Ultra High Current
Ferrite Common Mode Chokes
for AC and DC Power Supplies
Up to 55 Amps Contiuous Operating Current
• Effective for Low and High Frequency Applications
US Patent: 5,568,111
Features:
•Designed to be UL 1950 compliant for creepage up to 250 volts •Very high current continuous operation capability ••Small footprint
•Low clearance height ••Low cost ••Parts available in broadband and low frequency materials •Lighter, smaller and less susceptible
to vibration than older wire wound chokes
Applications:
•EMI suppression intended for use prior to a fusable link in conducted and radiated EMI applications in high and low-frequency
power supplies •Excellent in telecommunications, automotive and appliance applications
B
A
G
Normal Mode Impedance is the total impedance to the differential circuit (both out and back).
Open Circuit Impedance is the impedance measured across a single leg of the common mode choke.
Common Mode Impedance is the impedance of EMI noise conducted in the same direction along two conductors.
A
mm
(inches)
PART
NUMBER
B
mm
(inches)
C
mm
(inches)
D
mm
(inches)
G
mm
(inches)
IMPEDANCE (Z)
TYPICAL OHMS @
100MHz 500MHz 1GHz
C
D
DCR
MAX
( Ω)
RATED
I MAX
mA @250 C
TEMP RISE
RATED
I MAX
mA @400 C
TEMP RISE
CM5441Z161B-00
13.72 + 0.25
(0.540 + 0.010)
10.41 + 0.15
(0.410 + 0.006)
15.24 + 0.25
(0.600 + 0.010)
5.21 + 0.13
(0.205 + 0.005)
3.18 + 0.33
(0.125 + 0.013)
160
200
143
0.0003
30,000
55,000
CM5441Z101B-00
13.72 + 0.25
(0.540 + 0.010)
10.41 + 0.15
(0.410 + 0.006)
10.52 + 0.25
(0.414 + 0.010)
5.21 + 0.13
(0.205 + 0.005)
3.18 + 0.33
(0.125 + 0.013)
100
190
180
0.0003
30,000
55,000
CM5441Z990B-00
13.72 + 0.25
(0.540 + 0.010)
10.41 + 0.15
(0.410 + 0.006)
15.24 + 0.25
(0.600 + 0.010)
5.21 + 0.13
(0.205 + 0.005)
3.18 + 0.33
(0.125 + 0.013)
99
@ 4MHz
0.0003
30,000
55,000
CM5441Z161B-00
Z vs. Frequency
Open, Common and Normal Mode
CM5441Z101B-00
Z vs. Frequency
400
400
300
Normal
200
Open
100
Common
10
100
Frequency (MHz)
Steward
www.steward.com
1000
Impedance (Ω)
Impedance (Ω)
300
Normal
200
Open
Common
100
10
100
1000
Frequency (MHz)
North America - U.S.A. • Phone: +1 423 308 1690 • Fax +1 423 308 1622 • e-mail: americas@steward.com
North America - Mexico • Phone: +52 662 260-4832 • Fax: +52 662 260-5074 • e-mail: mexico@steward.com
Europe - Scotland, UK • Phone: +44 (0)1506 414200 • Fax +44 (0)1506 410694 • e-mail: europe@steward.com
Asia / Pacific - Singapore • Phone: +65 6337 9667 • Fax +65 6337 9686 • e-mail: asia@steward.com
BROCH 022
7/2002 REV 4
CM5441Z990B-00
Z vs. Frequency
180
160
Impedance (Ω)
140
Normal
120
100
Open
80
60
40
Common
10
1
100
1000
10000
Frequency (MHz)
Equivalent
Circuit
OUTPUT
CM5441Z_ _ _B-00
Recommended Hole Pattern
3.56
(0.140)
1.52
(0.060)
4
3
5.21
(0.205)
INPUT
1
Steward
www.steward.com
6.35
(0.250)
2
BROCH 022
7/2002 REV 4
很抱歉,暂时无法提供与“CM5441Z990B-00”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 165+10.54899165+1.36907
- 国内价格
- 1+21.74040
- 165+8.67240
- 495+8.39160
- 990+8.24040
