PCMF3DFN1X
PCMF3DFN1X
    NEXPERIA(安世)
    XSON14
    6 Line Common Mode Choke Surface Mount DCR 5 Ohm (Typ)
PCMF3DFN1X 数据手册
Important notice Dear Customer, On 7 February 2017 the former NXP Standard Product business became a new company with the tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS semiconductors with its focus on the automotive, industrial, computing, consumer and wearable application markets In data sheets and application notes which still contain NXP or Philips Semiconductors references, use the references to Nexperia, as shown below. Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/, use http://www.nexperia.com Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use salesaddresses@nexperia.com (email) Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on the version, as shown below: - © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights reserved Should be replaced with: - © Nexperia B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office via e-mail or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and understanding, Kind regards, Team Nexperia PCMF2DFN1; PCMF3DFN1 Common-mode EMI filter for differential channels with integrated ESD protection Rev. 2 — 28 April 2014 Product data sheet 1. Product profile 1.1 General description The devices are common-mode ElectroMagnetic Interference (EMI) filters with integrated ElectroStatic Discharge (ESD) protection for two and three differential channels. The devices are designed to provide low insertion loss for differential high-speed signals on each channel while unwanted common-mode signals are attenuated. Each differential channel incorporates two signal lines that are coupled by integrated coils. Diodes provide protection to downstream components from ESD voltages up to 15 kV on each signal line. Table 1. Product overview Type number Number of channels Package Name Version PCMF2DFN1 2 DFN2520-9 SOT1333-1 XSON9 PCMF3DFN1 3 DFN4020-14 SOT1334-1 XSON14 1.2 Features and benefits  Two and three differential channels  ESD protection up to 15 kV contact common-mode EMI filter with integrated discharge according to IEC 61000-4-2 ESD protection  Superior common-mode suppression  Maximum package height: 0.5 mm over a wide frequency range 1.3 Applications  Smartphone, cellular and cordless phone  MIPI D-PHY as used in Camera Serial Interface (CSI) and Display Serial Interface (DSI)  General-purpose EMI and Radio-Frequency Interference (RFI) filter and downstream ESD protection  Tablet PC and Mobile Internet Device (MID)  High-Definition Multimedia Interface (HDMI) PCMF2DFN1; PCMF3DFN1 NXP Semiconductors Common-mode EMI filter for differential channels with ESD protection 2. Pinning information Table 2. Pin Pinning Symbol Description Simplified outline Graphic symbol PCMF2DFN1 (SOT1333-1) 1 CH1_IN+ input channel 1 2 CH1_IN input channel 1 1 3 GND ground 2 4 CH2_IN+ input channel 2 3 5 CH2_IN input channel 2 4 7 6 CH2_OUT output channel 2 5 6 7 CH2_OUT+ output channel 2 8 CH1_OUT output channel 1 9 CH1_OUT+ output channel 1 9 8 1 9 2 8 3 Transparent top view DFN2520-9 4 7 5 6 aaa-007385 PCMF3DFN1 (SOT1334-1) 1 CH1_IN+ input channel 1 2 CH1_IN input channel 1 1 3 GND_1 ground 1 2 4 CH2_IN+ input channel 2 3 5 CH2_IN input channel 2 4 12 6 GND_2 ground 2 5 11 7 CH3_IN+ input channel 3 6 8 CH3_IN input channel 3 7 10 9 CH3_OUT output channel 3 8 9 10 CH3_OUT+ output channel 3 11 CH2_OUT output channel 2 12 CH2_OUT+ output channel 2 13 CH1_OUT output channel 1 14 CH1_OUT+ output channel 1 14 13 1 14 2 13 3 4 12 5 11 Transparent top view DFN4020-14 6 7 10 8 9 aaa-007384 PCMF2DFN1_PCMF3DFN1 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 28 April 2014 © NXP Semiconductors N.V. 2014. All rights reserved. 