COMMON MODE
Common Mode Choke Arrays
Steward ‘s multi-line common mode power/data array filters provide the most
economical EMI filtering available for common mode noise. These ferrite
surface mount filters provide EMI suppression for groups of conductors like
power traces and high speed input/output circuitry (including network and
storage subsystems). Steward’s common mode choke arrays exhibit high
frequency impedance essentially independent of low frequency AC or DC bias
current.
Protected by the following US Patent : 5,455,552
Features:
·Surface mount design ·The most economical common mode filter available for filtering groups of signals ·Can be used as multiturn device to multiply impedance ·With two turns, over 1000 ohms impedance at 100 MHz ·Will fit behind an RJ45 jack
·High continuous operating current carrying capability ·4, 6 or 8 line parts ·Parts available in broad band and high frequency
materials
Applications:
·Cost sensitive designs (no need for an expensive filtered connector) ·Filtering DC power on PC boards, especially in applications of
greater than 3.0 amperes ·Filtering common mode EMI on high speed differential lines such as network and SCSI subsystems
·Low normal mode distortion provides excellent response in telecom applications
Test Specifications:
·HP4396A (100KHz - 1.8 GHz) or HP8753 (to 6 GHz) Network/Spectrum Analyzer ·HP43961A Impedance Test Kit ·HP16192A Test
Fixture or Inter-Continental Microwave custom fixtures ·HP16200A DC Bias Adapter ·Philips PM2811 DC Power Supply ·Ambient
Temperature 23.5oC + 2o ·Bandwidth 3 kHz ·Sweep Time 423 ms ·Impedance is rated at + 25% @100MHz ·Board level components
are rated up to a maximum of 75 volts ·Maximum current ratings are determined by testing to a maximum temperature rise of 40oC
with continuous operating current. Part performance is shown with curves for Common, Open and Normal Mode Impedances
measured along two conductors. Common Mode Impedance is the impedance of EMI noise conducted in the same direction along
two conductors. Open Circuit Impedance is the impedance measured across a single leg of the common mode choke.
Normal Mode Impedance is the total impedance to the differential circuit (both out and back).
PART NUMBERING SYSTEM
CM
PRODUCT
SERIES CODE
3032
V
PART
SIZE CODE
201
RATED
CURRENT CODE
IMPEDANCE
VALUE CODE
R
PACKAGING
CODE
00
ADDITIONAL
DESCRIPTION
Ambient Operating Temperature Range: -55° C to +125° C
PART
NUMBER
Fig
# of
Single
Lines
A
mm
(inches)
B
mm
(inches)
C
mm
(inches)
E1
mm
(inches)
E
mm
(inches)
CM3032V201R-00
3
4
7.62 + 0.30
(0.300 + 0.012)
8.13 + 0.15
(0.320 + 0.006)
9.45 + 0.25
(0.372 + 0.010)
1.27 + 0.08
(0.050 + 0.003)
2.03 + 0.08
(0.080 + 0.003)
200
230
CM4732V201R-00
2
6
11.94 + 0.30
(0.470+ 0.012)
8.13 + 0.15
(0.320 + 0.006)
9.45 + 0.25
(0.372 + 0.010)
1.27 + 0.08
(0.050 + 0.003)
2.03 + 0.08
(0.080 + 0.003)
200
CM6032V201R-00
1
8
15.24 + 0.30
(0.600 + 0.012)
8.13 + 0.15
(0.320 + 0.006)
9.45 + 0.25
(0.372 + 0.010)
1.27 + 0.08
(0.050 + 0.003)
2.03 + 0.08
(0.080 + 0.003)
CM3032V301R-00
3
4
7.62 + 0.30
(0.300 + 0.012)
8.13 + 0.15
(0.320 + 0.006)
14.48 + 0.25
(0.570 + 0.010)
1.27 + 0.08
(0.050 + 0.003)
* CM4732V301R-00
2
6
11.94 + 0.30
(0.470+ 0.012)
8.13 + 0.15
(0.320 + 0.006)
14.48 + 0.25
(0.570 + 0.010)
* CM6032V301R-00
1
8
15.24 + 0.30
(0.600 + 0.012)
8.13 + 0.15
(0.320 + 0.006)
* CM3032V131R-00
3
4
7.62 + 0.30
(0.300 + 0.012)
* CM4732V131R-00
