CMS1-9-R
CMS1-9-R
    EATON(伊顿)
    SMD-4P,9.4x7.2mm
    三种尺寸的表面贴装环形共模电感,提供 300Vdc 隔离。 电感范围为 5.5μH 至 1600μH。 电流范围最高可达 7.0 安培
CMS1-9-R 数据手册
Technical Data 4313 Effective September 2018 Supersedes October 2015 CMS Common mode inductors, surface mount Applications • EMI filters • DC-DC brick power supplies • Discrete output supplies • Discrete and point-of-use power supplies (PUPS) Environmental data Product description • Three sizes of surface mount torroidal commonmode inductors that provide 300Vdc isolation • Inductance range from 5.5uH to 1600uH • Current range up to 7.0 Amps • Noise attenuation up to 44 dB • Frequency range up to 100 MHz • Meets UL94V-0 flammability standard • Ferrite core material • Storage temperature range: -40°C to +160°C • Operating ambient temperature range: -40°C to +160°C (range is application specific) • Solder reflow temperature: J-STD-020 (latest revision) compliant Pb CMS Common mode inductors, surface mount  Technical Data 4313 Effective Sepetember 2018 Product specifications Part number OCL (uH) minimum (1-2) & (4-3) I rms. Amperes Max* DCR (Ω) typ @ 20°C (1-2) DCR (Ω) typ @ 20°C (4-3) Leakage Inductance (uH) typ Interwinding Capacitance (pF) typ CMS1-1-R 4.5 7.00 0.0027 0.0027 0.05 2.0 CMS1-2-R 8 5.70 0.0040 0.0040 0.09 2.1 CMS1-3-R 12.6 4.10 0.077 0.077 0.14 2.2 CMS1-4-R 18 3.80 0.0089 0.0089 0.20 2.3 CMS1-5-R 25 3.60 0.0100 0.0100 0.28 2.4 CMS1-6-R 32.8 3.10 0.0138 0.0138 0.36 2.5 CMS1-7-R 41.5 2.60 0.019 0.019 0.45 2.6 CMS1-8-R 51.2 2.20 0.026 0.026 0.056 2.7 CMS1-9-R 62 1.90 0.035 0.035 0.68 2.7 CMS1-10-R 73.7 1.65 0.048 0.048 0.81 2.8 CMS1-11-R 100 1.35 0.070 0.070 1.10 3.9 CMS1-12-R 131 1.15 0.100 0.100 1.45 3.0 CMS1-13-R 166 1.00 0.138 0.138 1.83 3.1 CMS1-14-R 205 0.85 0.186 0.186 2.25 3.2 CMS2-0-R 14 6.00 0.004 0.004 0.13 1.7 CMS2-1-R 25 5.35 0.005 0.005 0.22 2.0 CMS2-2-R 40 4.40 0.008 0.008 0.34 2.3 CMS2-3-R 57 3.60 0.012 0.012 0.47 2.5 CMS2-4-R 102 2.80 0.019 0.019 0.80 2.8 CMS2-5-R 160 2.30 0.029 0.029 1.25 3.1 CMS2-6-R 230 1.85 0.044 0.044 1.75 3.4 CMS2-7-R 270 1.60 0.060 0.060 2.00 3.6 CMS2-8-R 360 1.35 0.084 0.084 2.60 3.9 CMS2-9-R 460 1.10 0.120 0.120 3.30 4.3 CMS2-10-R 575 0.94 0.170 0.170 4.00 4.3 CMS2-11-R 700 0.80 0.230 0.230 5.00 4.6 CMS2-12-R 915 0.67 0.330 0.330 6.30 4.9 CMS2-13-R 1070 0.58 0.440 0.440 7.30 5.1 CMS2-14-R 1340 