LPF1608LL53R2400A
LPF1608LL53R2400A
    YAGEO(国巨)
LPF1608LL53R2400A 数据手册
DATA SHEET WIRELESS COMPONENTS Low Pass Filter LPF1608LL53R2400A 2.4-2.5 GHZ Product Specification – February 8, 2013 V.0 1608 Series Product specification WIRELESS COMPONENTS 2 2 Low Pass Filter FEATURES  Compact size design  RoHS compliant ORDERING INFORMATION APPLICATIONS  WLAN, 802.11a/b/g/n  Bluetooth  ISM Band PART NUMBER All part numbers are identified by the series, packing type, material, size, antenna type, working frequency and packing quantity. LPF 1608 LL 53 R 2400A (1) (2) (3) (4) (5) (6) (1) PRODUCT LPF = Low Pass Filter (2) SIZE 1608 = 1.6 × 0.8 (3) MATERIALS Material Code LL (4) TYPE 53 = Type 53 (5) PACKING STYLE R = Tape and Reel (6) WORKING FREQUENCY 2400 = 2.4 GHz PHYCOMP CTC CFL4111715532454k 12NC 411171553245 www.yageo.com Feb. 8, 2013 V1 Product specification WIRELESS COMPONENTS Low Pass Filter 3 3 SPECIFICATION Table 1 VALUE DESCRIPTION Pass Band 2400-2500 MHz 50Ω Impedance 0.48dB (Max) at 25°C Insertion Loss 0.51 dB(Max) at –40~ 85 °C VSWR 1.5 (Max) 35dB Min @ 4.8 to 5.0GHz 27dB Min @ 7.2 to 7.5GHz Attenuation Operating Temperature -40 ~ 85 °C DIMENSIONS Table 2 Machinical Dimension OUTLINES DIMENSION L (mm) 1.60 ±0.15 W (mm) 0.80 ±0.15 T (mm) 0.65 ±0.15 P1 (mm) 0.30 ±0.15 P2 (mm) 0.30 ±0.15 P3 (mm) 0.30 ±0.15 P4 (mm) 0.30 ±0.15 P5 (mm) 0.30 ±0.15 P6 (mm) 0.30 ±0.15 D1 (mm) 0.10 ±0.05 D2 (mm) 0.25 ±0.10 D3 (mm) 0.15 ±0.10 Fig. 1 Filter outlines Table 3 Termination configuration TERMINAL NAME FUNCTION P1 Ground Terminal P2 I/O Terminal P3 Ground Terminal P4 Ground Terminal P5 I/O Terminal P6 Ground Terminal www.yageo.com Feb. 8, 2013 V1 Product specification WIRELESS COMPONENTS 4 4 Low Pass Filter Unit: mm Fig. 2 Reference design of evaluation board ELECTRICAL PERFORMANCES Fig. 3 Frequency Characteristics www.yageo.com Feb. 8, 2013 V1 Product specification WIRELESS COMPONENTS Low Pass Filter 5 5 REVISION HISTORY REVISION DATE CHANGE NOTIFICATION Version 0 - Feb. 08, 2013 DESCRIPTION - New data sheet for Low Pass Filter, 2.45 GHz application, 1608 series www.yageo.com Feb. 8, 2013 V1
LPF1608LL53R2400A 价格&库存
很抱歉,暂时无法提供与“LPF1608LL53R2400A”相匹配的价格&库存,您可以联系我们找货
LPF1608LL53R2400A
    • 4000+0.23000
    库存:352000