2
6
* CM6032V131R-00
1
8
22
IMPEDANCE (Z)
TYPICAL OHMS @
100MHz 500MHz 1GHz
DCR
MAX
OHMS
RATED I MAX
(continuous)
mA
205
0.010
8,000
230
205
0.010
8,000
200
230
205
0.010
8,000
2.03 + 0.08
(0.080 + 0.003)
300
300
240
0.010
8,000
1.27 + 0.08
(0.050 + 0.003)
2.03 + 0.08
(0.080 + 0.003)
300
300
240
0.010
8,000
14.48 + 0.25
(0.570 + 0.010)
1.27 + 0.08
(0.050 + 0.003)
2.03 + 0.08
(0.080 + 0.003)
300
300
240
0.010
8,000
8.13 + 0.15
(0.320 + 0.006)
9.45 + 0.25
(0.372 + 0.010)
1.27 + 0.08
(0.050 + 0.003)
2.03 + 0.08
(0.080 + 0.003)
130
260
250
0.010
8,000
11.94 + 0.30
(0.470+ 0.012)
8.13 + 0.15
(0.320 + 0.006)
9.45 + 0.25
(0.372 + 0.010)
1.27 + 0.08
(0.050 + 0.003)
2.03 + 0.08
(0.080 + 0.003)
130
260
250
0.010
8,000
15.24 + 0.30
(0.600 + 0.012)
8.13 + 0.15
(0.320 + 0.006)
9.45 + 0.25
(0.372 + 0.010)
1.27 + 0.08
(0.050 + 0.003)
2.03 + 0.08
(0.080 + 0.003)
130
260
250
0.010
8,000
STEWARD - U.S.A. • Telephone: 423/867-4100 • Fax 423/867-4102 • Internet: http://www.steward.com
SCOTLAND • Telephone: 44-(0)1-506-414200 • Fax 44-(0)1-506-410694
SINGAPORE • Telephone: (65)337-9667 • Fax (65)337-9686
PART
NUMBER
Fig
# of
Single
Lines
A
mm
(inches)
B
mm
(inches)
C
mm
(inches)
E1
mm
(inches)
E
mm
(inches)
IMPEDANCE (Z)
TYPICAL OHMS @
100MHz 500MHz 1GHz
DCR
M AX
OHMS
RATED I MAX
(continuous)
mA
3
4
7.62 + 0.30
(0.300+ 0.012)
8.13 + 0.15
(0.320 + 0.006
14.48 + 0.25
(0.570 + 0.010
1.27 + 0.08
(0.050 + 0.003)
2.03 + 0.08
(0.080 + 0.003
220
300
190
0.010
8,000
* CM4732V221R-00
2
6
11.94 + 0.30
(0.470+ 0.012)
8.13 + 0.15
(0.320 + 0.006)
14.48 + 0.25
(0.570 + 0.010)
1.27 + 0.08
(0.050 + 0.003)
2.03 + 0.08
(0.080 + 0.003)
220
300
190
0.010
8,000
* CM6032V221R-00
1
8
15.24 + 0.30
(0.600 + 0.012)
8.13 + 0.15
(0.320 + 0.006)
14.48 + 0.25
(0.570 + 0.010)
1.27 + 0.08
(0.050 + 0.003)
2.03 + 0.08
(0.080 + 0.003)
220
300
190
0.010
8,000
COMMON MODE
* CM3032V221R-00
*High Frequency Material
CM3032V201R-00, CM4732V201R-00 & CM6032V201R-00
Z (1 & 2 Turn), R, XL vs. Frequency
Impedance, Resistance, Inductive Reactance
1000
Z vs. Frequency
Open, Common and Normal Mode
600
1
900
500
700
Impedance (W)
Impedance (W)
800
600
Z (2 Turns)
500
400
300
400
300
200
Open
Common
Normal
Z (1 Turn)
200
R
100
100
XL
100
10
10000
10
Frequency (MHz)
100
1000
10000
Frequency (MHz)
CM3032V301R-00, CM4732V301R-00 & CM6032V301R-00
1200
Z vs. Frequency
600
1100
1000
500
Z (2 Turns)
Impedance (W)
Impedance (W)
900
800
700
600
500
400
300
Z (1 Turn)
200
100
R
1
10
300
Open
200
Common
100
XL
Normal
Frequency (MHz)
1000
10000
1
10
100
1000
10000
Frequency (MHz)
23
CM3032V131R-00, CM4732V131R-00 & CM6032V131R-00
Z vs. Frequency
COMMON MODE
1000
400
900
300
700
Impedance (W)
Impedance (W)
800
600
Z (2 Turns)
500
400
300
Open
200
Common
100
Z (1 Turn)
200
Normal
R
100
XL
10
1000
100
10000
1
10
Frequency (MHz)
100
1000
10000
Frequency (MHz)
CM3032V221R-00, CM4732V221R-00 & CM6032V221R-00
Z vs. Frequency
400
1200
1100
1000
300
Impedance (W)
Impedance (W)
900
800
700
600
Z (2 Turns)
500
400
300
Z (1 Turn)
200
Open
Common
100
R
200
100
1
10
100
Frequency (MHz)
24
Normal
XL
10000
1
10
100
Frequency (MHz)
1000
10000
Figure 2
Figure 1
A
B
A
A
COMMON MODE
B
B
Figure 3
C
C
C
E1
E1
E1
E
E
E
Land Patterns for Reflow Soldering
Figure 1
Figure 2
Recommended Soldering
Conditions
Figure 3
(For wave soldering, add 0.076mm (0.030”) to this dimension.)
One Turn / Two Turn Equivalent Circuits
Figure 1
Figure 2
Figure 3
25
