Approval sheet
RFBPF 2012(0805) Series – RoHS Compliance
MULTILAYER CERAMIC BAND PASS FILTER
Halogens Free Product
2.4 GHz ISM Band Working Frequency
P/N: RFBPF2012060AM2T62
*Contents in this sheet are subject to change without prior notice.
Page 1 of 7
ASC_RFBPF2012060AM2T62_V06
Jan. 2012
Approval sheet
FEATURES
1.
Miniature footprint: 2.0 X 1.2 X 0.6 mm
2.
Low Profile Thickness
3.
Low Insertion loss
4.
High Rejection Rate
5.
High attenuation on 2
6.
LTCC process
nd
3
harmonic suppressed
APPLICATIONS
1.
2.4GHz ISM band RF applications
2.
Bluetooth, Wireless LAN 802.11b/g/n, HomeRF
CONSTRUCTION
P1
P8
P2
P3
PIN
Definition
PIN
Definition
P1
OUT
P5
IN
P2
NC
P6
GND
P3
NC
P7
NC
P4
GND
P8
GND
P7
P4
P6
P5
DIMENSIONS
Figure
Page 2 of 7
Symbol
Dimension (mm)
L
2.00 ± 0.15
W
1.25 ± 0.15
T
0.60 ± 0.10
A
0.20 ± 0.15
B
0.30 ± 0.15
C
0.35 ± 0.15
D
0.65 ± 0.15
E
0.20 ± 0.15
F
0.475 ± 0.15
G
0.30 ± 0.15
H
0.25 ± 0.15
Jan. 2012
Approval sheet
ELECTRICAL CHARACTERISTICS
RFBPF2012060AM2T62
Specification
Frequency range
2450 ± 50 MHz
Insertion Loss
1.8 dB max
VSWR
2 max
Impedance
50 Ω
25dB @ 870~960 MHz
25dB @ 1710~1910 MHz
Attenuation ( min.)
20dB @ 1910~1990 MHz
15dB @ 4800~5000 MHz
15dB @ 7200~7500 MHz
Typical Electrical Chart
SOLDER LAND PATTERN
Figure
Symbol
Dimension (mm)
L1
0.40 ± 0.05
L2
0.20 ± 0.05
L3
0.90 ± 0.05
L4
2.10 ± 0.05
L5
0.80 ± 0.05
L6
0.80 ± 0.10
L7
0.80 ± 0.05
D1
0.40 ± 0.05
D2
0.20 ± 0.05
Line width to de designed to match 50 Ω characteristic impedance, depending on PCB material and thickness.
D1 and D2 are the grounding through holes.
Page 3 of 7
Jan. 2012
Approval sheet
RELIABILITY TEST
Test item
Test condition / Test method
Specification
Solderability
JIS C 0050-4.6
*Solder bath temperature:235 ± 5°C
At least 95% of a surface of each terminal
JESD22-B102D
*Immersion time:2 ± 0.5 sec
electrode must be covered by fresh solder.
*Solder:Sn3Ag0.5Cu for lead-free
Leaching
*Solder bath temperature:260 ± 5°C
Loss of metallization on the edges of each
of metallization)
*Leaching immersion time:30 ± 0.5 sec
electrode shall not exceed 25%.
IEC 60068-2-58
*Solder : SN63A
(Resistance to dissolution
Resistance to soldering heat
*Preheating temperature:120~150℃,
JIS C 0050-5.4
1 minute.
No mechanical damage.
Samples shall satisfy electrical specification
*Solder temperature:270±5°C
after test.
*Immersion time:10±1 sec
Measurement to be made after keeping at
room temperature for 24±2 hrs
Drop Test
JIS C 0044
*Height:75 cm
*Test Surface:Rigid surface of concrete
after test.
or steel.
*Times:6 surfaces for each units;2
times for each side.
Adhesive Strength
of Termination
JIS C 0051- 7.4.3
Bending test
JIS C 0051- 7.4.1
*Pressurizing force:
5N(≦0603);10N(>0603)
No remarkable damage or removal of the
termination.