2 of 14 PCMF2DFN1; PCMF3DFN1 NXP Semiconductors Common-mode EMI filter for differential channels with ESD protection 3. Ordering information Table 3. Ordering information Type number Package Name Description Version PCMF2DFN1 DFN2520-9 plastic extremely thin small outline package; no leads; 9 terminals; body 2  2.5  0.5 mm SOT1333-1 PCMF3DFN1 DFN4020-14 plastic extremely thin small outline package; no leads; 14 terminals; body 2  4  0.5 mm SOT1334-1 4. Marking Table 4. Marking codes Type number Marking code PCMF2DFN1 MP1 PCMF3DFN1 CMFMP1 5. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions VI input voltage VESD electrostatic discharge voltage Min Max Unit 0.5 5 V contact discharge 15 15 kV air discharge 15 15 kV contact discharge 2 2 kV air discharge IEC 61000-4-2, level 4; all input pins to ground IEC 61000-4-2, level 4; all output pins to ground PCMF2DFN1_PCMF3DFN1 Product data sheet 2 2 kV Tstg storage temperature 55 +125 C Tamb ambient temperature 40 +85 C All information provided in this document is subject to legal disclaimers. Rev. 2 — 28 April 2014 © NXP Semiconductors N.V. 2014. All rights reserved. 3 of 14 PCMF2DFN1; PCMF3DFN1 NXP Semiconductors Common-mode EMI filter for differential channels with ESD protection 6. Characteristics 6.1 Channel characteristics Table 6. Channel characteristics Tamb = 25 C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit Rs(ch) channel series resistance single line; input to output - 5 -  Cd diode capacitance f = 1 MHz; VI = 2.5 V - 0.6 0.75 pF IRM reverse leakage current per line; VI = 5 V - - 100 nA VBR breakdown voltage IR = 10 mA 6 - 9 V VF forward voltage IF = 10 mA 0.6 - 1.1 V positive transient - 0.6 -  negative transient - 0.6 -  - 0.6 -  Rdyn dynamic resistance TLP surge [1] [2] [3] positive transient - 0.6 -  positive transient; IPP = 4 A [3] - 4.8 - V negative transient; IPP = 5 A [3] - 3.6 - V TLP; ICL = 8 A - 8 - V TLP; ICL = 12 A - 10.5 - V TLP; ICL = 16 A - 13.4 - V TLP; ICL = 8 A - 6 - V TLP; ICL = 12 A - 8.4 - V TLP; ICL = 16 A - 10.7 - V negative transient VCL [1] PCMF2DFN1_PCMF3DFN1 Product data sheet clamping voltage This parameter is guaranteed by design. [2] 100 ns Transmission Line Pulse (TLP); 50 ; pulser at 70 to 90 ns. [3] According to IEC 61000-4-5 (8/20 s). All information provided in this document is subject to legal disclaimers. Rev. 2 — 28 April 2014 © NXP Semiconductors N.V. 2014. All rights reserved. 4 of 14 PCMF2DFN1; PCMF3DFN1 NXP Semiconductors Common-mode EMI filter for differential channels with ESD protection aaa-007659 5 aaa-007660 -1 ICL (A) ICL (A) 4 -3 3 -5 2 1 3.0 -7 3.5 4.0 4.5 5.0 5.5 VCL (V) -5 -2 -1 IEC 61000-4-5; tp = 8/20 s; negative pulse Dynamic resistance with positive clamping; typical values Fig 2. DDD  -3 VCL (V) IEC 61000-4-5; tp = 8/20 s; positive pulse Fig 1. -4 Dynamic resistance with negative clamping; typical values DDD  ,&/ $ ,&/ $                   9&/ 9    tp = 100 ns; Transmission Line Pulse (TLP) Fig 3.     9&/ 9  tp = 100 ns; Transmission Line Pulse (TLP) Dynamic resistance with positive clamping; typical values Fig 4. Dynamic resistance with negative clamping; typical values The device uses an advanced clamping structure showing a negative dynamic resistance. This snap-back behavior strongly reduces the clamping voltage to the system behind the ESD protection during an ESD event. Do not connect unlimited DC current sources to the data lines to avoid keeping the ESD protection device in snap-back state after exceeding breakdown voltage (due to an ESD pulse for instance). PCMF2DFN1_PCMF3DFN1 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 28 April 2014 © NXP Semiconductors N.V. 2014. All rights reserved. 5 of 14 PCMF2DFN1; PCMF3DFN1 NXP Semiconductors Common-mode EMI filter for differential channels with ESD protection 6.2 Frequency characteristics Table 7. Frequency characteristics Symbol Parameter Conditions Min Typ Max Unit f = 400 MHz - 15 - dB f = 800 MHz - 30 - dB f = 5 GHz - 21 - dB [1] - 0.6 - dB [1][2] - 2.2 - GHz Common mode: S21cc il [1] insertion loss Differential mode: S21dd il insertion loss f3dB cut-off frequency f = 1MHz [1] Measured with 4-port network analyzer; Rgen = 50 ; RL = 50 . [2] Normalized to attenuation at 1 MHz. DDD  DDD  6GG G% 6FF G%          Fig 5.    