0.50 0.620 0.620 9.00 5.4 CMS3-1-R 28 5.70 0.005 0.005 0.31 2.80 CMS3-2-R 45 5.10 0.006 0.006 0.46 3.05 CMS3-3-R 64 4.75 0.007 0.007 0.64 3.30 CMS3-4-R 88 3.95 0.010 0.010 0.85 3.50 CMS3-5-R 146 3.10 0.017 0.017 1.30 3.70 CMS3-6-R 217 2.85 0.020 0.020 1.90 3.90 CMS3-7-R 258 2.45 0.027 0.027 2.20 4.15 CMS3-8-R 350 2.00 0.040 0.040 3.00 4.40 CMS3-9-R 400 1.70 0.053 0.053 3.30 4.65 CMS3-10-R 518 1.45 0.076 0.076 4.20 4.85 CMS3-11-R 648 1.20 0.107 0.107 5.10 5.10 CMS3-12-R 790 1.05 0.145 0.145 6.10 5.35 CMS3-13-R 1030 0.88 0.210 0.210 7.80 5.55 CMS3-14-R 1310 0.75 0.300 0.300 9.60 5.80 Definitions: OCL = Open Circuit Inductance DCR = Direct Current Resistance Irms = rms current for approx. a 40°C temperature rise at an ambient temperature of 85°C. *Operating Temperature: 160°C Max. Inductance values are sustained up to 160°C. Electrical Characteristics: OCL (1-2) 0.10Vrms, 100kHz, 0.0Adc: (See Chart) 2 www.eaton.com/electronics OCL (4-3) 0.10Vrms, 100kHz, 0.0Adc: (See Chart) DCR (1-2) typ @ 20°C: (See Chart) DCR (4-3) typ @ 20°C: (See Chart) Hipot rating: winding to winding: 300Vdc min. for 1 second. Turns Ratio: (1-2):(4-3) 1:1 Technical Data 4313 CMS Common mode inductors, surface mount Effective September 2018  Dimensions–mm CMS1 RECOMMENDED PCB LAYOUT TOP VIEW SCHEMATIC 9.4 max 3 4 CMS1wwllyy R F RONT VIEW 2 1:1 7.2 max 1 2.6 max 1 4 2 3 Pin 1 indicator White dot CMS2 CMS3 wwllyy = Date code R = Revision level www.eaton.com/electronics 3 CMS Common mode inductors, surface mount  Technical Data 4313 Effective Sepetember 2018 Packaging Information CMS1 CMS2 Supplied in tape and reel packaging, 2,000 parts per 13” diameter reel (see note 1) See note 1 min. See note 6 Pin #1 indicator +0.1/-0.0 7 See note 6 Bo A B Ko= 2.7mm A Ao Ko Ao=9.3mm +/-0.3 (see note 6) min A 1.75 Pin #1 Indicator 0.3Rad max. Bo=9.3mm (see note 6) +/-0.3 B Ko=6.4mm K 0 typ. 12.0 SECTION A-A +0.1/-0.0 +/-0.05 1.75 A +/-0.05 0.3Rad max. Supplied in tape and reel packaging, 800 parts per 13” diameter reel 6.7 12.0 A SECTION A-A Direction of feed A typ User direction of feed CMS3 Supplied in tape and reel packaging, 600 parts per 13” diameter reel (see note 1) +0.1/-0.0 +/-0.05 Ao=11.8mm Bo=11.8mm (see note 6) min A 1.75 Pin #1 Indicator 0.3Rad max. (see note 6) +/-0.3 B Ko=6.8mm K A A 7.1 typ 16.0 SECTION A-A User