Min@ 1280~3000 MHz
Attenuation
25dB Min@ 3300~4000 MHz
25dB Min@ 9800~11900 MHz
DIMENSIONS
Table 2 Machinical Dimension
DIMENSION
L (mm)
2.00 ±0.15
W (mm)
1.25 ±0.15
T (mm)
1.00 ±0.15
P (mm)
0.30 ±0.20
C (mm)
0.20 ±0.15
G (mm)
1.60 ±0.15
E (mm)
0.20 ±0.15
F (mm)
0.25±0.15
OUTLINES
C
Fig. 1 Filter outlines
Table 3 Termination configuration
TERMINAL NAME
FUNCTION
P
I/O Terminal
G
Ground Terminal
www.yageo.com
Jan. 30, 2013 V.0
WIRELESS COMPONENTS
4
5
Band Pass Filter
TYPE
DIMENSION
FUNCTION
L(mm)
1.70±0.1
Ground Pad
W(mm)
6.00±0.1
P1(mm)
0.76±0.1
Feed Pad
P2(mm)
0.76±0.1
Feed Pad
D(mm)
0.50±0.1
O(mm)
d=0.3
Via hole
Fig. 2 Reference design of evaluation board
ELECTRICAL PERFORMANCES
Fig. 3 Frequency Characteristics
www.yageo.com
Jan. 30, 2013 V.0
WIRELESS COMPONENTS
Band Pass Filter
5
5
REVISION HISTORY
REVISION DATE
CHANGE NOTIFICATION
Version 0
Jan. 30, 2013
DESCRIPTION
- New data sheet for Band Pass Filter, 5 GHz application,
2012 series
www.yageo.com
Jan. 30, 2013 V.0
很抱歉,暂时无法提供与“BPF2012LL01R5000A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.47422
- 50+0.38298
- 150+0.33736
- 500+0.30315
- 2500+0.25424
- 4000+0.24055