I +]  Common-mode insertion loss; typical values PCMF2DFN1_PCMF3DFN1 Product data sheet   Fig 6.    I +]  Differential-mode insertion loss; typical values All information provided in this document is subject to legal disclaimers. Rev. 2 — 28 April 2014 © NXP Semiconductors N.V. 2014. All rights reserved. 6 of 14 PCMF2DFN1; PCMF3DFN1 NXP Semiconductors Common-mode EMI filter for differential channels with ESD protection 7. Application information 7.1 Application diagram PCMF2DFN1 (PCMF3DFN1) CLK_N D0_P D0_N D1_P D1_N SYSTEM-ON-CHIP (SoC) FLEX FOIL FLEX FOIL CONNECTOR MIPI LANE MODULE CLK_P CAMERA MODULE SUPPLY AND CONTROL aaa-007392 Fig 7. Application diagram for MIPI D-PHY CSI PCMF3DFN1 CLK_P CLK_N D0_P FLEX FOIL LIQUID CRYSTAL DISPLAY (LCD) D1_P D1_N FLEX FOIL CONNECTOR MIPI LANE MODULE D0_N D2_P D2_N D3_P D3_N PCMF2DFN1 SYSTEM-ON-CHIP (SoC) SUPPLY, CONTROL AND BACKLIGHT aaa-007393 Fig 8. Application diagram for MIPI D-PHY DSI PCMF2DFN1_PCMF3DFN1 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 28 April 2014 © NXP Semiconductors N.V. 2014. All rights reserved. 7 of 14 PCMF2DFN1; PCMF3DFN1 NXP Semiconductors Common-mode EMI filter for differential channels with ESD protection 7.2 Eye diagram aaa-007649 Data rate: 1.5 Gbit/s Vertical scale = 28.7 mV/div Horizontal scale = 100 ps/div Fig 9. MIPI D-PHY eye diagram aaa-007648 Data rate: 3.4 Gbit/s Vertical scale = 200 mV/div Horizontal scale = 58.9 ps/div Fig 10. HDMI eye diagram PCMF2DFN1_PCMF3DFN1 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 28 April 2014 © NXP Semiconductors N.V. 2014. All rights reserved. 8 of 14 PCMF2DFN1; PCMF3DFN1 NXP Semiconductors Common-mode EMI filter for differential channels with ESD protection 8. Package outline 0.5 max 0.9 0.7 0.05 0.00 0.2 min 6 5 0.25 0.15 2.6 2.4 3 2.0 0.5 1 9 0.152 0.050 2.1 1.9 Dimensions in mm 13-05-07 Fig 11. Package outline DFN2520-9 (SOT1333-1) 0.152 0.050 0.05 0.00 0.5 max 3.5 0.5 1 3 6 8 0.25 0.15 0.9 0.7 2.1 1.9 0.2 min 14 4.1 3.9 Dimensions in mm 9 13-05-07 Fig 12. Package outline DFN4020-14 (SOT1334-1) PCMF2DFN1_PCMF3DFN1 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 28 April 2014 © NXP Semiconductors N.V. 2014. All rights reserved. 9 of 14 PCMF2DFN1; PCMF3DFN1 NXP Semiconductors Common-mode EMI filter for differential channels with ESD protection 9. Soldering Footprint information for reflow soldering of DFN2520-9 package SOT1333-1 D1 (9x) C (8x) Ay solder land occupied area P1 DIMENSIONS in mm P1 Ay C D1 0.50 2.30 1.07 0.30 Dimensions in mm 13-05-08 13-05-21 sot1333-1_fr Fig 13. Reflow soldering footprint DFN2520-9 (SOT1333-1) Footprint information for reflow soldering of DFN4020-14 package SOT1334-1 D1 (14x) C (12x) Ay solder land occupied area DIMENSIONS in mm P1 P1 Ay C D1 0.50 2.30 1.07 0.30 Dimensions in mm 13-05-08 13-05-21 sot1334-1_fr Fig 14. Reflow soldering footprint DFN4020-14 (SOT1334-1) PCMF2DFN1_PCMF3DFN1 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 28 April 2014 © NXP Semiconductors N.V. 2014. All rights reserved. 10 of 14 PCMF2DFN1; PCMF3DFN1 NXP Semiconductors Common-mode EMI filter for differential channels with ESD protection 10. Revision history Table 8. Revision history Document ID Release date Data sheet status Change notice Supersedes PCMF2DFN1_PCMF3DFN1 v.2 20140428 Product data sheet - PCMF2DFN1_PCMF3DFN1 v.1 - - Modification: PCMF2DFN1_PCMF3DFN1 v.1 PCMF2DFN1_PCMF3DFN1 Product data sheet • Surge rating adapted 20130606 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 28 April 2014 © NXP Semiconductors N.V. 2014. All rights reserved. 11 of 14 PCMF2DFN1; PCMF3DFN1 NXP Semiconductors Common-mode EMI filter for differential channels with ESD protection 11. Legal information 11.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. 11.