direction of feed Attenuation Curves Attenuation 0 -1 -4 -5 Attenuation CMS 1 0 -5 -10 -7 -15 dB dB -10 -20 -25 -30 -35 -11 1 2 4 6 8 10 20 40 60 -1 -11 1 -14 2 4 dB Attenuation 0 -5 -10 -15 -20 -25 -30 -35 -40 -45 -50 CMS 3 -1 -11 1 -4 -7 -14 2 4 6 8 FREQUENCY (MHz) www.eaton.com/electronics 6 8 10 FREQUENCY (MHz) FREQUENCY (MHz) 4 -4 -7 -15 -20 -25 -30 -35 -40 -45 -50 -14 CMS 2 10 20 40 20 40 60 Technical Data 4313 CMS Common mode inductors, surface mount Effective September 2018  Impedance Curves 350 300 250 200 150 100 50 0 Impedance CMS1-1 & 4 4000 -4 -1 0.4 0.6 0.8 -14 1 2 3 4 6 8 -11 2000 0 10 0.4 0.6 CMS2 - 1 & 4 -1 0.6 0.8 1 2 4 6 8 10 20 18000 16000 14000 12000 10000 8000 6000 4000 2000 0 0.4 3 4 6 8 10 CMS2 - 7,11, & 14 -11 -7 0.6 0.8 1 2 3 4 6 FREQUENCY (MHz) CMS3 - 1 & 4 Impedance CMS3 - 7,11, & 14 16000 -4 Z (Ohms) Z (Ohms) 1600 1400 1200 1000 800 600 400 200 0 2 -14 0.4 FREQUENCY (MHz) Impedance 1 Impedance -4 0.4 0.8 FREQUENCY (MHz) Z (Ohms) Z (Ohms) Impedance -7 1000 FREQUENCY (MHz) 1800 1600 1400 1200 1000 800 600 400 200 0 CMS1 - 7,11, & 14 3000 Z (Ohms) Z (Ohms) Impedance -1 0.6 0.8 1 2 3 4 FREQUENCY (MHz) 6 8 14000 12000 10000 8000 6000 4000 2000 0 0.4 -14 0.6 -11 0.8 1 2 3 -7 4 6 8 FREQUENCY (MHz) www.eaton.com/electronics 5 Technical Data 4313 CMS Common mode inductors, surface mount  Effective September 2018 Solder reflow profile TP TC -5°C tP Max. Ramp Up Rate = 3°C/s Max. Ramp Down Rate = 6°C/s Temperature TL Preheat A T smax Package thickness Volume mm3
CMS1-9-R
物料型号:文档列出了多个型号的共模电感器,如CMS1-1-R、CMS1-2-R等,每个型号都有其特定的电感值和电流承载能力。
器件简介:这些共模电感器是表面安装型,采用环形铁氧体磁芯,提供300V直流隔离。它们适用于EMI滤波器、DC-DC电源模块、离散输出电源和离散及点对点电源供应(PUPS)。
引脚分配:文档提供了共模电感器的推荐PCB布局图,包括顶视图和前视图,以及引脚1的指示。
参数特性:共模电感器的电感范围从5.5微亨到1600微亨,电流范围高达7.0安培,噪声衰减高达44分贝,频率范围高达100MHz,符合UL94V-0可燃性标准。
功能详解:文档提供了详细的电气特性,包括开路电感(OCL)、直流电阻(DCR)、漏感和绕组间电容等。
应用信息:共模电感器广泛应用于电源供应器中,用于抑制电磁干扰(EMI),提高电源的稳定性和可靠性。
封装信息:文档提供了不同型号共模电感器的尺寸信息和包装信息,如CMS1型号的电感器每卷2000个,包装在13英寸直径的卷轴上。
CMS1-9-R 价格&库存
很抱歉,暂时无法提供与“CMS1-9-R”相匹配的价格&库存,您可以联系我们找货
CMS1-9-R
  • 2000+12.579822000+1.62720
CMS1-9-R
  • 2000+15.541212000+2.01026
  • 4000+14.939444000+1.93242
库存:324
CMS1-9-R
  • 1+25.692801+3.32337
  • 10+21.1552010+2.73643
  • 25+19.5705125+2.53145
  • 50+18.4524950+2.38683
  • 100+17.39842100+2.25049
  • 250+16.09866250+2.08237
  • 500+15.98214500+2.06729
库存:324
