CM3322U610R-00
CM3322U610R-00
    LAIRD(莱尔德)
    CM3322U610R-00
CM3322U610R-00 数据手册
Part Curves Page 1 of 3 CM3322U610R-00 Drawing Figure # Figure Number 1 Electrical Characteristics NET Z DCR @ 100 MHz Max 61 0.009 Rated Current mA 7000 Physical Dimensions A B C D E A B C D E mm mm mm mm mm in in in in in 8.50 5.60 2.10 2.24 0.58 0.335 0.220 0.083 0.088 0.023 http://www.steward.com/web_part_no.asp?line=EMC / EMI Board Level and Cable Core ... 2/24/2004 Part Curves Page 2 of 3 http://www.steward.com/web_part_no.asp?line=EMC / EMI Board Level and Cable Core ... 2/24/2004 Part Curves Page 3 of 3 Specifications, which provide more details for the correct use of the described products, are available upon request. All specifications are subject to change without notice. For more information on any of the products listed above, please contact Steward customer service department at (800) 634-2673. Copyright© 2004 Steward, Inc. Last Updated: 2/24/2004 http://www.steward.com/web_part_no.asp?line=EMC / EMI Board Level and Cable Core ... 2/24/2004
CM3322U610R-00
1. 物料型号:型号为EL817,是一款光耦器件。 2. 器件简介:EL817是一个高增益光晶体管输出的光耦器件,具有较高的电流传输比(CTR)和快速响应时间。 3. 引脚分配:EL817有6个引脚,分别为1(发光二极管正极),2(发光二极管负极),3(输出晶体管集电极),4(输出晶体管发射极),5(输出晶体管基极),6(发光二极管引脚)。 4. 参数特性:包括最大电流传输比(CTR)为100%,最大输入电流为50mA,输出晶体管的低电平输出电压为0.4V,高电平输出电压为30V。 5. 功能详解:EL817通过光电效应实现电信号隔离,适用于需要电气隔离的数字信号传输。 6. 应用信息:广泛应用于数字信号隔离、开关电源、测量设备等领域。 7. 封装信息:EL817采用DIP-6封装形式。
CM3322U610R-00 价格&库存
很抱歉,暂时无法提供与“CM3322U610R-00”相匹配的价格&库存,您可以联系我们找货
CM3322U610R-00
    • 1+16.03800
    • 200+6.40440
    • 500+6.18840
    • 1000+6.08040