*Test time:10±1 sec
The middle part of substrate shall be
pressurized by means of the pressurizing
rod at a rate of about 1 mm/s per second
after test.
until the deflection becomes 1mm/s and
then pressure shall be maintained for 5±1
sec.
room temperature for 24±2 hours
Page 4 of 7
Jan. 2012
Approval sheet
Temperature cycle
JIS C 0025
1.
30±3 minutes at -40°C±3°C,
2.
10~15 minutes at room temperature,
3.
30±3 minutes at +85°C±3°C,
4.
specification after test.
Total 100 continuous cycles
Vibration
JIS C 0040
*Frequency:10Hz~55Hz~10Hz(1min)
*Total amplitude:1.5mm
*Test times:6hrs.(Two hrs each in three
after test.
mutually perpendicular directions)
High temperature
JIS C 0021
*Temperature:85°C±2°C
*Test duration:1000+24/-0 hours
after test.
Humidity
(steady conditions)
*Humidity:90% to 95% R.H.
*Temperature:40±2°C
JIS C 0022
*Time:1000+24/-0 hrs.
after test.
※ 500hrs measuring the first data then
1000hrs data
Low temperature
JIS C 0020
*Temperature:-40°C±2°C
after test.
Page 5 of 7
Jan. 2012
Approval sheet
SOLDERING CONDITION
Typical examples of soldering processes that provide reliable joints without any damage are given in Fig 2,
Fig 2. Infrared soldering profile
ORDERING CODE
RF
BPF
201206
A
M2T62
Walsin
Product Code
Dimension code
Unit of dimension
Application
Specification
RF device
BPF :
Per 2 digits of Length,
Width, Thickness :
0 : 0.1 mm
A : 2.4GHZ ISM Band
Design Code
Band Pass Filter
1 : 1.0 mm
e.g. :
201206 =
Length 20,
Width 12,
Thickness 06
Minimum Ordering Quantity: 2000 pcs per reel.
PACKAGING
Paper Tape specifications (unit :mm)
Index
Dimension (mm)
Index
Dimension (mm)
Page 6 of 7
Ao
Bo
ΦD
T
W
1.40 ± 0.10
2.30 ± 0.10
1.55 ± 0.10
0.84 ± 0.10
8.00 ± 0.30
E
F
Po
P1
P2
1.75 ± 0.10
3.50± 0.05
4.00 ± 0.10
4.00 ± 0.10
2.00 ± 0.10
Jan. 2012
Approval sheet
Reel dimensions
C
Index
Dimension (mm)
A
B
A
B
C
Φ178
Φ60.0
Φ13.5
Typing Quantity: 2000 pieces per 7" reel
CAUTION OF HANDLING
Limitation of Applications
Please contact us before using our products for the applications listed below which require especially high reliability for
the prevention of defects, which might directly cause damage to the third party’s life, body or property.
(1)
(2)
(3)
(4)
(5)
(6)
(7)
(8)
Aircraft equipment
Aerospace equipment
Undersea equipment
Medical equipment
Disaster prevention / crime prevention equipment
Traffic signal equipment
Transportation equipment (vehicles, trains, ships, etc.)
Applications of similar complexity and /or reliability requirements to the applications listed in the above.
Storage condition
(1)
Products should be used in 6 months from the day of WALSIN outgoing inspection, which can be
confirmed.
(2)
Storage environment condition.
Products should be storage in the warehouse on the following conditions.
Products should be storage on the palette for the prevention of the influence from humidity, dust and son on.
Page 7 of 7
Temperature
: -10 to +40℃
Humidity
: 30 to 70% relative humidity
Don’t keep products in corrosive gases such as sulfur. Chlorine gas or acid or it may cause oxidization of
electrode, resulting in poor solderability.
Products should be storage in the warehouse without heat shock, vibration, direct sunlight and so on.
Products should be storage under the airtight packaged condition.
Jan. 2012
很抱歉,暂时无法提供与“RFBPF2012060AM2T62”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.65902
- 50+0.52532
- 150+0.45836
- 500+0.40824
- 2000+0.36807
- 4000+0.34809