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. NXP Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local NXP Semiconductors sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between NXP Semiconductors and its customer, unless NXP Semiconductors and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the NXP Semiconductors product is deemed to offer functions and qualities beyond those described in the Product data sheet. 11.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. NXP Semiconductors takes no responsibility for the content in this document if provided by an information source outside of NXP Semiconductors. In no event shall NXP Semiconductors be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, NXP Semiconductors’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of NXP Semiconductors. Right to make changes — NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. PCMF2DFN1_PCMF3DFN1 Product data sheet Suitability for use — NXP Semiconductors products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors and its suppliers accept no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using NXP Semiconductors products, and NXP Semiconductors accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the NXP Semiconductors product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. NXP Semiconductors does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using NXP Semiconductors products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). NXP does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. NXP Semiconductors hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of NXP Semiconductors products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. All information provided in this document is subject to legal disclaimers. Rev. 2 — 28 April 2014 © NXP Semiconductors N.V. 2014. All rights reserved. 12 of 14 PCMF2DFN1; PCMF3DFN1 NXP Semiconductors Common-mode EMI filter for differential channels with ESD protection Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Non-automotive qualified products — Unless this data sheet expressly states that this specific NXP Semiconductors product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. NXP Semiconductors accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without NXP Semiconductors’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond NXP Semiconductors’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies NXP Semiconductors for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond NXP Semiconductors’ standard warranty and NXP Semiconductors’ product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 11.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 12. Contact information For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com PCMF2DFN1_PCMF3DFN1 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 28 April 2014 © NXP Semiconductors N.V. 2014. All rights reserved. 13 of 14 PCMF2DFN1; PCMF3DFN1 NXP Semiconductors Common-mode EMI filter for differential channels with ESD protection 13. Contents 1 1.1 1.2 1.3 2 3 4 5 6 6.1 6.2 7 7.1 7.2 8 9 10 11 11.1 11.2 11.3 11.4 12 13 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 3 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Channel characteristics . . . . . . . . . . . . . . . . . . 4 Frequency characteristics. . . . . . . . . . . . . . . . . 6 Application information. . . . . . . . . . . . . . . . . . . 7 Application diagram . . . . . . . . . . . . . . . . . . . . . 7 Eye diagram . . . . . . . . . . . . . . . . . . . . . . . . . . . 8 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 9 Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 11 Legal information. . . . . . . . . . . . . . . . . . . . . . . 12 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 12 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Contact information. . . . . . . . . . . . . . . . . . . . . 13 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © NXP Semiconductors N.V. 2014. All rights reserved. For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com Date of release: 28 April 2014 Document identifier: PCMF2DFN1_PCMF3DFN1
PCMF3DFN1X 价格&库存
很抱歉,暂时无法提供与“PCMF3DFN1X”相匹配的价格&库存,您可以联系我们找货
